[PATCH v1 0/1] Update rtems-llvm to version 11.1.0
Jan.Sommer at dlr.de
Tue Feb 21 14:30:35 UTC 2023
Hello everyone,
I tried to build a riscv BSP with the information from Hesham. Thanks again.
It now compiles the files, but produces a lot of warnings and fails to link in the end.
The warnings are of this type
../../../cpukit/score/cpu/riscv/riscv-exception-handler.S:48:10: warning: unknown option, expected 'push', 'pop', 'rvc', 'norvc', 'relax' or 'norelax'
.option arch, +zicsr
And in the end the linker cannot find the " _RISCV_Exception_handler", so I guess the warning prevents those symbols from being built. My best guess is that it is related to this llvm issue: https://reviews.llvm.org/D141666 which is actively worked on as of this month and we probably have to wait for this to become part of llvm.
Out of curiosity, I tried the same with the Zedboard BSP. There, linking passed and I got to this point for base_sp.exe:
*** BEGIN OF TEST OH ***
*** TEST VERSION: 6.0.0.c0fad60c59bf14b9d1a4eb3d76f872e2cf43e7b8
*** TEST STATE: (null)
*** TEST BUILD:
*** TEST TOOLS: Clang 11.1.0 (https://git.rtems.org/rtems-source-builder 64df106288cf6c4289a9c78850a82bfb2b41caa2)
Creating and starting an application task
*** FATAL ***
fatal source: 0 (INTERNAL_ERROR_CORE)
fatal code: 31 (INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT)
RTEMS version: 6.0.0.c0fad60c59bf14b9d1a4eb3d76f872e2cf43e7b8
RTEMS tools: Clang 11.1.0 (https://git.rtems.org/rtems-source-builder 64df106288cf6c4289a9c78850a82bfb2b41caa2)
executing thread is NULL
So, let's say it's something. Now at least I have a system to debug. I will also have a look how to make the process more accessible. At the moment things are just crowbarred into the build system to make it work.
Coming back to the patch: If there are no objections I would like to push the commit for llvm11.
Chances are that further updates are to come as I progress.
Best regards,
Jan
> -----Original Message-----
> From: Hesham Almatary <heshamelmatary at gmail.com>
> Sent: Mittwoch, 15. Februar 2023 11:17
> To: Sommer, Jan <Jan.Sommer at dlr.de>
> Cc: joel at rtems.org; devel at rtems.org
> Subject: Re: [PATCH v1 0/1] Update rtems-llvm to version 11.1.0
> > > Sent: Montag, 13. Februar 2023 16:19
> > > > > From: Joel Sherrill <joel at rtems.org>
> > > > > Sent: Freitag, 10. Februar 2023 15:21
> > > > > Cc: devel at rtems.org
> > > > > On Fri, Feb 10, 2023 at 3:16 AM Jan Sommer <jan.sommer at dlr.de
> > > > > <mailto:jan.sommer at dlr.de> > wrote:
> > > > > Hello,
> > > > > I couldn't get the rtems-llvm buildset to work.
> > > > > As it was building llvm8 which is not that modern, I just tried to
> build
> > > > > a more recent version with the scripts.
> > > > > It works with llvm11. Are there any objections to updating?
> > > > > Nope. Please feel free to add this.
> > > > > And should we keep the rtems-llvm-8.cfg or should I remove
> > > > > this with
> > > > > this patch?
> > > > > My main concern is if the architectures that built with llvm 8
> > > > > still build with llvm 11. I think that's only SPARC and RISC-V.
> > > > > Are there
> > > others?
> > > Why not the latest LLVM (especially to pick up the latest RISC-V
> > > fixes/support). I am not sure how mature the RISC-V support is in
> > > LLVM 8, if it was supported at all.
> > Yes, that is also my goal. I got llvm11 building with only small changes to the
> buildset and wanted to go from there.
> > In the meantime I also managed to build llvm up to 14 locally. Once I have
> all the bits and pieces working to some degree I will probably consolidate to a
> more recent version.
> Seems like a good plan.
> > > > > I guess that points to me not knowing the list of architectures
> > > > > that are expected to work. I wonder where we would keep this
> information.
> > > > > Any thoughts?
> > > > Thanks for the information.
> > > > I tried to build those to check if they still work and failed, but
> > > > given that the
> > > information I could find is sparse I could very well be the problem.
> > > > What I did is:
> > > > - Build the gcc toolchains for sparc and riscv (as far as I
> > > > understand we need the binutils and libc from that)
> > > I haven't tried doing that for RISC-V. I used to build newlib
> > > manually, and not rely on GCC/binutils.
> > Ah, I see. Just for clarification you also cross-built newlib with clang?
> Yes, besides compiler-rt (LLVM's version of libgcc). But you don't need to go
> all the way there, you can just use GCC's newlib.
> > > > - Build the rtems-llvm build set
> > > > - Generate a config for waf using: ./waf bspdefaults
> > > > --rtems-bsps='sparc/gr712rc' --rtems-compiler=clang > sparc.cfg
> > > > - Configure the build with the config: ./waf configure
> > > > --rtems-config=sparc.cfg -$INSTALL_DIR
> > > > - Run ./waf
> > > > - I also tried with some riscv BSPs with the same results.
> > > > The build fails with missing std headers (stddef.h).
> > > > Looking at the generated config file there are only small
> > > > differences to the
> > > one for gcc (essentially the compiler name changed to clang).
> > > > And the verbose output confirms that the gcc toolchain is not part
> > > > of the
> > > include paths.
> > > > I didn't find an obvious option in "waf configure" to add this.
> > > I added [1] an option for "sysroot" in the old build system so that
> > > Clang could find the C library. I don't think that was integrated in
> > > waf. However, I was also using CHERI-based LLVM with a modified
> > > Driver so that it automatically fetches the C library (after it gets
> > > manually built and installed under a convenient LLVM) related to the
> LLVM install path.
> > > [1]
> https://github.com/RTEMS/rtems/commit/94481cedc4165f6a49ef528709825
> > > 1740922fee1
> > Ah, thanks for this. I think this is a good starting point to experiment with.
> > Best regards,
> > Jan
> > > > If you say that building worked only for few BSPs. Do you remember
> > > > which
> > > ones and if there was some magic to do first?
> > > > Then I could try to reproduce this with the llvm11 compiler.
> > > I don't think they'll build as is without a few modifications to the
> > > build system. Simplest thing to do is to use GCC's libgcc and newlib
> > > and add a "sysroot" or "-L -I" options to the current build system for
> them.
> > > > Best regards,
> > > > Jan
> > > > > --joel
> > > > > Have a nice weekend,
> > > > > Jan
> > > > > Jan Sommer (1):
> > > > > rtems-tools: Update rtems-llvm to version 11.1.0
> > > > > rtems/config/6/rtems-llvm.bset | 2 +-
> > > > > rtems/config/tools/rtems-llvm-11.1.0.cfg | 21
> > > > > source-builder/config/llvm-common-1.cfg | 6 +++---
> > > > > 3 files changed, 25 insertions(+), 4 deletions(-)
> > > > > create mode 100644
> > > > > 2.25.1
> > > > > _______________________________________________
> > > > > devel mailing list
> > > > > devel at rtems.org <mailto:devel at rtems.org>
> > > > > http://lists.rtems.org/mailman/listinfo/devel
> > > > devel mailing list
> > > > devel at rtems.org
> > > Regards,
> > > Hesham
> Regards,
> Hesham
