[PATCH v1 1/1] rtems-tools: Update rtems-llvm to version 11.1.0
Gedare Bloom
gedare at rtems.org
Fri Feb 10 14:58:26 UTC 2023
This looks good for someone to pick up on tools
On Fri, Feb 10, 2023 at 2:17 AM Jan Sommer <jan.sommer at dlr.de> wrote:
> rtems/config/6/rtems-llvm.bset | 2 +-
> rtems/config/tools/rtems-llvm-11.1.0.cfg | 21 +++++++++++++++++++++
> source-builder/config/llvm-common-1.cfg | 6 +++---
> 3 files changed, 25 insertions(+), 4 deletions(-)
> create mode 100644 rtems/config/tools/rtems-llvm-11.1.0.cfg
> diff --git a/rtems/config/6/rtems-llvm.bset b/rtems/config/6/rtems-llvm.bset
> index 2b461a0..b1f5e5a 100644
> --- a/rtems/config/6/rtems-llvm.bset
> +++ b/rtems/config/6/rtems-llvm.bset
> @@ -18,4 +18,4 @@
> %define swig_prefix %{_tmproot}/swig
> devel/swig
> -tools/rtems-llvm-8.0.1
> +tools/rtems-llvm-11.1.0
> diff --git a/rtems/config/tools/rtems-llvm-11.1.0.cfg b/rtems/config/tools/rtems-llvm-11.1.0.cfg
> new file mode 100644
> index 0000000..3e99ad6
> --- /dev/null
> +++ b/rtems/config/tools/rtems-llvm-11.1.0.cfg
> @@ -0,0 +1,21 @@
> +# LLVM
> +%define llvm_version 11.1.0
> +%hash sha512 llvm-%{llvm_version}.src.tar.xz B7+ZczhBUaGNXMKJIQPl8oqIxjLo5JZi/eVtEjYy8u0bNxD6eoe2uCGVXQ7EQWD/NvKqTyM+OJ4U1ijpv43HZA==
> +%hash sha512 clang-%{llvm_version}.src.tar.xz 9Lt+Te1h8sSJ4BMQQy2OBi66mS2ZLtZcouaafCDrXQyQ6BlouqpxwBrJ2W+BSi3MpO+Pi/rEzvbXkH7Ozgl9rA==
> +%hash sha512 clang-tools-extra-%{llvm_version}.src.tar.xz tim4uMCjOQu2zSzmCSQqb5f+6pUJFFoutVZtCTWc7lb8UQ8h9fjRUI/11hLsuRdlcuY1jAHNhZD8eZiYw0hztg==
> +%hash sha512 compiler-rt-%{llvm_version}.src.tar.xz mwslnMQ9Xk0gIAZ2vhU96BtIWz/fBlYj/3HH4YlOxcjtnZnBQW9wJGqw9BfLum0dSvnzdp4uZXdABoGnkTRiMQ==
> +%hash sha512 libcxx-%{llvm_version}.src.tar.xz r1Mz2luQ9KRqUYRTIWT0xlIuPAOlgBMWJ8DxZ6uY+z5xs+FVGNbiJBQUFITsWrDRhClK5/EANOv+0o5wcoNrKA==
> +%hash sha512 libcxxabi-%{llvm_version}.src.tar.xz C/OAb9k4LKZ5DKKo6ZFCTK9k6BQVOGh1JDVlA0JD8qx0QsWW48VezoCTLC7Fm3GAHj5BXe3J203Uw/Zraok1WA==
> +%hash sha512 libunwind-%{llvm_version}.src.tar.xz UH8pzxoxjZdh/mMGsum1fAKjQvE4tH7FQg3OUnEyoz96/804aRN5LEcs7rn7HBsQW7oyNKFXWq4PaAJOlMjVlg==
> +%hash sha512 lld-%{llvm_version}.src.tar.xz PiSZFOpzsq+2V13IwY4zn+B2Z4Su3bh827ynP/xHJQlyXjMLnBsn1pCfuRw3VetfKfndHMl/9qWfF/kTMX1YTw==
> +%hash sha512 lldb-%{llvm_version}.src.tar.xz E+oVb0XdlyATyGJDN3CKhHhpMkmCsquIFapdTCUvp17klC5WVZoYTffxxg2PdU4Zi0Vt5+Wc6A3lhY6VEvt3XQ==
> +%hash sha512 openmp-%{llvm_version}.src.tar.xz u+oQP0T0NvK7x9Vr538pI1wVr1eOi2rwLE8WLjRn42wSLaIa2kKPsY0JygPTk6jfmf/QIAhCbcxoDiA7oQPXug==
> +# The llvm build instructions.
> +%include %{_configdir}/llvm-common-1.cfg
> diff --git a/source-builder/config/llvm-common-1.cfg b/source-builder/config/llvm-common-1.cfg
> index 629d2bf..37c4341 100644
> --- a/source-builder/config/llvm-common-1.cfg
> +++ b/source-builder/config/llvm-common-1.cfg
> @@ -33,7 +33,7 @@ URL: http://llvm.org/
> # Packages
> -%source set cfe %{llvm_url}/cfe-%{llvm_version}.src.tar.xz
> +%source set clang %{llvm_url}/clang-%{llvm_version}.src.tar.xz
> %source set clang-tools-extra %{llvm_url}/clang-tools-extra-%{llvm_version}.src.tar.xz
> %source set compiler-rt %{llvm_url}/compiler-rt-%{llvm_version}.src.tar.xz
> %source set libcxx %{llvm_url}/libcxx-%{llvm_version}.src.tar.xz
> @@ -89,8 +89,8 @@ URL: http://llvm.org/
> %source setup llvm -q -E
> %{__mv} llvm-%{llvm_version}.src ${source_dir_llvm}
> - %source setup cfe -q -E
> - %{__mv} cfe-%{llvm_version}.src ${source_dir_llvm}/tools/clang
> + %source setup clang -q -E
> + %{__mv} clang-%{llvm_version}.src ${source_dir_llvm}/tools/clang
> %source setup clang-tools-extra -q -E
> %{__mv} clang-tools-extra-%{llvm_version}.src ${source_dir_llvm}/tools/clang/extra
> 2.25.1
> devel mailing list
> devel at rtems.org
