warnings report on builder wrong?
Mon Feb 13 23:47:44 UTC 2023
Chris.. see below
On Mon, Feb 13, 2023 at 5:42 PM Karel Gardas <karel at functional.vision>
wrote:
> On 2/14/23 00:33, Joel Sherrill wrote:
> > With fresh tools on CentOS 7, I have 5 warnings in beaglebonewhite. Log
> > attached.
> > Sorry it took so long. I ran out of disk space, then got distracted.
> > I have no idea why the rtems-bsp-builder isn't tripping these unless it
> > isn't actually hitting the default build settings. But these warnings
> > looked pretty generic at first glance.
> Don't worry about delay, I was just reporting those as you IIRC asked
> for warnings fixes and I just saw evidence that builder is not showing
> actual state.
> Is it possible that software building the table for the report is a bit
> buggy and ignores warnings or it assign those into wrong category? If
> you would have build logs from those then such judgment is easy to do...
Chris wrong the bsp builder so I have no idea. But I saw ones which were
triggered in bsp specific files along with some tests. The tests might have
gotten counted elsewhere. Fix them if you see them.
I'm not sure what to look for on the build VMs.
--joel
> Thanks,
> Karel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230213/0fa05b26/attachment.htm>
