[PATCH 2/2] bsps/aarch64: Fix off-by-one cache bug
Kinsey Moore
kinsey.moore at oarcorp.com
Fri Feb 10 22:00:36 UTC 2023
The whole cache invalidation and flushing functions only ended up
flusing the first N-1 levels of cache due to an off by one error. This
resovles that issue and makes consistent the usage of levels as they
relate to caching.
bsps/aarch64/shared/cache/cache.c | 32 +++++++++++++++----------------
1 file changed, 16 insertions(+), 16 deletions(-)
diff --git a/bsps/aarch64/shared/cache/cache.c b/bsps/aarch64/shared/cache/cache.c
index fc1766c2b9..4d299bf665 100644
--- a/bsps/aarch64/shared/cache/cache.c
+++ b/bsps/aarch64/shared/cache/cache.c
@@ -181,9 +181,15 @@ static inline void _CPU_cache_unfreeze_instruction(void)
/* TODO */
-static inline uint64_t AArch64_get_ccsidr_for_level(uint64_t val)
+static inline uint64_t AArch64_get_ccsidr_for_level(
+ uint64_t level, bool instruction
- _AArch64_Write_csselr_el1(val);
+ uint64_t csselr = AARCH64_CSSELR_EL1_LEVEL(level - 1);
+ csselr |= instruction ? AARCH64_CSSELR_EL1_IND : 0;
+ _AArch64_Write_csselr_el1(csselr);
return _AArch64_Read_ccsidr_el1();
@@ -214,7 +220,7 @@ static inline void AArch64_data_cache_clean_level(uint64_t level)
uint64_t way;
uint64_t way_shift;
- ccsidr = AArch64_get_ccsidr_for_level(AARCH64_CSSELR_EL1_LEVEL(level));
+ ccsidr = AArch64_get_ccsidr_for_level(level, false);
line_power = AArch64_ccsidr_get_line_power(ccsidr);
associativity = AArch64_ccsidr_get_associativity(ccsidr);
@@ -227,7 +233,7 @@ static inline void AArch64_data_cache_clean_level(uint64_t level)
for (set = 0; set < num_sets; ++set) {
uint64_t set_and_way = (way << way_shift)
| (set << line_power)
- | (level << 1);
+ | ((level - 1) << 1);
__asm__ volatile (
"dc csw, %[set_and_way]"
@@ -274,7 +280,7 @@ static inline void AArch64_data_cache_clean_all_levels(void)
uint64_t loc = AArch64_clidr_get_level_of_coherency(clidr);
uint64_t level = 0;
- for (level = 0; level < loc; ++level) {
+ for (level = 1; level <= loc; ++level) {
uint64_t ctype = AArch64_clidr_get_cache_type(clidr, level);
/* Check if this level has a data cache or unified cache */
@@ -299,7 +305,7 @@ static inline void AArch64_cache_invalidate_level(uint64_t level)
uint64_t way;
uint64_t way_shift;
@@ -312,7 +318,7 @@ static inline void AArch64_cache_invalidate_level(uint64_t level)
| (set << line_power)
- | (level << 1);
__asm__ volatile (
"dc isw, %[set_and_way]"
@@ -330,7 +336,7 @@ static inline void AArch64_data_cache_invalidate_all_levels(void)
uint64_t level = 0;
@@ -444,17 +450,11 @@ static inline size_t AArch64_get_cache_size(
clidr = _AArch64_Read_clidr_el1();
- if (level >= loc) {
+ if (level > loc) {
return 0;
- if (level == 0) {
- level = loc - 1;
- AARCH64_CSSELR_EL1_LEVEL(level) | (instruction ? AARCH64_CSSELR_EL1_IND : 0)
+ ccsidr = AArch64_get_ccsidr_for_level(level, instruction);
return (1U << (AArch64_ccsidr_get_line_power(ccsidr)+4))
* AArch64_ccsidr_get_associativity(ccsidr)
2.30.2
