[PATCH rtems-source-builder 1/2] Update to gdb 13.1 for rtems 6
Frank Kühndel
frank.kuehndel at embedded-brains.de
Wed Feb 22 09:28:57 UTC 2023
Hello Joel,
On 2/21/23 16:25, Joel Sherrill wrote:
> Subject:
> From:
> Joel Sherrill <joel at rtems.org>
> Date:
> 2/21/23, 16:25
> To:
> devel at rtems.org
> rtems/config/6/rtems-default.bset | 2 +-
> rtems/config/tools/rtems-gdb-13.1.cfg | 16 ++++++++++++++++
> 2 files changed, 17 insertions(+), 1 deletion(-)
> create mode 100644 rtems/config/tools/rtems-gdb-13.1.cfg
> diff --git a/rtems/config/6/rtems-default.bset b/rtems/config/6/rtems-default.bset
> index a0601aa..a76efe6 100644
> --- a/rtems/config/6/rtems-default.bset
> +++ b/rtems/config/6/rtems-default.bset
> @@ -12,7 +12,7 @@
> %defineifnot with_rtems_dtc devel/dtc-1.6.1-1
> %defineifnot with_rtems_expat devel/expat-2.4.8-1
> %defineifnot with_rtems_gmp devel/gmp-6.2.1
> -%defineifnot with_rtems_gdb tools/rtems-gdb-12.1
> +%defineifnot with_rtems_gdb tools/rtems-gdb-13.1
> %defineifnot with_rtems_binutils tools/rtems-binutils-2.38
> %defineifnot with_rtems_gcc tools/rtems-gcc-12-newlib-head
> %defineifnot with_rtems_tools tools/rtems-tools-6
> diff --git a/rtems/config/tools/rtems-gdb-13.1.cfg b/rtems/config/tools/rtems-gdb-13.1.cfg
> new file mode 100644
> index 0000000..4a6a1c7
> --- /dev/null
> +++ b/rtems/config/tools/rtems-gdb-13.1.cfg
> @@ -0,0 +1,16 @@
> +# GDB 12.1
Is 12.1 correct? It looks like a copy-paste error.
Greetings
Frank
> +%include %{_configdir}/checks.cfg
> +%include %{_configdir}/base.cfg
> +%define gdb_version 13.1
> +%define gdb_src_ext xz
> +%hash sha512 gdb-%{gdb_version}.tar.xz \
> + 5lBU/7wDV+7tSxfh7cXvRapzyd3zsSEGUePYWVduJ8HSeyZoAP4mMo7aWIV0VczYYy9AAM/F9j+QhUCWKQGHyg==
> +#%patch add gdb --rsb-file=gdb-readline8.2.patchhttps://sourceware.org/git/?p=binutils-gdb.git;a=commitdiff_plain;h=1add37b567a7dee39d99f37b37802034c3fce9c4
> +#%hash sha512 gdb-readline8.2.patch E/nGalfBBfn0rl/pi1SGIuKD11x0qREZBp3ajaFbl/nGMZUIm31M/1z0FsG76K7IjvE5pPsl2JqESt+LBN9lZA==
> +%include %{_configdir}/gdb-common-1.cfg
> -- 2.24.4 _______________________________________________ devel mailing
> list devel at rtems.org http://lists.rtems.org/mailman/listinfo/devel
embedded brains GmbH
Herr Frank KÜHNDEL
Dornierstr. 4
82178 Puchheim
Germany
email: frank.kuehndel at embedded-brains.de
phone: +49-89-18 94 741 - 23
mobile: +49-176-15 22 06 - 11
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
