Risc-v failures Fwd: [rtems-bsp-builder] 2023-02-12 05:13:18: Profile(s): everything
Hesham Almatary heshamelmatary at gmail.com
Mon Feb 13 09:11:46 UTC 2023
Hello Joel,
There shouldn't be any BSP with "medany" name in it. Where's the build
script? I tried to fix your build in the cron script [1] but not sure
if you use "medany" anywhere else.
[1] https://github.com/joelsherrill/rtems-cron-helpers/pulls
On Sun, 12 Feb 2023 at 18:12, Joel Sherrill <joel at rtems.org> wrote:
> Hi
> Looks like after Karel's fix goes in, the failures to build are all risc-v bsps. They show up on the Ubuntu and Freebsd build reports but are likely everywhere but the other hosts haven't rotated around yet.
> Hesham.. could you kindly please try to resolve those?
> Thanks
> ---------- Forwarded message ---------
> From: OAR Tester for FreeBSD 12 <rtems-tester at oarcorp.com>
> Date: Sun, Feb 12, 2023, 11:50 AM
> Subject: [rtems-bsp-builder] 2023-02-12 05:13:18: Profile(s): everything
> To: <build at rtems.org>
> RTEMS Tools Project - RTEMS Kernel BSP Builder, 6.0.not_released
> Host: FreeBSD 12.3-RELEASE-p6 GENERIC
> command: /home/tester/rtems-cron-6/tools/6/bin/rtems-bsp-builder\
>          --rtems=/home/tester/rtems-cron-6/rtems --build-path=/home/tester\
>          /rtems-cron-6/build --prefix=/home/tester/rtems-\
>          cron-6/tools/6/bsps --log=/home/tester/rtems-cron-6/bsp-\
>          builder.log --warnings-report=warnings.log --mail --use-gitconfig\
>          --profiles=everything
> Total Time            : 6:36:35.332796 for 1282 completed job(s)
> Average BSP Build Time: 0:00:18.561102
> Builds
>  debug
>  no-posix
>  posix
>  posix-debug
>  posix-profiling
>  profiling
>  smp
>  smp-debug
> Failures Report
>    1 debug arm/stm32h757i-eval-m4 build:
>       configure: /home/tester/rtems-cron-6/rtems/waf configure\
>       --prefix=/home/tester/rtems-cron-6/tools/6/bsps --top=/home/tester\
>       /rtems-cron-6/rtems --rtems-config=config-arm-stm32h757i-\
>       eval-m4-debug.ini
>      error: bsps/arm/stm32h7/boards/stm/stm32h757i-
>             eval/stm32h7-bspstarthooks.c:39:10: fatal error:
>             stm32h747i_eval_qspi.h: No such file or directory
>    2 no-posix arm/stm32h757i-eval-m4 build:
>       /rtems-cron-6/rtems --rtems-config=config-arm-stm32h757i-eval-m4-no-\
>       posix.ini
>    3 posix arm/stm32h757i-eval-m4 build:
>       eval-m4-posix.ini
>    4 posix-debug arm/stm32h757i-eval-m4 build:
>       /rtems-cron-6/rtems --rtems-config=config-arm-stm32h757i-eval-m4\
>       -posix-debug.ini
>    5 posix-profiling arm/stm32h757i-eval-m4 build:
>       -posix-profiling.ini
>    6 profiling arm/stm32h757i-eval-m4 build:
>       eval-m4-profiling.ini
>    7 debug riscv/rv64imac_medany configure:
>       /rtems-cron-6/rtems --rtems-config=config-riscv-rv64imac_medany-\
>       debug.ini
>    8 no-posix riscv/rv64imac_medany configure:
>       /rtems-cron-6/rtems --rtems-config=config-riscv-rv64imac_medany-no-\
>       posix.ini
>    9 posix riscv/rv64imac_medany configure:
>       posix.ini
>   10 posix-debug riscv/rv64imac_medany configure:
>       posix-debug.ini
>   11 posix-profiling riscv/rv64imac_medany configure:
>       posix-profiling.ini
>   12 profiling riscv/rv64imac_medany configure:
>       profiling.ini
>   13 smp riscv/rv64imac_medany configure:
>       smp.ini
>   14 smp-debug riscv/rv64imac_medany configure:
>       /rtems-cron-6/rtems --rtems-config=config-riscv-rv64imac_medany-smp-\
>       debug.ini
>   15 debug riscv/rv64imafd_medany configure:
>       /rtems-cron-6/rtems --rtems-config=config-riscv-rv64imafd_medany-\
>       debug.ini
>   16 no-posix riscv/rv64imafd_medany configure:
>       /rtems-cron-6/rtems --rtems-config=config-riscv-rv64imafd_medany-no-\
>       posix.ini
>   17 posix riscv/rv64imafd_medany configure:
>       posix.ini
>   18 posix-debug riscv/rv64imafd_medany configure:
>       posix-debug.ini
>   19 posix-profiling riscv/rv64imafd_medany configure:
>       posix-profiling.ini
>   20 profiling riscv/rv64imafd_medany configure:
>       profiling.ini
>   21 smp riscv/rv64imafd_medany configure:
>       smp.ini
>   22 smp-debug riscv/rv64imafd_medany configure:
>       smp-debug.ini
>   23 debug riscv/rv64imafdc_medany configure:
>       /rtems-cron-6/rtems --rtems-config=config-riscv-rv64imafdc_medany-\
>       debug.ini
>   24 no-posix riscv/rv64imafdc_medany configure:
>       no-posix.ini
>   25 posix riscv/rv64imafdc_medany configure:
>       posix.ini
>   26 posix-debug riscv/rv64imafdc_medany configure:
>       posix-debug.ini
>   27 posix-profiling riscv/rv64imafdc_medany configure:
>       posix-profiling.ini
>   28 profiling riscv/rv64imafdc_medany configure:
>       profiling.ini
>   29 smp riscv/rv64imafdc_medany configure:
>       smp.ini
>   30 smp-debug riscv/rv64imafdc_medany configure:
>       smp-debug.ini
> Warnings Report
>  | By Architecture (total : 10477)                                     |
>  | common : 14 warning(s)                                              |
>  |   Shared :  738 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :    0 | CPU Kit :  168 |                |                 |
>  | aarch64 : 21 warning(s)                                             |
>  |   Shared :    3 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :    0 | CPU Kit :  532 |                |                 |
>  | arm : 34 warning(s)                                                 |
>  |   Shared :  192 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :    0 | CPU Kit :  202 |                |                 |
>  | bfin : 32 warning(s)                                                |
>  |   Shared :  138 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :  234 | CPU Kit :   90 |                |                 |
>  | i386 : 31 warning(s)                                                |
>  |   Shared :    0 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :    0 | CPU Kit :   60 |                |                 |
>  | lm32 : 14 warning(s)                                                |
>  |   Shared :  156 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :    0 | CPU Kit :   72 |                |                 |
>  | m68k : 33 warning(s)                                                |
>  |   Shared :  936 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :    0 | CPU Kit :  330 |                |                 |
>  | microblaze : 1 warning(s)                                           |
>  |   Shared :   36 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :    0 | CPU Kit :    0 |                |                 |
>  | mips : 8 warning(s)                                                 |
>  |   LibCPU :    0 | CPU Kit :   24 |                |                 |
>  | moxie : 2 warning(s)                                                |
>  |   Shared :   12 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :    0 | CPU Kit :   18 |                |                 |
>  | nios2 : 0 warning(s)                                                |
>  | or1k : 1 warning(s)                                                 |
>  |   Shared :    6 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  | powerpc : 25 warning(s)                                             |
>  |   Shared :  140 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :   12 | CPU Kit :  218 |                |                 |
>  | sh : 162 warning(s)                                                 |
>  |   Shared :   84 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :    0 | CPU Kit :   84 |                |                 |
>  | sparc : 4 warning(s)                                                |
>  | sparc64 : 2 warning(s)                                              |
>  | v850 : 1 warning(s)                                                 |
>  |   Shared :   72 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :    0 | CPU Kit :   36 |                |                 |
>  | x86_64 : 1 warning(s)                                               |
>  |   LibCPU :    0 | CPU Kit :    6 |                |                 |
>  | By BSP (total : 10477)                                              |
>  | common : 291 warning(s)                                             |
>  |   Shared : 1557 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :   96 | CPU Kit : 1300 |                |                 |
>  | aarch64/a53_ilp32_qemu : 0 warning(s)                               |
>  | aarch64/a72_ilp32_qemu : 0 warning(s)                               |
>  | aarch64/xilinx_zynqmp_ilp32_qemu : 0 warning(s)                     |
>  | aarch64/xilinx_zynqmp_ilp32_zu3eg : 1 warning(s)                    |
>  |   Shared :    2 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :    0 | CPU Kit :  152 |                |                 |
>  | arm/altcycv_devkit : 7 warning(s)                                   |
>  | arm/atsamv : 6 warning(s)                                           |
>  | arm/beagleboardorig : 0 warning(s)                                  |
>  | arm/beagleboardxm : 0 warning(s)                                    |
>  | arm/beagleboneblack : 0 warning(s)                                  |
>  | arm/beaglebonewhite : 0 warning(s)                                  |
>  | arm/csb336 : 0 warning(s)                                           |
>  | arm/csb337 : 0 warning(s)                                           |
>  | arm/csb637 : 0 warning(s)                                           |
>  | arm/gumstix : 0 warning(s)                                          |
>  | arm/imx7 : 2 warning(s)                                             |
>  |   LibCPU :    0 | CPU Kit :   32 |                |                 |
>  | arm/imxrt1052 : 0 warning(s)                                        |
>  | arm/kit637_v6 : 0 warning(s)                                        |
>  | arm/lm3s3749 : 0 warning(s)                                         |
>  | arm/lm3s6965 : 0 warning(s)                                         |
>  | arm/lm3s6965_qemu : 0 warning(s)                                    |
>  | arm/lm4f120 : 0 warning(s)                                          |
>  | arm/lpc1768_mbed : 0 warning(s)                                     |
>  | arm/lpc1768_mbed_ahb_ram : 0 warning(s)                             |
>  | arm/lpc1768_mbed_ahb_ram_eth : 0 warning(s)                         |
>  | arm/lpc17xx_ea_ram : 0 warning(s)                                   |
>  | arm/lpc17xx_ea_rom_int : 0 warning(s)                               |
>  | arm/lpc17xx_plx800_ram : 0 warning(s)                               |
>  | arm/lpc17xx_plx800_rom_int : 0 warning(s)                           |
>  | arm/lpc2362 : 0 warning(s)                                          |
>  | arm/lpc23xx_tli800 : 0 warning(s)                                   |
>  | arm/lpc24xx_ea : 0 warning(s)                                       |
>  | arm/lpc24xx_ncs_ram : 0 warning(s)                                  |
>  | arm/lpc24xx_ncs_rom_ext : 0 warning(s)                              |
>  | arm/lpc24xx_ncs_rom_int : 0 warning(s)                              |
>  | arm/lpc24xx_plx800_ram : 0 warning(s)                               |
>  | arm/lpc24xx_plx800_rom_int : 0 warning(s)                           |
>  | arm/lpc32xx_mzx : 0 warning(s)                                      |
>  | arm/lpc32xx_mzx_stage_1 : 0 warning(s)                              |
>  | arm/lpc32xx_mzx_stage_2 : 0 warning(s)                              |
>  | arm/lpc32xx_phycore : 0 warning(s)                                  |
>  | arm/lpc40xx_ea_ram : 0 warning(s)                                   |
>  | arm/lpc40xx_ea_rom_int : 0 warning(s)                               |
>  | arm/nucleo-h743zi : 0 warning(s)                                    |
>  | arm/raspberrypi : 0 warning(s)                                      |
>  | arm/raspberrypi2 : 0 warning(s)                                     |
>  | arm/realview_pbx_a9_qemu : 0 warning(s)                             |
>  | arm/smdk2410 : 0 warning(s)                                         |
>  | arm/stm32f105rc : 0 warning(s)                                      |
>  | arm/stm32f4 : 2 warning(s)                                          |
>  | arm/stm32h7 : 0 warning(s)                                          |
>  | arm/stm32h747i-disco : 0 warning(s)                                 |
>  | arm/stm32h747i-disco-m4 : 0 warning(s)                              |
>  | arm/stm32h757i-eval : 0 warning(s)                                  |
>  | arm/stm32h757i-eval-m4 : 0 warning(s)                               |
>  | arm/stm32h7b3i-dk : 0 warning(s)                                    |
>  | arm/xilinx_zynqmp_ultra96 : 1 warning(s)                            |
>  | bfin/TLL6527M : 11 warning(s)                                       |
>  |   Shared :   42 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :  138 | CPU Kit :   30 |                |                 |
>  | bfin/bf537Stamp : 0 warning(s)                                      |
>  | bfin/eZKit533 : 0 warning(s)                                        |
>  | i386/pc386 : 0 warning(s)                                           |
>  | i386/pc486 : 0 warning(s)                                           |
>  | i386/pc586 : 0 warning(s)                                           |
>  | i386/pc586-sse : 0 warning(s)                                       |
>  | i386/pc686 : 0 warning(s)                                           |
>  | i386/pcp4 : 0 warning(s)                                            |
>  | lm32/lm32_evr : 0 warning(s)                                        |
>  | lm32/lm32_evr_gdbsim : 0 warning(s)                                 |
>  | lm32/milkymist : 12 warning(s)                                      |
>  |   Shared :   96 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  | m68k/COBRA5475 : 0 warning(s)                                       |
>  | m68k/av5282 : 0 warning(s)                                          |
>  | m68k/csb360 : 0 warning(s)                                          |
>  | m68k/gen68340 : 0 warning(s)                                        |
>  | m68k/gen68360 : 2 warning(s)                                        |
>  |   Shared :   18 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :    0 | CPU Kit :   12 |                |                 |
>  | m68k/gen68360_040 : 0 warning(s)                                    |
>  | m68k/m5484FireEngine : 3 warning(s)                                 |
>  |   Shared :   66 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  | m68k/mcf5206elite : 1 warning(s)                                    |
>  |   Shared :   78 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  | m68k/mcf52235 : 3 warning(s)                                        |
>  | m68k/mcf5225x : 3 warning(s)                                        |
>  | m68k/mcf5235 : 1 warning(s)                                         |
>  | m68k/mcf5329 : 3 warning(s)                                         |
>  | m68k/mrm332 : 0 warning(s)                                          |
>  | m68k/mvme147 : 0 warning(s)                                         |
>  | m68k/mvme147s : 0 warning(s)                                        |
>  | m68k/mvme162 : 0 warning(s)                                         |
>  | m68k/mvme162lx : 0 warning(s)                                       |
>  | m68k/mvme167 : 0 warning(s)                                         |
>  | m68k/pgh360 : 0 warning(s)                                          |
>  | m68k/uC5282 : 6 warning(s)                                          |
>  | microblaze/kcu105 : 0 warning(s)                                    |
>  | microblaze/kcu105_qemu : 0 warning(s)                               |
>  | mips/hurricane : 1 warning(s)                                       |
>  | mips/malta : 6 warning(s)                                           |
>  | mips/rbtx4938 : 1 warning(s)                                        |
>  | moxie/moxiesim : 2 warning(s)                                       |
>  | nios2/nios2_iss : 0 warning(s)                                      |
>  | or1k/generic_or1k : 1 warning(s)                                    |
>  | powerpc/beatnik : 2 warning(s)                                      |
>  |   LibCPU :   12 | CPU Kit :    4 |                |                 |
>  | powerpc/br_uid : 0 warning(s)                                       |
>  | powerpc/gwlcfm : 0 warning(s)                                       |
>  | powerpc/hsc_cm01 : 0 warning(s)                                     |
>  | powerpc/icecube : 0 warning(s)                                      |
>  | powerpc/mcp750 : 0 warning(s)                                       |
>  | powerpc/mpc5566evb : 0 warning(s)                                   |
>  | powerpc/mpc5643l_evb : 0 warning(s)                                 |
>  | powerpc/mpc5668g : 0 warning(s)                                     |
>  | powerpc/mpc5674fevb : 0 warning(s)                                  |
>  | powerpc/mpc8260ads : 0 warning(s)                                   |
>  | powerpc/mpc8309som : 0 warning(s)                                   |
>  | powerpc/mpc8313erdb : 0 warning(s)                                  |
>  | powerpc/mpc8349eamds : 0 warning(s)                                 |
>  | powerpc/mtx603e : 0 warning(s)                                      |
>  | powerpc/mvme2100 : 0 warning(s)                                     |
>  | powerpc/mvme2307 : 0 warning(s)                                     |
>  | powerpc/mvme3100 : 1 warning(s)                                     |
>  |   LibCPU :    0 | CPU Kit :    4 |                |                 |
>  | powerpc/mvme5500 : 2 warning(s)                                     |
>  | powerpc/pghplus : 0 warning(s)                                      |
>  | powerpc/phycore_mpc5554 : 0 warning(s)                              |
>  | powerpc/pm520_cr825 : 0 warning(s)                                  |
>  | powerpc/pm520_ze30 : 0 warning(s)                                   |
>  | powerpc/psim : 1 warning(s)                                         |
>  | powerpc/qemuppc : 1 warning(s)                                      |
>  | powerpc/qemuprep : 0 warning(s)                                     |
>  | powerpc/qemuprep-altivec : 0 warning(s)                             |
>  | powerpc/qoriq_core_0 : 0 warning(s)                                 |
>  | powerpc/qoriq_core_1 : 0 warning(s)                                 |
>  | powerpc/qoriq_e500 : 0 warning(s)                                   |
>  | powerpc/qoriq_e6500_32 : 0 warning(s)                               |
>  | powerpc/qoriq_e6500_64 : 4 warning(s)                               |
>  |   Shared :   24 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :    0 | CPU Kit :   30 |                |                 |
>  | powerpc/ss555 : 2 warning(s)                                        |
>  | powerpc/t32mppc : 2 warning(s)                                      |
>  |   LibCPU :    0 | CPU Kit :   40 |                |                 |
>  | powerpc/tqm8xx_stk8xx : 0 warning(s)                                |
>  | powerpc/virtex : 0 warning(s)                                       |
>  | powerpc/virtex4 : 0 warning(s)                                      |
>  | powerpc/virtex5 : 0 warning(s)                                      |
>  | sh/gensh1 : 1 warning(s)                                            |
>  | sh/gensh2 : 1 warning(s)                                            |
>  | sh/gensh4 : 1 warning(s)                                            |
>  | sh/simsh1 : 0 warning(s)                                            |
>  | sh/simsh2 : 0 warning(s)                                            |
>  | sh/simsh2e : 0 warning(s)                                           |
>  | sh/simsh4 : 0 warning(s)                                            |
>  | sparc/at697f : 0 warning(s)                                         |
>  | sparc/gr712rc : 0 warning(s)                                        |
>  | sparc/gr740 : 0 warning(s)                                          |
>  | sparc/leon2 : 0 warning(s)                                          |
>  | sparc/leon3 : 0 warning(s)                                          |
>  | sparc/ut699 : 0 warning(s)                                          |
>  | sparc/ut700 : 0 warning(s)                                          |
>  | sparc64/niagara : 0 warning(s)                                      |
>  | sparc64/usiii : 1 warning(s)                                        |
>  | v850/v850e1sim : 0 warning(s)                                       |
>  | v850/v850e2sim : 0 warning(s)                                       |
>  | v850/v850e2v3sim : 0 warning(s)                                     |
>  | v850/v850esim : 0 warning(s)                                        |
>  | v850/v850essim : 0 warning(s)                                       |
>  | v850/v850sim : 0 warning(s)                                         |
>  | x86_64/amd64 : 1 warning(s)                                         |
>  | By Build (total : 10477)                                            |
>  | common : 381 warning(s)                                             |
>  |   Shared : 1491 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :  205 | CPU Kit : 1574 |                |                 |
>  | debug : 5 warning(s)                                                |
>  |   Shared :  296 |     BSP :    0 | Network :    0 |    Tests :    0 |
>  |   LibCPU :   41 | CPU Kit :  324 |                |                 |
>  | no-posix : 0 warning(s)                                             |
>  | posix-debug : 0 warning(s)                                          |
>  | posix-profiling : 0 warning(s)                                      |
>  | smp : 0 warning(s)                                                  |
>  | smp-debug : 0 warning(s)                                            |
> build mailing list
> build at rtems.org
> http://lists.rtems.org/mailman/listinfo/build
Regards,
Hesham
