[PATCH] bsps/aarch64: Disable interrupts during MMU remap
Kinsey Moore
kinsey.moore at oarcorp.com
Fri Feb 24 22:27:33 UTC 2023
Interrupts must be disabled during MMU remapping since the majority of
RTEMS including interrupts expects normal memory mapping semantics such
as unaligned accesses.
bsps/aarch64/shared/mmu/vmsav8-64.c | 6 ++++++
1 file changed, 6 insertions(+)
diff --git a/bsps/aarch64/shared/mmu/vmsav8-64.c b/bsps/aarch64/shared/mmu/vmsav8-64.c
index 190a05f7d5..270b9319ad 100644
--- a/bsps/aarch64/shared/mmu/vmsav8-64.c
+++ b/bsps/aarch64/shared/mmu/vmsav8-64.c
@@ -47,12 +47,16 @@ rtems_status_code aarch64_mmu_map(
rtems_status_code sc;
+ ISR_Level level;
uint64_t max_mappable = 1LLU << aarch64_mmu_get_cpu_pa_bits();
if ( addr >= max_mappable || (addr + size) > max_mappable ) {
return RTEMS_INVALID_ADDRESS;
+ /* Disable interrupts so they don't run while the MMU is disabled */
+ _ISR_Local_disable( level );
aarch64_mmu_disable();
sc = aarch64_mmu_map_block(
(uint64_t *) bsp_translation_table_base,
@@ -70,5 +74,7 @@ rtems_status_code aarch64_mmu_map(
_AARCH64_Instruction_synchronization_barrier();
aarch64_mmu_enable();
+ _ISR_Local_enable( level );
return sc;
2.30.2
