[PATCH] bsps/aarch64: Disable interrupts during MMU remap
Mon Feb 27 18:20:34 UTC 2023
seems ok to me
On Fri, Feb 24, 2023 at 3:27 PM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> Interrupts must be disabled during MMU remapping since the majority of
> RTEMS including interrupts expects normal memory mapping semantics such
> as unaligned accesses.
>  bsps/aarch64/shared/mmu/vmsav8-64.c | 6 ++++++
>  1 file changed, 6 insertions(+)
> diff --git a/bsps/aarch64/shared/mmu/vmsav8-64.c b/bsps/aarch64/shared/mmu/vmsav8-64.c
> index 190a05f7d5..270b9319ad 100644
> --- a/bsps/aarch64/shared/mmu/vmsav8-64.c
> +++ b/bsps/aarch64/shared/mmu/vmsav8-64.c
> @@ -47,12 +47,16 @@ rtems_status_code aarch64_mmu_map(
>    rtems_status_code sc;
> +  ISR_Level        level;
>    uint64_t max_mappable = 1LLU << aarch64_mmu_get_cpu_pa_bits();
>    if ( addr >= max_mappable || (addr + size) > max_mappable ) {
>      return RTEMS_INVALID_ADDRESS;
> +  /* Disable interrupts so they don't run while the MMU is disabled */
> +  _ISR_Local_disable( level );
>    aarch64_mmu_disable();
>    sc = aarch64_mmu_map_block(
>      (uint64_t *) bsp_translation_table_base,
> @@ -70,5 +74,7 @@ rtems_status_code aarch64_mmu_map(
>    _AARCH64_Instruction_synchronization_barrier();
>    aarch64_mmu_enable();
> +  _ISR_Local_enable( level );
>    return sc;
> 2.30.2
> devel mailing list
> devel at rtems.org
