[docs 2/3] eng: Improve build option default values
Sebastian Huber
Tue Jan 17 14:15:23 UTC 2023
Merge "default" and "default-by-variant" attributes. Use an enabled-by
expression to select the default value.
eng/req/items.rst | 62 +++++++++++++++++++----------------------------
1 file changed, 25 insertions(+), 37 deletions(-)
diff --git a/eng/req/items.rst b/eng/req/items.rst
index eb7ce38..c037a93 100644
--- a/eng/req/items.rst
+++ b/eng/req/items.rst
@@ -714,8 +714,6 @@ option. The following explicit attributes are mandatory:
* ``default``
-* ``default-by-variant``
* ``description``
The explicit attributes for this type are:
@@ -729,19 +727,11 @@ actions
actions are carried out during the configure command execution.
default
- The attribute value shall be a :ref:`SpecTypeBuildOptionValue`. It shall be
- the default value of the option if no variant-specific default value is
- specified. Use ``null`` to specify that no default value exits. The
- variant-specific default values may be specified by the
- ``default-by-variant`` attribute.
-default-by-variant
The attribute value shall be a list. Each list element shall be a
- :ref:`SpecTypeBuildOptionDefaultByVariant`. The list is checked two times
- and processed from top to bottom. Firstly, the base BSP name is used to
- match with a variant. Secondly, the BSP family name prefixed by ``bsps/``
- is used to match with a variant. If a matching variant is found, then the
- processing stops.
+ :ref:`SpecTypeBuildOptionDefaultValue`. It shall be the list of default
+ values of the option. When a default value is needed, the first value on
+ the list which is enabled according to the enabled set is choosen. If no
+ value is enabled, then the default value is ``null``.
description
The attribute value shall be an optional string. It shall be the
@@ -766,17 +756,17 @@ Please have a look at the following example:
- define: null
build-type: option
copyrights:
- - Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
- default: 115200
- default-by-variant:
- - value: 9600
- variants:
+ - Copyright (C) 2020, 2022 embedded brains GmbH (http://www.embedded-brains.de)
+ default:
+ - enabled-by:
- bsps/powerpc/motorola_powerpc
- m68k/m5484FireEngine
- powerpc/hsc_cm01
- - value: 19200
- variants:
- - m68k/COBRA5475
+ value: 9600
+ - enabled-by: m68k/COBRA5475
+ value: 19200
+ - enabled-by: true
+ value: 115200
description: |
Default baud for console and other serial devices.
enabled-by: true
@@ -3423,22 +3413,20 @@ This type is used by the following types:
* :ref:`SpecTypeBuildOptionAction`
-.. _SpecTypeBuildOptionDefaultByVariant:
+.. _SpecTypeBuildOptionDefaultValue:
-Build Option Default by Variant
+Build Option Default Value
-This set of attributes specifies build option default values by variant. All
-explicit attributes shall be specified. The explicit attributes for this type
-are:
+This set of attributes specifies a build option default value. All explicit
+attributes shall be specified. The explicit attributes for this type are:
-value
- The attribute value shall be a :ref:`SpecTypeBuildOptionValue`. It value
- shall be the default value for the matching variants.
+enabled-by
+ The attribute value shall be an :ref:`SpecTypeEnabledByExpression`.
-variants
- The attribute value shall be a list of strings. It shall be a list of
- Python regular expression matching with the desired variants.
+value
+ The attribute value shall be a :ref:`SpecTypeBuildOptionValue`. Its value
+ shall be the default value for the associated enabled-by expression.
@@ -3495,9 +3483,7 @@ This type is used by the following types:
-* :ref:`SpecTypeBuildOptionDefaultByVariant`
-* :ref:`SpecTypeBuildOptionItemType`
+* :ref:`SpecTypeBuildOptionDefaultValue`
.. _SpecTypeBuildSource:
@@ -3681,6 +3667,8 @@ This type is used by the following types:
* :ref:`SpecTypeActionRequirementTransition`
* :ref:`SpecTypeEnabledByExpression`
* :ref:`SpecTypeInterfaceIncludeLinkRole`
2.35.3
