[PATCH 1/3] build: Format build items
Sebastian Huber
Thu Jan 12 16:38:39 UTC 2023
On 12.01.23 16:52, Kinsey Moore wrote:
> Annotation of expected test states with a description could get quite
> repetitive, but I suppose that's better than losing the information. I'm
> fine with this going in for now with a ticket to address this issue and
> we can pull the annotations back in when the ticket is dealt with.
It could look like this:
SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
actions:
- set-test-state:
- reason: |
expected to fail, don't compile these
state: exclude
tests:
- minimum
- reason: |
tests that are passing intermittently
state: indeterminate
tests:
- psx12
- psxtimes01
- rtmonuse
- rtmonusxtimes01
- sp04
- sp20
- sp68
- sp69
- spcpucounter01
- spedfsched02
- spedfsched04
- sprmsched01
- sptimecounter02
- sptimecounter04
- ttest02
- reason: |
tests that pass nominally, but fail under Qemu when the host is under
heavy load
tests:
- spintrcritical03
- spintrcritical04
- spintrcritical05
build-type: option
copyrights:
- Copyright (C) 2020 On-Line Applications Research (OAR)
default: []
description: ''
enabled-by: true
links: []
type: build
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
