[patch] medit issue
    Gedare Bloom
    gedare at rtems.org
    Mon Feb 13 18:19:16 UTC 2023
Hi Zack,
This is very close but I think something is still going strangely with
your patch commit message or with your git-send-email. The subject
line of the git-send-email should inherit from the first line of your
commit message, so either your commit message has "medit issue" as its
first line, or there is something strange in how your patch is being
emailed.
Can you either check your configuration and command for
git-send-email, or just send the patch as a diff/.patch file?
Gedare
On Fri, Feb 10, 2023 at 7:35 PM zack leung <zakthertemsdev at gmail.com> wrote:
> libmisc/shell: User can't cut using ctrl e and x in medit
> Closes #4557
>  cpukit/libmisc/shell/main_edit.c | 3 +--
>  1 file changed, 1 insertion(+), 2 deletions(-)
> diff --git a/cpukit/libmisc/shell/main_edit.c b/cpukit/libmisc/shell/main_edit.c
> index 6e954639e2..8317452b7b 100644
> --- a/cpukit/libmisc/shell/main_edit.c
> +++ b/cpukit/libmisc/shell/main_edit.c
> @@ -1713,7 +1713,6 @@ static void copy_selection(struct editor *ed) {
>    ed->env->clipboard = (unsigned char *) realloc(ed->env->clipboard, ed->env->clipsize);
>    if (!ed->env->clipboard) return;
>    copy(ed, ed->env->clipboard, selstart, ed->env->clipsize);
> -  select_toggle(ed);
>  static void cut_selection(struct editor *ed) {
> @@ -2132,7 +2131,7 @@ static void edit(struct editor *ed) {
>          case ctrl('e'): select_toggle(ed); break;
>          case ctrl('a'): select_all(ed); break;
> -        case ctrl('c'): copy_selection(ed); break;
> +        case ctrl('c'): copy_selection(ed);select_toggle(ed); break;
>          case ctrl('f'): find_text(ed, 0); break;
>          case ctrl('l'): goto_line(ed); break;
>          case ctrl('g'): find_text(ed, 1); break;
> 2.39.1
> devel mailing list
> devel at rtems.org
