[PATCH 1/3] build: Format build items
Mon Jan 16 07:56:33 UTC 2023
On 16.01.23 01:35, Chris Johns wrote:
> On 13/1/2023 1:54 am, Sebastian Huber wrote:
>> On 12.01.23 15:44, Kinsey Moore wrote:
>>> The other two patches look fine to me. The use of dump() that results in this
>>> patch does several things:
>>> * Removal of whitespace
>>> This is fine for whitespace at the base level of indentation. Whitespace
>>> within an indented block may be more important for readability.
>>> * Removal of comments
>>> This is not good as they are exclusively used to annotate manually ordered
>>> blocks of test result expectations
>>> * Rearrangement of items in alphabetical order
>>> In general, rearrangement of top-level sections is good. For indented sections
>>> specifically in tst*.yml, this is bad for the above reaso
>> One goal of the new build system was to be able to alter the data through
>> scripts. This requires that the build items are human and machine readable and
>> writable. The Python YAML import/export does not preserve white space and comments.
> Can someone edit the file and add a hex number?
Yes, you can manually use whatever format is understood by the YAML
loader. When you write the file with the YAML dumper, then the standard
representation is used. I changed the representer to use the format
attribute, see v2 of the patch:
https://lists.rtems.org/pipermail/devel/2023-January/074094.html
>> This there is a need for comments, then the data format should be improved. For
>> example, the test state list could be changed to also include a reason for a
>> categorization.
>>> * Alteration of integer representation to base-10 in all cases
>>> I'd say this is a net-negative as most items represented in hex are
>>> memory-related and should stay that way.
>> Yes, this is a bit annoying. To mitigate this issue the options have a format
>> attribute so that the numbers are correctly formatted in user visible content,
>> for example the configuration files or generated header and linker command
>> files. The build item maintainer has to use a calculator or whatever to look at
>> the numbers in the right format.
> I cannot see an example of a format attribute? Do the patches contain an example?
grep 'format:' -r spec
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
