[PATCH 2/2] bsps/aarch64: Fix off-by-one cache bug
Chris Johns
chrisj at rtems.org
Tue Feb 14 04:59:26 UTC 2023
OK to push
Thanks
On 11/2/2023 9:00 am, Kinsey Moore wrote:
> The whole cache invalidation and flushing functions only ended up
> flusing the first N-1 levels of cache due to an off by one error. This
> resovles that issue and makes consistent the usage of levels as they
> relate to caching.
> bsps/aarch64/shared/cache/cache.c | 32 +++++++++++++++----------------
> 1 file changed, 16 insertions(+), 16 deletions(-)
> diff --git a/bsps/aarch64/shared/cache/cache.c b/bsps/aarch64/shared/cache/cache.c
> index fc1766c2b9..4d299bf665 100644
> --- a/bsps/aarch64/shared/cache/cache.c
> +++ b/bsps/aarch64/shared/cache/cache.c
> @@ -181,9 +181,15 @@ static inline void _CPU_cache_unfreeze_instruction(void)
> /* TODO */
> -static inline uint64_t AArch64_get_ccsidr_for_level(uint64_t val)
> +static inline uint64_t AArch64_get_ccsidr_for_level(
> + uint64_t level, bool instruction
> - _AArch64_Write_csselr_el1(val);
> + uint64_t csselr = AARCH64_CSSELR_EL1_LEVEL(level - 1);
> + csselr |= instruction ? AARCH64_CSSELR_EL1_IND : 0;
> + _AArch64_Write_csselr_el1(csselr);
> return _AArch64_Read_ccsidr_el1();
> @@ -214,7 +220,7 @@ static inline void AArch64_data_cache_clean_level(uint64_t level)
> uint64_t way;
> uint64_t way_shift;
> - ccsidr = AArch64_get_ccsidr_for_level(AARCH64_CSSELR_EL1_LEVEL(level));
> + ccsidr = AArch64_get_ccsidr_for_level(level, false);
> line_power = AArch64_ccsidr_get_line_power(ccsidr);
> associativity = AArch64_ccsidr_get_associativity(ccsidr);
> @@ -227,7 +233,7 @@ static inline void AArch64_data_cache_clean_level(uint64_t level)
> for (set = 0; set < num_sets; ++set) {
> uint64_t set_and_way = (way << way_shift)
> | (set << line_power)
> - | (level << 1);
> + | ((level - 1) << 1);
> __asm__ volatile (
> "dc csw, %[set_and_way]"
> @@ -274,7 +280,7 @@ static inline void AArch64_data_cache_clean_all_levels(void)
> uint64_t loc = AArch64_clidr_get_level_of_coherency(clidr);
> uint64_t level = 0;
> - for (level = 0; level < loc; ++level) {
> + for (level = 1; level <= loc; ++level) {
> uint64_t ctype = AArch64_clidr_get_cache_type(clidr, level);
> /* Check if this level has a data cache or unified cache */
> @@ -299,7 +305,7 @@ static inline void AArch64_cache_invalidate_level(uint64_t level)
> uint64_t way;
> uint64_t way_shift;
> @@ -312,7 +318,7 @@ static inline void AArch64_cache_invalidate_level(uint64_t level)
> | (set << line_power)
> - | (level << 1);
> __asm__ volatile (
> "dc isw, %[set_and_way]"
> @@ -330,7 +336,7 @@ static inline void AArch64_data_cache_invalidate_all_levels(void)
> uint64_t level = 0;
> @@ -444,17 +450,11 @@ static inline size_t AArch64_get_cache_size(
> clidr = _AArch64_Read_clidr_el1();
> - if (level >= loc) {
> + if (level > loc) {
> return 0;
> - if (level == 0) {
> - level = loc - 1;
> - AARCH64_CSSELR_EL1_LEVEL(level) | (instruction ? AARCH64_CSSELR_EL1_IND : 0)
> + ccsidr = AArch64_get_ccsidr_for_level(level, instruction);
> return (1U << (AArch64_ccsidr_get_line_power(ccsidr)+4))
> * AArch64_ccsidr_get_associativity(ccsidr)
