[PATCH] bsp/clock_isr: move the Fast Idle clock code into normal clock driver
Zhu Zhongjie zhongjiezhu1 at gmail.com
Fri Jan 13 07:57:07 UTC 2023
Fast Idle is not supported in SMP and n ISRs per tick, so move the code
into the normal clock driver, make this more clearly.
 bsps/shared/dev/clock/clockimpl.h | 119 +++++++++++++-----------------
 1 file changed, 51 insertions(+), 68 deletions(-)
diff --git a/bsps/shared/dev/clock/clockimpl.h b/bsps/shared/dev/clock/clockimpl.h
index ccf6d3ab60..b689c42902 100644
--- a/bsps/shared/dev/clock/clockimpl.h
+++ b/bsps/shared/dev/clock/clockimpl.h
@@ -48,18 +48,6 @@
 #error "Update driver to use the timecounter instead of nanoseconds extension"
 #endif
- * @defgroup bsp_clock Clock Support
- * @ingroup RTEMSBSPsShared
- * @brief Clock support
-#if CLOCK_DRIVER_USE_FAST_IDLE && CLOCK_DRIVER_ISRS_PER_TICK
-#error "Fast Idle PLUS n ISRs per tick is not supported"
-#endif
  * @brief Do nothing by default.
@@ -160,64 +148,59 @@ rtems_isr Clock_isr(
   Clock_driver_ticks += 1;
-  #if CLOCK_DRIVER_USE_FAST_IDLE
-      Clock_driver_timecounter_tick();
-      if (_SMP_Get_processor_maximum() == 1) {
-        struct timecounter *tc;
-        uint64_t            us_per_tick;
-        uint32_t            interval;
-        Per_CPU_Control    *cpu_self;
-        cpu_self = _Per_CPU_Get();
-        tc = _Timecounter;
-        us_per_tick = rtems_configuration_get_microseconds_per_tick();
-        interval = (uint32_t) ((tc->tc_frequency * us_per_tick) / 1000000);
-        while (
-          cpu_self->thread_dispatch_disable_level == cpu_self->isr_nest_level
-            && cpu_self->heir == cpu_self->executing
-            && cpu_self->executing->is_idle
-          ISR_lock_Context lock_context;
-          _Timecounter_Acquire(&lock_context);
-          _Timecounter_Tick_simple(
-            interval,
-            (*tc->tc_get_timecount)(tc),
-            &lock_context
-      Clock_driver_support_at_tick();
+   *  Do the hardware specific per-tick action.
+   *  The counter/timer may or may not be set to automatically reload.
+  Clock_driver_support_at_tick();
+#if CLOCK_DRIVER_ISRS_PER_TICK
+   *  The driver is multiple ISRs per clock tick.
+  if ( !Clock_driver_isrs ) {
+    Clock_driver_timecounter_tick();
+    Clock_driver_isrs = CLOCK_DRIVER_ISRS_PER_TICK_VALUE;
+  Clock_driver_isrs--;
+#else
+   *  The driver is one ISR per clock tick.
+  #if CLOCK_DRIVER_USE_FAST_IDLE && !defined(RTEMS_SMP)
+    struct timecounter *tc;
+    uint64_t            us_per_tick;
+    uint32_t            interval;
+    Per_CPU_Control    *cpu_self;
+    cpu_self = _Per_CPU_Get();
+    tc = _Timecounter;
+    us_per_tick = rtems_configuration_get_microseconds_per_tick();
+    interval = (uint32_t) ((tc->tc_frequency * us_per_tick) / 1000000);
+    while (
+      cpu_self->thread_dispatch_disable_level == cpu_self->isr_nest_level
+        && cpu_self->heir == cpu_self->executing
+        && cpu_self->executing->is_idle
+      ISR_lock_Context lock_context;
+      _Timecounter_Acquire(&lock_context);
+      _Timecounter_Tick_simple(
+        interval,
+        (*tc->tc_get_timecount)(tc),
+        &lock_context
-  #else
-     *  Do the hardware specific per-tick action.
-     *  The counter/timer may or may not be set to automatically reload.
-    #if CLOCK_DRIVER_ISRS_PER_TICK
-       *  The driver is multiple ISRs per clock tick.
-      if ( !Clock_driver_isrs ) {
-        Clock_driver_isrs = CLOCK_DRIVER_ISRS_PER_TICK_VALUE;
-      Clock_driver_isrs--;
-    #else
-       *  The driver is one ISR per clock tick.
-    #endif
   #endif
+#endif
 void _Clock_Initialize( void )
2.34.1
