[PATCH 1/4] cpukit/include/dev/can: Added debug print configuration under RTEMS_CAN_DEBUG macro.
Prashanth S
fishesprashanth at gmail.com
Wed Jan 11 11:51:31 UTC 2023
Hi All,
This is a reminder for review requests for the patches to CAN Framework
changes based on review comments.
Regards
Prashanth S
On Fri, 16 Dec 2022 at 18:58, Prashanth S <fishesprashanth at gmail.com> wrote:
> cpukit/include/dev/can/can.h | 27 +++++++++++++++++++++------
> 1 file changed, 21 insertions(+), 6 deletions(-)
> diff --git a/cpukit/include/dev/can/can.h b/cpukit/include/dev/can/can.h
> index 9e55395039..4ee51ebc9d 100644
> --- a/cpukit/include/dev/can/can.h
> +++ b/cpukit/include/dev/can/can.h
> @@ -53,13 +53,28 @@
> printf(str, ##__VA_ARGS__);
> } while (false);
> +#ifdef RTEMS_CAN_DEBUG
> #define CAN_DEBUG(str, ...) DEBUG(str, ##__VA_ARGS__)
> -#define CAN_DEBUG_BUF(str, ...) CAN_DEBUG(str, ##__VA_ARGS__)
> -#define CAN_DEBUG_ISR(str, ...) CAN_DEBUG(str, ##__VA_ARGS__)
> -#define CAN_DEBUG_LOCK(str, ...) CAN_DEBUG(str, ##__VA_ARGS__)
> -#define CAN_DEBUG_RX(str, ...) CAN_DEBUG(str, ##__VA_ARGS__)
> -#define CAN_DEBUG_TX(str, ...) CAN_DEBUG(str, ##__VA_ARGS__)
> -#define CAN_DEBUG_REG(str, ...) //CAN_DEBUG(str, ##__VA_ARGS__)
> +#define CAN_DEBUG_BUF(str, ...) DEBUG(str, ##__VA_ARGS__)
> +#define CAN_DEBUG_ISR(str, ...) DEBUG(str, ##__VA_ARGS__)
> +#define CAN_DEBUG_LOCK(str, ...) DEBUG(str, ##__VA_ARGS__)
> +#define CAN_DEBUG_RX(str, ...) DEBUG(str, ##__VA_ARGS__)
> +#define CAN_DEBUG_TX(str, ...) DEBUG(str, ##__VA_ARGS__)
> +#define CAN_DEBUG_REG(str, ...) /* CAN_DEBUG(str, ##__VA_ARGS__) */
> +#else /* RTEMS_CAN_DEBUG */
> +#define CAN_DEBUG(str, ...)
> +#endif /* RTEMS_CAN_DEBUG */
> #define CAN_ERR(str, ...) DEBUG(str, ##__VA_ARGS__)
> #define CAN_MSG_LEN(msg) ((char *)(&((struct can_msg
> *)msg)->data[(uint16_t)((struct can_msg *)msg)->len]) - (char *)(msg))
> 2.25.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230111/0faf6c99/attachment.htm>
