Risc-v failures Fwd: [rtems-bsp-builder] 2023-02-12 05:13:18: Profile(s): everything
Joel Sherrill
joel at rtems.org
Sun Feb 12 18:11:54 UTC 2023
Hi
Looks like after Karel's fix goes in, the failures to build are all risc-v
bsps. They show up on the Ubuntu and Freebsd build reports but are likely
everywhere but the other hosts haven't rotated around yet.
Hesham.. could you kindly please try to resolve those?
Thanks
---------- Forwarded message ---------
From: OAR Tester for FreeBSD 12 <rtems-tester at oarcorp.com>
Date: Sun, Feb 12, 2023, 11:50 AM
Subject: [rtems-bsp-builder] 2023-02-12 05:13:18: Profile(s): everything
To: <build at rtems.org>
RTEMS Tools Project - RTEMS Kernel BSP Builder, 6.0.not_released
Host: FreeBSD 12.3-RELEASE-p6 GENERIC
command: /home/tester/rtems-cron-6/tools/6/bin/rtems-bsp-builder\
--rtems=/home/tester/rtems-cron-6/rtems --build-path=/home/tester\
/rtems-cron-6/build --prefix=/home/tester/rtems-\
cron-6/tools/6/bsps --log=/home/tester/rtems-cron-6/bsp-\
builder.log --warnings-report=warnings.log --mail --use-gitconfig\
--profiles=everything
Total Time : 6:36:35.332796 for 1282 completed job(s)
Average BSP Build Time: 0:00:18.561102
Builds
debug
no-posix
posix
posix-debug
posix-profiling
profiling
smp
smp-debug
Failures Report
1 debug arm/stm32h757i-eval-m4 build:
configure: /home/tester/rtems-cron-6/rtems/waf configure\
--prefix=/home/tester/rtems-cron-6/tools/6/bsps --top=/home/tester\
/rtems-cron-6/rtems --rtems-config=config-arm-stm32h757i-\
eval-m4-debug.ini
error: bsps/arm/stm32h7/boards/stm/stm32h757i-
eval/stm32h7-bspstarthooks.c:39:10: fatal error:
stm32h747i_eval_qspi.h: No such file or directory
2 no-posix arm/stm32h757i-eval-m4 build:
/rtems-cron-6/rtems --rtems-config=config-arm-stm32h757i-eval-m4-no-\
posix.ini
3 posix arm/stm32h757i-eval-m4 build:
eval-m4-posix.ini
4 posix-debug arm/stm32h757i-eval-m4 build:
/rtems-cron-6/rtems --rtems-config=config-arm-stm32h757i-eval-m4\
-posix-debug.ini
5 posix-profiling arm/stm32h757i-eval-m4 build:
-posix-profiling.ini
6 profiling arm/stm32h757i-eval-m4 build:
eval-m4-profiling.ini
7 debug riscv/rv64imac_medany configure:
/rtems-cron-6/rtems --rtems-config=config-riscv-rv64imac_medany-\
debug.ini
8 no-posix riscv/rv64imac_medany configure:
/rtems-cron-6/rtems --rtems-config=config-riscv-rv64imac_medany-no-\
posix.ini
9 posix riscv/rv64imac_medany configure:
posix.ini
10 posix-debug riscv/rv64imac_medany configure:
posix-debug.ini
11 posix-profiling riscv/rv64imac_medany configure:
posix-profiling.ini
12 profiling riscv/rv64imac_medany configure:
profiling.ini
13 smp riscv/rv64imac_medany configure:
smp.ini
14 smp-debug riscv/rv64imac_medany configure:
/rtems-cron-6/rtems --rtems-config=config-riscv-rv64imac_medany-smp-\
debug.ini
15 debug riscv/rv64imafd_medany configure:
/rtems-cron-6/rtems --rtems-config=config-riscv-rv64imafd_medany-\
debug.ini
16 no-posix riscv/rv64imafd_medany configure:
/rtems-cron-6/rtems --rtems-config=config-riscv-rv64imafd_medany-no-\
posix.ini
17 posix riscv/rv64imafd_medany configure:
posix.ini
18 posix-debug riscv/rv64imafd_medany configure:
posix-debug.ini
19 posix-profiling riscv/rv64imafd_medany configure:
posix-profiling.ini
20 profiling riscv/rv64imafd_medany configure:
profiling.ini
21 smp riscv/rv64imafd_medany configure:
smp.ini
22 smp-debug riscv/rv64imafd_medany configure:
smp-debug.ini
23 debug riscv/rv64imafdc_medany configure:
/rtems-cron-6/rtems --rtems-config=config-riscv-rv64imafdc_medany-\
debug.ini
24 no-posix riscv/rv64imafdc_medany configure:
no-posix.ini
25 posix riscv/rv64imafdc_medany configure:
posix.ini
26 posix-debug riscv/rv64imafdc_medany configure:
posix-debug.ini
27 posix-profiling riscv/rv64imafdc_medany configure:
posix-profiling.ini
28 profiling riscv/rv64imafdc_medany configure:
profiling.ini
29 smp riscv/rv64imafdc_medany configure:
smp.ini
30 smp-debug riscv/rv64imafdc_medany configure:
smp-debug.ini
Warnings Report
| By Architecture (total : 10477) |
| common : 14 warning(s) |
| Shared : 738 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 168 | | |
| aarch64 : 21 warning(s) |
| Shared : 3 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 532 | | |
| arm : 34 warning(s) |
| Shared : 192 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 202 | | |
| bfin : 32 warning(s) |
| Shared : 138 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 234 | CPU Kit : 90 | | |
| i386 : 31 warning(s) |
| Shared : 0 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 60 | | |
| lm32 : 14 warning(s) |
| Shared : 156 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 72 | | |
| m68k : 33 warning(s) |
| Shared : 936 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 330 | | |
| microblaze : 1 warning(s) |
| Shared : 36 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 0 | | |
| mips : 8 warning(s) |
| LibCPU : 0 | CPU Kit : 24 | | |
| moxie : 2 warning(s) |
| Shared : 12 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 18 | | |
| nios2 : 0 warning(s) |
| or1k : 1 warning(s) |
| Shared : 6 | BSP : 0 | Network : 0 | Tests : 0 |
| powerpc : 25 warning(s) |
| Shared : 140 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 12 | CPU Kit : 218 | | |
| sh : 162 warning(s) |
| Shared : 84 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 84 | | |
| sparc : 4 warning(s) |
| sparc64 : 2 warning(s) |
| v850 : 1 warning(s) |
| Shared : 72 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 36 | | |
| x86_64 : 1 warning(s) |
| LibCPU : 0 | CPU Kit : 6 | | |
| By BSP (total : 10477) |
| common : 291 warning(s) |
| Shared : 1557 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 96 | CPU Kit : 1300 | | |
| aarch64/a53_ilp32_qemu : 0 warning(s) |
| aarch64/a72_ilp32_qemu : 0 warning(s) |
| aarch64/xilinx_zynqmp_ilp32_qemu : 0 warning(s) |
| aarch64/xilinx_zynqmp_ilp32_zu3eg : 1 warning(s) |
| Shared : 2 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 152 | | |
| arm/altcycv_devkit : 7 warning(s) |
| arm/atsamv : 6 warning(s) |
| arm/beagleboardorig : 0 warning(s) |
| arm/beagleboardxm : 0 warning(s) |
| arm/beagleboneblack : 0 warning(s) |
| arm/beaglebonewhite : 0 warning(s) |
| arm/csb336 : 0 warning(s) |
| arm/csb337 : 0 warning(s) |
| arm/csb637 : 0 warning(s) |
| arm/gumstix : 0 warning(s) |
| arm/imx7 : 2 warning(s) |
| LibCPU : 0 | CPU Kit : 32 | | |
| arm/imxrt1052 : 0 warning(s) |
| arm/kit637_v6 : 0 warning(s) |
| arm/lm3s3749 : 0 warning(s) |
| arm/lm3s6965 : 0 warning(s) |
| arm/lm3s6965_qemu : 0 warning(s) |
| arm/lm4f120 : 0 warning(s) |
| arm/lpc1768_mbed : 0 warning(s) |
| arm/lpc1768_mbed_ahb_ram : 0 warning(s) |
| arm/lpc1768_mbed_ahb_ram_eth : 0 warning(s) |
| arm/lpc17xx_ea_ram : 0 warning(s) |
| arm/lpc17xx_ea_rom_int : 0 warning(s) |
| arm/lpc17xx_plx800_ram : 0 warning(s) |
| arm/lpc17xx_plx800_rom_int : 0 warning(s) |
| arm/lpc2362 : 0 warning(s) |
| arm/lpc23xx_tli800 : 0 warning(s) |
| arm/lpc24xx_ea : 0 warning(s) |
| arm/lpc24xx_ncs_ram : 0 warning(s) |
| arm/lpc24xx_ncs_rom_ext : 0 warning(s) |
| arm/lpc24xx_ncs_rom_int : 0 warning(s) |
| arm/lpc24xx_plx800_ram : 0 warning(s) |
| arm/lpc24xx_plx800_rom_int : 0 warning(s) |
| arm/lpc32xx_mzx : 0 warning(s) |
| arm/lpc32xx_mzx_stage_1 : 0 warning(s) |
| arm/lpc32xx_mzx_stage_2 : 0 warning(s) |
| arm/lpc32xx_phycore : 0 warning(s) |
| arm/lpc40xx_ea_ram : 0 warning(s) |
| arm/lpc40xx_ea_rom_int : 0 warning(s) |
| arm/nucleo-h743zi : 0 warning(s) |
| arm/raspberrypi : 0 warning(s) |
| arm/raspberrypi2 : 0 warning(s) |
| arm/realview_pbx_a9_qemu : 0 warning(s) |
| arm/smdk2410 : 0 warning(s) |
| arm/stm32f105rc : 0 warning(s) |
| arm/stm32f4 : 2 warning(s) |
| arm/stm32h7 : 0 warning(s) |
| arm/stm32h747i-disco : 0 warning(s) |
| arm/stm32h747i-disco-m4 : 0 warning(s) |
| arm/stm32h757i-eval : 0 warning(s) |
| arm/stm32h757i-eval-m4 : 0 warning(s) |
| arm/stm32h7b3i-dk : 0 warning(s) |
| arm/xilinx_zynqmp_ultra96 : 1 warning(s) |
| bfin/TLL6527M : 11 warning(s) |
| Shared : 42 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 138 | CPU Kit : 30 | | |
| bfin/bf537Stamp : 0 warning(s) |
| bfin/eZKit533 : 0 warning(s) |
| i386/pc386 : 0 warning(s) |
| i386/pc486 : 0 warning(s) |
| i386/pc586 : 0 warning(s) |
| i386/pc586-sse : 0 warning(s) |
| i386/pc686 : 0 warning(s) |
| i386/pcp4 : 0 warning(s) |
| lm32/lm32_evr : 0 warning(s) |
| lm32/lm32_evr_gdbsim : 0 warning(s) |
| lm32/milkymist : 12 warning(s) |
| Shared : 96 | BSP : 0 | Network : 0 | Tests : 0 |
| m68k/COBRA5475 : 0 warning(s) |
| m68k/av5282 : 0 warning(s) |
| m68k/csb360 : 0 warning(s) |
| m68k/gen68340 : 0 warning(s) |
| m68k/gen68360 : 2 warning(s) |
| Shared : 18 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 12 | | |
| m68k/gen68360_040 : 0 warning(s) |
| m68k/m5484FireEngine : 3 warning(s) |
| Shared : 66 | BSP : 0 | Network : 0 | Tests : 0 |
| m68k/mcf5206elite : 1 warning(s) |
| Shared : 78 | BSP : 0 | Network : 0 | Tests : 0 |
| m68k/mcf52235 : 3 warning(s) |
| m68k/mcf5225x : 3 warning(s) |
| m68k/mcf5235 : 1 warning(s) |
| m68k/mcf5329 : 3 warning(s) |
| m68k/mrm332 : 0 warning(s) |
| m68k/mvme147 : 0 warning(s) |
| m68k/mvme147s : 0 warning(s) |
| m68k/mvme162 : 0 warning(s) |
| m68k/mvme162lx : 0 warning(s) |
| m68k/mvme167 : 0 warning(s) |
| m68k/pgh360 : 0 warning(s) |
| m68k/uC5282 : 6 warning(s) |
| microblaze/kcu105 : 0 warning(s) |
| microblaze/kcu105_qemu : 0 warning(s) |
| mips/hurricane : 1 warning(s) |
| mips/malta : 6 warning(s) |
| mips/rbtx4938 : 1 warning(s) |
| moxie/moxiesim : 2 warning(s) |
| nios2/nios2_iss : 0 warning(s) |
| or1k/generic_or1k : 1 warning(s) |
| powerpc/beatnik : 2 warning(s) |
| LibCPU : 12 | CPU Kit : 4 | | |
| powerpc/br_uid : 0 warning(s) |
| powerpc/gwlcfm : 0 warning(s) |
| powerpc/hsc_cm01 : 0 warning(s) |
| powerpc/icecube : 0 warning(s) |
| powerpc/mcp750 : 0 warning(s) |
| powerpc/mpc5566evb : 0 warning(s) |
| powerpc/mpc5643l_evb : 0 warning(s) |
| powerpc/mpc5668g : 0 warning(s) |
| powerpc/mpc5674fevb : 0 warning(s) |
| powerpc/mpc8260ads : 0 warning(s) |
| powerpc/mpc8309som : 0 warning(s) |
| powerpc/mpc8313erdb : 0 warning(s) |
| powerpc/mpc8349eamds : 0 warning(s) |
| powerpc/mtx603e : 0 warning(s) |
| powerpc/mvme2100 : 0 warning(s) |
| powerpc/mvme2307 : 0 warning(s) |
| powerpc/mvme3100 : 1 warning(s) |
| LibCPU : 0 | CPU Kit : 4 | | |
| powerpc/mvme5500 : 2 warning(s) |
| powerpc/pghplus : 0 warning(s) |
| powerpc/phycore_mpc5554 : 0 warning(s) |
| powerpc/pm520_cr825 : 0 warning(s) |
| powerpc/pm520_ze30 : 0 warning(s) |
| powerpc/psim : 1 warning(s) |
| powerpc/qemuppc : 1 warning(s) |
| powerpc/qemuprep : 0 warning(s) |
| powerpc/qemuprep-altivec : 0 warning(s) |
| powerpc/qoriq_core_0 : 0 warning(s) |
| powerpc/qoriq_core_1 : 0 warning(s) |
| powerpc/qoriq_e500 : 0 warning(s) |
| powerpc/qoriq_e6500_32 : 0 warning(s) |
| powerpc/qoriq_e6500_64 : 4 warning(s) |
| Shared : 24 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 30 | | |
| powerpc/ss555 : 2 warning(s) |
| powerpc/t32mppc : 2 warning(s) |
| LibCPU : 0 | CPU Kit : 40 | | |
| powerpc/tqm8xx_stk8xx : 0 warning(s) |
| powerpc/virtex : 0 warning(s) |
| powerpc/virtex4 : 0 warning(s) |
| powerpc/virtex5 : 0 warning(s) |
| sh/gensh1 : 1 warning(s) |
| sh/gensh2 : 1 warning(s) |
| sh/gensh4 : 1 warning(s) |
| sh/simsh1 : 0 warning(s) |
| sh/simsh2 : 0 warning(s) |
| sh/simsh2e : 0 warning(s) |
| sh/simsh4 : 0 warning(s) |
| sparc/at697f : 0 warning(s) |
| sparc/gr712rc : 0 warning(s) |
| sparc/gr740 : 0 warning(s) |
| sparc/leon2 : 0 warning(s) |
| sparc/leon3 : 0 warning(s) |
| sparc/ut699 : 0 warning(s) |
| sparc/ut700 : 0 warning(s) |
| sparc64/niagara : 0 warning(s) |
| sparc64/usiii : 1 warning(s) |
| v850/v850e1sim : 0 warning(s) |
| v850/v850e2sim : 0 warning(s) |
| v850/v850e2v3sim : 0 warning(s) |
| v850/v850esim : 0 warning(s) |
| v850/v850essim : 0 warning(s) |
| v850/v850sim : 0 warning(s) |
| x86_64/amd64 : 1 warning(s) |
| By Build (total : 10477) |
| common : 381 warning(s) |
| Shared : 1491 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 205 | CPU Kit : 1574 | | |
| debug : 5 warning(s) |
| Shared : 296 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 41 | CPU Kit : 324 | | |
| no-posix : 0 warning(s) |
| posix-debug : 0 warning(s) |
| posix-profiling : 0 warning(s) |
| smp : 0 warning(s) |
| smp-debug : 0 warning(s) |
build mailing list
build at rtems.org
http://lists.rtems.org/mailman/listinfo/build
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230212/814a5eaf/attachment-0001.htm>
