[PATCH rtems] libmisc/serdbg: Remove obsolete serial debug
Chris Johns
chrisj at rtems.org
Thu Feb 9 21:36:20 UTC 2023
Looks good and thanks
On 10/2/2023 2:11 am, Joel Sherrill wrote:
> Closes #2828.
> cpukit/include/rtems/serdbg.h | 168 -------------------
> cpukit/include/rtems/serdbgcnf.h | 101 ------------
> cpukit/include/rtems/termios_printk.h | 116 -------------
> cpukit/include/rtems/termios_printk_cnf.h | 91 ----------
> cpukit/libmisc/serdbg/README | 134 ---------------
> cpukit/libmisc/serdbg/serdbg.c | 105 ------------
> cpukit/libmisc/serdbg/serdbgio.c | 264 ------------------------------
> cpukit/libmisc/serdbg/termios_printk.c | 245 ---------------------------
> spec/build/cpukit/librtemscpu.yml | 4 -
> 9 files changed, 1228 deletions(-)
> delete mode 100644 cpukit/include/rtems/serdbg.h
> delete mode 100644 cpukit/include/rtems/serdbgcnf.h
> delete mode 100644 cpukit/include/rtems/termios_printk.h
> delete mode 100644 cpukit/include/rtems/termios_printk_cnf.h
> delete mode 100644 cpukit/libmisc/serdbg/README
> delete mode 100644 cpukit/libmisc/serdbg/serdbg.c
> delete mode 100644 cpukit/libmisc/serdbg/serdbgio.c
> delete mode 100644 cpukit/libmisc/serdbg/termios_printk.c
> diff --git a/cpukit/include/rtems/serdbg.h b/cpukit/include/rtems/serdbg.h
> deleted file mode 100644
> index eef2a01..0000000
> --- a/cpukit/include/rtems/serdbg.h
> +++ /dev/null
> @@ -1,168 +0,0 @@
> -/* SPDX-License-Identifier: BSD-2-Clause */
> - * RTEMS remote gdb over serial line
> - * This file declares intialization functions to add
> - * a gdb remote debug stub to an RTEMS system.
> - * Copyright (c) 2002 IMD Ingenieurbuero fuer Microcomputertechnik
> - * All rights reserved.
> - * Redistribution and use in source and binary forms, with or without
> - * modification, are permitted provided that the following conditions
> - * are met:
> - * 1. Redistributions of source code must retain the above copyright
> - * notice, this list of conditions and the following disclaimer.
> - * 2. Redistributions in binary form must reproduce the above copyright
> - * notice, this list of conditions and the following disclaimer in the
> - * documentation and/or other materials provided with the distribution.
> - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> - * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> - * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> - * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> - * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> - * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> - * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> - * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> - * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> - * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> - * POSSIBILITY OF SUCH DAMAGE.
> -#ifndef _SERDBG_H
> -#define _SERDBG_H
> -#include <rtems.h>
> -#include <termios.h>
> -#ifdef __cplusplus
> -extern "C" {
> -#endif
> -typedef struct {
> - uint32_t baudrate; /* debug baud rate, e.g. 57600 */
> - void (*callout)(void); /* callout pointer during polling */
> - int (*open_io)(const char *dev_name, uint32_t baudrate); /* I/O open fnc */
> - const char *devname; /* debug device, e.g. "/dev/tty01" */
> - bool skip_init_bkpt; /* if TRUE, do not stop when initializing */
> -} serdbg_conf_t;
> - * must be defined in init module...
> -extern serdbg_conf_t serdbg_conf;
> -| Function: |
> -void putDebugChar
> -| Purpose: |
> -| send character to remote debugger |
> -| Input Parameters: |
> - char c /* char to send */
> -| Return Value: |
> -| <none> |
> -| Function: |
> -int getDebugChar
> -| Purpose: |
> -| get character from remote debugger |
> - void /* <none> */
> -| Return Value: |
> -| <none> |
> -| Function: |
> -void serdbg_exceptionHandler
> -| Purpose: |
> -| hook directly to an exception vector |
> - int vecnum, /* vector index to hook at */
> - void *vector /* address of handler function */
> -| Return Value: |
> -| <none> |
> -| Function: |
> -int serdbg_init
> -| Purpose: |
> -| initialize remote gdb session over serial line |
> - void
> -| Return Value: |
> -| rtems_status_code |
> - * stuff from serdbgio.c
> -| Function: |
> -int serdbg_open
> -| Purpose: |
> -| try to open given serial debug port |
> - const char *dev_name, /* name of device to open */
> - uint32_t baudrate /* baud rate to use */
> -| Return Value: |
> -| 0 on success, -1 and errno otherwise |
> -extern int serdbg_init_dbg(void);
> - * Assumed to be provided by the BSP
> -extern void set_debug_traps(void);
> -extern void breakpoint(void);
> -#ifdef __cplusplus
> -#endif
> -#endif /* _SERDBG_H */
> diff --git a/cpukit/include/rtems/serdbgcnf.h b/cpukit/include/rtems/serdbgcnf.h
> index 59d254c..0000000
> --- a/cpukit/include/rtems/serdbgcnf.h
> +++ /dev/null
> @@ -1,101 +0,0 @@
> - * @file
> - * @brief Adds a GDB remote Debug Stub to an RTEMS System
> - * are met:
> -#ifndef _SERDBGCNF_H
> -#define _SERDBGCNF_H
> -#include <rtems/serdbg.h>
> -#ifdef __cplusplus
> -extern "C" {
> -#endif
> -#ifdef CONFIGURE_INIT
> - * fallback for baud rate to use
> -#ifndef CONFIGURE_SERDBG_BAUDRATE
> -#define CONFIGURE_SERDBG_BAUDRATE 9600
> -#endif
> - * fallback for device name to use
> -#ifndef CONFIGURE_SERDBG_DEVNAME
> -#define CONFIGURE_SERDBG_DEVNAME "/dev/tty01"
> -#endif
> - * fill in serdbg_conf structure
> -serdbg_conf_t serdbg_conf = {
> - CONFIGURE_SERDBG_BAUDRATE,
> -#ifdef CONFIGURE_SERDBG_CALLOUT
> - CONFIGURE_SERDBG_CALLOUT,
> -#else
> - NULL,
> -#endif
> -#ifdef CONFIGURE_SERDBG_USE_POLLED_TERMIOS
> - serdbg_open,
> -#else
> - NULL,
> -#endif
> - CONFIGURE_SERDBG_DEVNAME,
> -#ifdef CONFIGURE_SERDBG_SKIP_INIT_BKPT
> - true,
> -#else
> - false,
> -#endif
> -int serdbg_init(void) {
> -#ifdef CONFIGURE_USE_SERDBG
> - return serdbg_init_dbg();
> -#else
> - return 0;
> -#endif
> -#endif /* CONFIGURE_INIT */
> -#ifdef __cplusplus
> -#endif
> -#endif /* _SERDBGCNF_H */
> diff --git a/cpukit/include/rtems/termios_printk.h b/cpukit/include/rtems/termios_printk.h
> index 6273f1b..0000000
> --- a/cpukit/include/rtems/termios_printk.h
> +++ /dev/null
> @@ -1,116 +0,0 @@
> - * printk polled output via termios polled drivers.
> - * are met:
> -#ifndef _TERMIOS_PRINTK_H
> -#define _TERMIOS_PRINTK_H
> -#include <rtems.h>
> -#ifdef __cplusplus
> -extern "C" {
> -#endif
> -typedef struct {
> -} termios_printk_conf_t;
> -extern termios_printk_conf_t termios_printk_conf;
> -| Function: |
> -void termios_printk_outputchar
> -| Purpose: |
> -| send one character to serial port |
> - char c /* character to print */
> -| Return Value: |
> -| <none> |
> -| Function: |
> -int termios_printk_inputchar
> -| Purpose: |
> -| wait for one character from serial port |
> - void /* none */
> -| Return Value: |
> -| received character |
> -| Function: |
> -int termios_printk_open
> -| Purpose: |
> -| Return Value: |
> -#ifdef __cplusplus
> -#endif
> -#endif /* _TERMIOS_PRINTK_H */
> diff --git a/cpukit/include/rtems/termios_printk_cnf.h b/cpukit/include/rtems/termios_printk_cnf.h
> index 7a5f6cc..0000000
> --- a/cpukit/include/rtems/termios_printk_cnf.h
> +++ /dev/null
> @@ -1,91 +0,0 @@
> - * @file
> - * @brief Adds printk Support via Polled termios
> - * are met:
> -#ifndef _TERMIOS_PRINTK_CNF_H
> -#define _TERMIOS_PRINTK_CNF_H
> -#include <rtems/termios_printk.h>
> -#ifdef __cplusplus
> -extern "C" {
> -#endif
> -#ifndef CONFIGURE_TERMIOS_PRINTK_BAUDRATE
> -#define CONFIGURE_TERMIOS_PRINTK_BAUDRATE 9600
> -#endif
> -#ifndef CONFIGURE_TERMIOS_PRINTK_DEVNAME
> -#define CONFIGURE_TERMIOS_PRINTK_DEVNAME "/dev/console"
> -#endif
> -#ifdef CONFIGURE_USE_TERMIOS_PRINTK
> - * fill in termios_printk_conf structure
> -termios_printk_conf_t termios_printk_conf = {
> - CONFIGURE_TERMIOS_PRINTK_BAUDRATE,
> -#ifdef CONFIGURE_TERMIOS_PRINTK_CALLOUT
> - CONFIGURE_TERMIOS_PRINTK_CALLOUT,
> -#else
> - NULL,
> -#endif
> - CONFIGURE_TERMIOS_PRINTK_DEVNAME,
> -#endif
> -int termios_printk_init(void) {
> - return termios_printk_open(termios_printk_conf.devname,
> - termios_printk_conf.baudrate);
> -#else
> - return 0;
> -#endif
> -#ifdef __cplusplus
> -#endif
> -#endif /* _TERMIOS_PRINTK_CNF_H */
> diff --git a/cpukit/libmisc/serdbg/README b/cpukit/libmisc/serdbg/README
> index 64623eb..0000000
> --- a/cpukit/libmisc/serdbg/README
> +++ /dev/null
> @@ -1,134 +0,0 @@
> -This directory contains three useful packages related to the termios I/O
> -system:
> -PACKAGE SERDBGIO
> -"serdbgio" provides the "serial gdb" standard I/O functions "getDebugChar"
> -and "putDebugChar" for any device driver supporting polled termios mode.
> -The initialization function "serdbg_open" opens the v.24 port intended
> -for the serial debug connection, and sets the desired baud rate. The
> -"getDebugChar" and "putDebugChar" functions then interact with the
> -corresponding driver using the calls intended for polled termios
> -operation.
> -Specification for the debug device, baud rate and other parameters is
> -done in a global structure of type "serdbg_conf_t". A configuration
> -mechanism quite similar to the overall RTEMS configuration is available.
> -PACKAGE SERDBG
> -"serdbg" provides a means to optionally initialize and/or start a
> -serial gdb session as soon as possible, this means as soon as all
> -drivers have been initialized. The serial debug I/O functions can
> -either be integrated as special routines of the BSP drivers, or using
> -the package "serdbgio"
> -PACKAGE TERMIOS_PRINTK
> -"termios_printk" provides a standard output function suitable to use
> -with "printk". It uses the same technique as serdbgio, hooking the
> -interface between a polled device driver and the termios system.
> -REQUIREMENTS
> -- These two packages can be used with any polled termios device
> -driver.
> -- For standard initialization, they need a modified "bsppost.c"
> -to perform the initialization calls.
> -USAGE
> -For using these packages add the following to your "init" module or
> -your "system.h" file (Note: most macro settings fall back to a
> -default, if not set.):
> - * CONFIGURE_USE_SERDBG
> - * set this macro, if you want to connect gdb over a serial line
> - * when set, the debug stub will be connected after driver
> - * initialization in "bsppost.c"
> -#define CONFIGURE_USE_SERDBG
> - * CONFIGURE_SERDBG_SKIP_INIT_BKPT
> - * set this macro, if you do not want the gdb interface to wait for a
> - * debugger connection directly after initialization
> - * If you set this macro, the gdb stub will only hook various
> - * exception vectors when called from "bsppost.c".
> -/* #define CONFIGURE_SERDBG_SKIP_INIT_BKPT */
> - * CONFIGURE_SERDBG_USE_POLLED_TERMIOS
> - * set this macro, if you want "serdbgio" to provide the I/O
> - * functions for the serial gdb connection
> -#define CONFIGURE_SERDBG_USE_POLLED_TERMIOS
> - * CONFIGURE_SERDBG_DEVNAME
> - * use this macro to specify the serial device to use
> - * for "serdbgio".
> - * Only used, when CONFIGURE_SERDBG_USE_POLLED_TERMIOS is set
> -#define CONFIGURE_SERDBG_DEVNAME "/dev/tty03"
> - * CONFIGURE_SERDBG_BAUDRATE
> - * use this macro to specify the baud rate to use
> - * for "serdbgio".
> -#define CONFIGURE_SERDBG_BAUDRATE 57600
> - * CONFIGURE_SERDBG_CALLOUT
> - * use this macro to specify a routine that will called during I/O polling
> - * This function of type "void pollfnc(void)" can be used for e.g.
> - * tickling a watchdog
> -/* #define CONFIGURE_SERDBG_CALLOUT tickle_my_watchdog_fnc */
> -#include <serdbgcnf.h>
> - * CONFIGURE_USE_TERMIOS_PRINTK
> - * set this macro, if you want printk output to be sent to a serial
> - * driver using the polled termios interface
> - * when set, the printk output function will be connected after driver
> -#define CONFIGURE_USE_TERMIOS_PRINTK
> - * CONFIGURE_TERMIOS_PRINTK_DEVNAME
> - * for printk output.
> - * Only used, when CONFIGURE_USE_TERMIOS_PRINTK is set
> - * CONFIGURE_TERMIOS_PRINTK_BAUDRATE
> - * use this macro to specify the baudrate to use
> - * CONFIGURE_TERMIOS_PRINTK_CALLOUT
> -/* #define CONFIGURE_TERMIOS_PRINTK_CALLOUT tickle_my_watchdog_fnc */
> -#include <termios_printk_cnf.h>
> diff --git a/cpukit/libmisc/serdbg/serdbg.c b/cpukit/libmisc/serdbg/serdbg.c
> index c49e787..0000000
> --- a/cpukit/libmisc/serdbg/serdbg.c
> +++ /dev/null
> @@ -1,105 +0,0 @@
> - * This file contains intialization and utility functions to add
> - * are met:
> -#ifdef HAVE_CONFIG_H
> -#include "config.h"
> -#endif
> -#include <rtems.h>
> -#include <stdio.h>
> -#include <string.h>
> -#include <fcntl.h>
> -#include <errno.h>
> -| Function: |
> -int serdbg_init_dbg
> -| Purpose: |
> - void
> -| Return Value: |
> - static bool is_initialized = false;
> - rtems_status_code rc = RTEMS_SUCCESSFUL;
> - if (is_initialized) {
> - return RTEMS_SUCCESSFUL;
> - is_initialized = true;
> - * try to open serial device
> - if (rc == RTEMS_SUCCESSFUL) {
> - if ((serdbg_conf.open_io != NULL) &&
> - (0 > serdbg_conf.open_io(serdbg_conf.devname,serdbg_conf.baudrate))) {
> - fprintf(stderr,
> - "remote_gdb_init: cannot open device %s "
> - "for gdb connection:%s\n",serdbg_conf.devname,strerror(errno));
> - rc = RTEMS_IO_ERROR;
> - * initialize gdb stub
> - set_debug_traps();
> - * now activate gdb stub
> - if ((rc == RTEMS_SUCCESSFUL) &&
> - !serdbg_conf.skip_init_bkpt) {
> - breakpoint();
> - * return to original function
> - * this may be already unter gdb control
> - return rc;
> diff --git a/cpukit/libmisc/serdbg/serdbgio.c b/cpukit/libmisc/serdbg/serdbgio.c
> index 07c77a0..0000000
> --- a/cpukit/libmisc/serdbg/serdbgio.c
> +++ /dev/null
> @@ -1,264 +0,0 @@
> - * TERMIOS serial gdb interface support
> - * the functions in this file allow the standard gdb stubs like
> - * "m68k-stub.c" to access any serial interfaces that work with
> - * RTEMS termios in polled mode
> - * are met:
> -#endif
> -#include <rtems.h>
> -#include <rtems/libio_.h>
> -#include <errno.h>
> -#include <unistd.h> /* close */
> -#include <stdio.h>
> -#include <fcntl.h>
> -#include <rtems/termiostypes.h>
> - * internal variables
> -int serdbg_fd = -1;
> -struct rtems_termios_tty *serdbg_tty;
> -| Function: |
> -int serdbg_open
> -| Purpose: |
> -| Return Value: |
> - bool err_occurred = false;
> - rtems_libio_t *iop = NULL;
> - struct termios act_termios;
> - tcflag_t baudcode = B0;
> -#define FD_STORE_CNT 3
> - int fd_store[FD_STORE_CNT];
> - int fd_store_used = 0;
> - * translate baudrate into baud code
> - switch(baudrate) {
> - case 50: baudcode = B50; break;
> - case 75: baudcode = B75; break;
> - case 110: baudcode = B110; break;
> - case 134: baudcode = B134; break;
> - case 150: baudcode = B150; break;
> - case 200: baudcode = B200; break;
> - case 300: baudcode = B300; break;
> - case 600: baudcode = B600; break;
> - case 1200: baudcode = B1200; break;
> - case 1800: baudcode = B1800; break;
> - case 2400: baudcode = B2400; break;
> - case 4800: baudcode = B4800; break;
> - case 9600: baudcode = B9600; break;
> - case 19200: baudcode = B19200; break;
> - case 38400: baudcode = B38400; break;
> - case 57600: baudcode = B57600; break;
> - case 115200: baudcode = B115200; break;
> - case 230400: baudcode = B230400; break;
> - case 460800: baudcode = B460800; break;
> - default : err_occurred = true; errno = EINVAL; break;
> - * open device for serdbg operation
> - * skip any fds that are between 0..2, because they are
> - * reserved for stdin/out/err
> - if (!err_occurred &&
> - (dev_name != NULL) &&
> - (dev_name[0] != '\0')) {
> - do {
> - serdbg_fd = open(dev_name,O_RDWR);
> - if (serdbg_fd < 0) {
> - err_occurred = true;
> - else {
> - if (serdbg_fd < 3) {
> - if (fd_store_used >= FD_STORE_CNT) {
> - else {
> - fd_store[fd_store_used++] = serdbg_fd;
> - } while (!err_occurred &&
> - (serdbg_fd < 3));
> - * close any fds, that have been placed in fd_store
> - * so fd 0..2 are reusable again
> - while (--fd_store_used >= 0) {
> - close(fd_store[fd_store_used]);
> - * capture tty structure
> - if (!err_occurred) {
> - iop = rtems_libio_iop(serdbg_fd);
> - serdbg_tty = iop->data1;
> - * set device baudrate
> - * (and transp mode, this is not really needed)
> - * ... get fd settings
> - (0 != tcgetattr(serdbg_fd,&act_termios))) {
> - act_termios.c_iflag
> - &= ~(IGNBRK|BRKINT|PARMRK|ISTRIP
> - |INLCR|IGNCR|ICRNL|IXON);
> - act_termios.c_oflag
> - &= ~OPOST;
> - act_termios.c_lflag
> - &= ~(ECHO|ECHONL|ICANON|ISIG|IEXTEN);
> - cfsetospeed(&act_termios,baudcode);
> - cfsetispeed(&act_termios,baudcode);
> - if (0 != tcsetattr(serdbg_fd,TCSANOW,&act_termios)) {
> - return (err_occurred
> - ? -1
> - : 0);
> -void putDebugChar(char c) __attribute__ ((__weak__));
> -| Function: |
> -void putDebugChar
> -| Purpose: |
> -| Return Value: |
> -| <none> |
> - * call serdbg polling callout, if available
> - if (serdbg_conf.callout != NULL) {
> - serdbg_conf.callout();
> - * check, whether debug serial port is available
> - if ((serdbg_tty != NULL) &&
> - (serdbg_tty->device.write != NULL)) {
> - * send character to debug serial port
> - serdbg_tty->device.write(serdbg_tty->minor,&c,1);
> -int getDebugChar(void) __attribute__ ((__weak__));
> -| Function: |
> -int getDebugChar
> -| Purpose: |
> - void /* none */
> -| Return Value: |
> - int c = -1;
> - (serdbg_tty->device.pollRead != NULL)) {
> - do {
> - * get character from debug serial port
> - c = serdbg_tty->device.pollRead(serdbg_tty->minor);
> - } while (c < 0);
> - return c;
> diff --git a/cpukit/libmisc/serdbg/termios_printk.c b/cpukit/libmisc/serdbg/termios_printk.c
> index 2b5a7f8..0000000
> --- a/cpukit/libmisc/serdbg/termios_printk.c
> +++ /dev/null
> @@ -1,245 +0,0 @@
> - * TERMIOS printk support
> - * this module performs low-level printk output using
> - * a polled termios driver
> - * are met:
> -#endif
> -#include <rtems.h>
> -#include <errno.h>
> -#include <stdio.h>
> -#include <fcntl.h>
> -#include <rtems/bspIo.h>
> -int termios_printk_fd = -1;
> -struct rtems_termios_tty *termios_printk_tty;
> -static void _termios_printk_null_char(
> - char c RTEMS_UNUSED)
> - return;
> -BSP_output_char_function_type BSP_output_char = _termios_printk_null_char;
> -BSP_polling_getchar_function_type BSP_poll_char;
> -| Function: |
> -| Purpose: |
> -| Return Value: |
> -| <none> |
> - * check, whether printk serial port is available
> - if ((termios_printk_tty != NULL) &&
> - (termios_printk_tty->device.write != NULL)) {
> - * call termios_printk polling callout, if available
> - if (termios_printk_conf.callout != NULL) {
> - termios_printk_conf.callout();
> - termios_printk_tty->device.write(termios_printk_tty->minor,&c,1);
> -| Function: |
> -| Purpose: |
> - void /* none */
> -| Return Value: |
> - int c = -1;
> - (termios_printk_tty->device.pollRead != NULL)) {
> - do {
> - c = termios_printk_tty->device.pollRead(termios_printk_tty->minor);
> - } while (c < 0);
> - return c;
> -| Function: |
> -| Purpose: |
> -| Return Value: |
> - if (termios_printk_fd >= 0) {
> - * already initialized
> - return 0;
> - termios_printk_fd = open(dev_name,O_RDWR);
> - if (termios_printk_fd < 0) {
> - iop = rtems_libio_iop(termios_printk_fd);
> - termios_printk_tty = iop->data1;
> - (0 != tcgetattr(termios_printk_fd,&act_termios))) {
> - if (0 != tcsetattr(termios_printk_fd,TCSANOW,&act_termios)) {
> - BSP_output_char = termios_printk_outputchar;
> - BSP_poll_char = termios_printk_inputchar;
> - ? -1
> - : 0);
> diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
> index 0b0dc95..2c969aa 100644
> --- a/spec/build/cpukit/librtemscpu.yml
> +++ b/spec/build/cpukit/librtemscpu.yml
> @@ -165,8 +165,6 @@ install:
> - cpukit/include/rtems/rtems-rfs.h
> - cpukit/include/rtems/rtemsdialer.h
> - cpukit/include/rtems/scheduler.h
> - - cpukit/include/rtems/serdbg.h
> - - cpukit/include/rtems/serdbgcnf.h
> - cpukit/include/rtems/serial_mouse.h
> - cpukit/include/rtems/seterr.h
> - cpukit/include/rtems/shell.h
> @@ -178,8 +176,6 @@ install:
> - cpukit/include/rtems/stdio-redirect.h
> - cpukit/include/rtems/stringto.h
> - cpukit/include/rtems/sysinit.h
> - - cpukit/include/rtems/termios_printk.h
> - - cpukit/include/rtems/termios_printk_cnf.h
> - cpukit/include/rtems/termiostypes.h
> - cpukit/include/rtems/thread.h
> - cpukit/include/rtems/timecounter.h
