[PATCH 00/18] jffs2: Update baseline version to Linux v6.1
Wed Jan 11 11:58:34 UTC 2023
Arnd Bergmann (1):
  jffs2: avoid Wempty-body warnings
Baokun Li (2):
  jffs2: fix memory leak in jffs2_do_mount_fs
  jffs2: fix memory leak in jffs2_scan_medium
Christian Brauner (1):
  fs: make helpers idmap mount aware
Gustavo A. R. Silva (1):
  treewide: uapi: Replace zero-length arrays with flexible-array members
Haowen Bai (1):
  jffs2: Use kzalloc instead of kmalloc/memset
Matthew Wilcox (Oracle) (2):
  jffs2: Pass the file pointer to jffs2_do_readpage_unlock()
  fs: Change the type of filler_t
Miklos Szeredi (1):
  vfs: add rcu argument to ->get_acl() callback
Randy Dunlap (1):
  jffs2: Fix if/else empty body warnings
Sebastian Huber (2):
  jffs2: Add <linux/printk.h>
Tom Rix (1):
  jffs2: remove trailing semicolon in macro definition
Yang Yang (1):
  jffs2: check the validity of dstlen in jffs2_zlib_compress()
Zhe Li (1):
  jffs2: Fix GC exit abnormally
hongnanli (1):
  fs/jffs2: fix comments mentioning i_mutex
lizhe (2):
  jffs2: Allow setting rp_size to zero during remounting
  jffs2: Fix kasan slab-out-of-bounds problem
 cpukit/libfs/src/jffs2/VERSION                |  2 +-
 cpukit/libfs/src/jffs2/include/linux/jffs2.h  |  8 +++----
 cpukit/libfs/src/jffs2/include/linux/printk.h |  6 +++++
 cpukit/libfs/src/jffs2/src/acl.h              |  5 ++--
 cpukit/libfs/src/jffs2/src/build.c            |  4 +++-
 cpukit/libfs/src/jffs2/src/compr_rtime.c      |  3 +++
 cpukit/libfs/src/jffs2/src/debug.h            | 23 ++++++++++---------
 cpukit/libfs/src/jffs2/src/erase.c            |  6 ++---
 cpukit/libfs/src/jffs2/src/gc.c               |  2 +-
 cpukit/libfs/src/jffs2/src/jffs2_fs_i.h       |  4 ++--
 cpukit/libfs/src/jffs2/src/jffs2_fs_sb.h      |  1 +
 cpukit/libfs/src/jffs2/src/nodelist.h         |  4 ++--
 cpukit/libfs/src/jffs2/src/readinode.c        | 16 +++++++++++++
 cpukit/libfs/src/jffs2/src/scan.c             |  8 ++++---
 cpukit/libfs/src/jffs2/src/summary.h          | 16 ++++++-------
 15 files changed, 69 insertions(+), 39 deletions(-)
 create mode 100644 cpukit/libfs/src/jffs2/include/linux/printk.h
2.35.3
