Interested for GSoC 2023
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Mon Feb 27 10:07:59 UTC 2023
> -----Original Message-----
> From: devel <devel-bounces at rtems.org> On Behalf Of Karel Gardas
> Sent: Montag, 27. Februar 2023 09:16
> To: joel at rtems.org; Vihas Makwana <makvihas at gmail.com>
> Cc: rtems-devel at rtems.org <devel at rtems.org>
> Subject: Re: Interested for GSoC 2023
> On 2/27/23 02:16, Joel Sherrill wrote:
> > Another GCC related project could be Rust RTEMS Support but I don't
> > know what that entails beyond turning it on and seeing what goes
> > wrong. I tried to build it last year and got far enough to decide to
> > wait before trying again.
> Not sure how far you went. The process is generally:
> (1) tune Rust compiler to cross-compile correctly for specific hardware/os
> platform. So basically you get no_std capable compiler
> (2) review, patch and by using (1) cross-compile libc
> (3) using sources from (1) and (2) build full stage (std enabled) rustc.
> (4) tweak and tune tools (rustup/cargo etc.) whenever required to smooth
> sharp edges for RTEMS.
> Here, I'm nearly finished with (1) for arm-rtems (e.g. cortex-aX not cortex-
> mX).
Hi Karel,
Very interesting work. I am currently trying to reach the same goal.
The steps I came up with are a bit different:
A.) Build working llvm toolchain for RTEMS (figure out all flags etc., maybe building RTEMS with llvm as a bonus)
B.) Build rustc with the "RTEMS-llvm" as backend
C.) Start with no_std and then inch forward to building the stdlib
I work currently on step A (see my llvm experiments in the other thread) and started to look at the build stages for rustc.
If you have any tips for the configuration from your step (1), it would be greatly appreciated.
My hope is that with the results of step A I can reuse the libc from the standard rtems-gcc build environment as this is provided conveniently via rsb.
I am really looking forward to seeing rust supported on RTEMS.
Best regards,
    Jan
PS: Maybe it is worth starting a new thread for exchanging ideas? I don't mean to hijack Vihas thread.
> Karel
> devel mailing list
> devel at rtems.org
