[PATCH v1 4/4] testsuites/libtest/dl11: Add DL test for TLS
Kinsey Moore wkm042 at oarcorp.com
Thu Jan 19 21:40:18 UTC 2023
On 1/15/2023 6:07 PM, Chris Johns wrote:
> On 13/1/2023 12:51 pm, Kinsey Moore wrote:
>> On Thu, Jan 12, 2023 at 5:11 PM Joel Sherrill <joel at rtems.org
>> <mailto:joel at rtems.org>> wrote:
>>      Will this need to be added as an expected fail on other architectures?
>>      Just wondering how many bsp test configuration files need touching
>> I suppose I could set it to enabled for only AArch64 for now. It would
>> definitely fail on other architectures.
> Should we enable it for archs we would like supported for 6 and then make sure
> we have support for the release?
> The support is a side effect of the switch to TLS in newlib and not related to
> libdl.
That sounds reasonable. I'll leave it as-is.
Assuming that's commit approval, I'll open a ticket for the missing support.
Kinsey
