[PATCH rtems-source-builder 2/2] 6/rtems-default.bset: Update binutils version to 2.40
Joel Sherrill
joel at rtems.org
Tue Feb 21 15:25:32 UTC 2023
rtems/config/6/rtems-default.bset | 2 +-
rtems/config/tools/rtems-binutils-2.40.cfg | 13 +++++++++++++
2 files changed, 14 insertions(+), 1 deletion(-)
create mode 100644 rtems/config/tools/rtems-binutils-2.40.cfg
diff --git a/rtems/config/6/rtems-default.bset b/rtems/config/6/rtems-default.bset
index a76efe6..ff9f9f5 100644
--- a/rtems/config/6/rtems-default.bset
+++ b/rtems/config/6/rtems-default.bset
@@ -13,7 +13,7 @@
%defineifnot with_rtems_expat devel/expat-2.4.8-1
%defineifnot with_rtems_gmp devel/gmp-6.2.1
%defineifnot with_rtems_gdb tools/rtems-gdb-13.1
-%defineifnot with_rtems_binutils tools/rtems-binutils-2.38
+%defineifnot with_rtems_binutils tools/rtems-binutils-2.40
%defineifnot with_rtems_gcc tools/rtems-gcc-12-newlib-head
%defineifnot with_rtems_tools tools/rtems-tools-6
diff --git a/rtems/config/tools/rtems-binutils-2.40.cfg b/rtems/config/tools/rtems-binutils-2.40.cfg
new file mode 100644
index 0000000..87f634b
--- /dev/null
+++ b/rtems/config/tools/rtems-binutils-2.40.cfg
@@ -0,0 +1,13 @@
+%include %{_configdir}/checks.cfg
+%include %{_configdir}/base.cfg
+%define binutils_version 2.40
+#%define binutils_external 1
+%hash sha512 binutils-%{binutils_version}.tar.bz2 \
+ MCVjYpRRhDKcmUcw9g2EkyklR+Dl3l9J1XSQ2NmxoKGDk79/cJNLpQYe4gAexMv18gbTEN+VEqf7NiWjYuNY+Q==
+%define with_deterministic_archives 1
+%define with_64_bit_bfd 1
+%include %{_configdir}/binutils-2-1.cfg
2.24.4
