Build failures on CentOS 8
Chris Johns
chrisj at rtems.org
Thu Feb 16 22:11:08 UTC 2023
On 17/2/2023 3:36 am, Joel Sherrill wrote:
> On Thu, Feb 16, 2023, 8:57 AM Jeff Mayes <Jeff.Mayes at oarcorp.com
> <mailto:Jeff.Mayes at oarcorp.com>> wrote:
> >>On 16/2/2023 8:43 am, Jeff Mayes wrote:
> >> We?re getting an odd build failure on CentOS 8. (I know it?s EOL.)
> >> ?Below is a snip of the output.? Any ideas?
> >Are you able to run a test with the latest version of waf?
> >You can download it here https://waf.io/waf-2.0.25
> <https://waf.io/waf-2.0.25> (https://waf.io/ <https://waf.io/>) and simply
> replace the `waf` file in our top level with it. You will need to `distclean
> configure ...` once replaced.
> >Chris
> Yes. That did the trick.
> That's good news.
Yes it is good new.
> The questiona now for Chris are:
> (1) Should Jeff file a ticket?
> (2) Does waf need updating in every repo?
That would good.
> If so, is that RTEMS, libbsd, examples, and lwip? Anywhere else ?
rtems-tools?
