[PATCH v1 4/4] testsuites/libtest/dl11: Add DL test for TLS
Chris Johns
chrisj at rtems.org
Mon Jan 16 00:07:24 UTC 2023
On 13/1/2023 12:51 pm, Kinsey Moore wrote:
> On Thu, Jan 12, 2023 at 5:11 PM Joel Sherrill <joel at rtems.org
> <mailto:joel at rtems.org>> wrote:
> Will this need to be added as an expected fail on other architectures?
> Just wondering how many bsp test configuration files need touching
> I suppose I could set it to enabled for only AArch64 for now. It would
> definitely fail on other architectures.
Should we enable it for archs we would like supported for 6 and then make sure
we have support for the release?
The support is a side effect of the switch to TLS in newlib and not related to
libdl.
