[gcc] RTEMS: Tune multilib selection
Fri Feb 24 06:23:13 UTC 2023
On 23.02.23 19:38, Palmer Dabbelt wrote:
> On Thu, 23 Feb 2023 03:48:26 PST (-0800),
> sebastian.huber at embedded-brains.de wrote:
>> gcc/ChangeLog:
>>     * config/riscv/t-rtems: Keep only -mcmodel=medany 64-bit multilibs.
>>     Add non-compact 32-bit multilibs.
>>  gcc/config/riscv/t-rtems | 17 +++++++++--------
>>  1 file changed, 9 insertions(+), 8 deletions(-)
>> diff --git a/gcc/config/riscv/t-rtems b/gcc/config/riscv/t-rtems
>> index 41f5927fc87..19b12030895 100644
>> --- a/gcc/config/riscv/t-rtems
>> +++ b/gcc/config/riscv/t-rtems
>> @@ -1,8 +1,8 @@
>>  MULTILIB_OPTIONS    =
>>  MULTILIB_DIRNAMES    =
>> -MULTILIB_OPTIONS    +=
>> march=rv32i/march=rv32im/march=rv32imafd/march=rv32iac/march=rv32imac/march=rv32imafc/march=rv64imafd/march=rv64imac/march=rv64imafdc
>> -MULTILIB_DIRNAMES    += rv32i       rv32im       rv32imafd
>> rv32iac       rv32imac       rv32imafc       rv64imafd rv64imac
>> rv64imafdc
>> +MULTILIB_OPTIONS    +=
>> march=rv32i/march=rv32iac/march=rv32im/march=rv32ima/march=rv32imac/march=rv32imaf/march=rv32imafc/march=rv32imafd/march=rv32imafdc/march=rv64ima/march=rv64imac/march=rv64imafd/march=rv64imafdc
>> +MULTILIB_DIRNAMES    += rv32i       rv32iac       rv32im
>> rv32ima       rv32imac       rv32imaf       rv32imafc rv32imafd
>> rv32imafdc       rv64ima       rv64imac rv64imafd       rv64imafdc
>>  MULTILIB_OPTIONS    +=
>> mabi=ilp32/mabi=ilp32f/mabi=ilp32d/mabi=lp64/mabi=lp64d
>>  MULTILIB_DIRNAMES    += ilp32      ilp32f      ilp32d      lp64
>> lp64d
>> @@ -12,14 +12,15 @@ MULTILIB_DIRNAMES    += medany
>>  MULTILIB_REQUIRED    =
>>  MULTILIB_REQUIRED    += march=rv32i/mabi=ilp32
>> -MULTILIB_REQUIRED    += march=rv32im/mabi=ilp32
>> -MULTILIB_REQUIRED    += march=rv32imafd/mabi=ilp32d
>>  MULTILIB_REQUIRED    += march=rv32iac/mabi=ilp32
>> +MULTILIB_REQUIRED    += march=rv32im/mabi=ilp32
>> +MULTILIB_REQUIRED    += march=rv32ima/mabi=ilp32
>>  MULTILIB_REQUIRED    += march=rv32imac/mabi=ilp32
>> +MULTILIB_REQUIRED    += march=rv32imaf/mabi=ilp32f
>>  MULTILIB_REQUIRED    += march=rv32imafc/mabi=ilp32f
>> -MULTILIB_REQUIRED    += march=rv64imafd/mabi=lp64d
>> -MULTILIB_REQUIRED    += march=rv64imafd/mabi=lp64d/mcmodel=medany
>> -MULTILIB_REQUIRED    += march=rv64imac/mabi=lp64
>> +MULTILIB_REQUIRED    += march=rv32imafd/mabi=ilp32d
>> +MULTILIB_REQUIRED    += march=rv32imafdc/mabi=ilp32d
>> +MULTILIB_REQUIRED    += march=rv64ima/mabi=lp64/mcmodel=medany
>>  MULTILIB_REQUIRED    += march=rv64imac/mabi=lp64/mcmodel=medany
>> -MULTILIB_REQUIRED    += march=rv64imafdc/mabi=lp64d
>> +MULTILIB_REQUIRED    += march=rv64imafd/mabi=lp64d/mcmodel=medany
>>  MULTILIB_REQUIRED    += march=rv64imafdc/mabi=lp64d/mcmodel=medany
> Reviewed-by: Palmer Dabbelt <palmer at rivosinc.com>
> IMO it's fine to remove multilibs from the default set.  It could be
> seen as breaking users, but IIRC last time we talked about something
> like this it was OK as otherwise we're going to end up with a huge set
> of multilibs for defunct ISAs.  This one is also extra safe, since
> moving to medany shouldn't break any users (aside from maybe a slight
> performance issue).
Thanks for the review. Which performance issue may show up here?
> Are you aiming for GCC-13 with this?  I wouldn't be opposed to that:
> there's some risk of breaking users this late in the process, but my
> guess is that most of them aren't looking until release anyway.  Still
> better to hold off, but if there's something in RTEMS land that benefits
> from this being early then I think it's fine.
RTEMS has its own release cycle, so I would back port this change to all
GCC branches which may be used with RTEMS 6 and this is GCC 10 or later.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
