[PATCH] riscv: Update RISC-V BSPs
Wed Feb 22 15:32:09 UTC 2023
This is OK.
Be sure to follow up with a patch to bump the rtems-tools hash in the RSB.
--joel
On Wed, Feb 22, 2023 at 9:14 AM Hesham Almatary <heshamelmatary at gmail.com>
wrote:
> * Only use BSPs supported by GCC's multilibs. This removes rv32imafdc
> * Remove BSPs with medany name in them (See #4775).
> RV64 BSPs are now all medany by default.
>  config/rtems-bsps-riscv.ini | 5 ++---
>  config/rtems-bsps-tiers.ini | 5 ++---
>  2 files changed, 4 insertions(+), 6 deletions(-)
> diff --git a/config/rtems-bsps-riscv.ini b/config/rtems-bsps-riscv.ini
> index 804245e..af037ec 100644
> --- a/config/rtems-bsps-riscv.ini
> +++ b/config/rtems-bsps-riscv.ini
> @@ -23,7 +23,6 @@
>  [riscv]
>  bsps = frdme310arty,
>         griscv, grv32i, grv32im, grv32imac, grv32imafdc,
> -       rv32iac, rv32i, rv32imac, rv32imafc, rv32imafdc, rv32imafd, rv32im,
> -       rv64imac, rv64imac_medany, rv64imafdc, rv64imafd,
> rv64imafdc_medany,
> -       rv64imafd_medany
> +       rv32iac, rv32i, rv32imac, rv32imafc, rv32imafd, rv32im,
> +       rv64imac, rv64imafdc, rv64imafd
>  exclude-smp = rv32i, rv32im
> diff --git a/config/rtems-bsps-tiers.ini b/config/rtems-bsps-tiers.ini
> index 9b52429..c8b4ad5 100644
> --- a/config/rtems-bsps-tiers.ini
> +++ b/config/rtems-bsps-tiers.ini
> @@ -124,9 +124,8 @@ bsps_powerpc = beatnik,
>      virtex, virtex4, virtex5
>  bsps_riscv = griscv, grv32i, grv32im, grv32imac, grv32imafdc,
>      frdme310arty,
> -    rv32i, rv32iac, rv32im, rv32imac, rv32imafc, rv32imafd, rv32imafdc,
> -    rv64imac, rv64imac_medany, rv64imafd, rv64imafd_medany,
> -    rv64imafdc, rv64imafdc_medany
> +    rv32i, rv32iac, rv32im, rv32imac, rv32imafc, rv32imafd,
> +    rv64imac, rv64imafd, rv64imafdc
>  bsps_sh = gensh1, gensh2, gensh4, simsh1, simsh2, simsh2e, simsh4
>  bsps_sparc = at697f, gr712rc, ut699, ut700, gr740
>  bsps_sparc64 = niagara, usiii
> 2.25.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230222/23f4192d/attachment.htm>
