[PATCH] score: Replace goto with a break
Sebastian Huber
Fri Feb 10 07:21:42 UTC 2023
The goto label was directly after the loop, so we can replace the goto
with a break.
Close #4847.
cpukit/score/src/threaddispatch.c | 17 +++++++++++------
1 file changed, 11 insertions(+), 6 deletions(-)
diff --git a/cpukit/score/src/threaddispatch.c b/cpukit/score/src/threaddispatch.c
index b2426fa8ac..ad4c1aca3e 100644
--- a/cpukit/score/src/threaddispatch.c
+++ b/cpukit/score/src/threaddispatch.c
@@ -301,12 +301,13 @@ void _Thread_Do_dispatch( Per_CPU_Control *cpu_self, ISR_Level level )
heir = _Thread_Get_heir_and_make_it_executing( cpu_self );
- * When the heir and executing are the same, then we are being
- * requested to do the post switch dispatching. This is normally
- * done to dispatch signals.
+ * If the heir and executing are the same, then there is no need to do a
+ * context switch. Proceed to run the post switch actions. This is
+ * normally done to dispatch signals.
- if ( heir == executing )
- goto post_switch;
+ if ( heir == executing ) {
+ break;
* Since heir and executing are not the same, we need to do a real
@@ -341,7 +342,11 @@ void _Thread_Do_dispatch( Per_CPU_Control *cpu_self, ISR_Level level )
_ISR_Local_disable( level );
} while ( cpu_self->dispatch_necessary );
-post_switch:
+ * We are done with context switching. Proceed to run the post switch
+ * actions.
_Assert( cpu_self->thread_dispatch_disable_level == 1 );
cpu_self->thread_dispatch_disable_level = 0;
_Profiling_Thread_dispatch_enable( cpu_self, 0 );
2.35.3
