[PATCH] fixes 4557
Zack leung
zakthertemsdev at gmail.com
Tue Feb 14 02:01:04 UTC 2023
Closes #4557
cpukit/libmisc/shell/main_edit.c | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/cpukit/libmisc/shell/main_edit.c b/cpukit/libmisc/shell/main_edit.c
index 6e954639e2..8317452b7b 100644
--- a/cpukit/libmisc/shell/main_edit.c
+++ b/cpukit/libmisc/shell/main_edit.c
@@ -1713,7 +1713,6 @@ static void copy_selection(struct editor *ed) {
ed->env->clipboard = (unsigned char *) realloc(ed->env->clipboard, ed->env->clipsize);
if (!ed->env->clipboard) return;
copy(ed, ed->env->clipboard, selstart, ed->env->clipsize);
- select_toggle(ed);
static void cut_selection(struct editor *ed) {
@@ -2132,7 +2131,7 @@ static void edit(struct editor *ed) {
case ctrl('e'): select_toggle(ed); break;
case ctrl('a'): select_all(ed); break;
- case ctrl('c'): copy_selection(ed); break;
+ case ctrl('c'): copy_selection(ed);select_toggle(ed); break;
case ctrl('f'): find_text(ed, 0); break;
case ctrl('l'): goto_line(ed); break;
case ctrl('g'): find_text(ed, 1); break;
2.39.1
