[PATCH 5/5] bsps/microblaze: Add device tree support to UART Lite
Alex White
alex.white at oarcorp.com
Fri Jan 13 04:33:37 UTC 2023
.../microblaze_fpga/console/console-io.c | 19 ++++++++++--
.../microblaze_fpga/console/debug-io.c | 29 +++++++++++++++----
bsps/microblaze/shared/dev/serial/uartlite.c | 9 +++++-
3 files changed, 49 insertions(+), 8 deletions(-)
diff --git a/bsps/microblaze/microblaze_fpga/console/console-io.c b/bsps/microblaze/microblaze_fpga/console/console-io.c
index cb2e367035..81c4e73690 100644
--- a/bsps/microblaze/microblaze_fpga/console/console-io.c
+++ b/bsps/microblaze/microblaze_fpga/console/console-io.c
@@ -35,20 +35,35 @@
#include <bsp/console-termios.h>
+#include <bsp/microblaze-fdt-support.h>
#include <dev/serial/uartlite.h>
#include <bspopts.h>
uart_lite_context microblaze_qemu_uart_context = {
.base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER( "UARTLITE" ),
- .address = BSP_MICROBLAZE_FPGA_UART_BASE,
.initial_baud = 115200
+static bool fill_uart_base(rtems_termios_device_context *context)
+ uint32_t mblaze_uart_base;
+ mblaze_uart_base = try_get_prop_from_device_tree(
+ "xlnx,xps-uartlite-1.00.a",
+ "reg",
+ BSP_MICROBLAZE_FPGA_UART_BASE
+ microblaze_qemu_uart_context.address = mblaze_uart_base;
+ return true;
const console_device console_device_table[] = {
.device_file = "/dev/ttyS0",
- .probe = console_device_probe_default,
+ .probe = fill_uart_base,
.handler = µblaze_uart_fns,
.context = µblaze_qemu_uart_context.base
diff --git a/bsps/microblaze/microblaze_fpga/console/debug-io.c b/bsps/microblaze/microblaze_fpga/console/debug-io.c
index e88f5468a7..d85229ae9e 100644
--- a/bsps/microblaze/microblaze_fpga/console/debug-io.c
+++ b/bsps/microblaze/microblaze_fpga/console/debug-io.c
@@ -37,23 +37,42 @@
#include <dev/serial/uartlite_l.h>
#include <rtems/bspIo.h>
+#include <bsp.h>
+static uint32_t mblaze_uart_base = 0;
static void output_char( char c )
- if ( c == '\n' ) {
- XUartLite_SendByte( BSP_MICROBLAZE_FPGA_UART_BASE, '\r' );
+ if (mblaze_uart_base == 0 ) {
+ "reg",
+ if ( c == '\n' ) {
+ XUartLite_SendByte( mblaze_uart_base, '\r' );
- XUartLite_SendByte( BSP_MICROBLAZE_FPGA_UART_BASE, c );
+ XUartLite_SendByte( mblaze_uart_base, c );
static int xUartLite_RecvByte( int minor )
- if ( XUartLite_IsReceiveEmpty( BSP_MICROBLAZE_FPGA_UART_BASE ) ) {
+ "reg",
+ if ( XUartLite_IsReceiveEmpty( mblaze_uart_base ) ) {
return -1;
- return XUartLite_ReadReg( BSP_MICROBLAZE_FPGA_UART_BASE, XUL_RX_FIFO_OFFSET );
+ return XUartLite_ReadReg( mblaze_uart_base, XUL_RX_FIFO_OFFSET );
static int get_char( void )
diff --git a/bsps/microblaze/shared/dev/serial/uartlite.c b/bsps/microblaze/shared/dev/serial/uartlite.c
index a5fc4fe82b..953c630759 100644
--- a/bsps/microblaze/shared/dev/serial/uartlite.c
+++ b/bsps/microblaze/shared/dev/serial/uartlite.c
@@ -70,8 +70,15 @@ static bool uart_first_open(
#ifdef BSP_MICROBLAZE_FPGA_CONSOLE_INTERRUPTS
XUartLite_EnableIntr( ctx->address );
+ uint32_t uart_irq_num = try_get_prop_from_device_tree(
+ "interrupts",
+ 1
sc = rtems_interrupt_handler_install(
- 1,
+ uart_irq_num,
"UART",
RTEMS_INTERRUPT_SHARED,
microblaze_uart_interrupt,
2.34.1
