[PATCH] riscv: Update RISC-V BSPs
Hesham Almatary
heshamelmatary at gmail.com
Wed Feb 22 15:14:39 UTC 2023
* Only use BSPs supported by GCC's multilibs. This removes rv32imafdc
* Remove BSPs with medany name in them (See #4775).
RV64 BSPs are now all medany by default.
config/rtems-bsps-riscv.ini | 5 ++---
config/rtems-bsps-tiers.ini | 5 ++---
2 files changed, 4 insertions(+), 6 deletions(-)
diff --git a/config/rtems-bsps-riscv.ini b/config/rtems-bsps-riscv.ini
index 804245e..af037ec 100644
--- a/config/rtems-bsps-riscv.ini
+++ b/config/rtems-bsps-riscv.ini
@@ -23,7 +23,6 @@
[riscv]
bsps = frdme310arty,
griscv, grv32i, grv32im, grv32imac, grv32imafdc,
- rv32iac, rv32i, rv32imac, rv32imafc, rv32imafdc, rv32imafd, rv32im,
- rv64imac, rv64imac_medany, rv64imafdc, rv64imafd, rv64imafdc_medany,
- rv64imafd_medany
+ rv32iac, rv32i, rv32imac, rv32imafc, rv32imafd, rv32im,
+ rv64imac, rv64imafdc, rv64imafd
exclude-smp = rv32i, rv32im
diff --git a/config/rtems-bsps-tiers.ini b/config/rtems-bsps-tiers.ini
index 9b52429..c8b4ad5 100644
--- a/config/rtems-bsps-tiers.ini
+++ b/config/rtems-bsps-tiers.ini
@@ -124,9 +124,8 @@ bsps_powerpc = beatnik,
virtex, virtex4, virtex5
bsps_riscv = griscv, grv32i, grv32im, grv32imac, grv32imafdc,
frdme310arty,
- rv32i, rv32iac, rv32im, rv32imac, rv32imafc, rv32imafd, rv32imafdc,
- rv64imac, rv64imac_medany, rv64imafd, rv64imafd_medany,
- rv64imafdc, rv64imafdc_medany
+ rv32i, rv32iac, rv32im, rv32imac, rv32imafc, rv32imafd,
+ rv64imac, rv64imafd, rv64imafdc
bsps_sh = gensh1, gensh2, gensh4, simsh1, simsh2, simsh2e, simsh4
bsps_sparc = at697f, gr712rc, ut699, ut700, gr740
bsps_sparc64 = niagara, usiii
2.25.1
