[patch] medit issue
Joel Sherrill
joel at rtems.org
Tue Feb 14 05:22:15 UTC 2023
On Mon, Feb 13, 2023, 11:04 PM Gedare Bloom <gedare at rtems.org> wrote:
> Hi Zack,
> This is very close but I think something is still going strangely with
> your patch commit message or with your git-send-email. The subject
> line of the git-send-email should inherit from the first line of your
> commit message, so either your commit message has "medit issue" as its
> first line, or there is something strange in how your patch is being
> emailed.
Copy and pasted in an email? Rather than git send-email or attaching it?
> Can you either check your configuration and command for
> git-send-email, or just send the patch as a diff/.patch file?
> Gedare
> On Fri, Feb 10, 2023 at 7:35 PM zack leung <zakthertemsdev at gmail.com>
> wrote:
> > libmisc/shell: User can't cut using ctrl e and x in medit
> > Closes #4557
> > cpukit/libmisc/shell/main_edit.c | 3 +--
> > 1 file changed, 1 insertion(+), 2 deletions(-)
> > diff --git a/cpukit/libmisc/shell/main_edit.c
> b/cpukit/libmisc/shell/main_edit.c
> > index 6e954639e2..8317452b7b 100644
> > --- a/cpukit/libmisc/shell/main_edit.c
> > +++ b/cpukit/libmisc/shell/main_edit.c
> > @@ -1713,7 +1713,6 @@ static void copy_selection(struct editor *ed) {
> > ed->env->clipboard = (unsigned char *) realloc(ed->env->clipboard,
> ed->env->clipsize);
> > if (!ed->env->clipboard) return;
> > copy(ed, ed->env->clipboard, selstart, ed->env->clipsize);
> > - select_toggle(ed);
> > static void cut_selection(struct editor *ed) {
> > @@ -2132,7 +2131,7 @@ static void edit(struct editor *ed) {
> > case ctrl('e'): select_toggle(ed); break;
> > case ctrl('a'): select_all(ed); break;
> > - case ctrl('c'): copy_selection(ed); break;
> > + case ctrl('c'): copy_selection(ed);select_toggle(ed); break;
> > case ctrl('f'): find_text(ed, 0); break;
> > case ctrl('l'): goto_line(ed); break;
> > case ctrl('g'): find_text(ed, 1); break;
> > 2.39.1
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230213/20bbaf7f/attachment-0001.htm>
