[PATCH 4/5] bsps/microblaze: Add device tree support to JFFS2 QSPI
Alex White
alex.white at oarcorp.com
Fri Jan 13 04:33:36 UTC 2023
bsps/microblaze/microblaze_fpga/fs/jffs2_qspi.c | 17 +++++++++++++++--
1 file changed, 15 insertions(+), 2 deletions(-)
diff --git a/bsps/microblaze/microblaze_fpga/fs/jffs2_qspi.c b/bsps/microblaze/microblaze_fpga/fs/jffs2_qspi.c
index 39328b6b7c..49859a03f1 100644
--- a/bsps/microblaze/microblaze_fpga/fs/jffs2_qspi.c
+++ b/bsps/microblaze/microblaze_fpga/fs/jffs2_qspi.c
@@ -46,6 +46,7 @@
#include <rtems/jffs2.h>
#include <rtems/libio.h>
+#include <bsp.h>
#include <bsp/jffs2_qspi.h>
#define BLOCK_SIZE (64UL * 1024UL)
@@ -286,12 +287,24 @@ int microblaze_jffs2_initialize( const char* mount_dir )
int rv = 0;
int fd = -1;
+ uintptr_t mblaze_spi_base = try_get_prop_from_device_tree(
+ "xlnx,xps-spi-2.00.a",
+ "reg",
+ BSP_MICROBLAZE_FPGA_SPI_BASE
+ rtems_vector_number mblaze_spi_irq_num = try_get_prop_from_device_tree(
+ "interrupts",
+ BSP_MICROBLAZE_FPGA_SPI_IRQ_NUM
rv = spi_bus_register_xilinx_axi(
BUS_PATH,
- BSP_MICROBLAZE_FPGA_SPI_BASE,
+ mblaze_spi_base,
FLASH_PAGE_SIZE,
FLASH_NUM_CS,
- BSP_MICROBLAZE_FPGA_SPI_IRQ_NUM
+ mblaze_spi_irq_num
if ( rv != 0 ) {
return rv;
2.34.1
