[PATCH v1 0/1] Update rtems-llvm to version 11.1.0
Joel Sherrill
joel at rtems.org
Fri Feb 10 14:21:00 UTC 2023
On Fri, Feb 10, 2023 at 3:16 AM Jan Sommer <jan.sommer at dlr.de> wrote:
> Hello,
> I couldn't get the rtems-llvm buildset to work.
> As it was building llvm8 which is not that modern, I just tried to build
> a more recent version with the scripts.
> It works with llvm11. Are there any objections to updating?
Nope. Please feel free to add this.
> And should we keep the rtems-llvm-8.cfg or should I remove this with
> this patch?
My main concern is if the architectures that built with llvm 8 still build
with llvm 11. I think that's only SPARC and RISC-V. Are there others?
I guess that points to me not knowing the list of architectures that are
expected to work. I wonder where we would keep this information. Any
thoughts?
--joel
> Have a nice weekend,
> Jan
> Jan Sommer (1):
> rtems-tools: Update rtems-llvm to version 11.1.0
> rtems/config/6/rtems-llvm.bset | 2 +-
> rtems/config/tools/rtems-llvm-11.1.0.cfg | 21 +++++++++++++++++++++
> source-builder/config/llvm-common-1.cfg | 6 +++---
> 3 files changed, 25 insertions(+), 4 deletions(-)
> create mode 100644 rtems/config/tools/rtems-llvm-11.1.0.cfg
> 2.25.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230210/c8dde029/attachment.htm>
