Build failures on CentOS 8
Thu Feb 16 16:36:40 UTC 2023
On Thu, Feb 16, 2023, 8:57 AM Jeff Mayes <Jeff.Mayes at oarcorp.com> wrote:
> >>On 16/2/2023 8:43 am, Jeff Mayes wrote:
> >> We?re getting an odd build failure on CentOS 8. (I know it?s EOL.)
> >> ?Below is a snip of the output.? Any ideas?
> >Are you able to run a test with the latest version of waf?
> >You can download it here https://waf.io/waf-2.0.25 (https://waf.io/) and
> simply replace the `waf` file in our top level with it. You will need to
> `distclean configure ...` once replaced.
> >Chris
> Yes. That did the trick.
That's good news. The questiona now for Chris are:
(1) Should Jeff file a ticket?
(2) Does waf need updating in every repo? If so, is that RTEMS, libbsd,
examples, and lwip? Anywhere else ?
Luckily this only impacts 6
--joel
Thanks!
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230216/93cdb3c8/attachment.htm>
