[PATCH v1 0/1] Update rtems-llvm to version 11.1.0
Hesham Almatary
heshamelmatary at gmail.com
Wed Feb 22 13:33:31 UTC 2023
On Tue, 21 Feb 2023 at 14:30, <Jan.Sommer at dlr.de> wrote:
> Hello everyone,
> I tried to build a riscv BSP with the information from Hesham. Thanks again.
> It now compiles the files, but produces a lot of warnings and fails to link in the end.
> The warnings are of this type
> ../../../cpukit/score/cpu/riscv/riscv-exception-handler.S:48:10: warning: unknown option, expected 'push', 'pop', 'rvc', 'norvc', 'relax' or 'norelax'
> .option arch, +zicsr
Does this happen if you use the latest LLVM?
> And in the end the linker cannot find the " _RISCV_Exception_handler", so I guess the warning prevents those symbols from being built. My best guess is that it is related to this llvm issue: https://reviews.llvm.org/D141666 which is actively worked on as of this month and we probably have to wait for this to become part of llvm.
Are you sure the right linker is used (lld?) I remember I had to add a
custom patch for RTEMS to be able to use the right linker and options.
https://github.com/CTSRD-CHERI/clang/blob/master/lib/Driver/ToolChains/RTEMS.cpp
> Out of curiosity, I tried the same with the Zedboard BSP. There, linking passed and I got to this point for base_sp.exe:
> *** BEGIN OF TEST OH ***
> *** TEST VERSION: 6.0.0.c0fad60c59bf14b9d1a4eb3d76f872e2cf43e7b8
> *** TEST STATE: (null)
> *** TEST BUILD:
> *** TEST TOOLS: Clang 11.1.0 (https://git.rtems.org/rtems-source-builder 64df106288cf6c4289a9c78850a82bfb2b41caa2)
> Creating and starting an application task
> *** FATAL ***
> fatal source: 0 (INTERNAL_ERROR_CORE)
> fatal code: 31 (INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT)
> RTEMS version: 6.0.0.c0fad60c59bf14b9d1a4eb3d76f872e2cf43e7b8
> RTEMS tools: Clang 11.1.0 (https://git.rtems.org/rtems-source-builder 64df106288cf6c4289a9c78850a82bfb2b41caa2)
> executing thread is NULL
> So, let's say it's something. Now at least I have a system to debug. I will also have a look how to make the process more accessible. At the moment things are just crowbarred into the build system to make it work.
> Coming back to the patch: If there are no objections I would like to push the commit for llvm11.
> Chances are that further updates are to come as I progress.
> Best regards,
> Jan
> > -----Original Message-----
> > From: Hesham Almatary <heshamelmatary at gmail.com>
> > Sent: Mittwoch, 15. Februar 2023 11:17
> > To: Sommer, Jan <Jan.Sommer at dlr.de>
> > Cc: joel at rtems.org; devel at rtems.org
> > Subject: Re: [PATCH v1 0/1] Update rtems-llvm to version 11.1.0
> > > > Sent: Montag, 13. Februar 2023 16:19
> > > > > > From: Joel Sherrill <joel at rtems.org>
> > > > > > Sent: Freitag, 10. Februar 2023 15:21
> > > > > > Cc: devel at rtems.org
> > > > > > On Fri, Feb 10, 2023 at 3:16 AM Jan Sommer <jan.sommer at dlr.de
> > > > > > <mailto:jan.sommer at dlr.de> > wrote:
> > > > > > Hello,
> > > > > > I couldn't get the rtems-llvm buildset to work.
> > > > > > As it was building llvm8 which is not that modern, I just tried to
> > build
> > > > > > a more recent version with the scripts.
> > > > > > It works with llvm11. Are there any objections to updating?
> > > > > > Nope. Please feel free to add this.
> > > > > > And should we keep the rtems-llvm-8.cfg or should I remove
> > > > > > this with
> > > > > > this patch?
> > > > > > My main concern is if the architectures that built with llvm 8
> > > > > > still build with llvm 11. I think that's only SPARC and RISC-V.
> > > > > > Are there
> > > > others?
> > > > Why not the latest LLVM (especially to pick up the latest RISC-V
> > > > fixes/support). I am not sure how mature the RISC-V support is in
> > > > LLVM 8, if it was supported at all.
> > > Yes, that is also my goal. I got llvm11 building with only small changes to the
> > buildset and wanted to go from there.
> > > In the meantime I also managed to build llvm up to 14 locally. Once I have
> > all the bits and pieces working to some degree I will probably consolidate to a
> > more recent version.
> > Seems like a good plan.
> > > > > > I guess that points to me not knowing the list of architectures
> > > > > > that are expected to work. I wonder where we would keep this
> > information.
> > > > > > Any thoughts?
> > > > > Thanks for the information.
> > > > > I tried to build those to check if they still work and failed, but
> > > > > given that the
> > > > information I could find is sparse I could very well be the problem.
> > > > > What I did is:
> > > > > - Build the gcc toolchains for sparc and riscv (as far as I
> > > > > understand we need the binutils and libc from that)
> > > > I haven't tried doing that for RISC-V. I used to build newlib
> > > > manually, and not rely on GCC/binutils.
> > > Ah, I see. Just for clarification you also cross-built newlib with clang?
> > Yes, besides compiler-rt (LLVM's version of libgcc). But you don't need to go
> > all the way there, you can just use GCC's newlib.
> > > > > - Build the rtems-llvm build set
> > > > > - Generate a config for waf using: ./waf bspdefaults
> > > > > --rtems-bsps='sparc/gr712rc' --rtems-compiler=clang > sparc.cfg
> > > > > - Configure the build with the config: ./waf configure
> > > > > --rtems-config=sparc.cfg -$INSTALL_DIR
> > > > > - Run ./waf
> > > > > - I also tried with some riscv BSPs with the same results.
> > > > > The build fails with missing std headers (stddef.h).
> > > > > Looking at the generated config file there are only small
> > > > > differences to the
> > > > one for gcc (essentially the compiler name changed to clang).
> > > > > And the verbose output confirms that the gcc toolchain is not part
> > > > > of the
> > > > include paths.
> > > > > I didn't find an obvious option in "waf configure" to add this.
> > > > I added [1] an option for "sysroot" in the old build system so that
> > > > Clang could find the C library. I don't think that was integrated in
> > > > waf. However, I was also using CHERI-based LLVM with a modified
> > > > Driver so that it automatically fetches the C library (after it gets
> > > > manually built and installed under a convenient LLVM) related to the
> > LLVM install path.
> > > > [1]
> > https://github.com/RTEMS/rtems/commit/94481cedc4165f6a49ef528709825
> > > > 1740922fee1
> > > Ah, thanks for this. I think this is a good starting point to experiment with.
> > > Best regards,
> > > Jan
> > > > > If you say that building worked only for few BSPs. Do you remember
> > > > > which
> > > > ones and if there was some magic to do first?
> > > > > Then I could try to reproduce this with the llvm11 compiler.
> > > > I don't think they'll build as is without a few modifications to the
> > > > build system. Simplest thing to do is to use GCC's libgcc and newlib
> > > > and add a "sysroot" or "-L -I" options to the current build system for
> > them.
> > > > > Best regards,
> > > > > Jan
> > > > > > --joel
> > > > > > Have a nice weekend,
> > > > > > Jan
> > > > > > Jan Sommer (1):
> > > > > > rtems-tools: Update rtems-llvm to version 11.1.0
> > > > > > rtems/config/6/rtems-llvm.bset | 2 +-
> > > > > > rtems/config/tools/rtems-llvm-11.1.0.cfg | 21
> > > > > > source-builder/config/llvm-common-1.cfg | 6 +++---
> > > > > > 3 files changed, 25 insertions(+), 4 deletions(-)
> > > > > > create mode 100644
> > > > > > 2.25.1
> > > > > > _______________________________________________
> > > > > > devel mailing list
> > > > > > devel at rtems.org <mailto:devel at rtems.org>
> > > > > > http://lists.rtems.org/mailman/listinfo/devel
> > > > > devel mailing list
> > > > > devel at rtems.org
> > > > Regards,
> > > > Hesham
> > Regards,
> > Hesham
Regards,
Hesham
