[PATCH 1/3] build: Format build items
Thu Jan 12 14:54:12 UTC 2023
On 12.01.23 15:44, Kinsey Moore wrote:
> The other two patches look fine to me. The use of dump() that results in
> this patch does several things:
> * Removal of whitespace
> This is fine for whitespace at the base level of indentation. Whitespace
> within an indented block may be more important for readability.
> * Removal of comments
> This is not good as they are exclusively used to annotate manually
> ordered blocks of test result expectations
> * Rearrangement of items in alphabetical order
> In general, rearrangement of top-level sections is good. For indented
> sections specifically in tst*.yml, this is bad for the above reaso
One goal of the new build system was to be able to alter the data
through scripts. This requires that the build items are human and
machine readable and writable. The Python YAML import/export does not
preserve white space and comments.
This there is a need for comments, then the data format should be
improved. For example, the test state list could be changed to also
include a reason for a categorization.
> * Alteration of integer representation to base-10 in all cases
> I'd say this is a net-negative as most items represented in hex are
> memory-related and should stay that way.
Yes, this is a bit annoying. To mitigate this issue the options have a
format attribute so that the numbers are correctly formatted in user
visible content, for example the configuration files or generated header
and linker command files. The build item maintainer has to use a
calculator or whatever to look at the numbers in the right format.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
