[docs] eng: Use a recommendation for requirement texts
Sebastian Huber
Tue Jan 17 15:38:44 UTC 2023
Update #3715.
eng/req/items.rst | 126 +++++++++++++++++++++++-----------------------
1 file changed, 63 insertions(+), 63 deletions(-)
diff --git a/eng/req/items.rst b/eng/req/items.rst
index 95531a8..19e8726 100644
--- a/eng/req/items.rst
+++ b/eng/req/items.rst
@@ -4597,130 +4597,130 @@ of links.
Requirement Text
-The value shall be a string. It shall state a requirement or constraint. The
-value shall not contain an element of
+The value shall be a string. It shall state a requirement or constraint. The
+text should not use one of the following words or phrases:
-* "``acceptable``",
+* acceptable
-* "``adequate``",
+* adequate
-* "``almost always``",
+* almost always
-* "``and/or``",
+* and/or
-* "``appropriate``",
+* appropriate
-* "``approximately``",
+* approximately
-* "``as far as possible``",
+* as far as possible
-* "``as much as practicable``",
+* as much as practicable
-* "``best``",
+* best
-* "``best possible``",
+* best possible
-* "``easy``",
+* easy
-* "``efficient``",
+* efficient
-* "``e.g.``",
+* e.g.
-* "``enable``",
+* enable
-* "``enough``",
+* enough
-* "``etc.``",
+* etc.
-* "``few``",
+* few
-* "``first rate``",
+* first rate
-* "``flexible``",
+* flexible
-* "``generally``",
+* generally
-* "``goal``",
+* goal
-* "``graceful``",
+* graceful
-* "``great``",
+* great
-* "``greatest``",
+* greatest
-* "``ideally``",
+* ideally
-* "``i.e.``",
+* i.e.
-* "``if possible``",
+* if possible
-* "``in most cases``",
+* in most cases
-* "``large``",
+* large
-* "``many``",
+* many
-* "``maximize``",
+* maximize
-* "``minimize``",
+* minimize
-* "``most``",
+* most
-* "``multiple``",
+* multiple
-* "``necessary``",
+* necessary
-* "``numerous``",
+* numerous
-* "``optimize``",
+* optimize
-* "``ought to``",
+* ought to
-* "``probably``",
+* probably
-* "``quick``",
+* quick
-* "``rapid``",
+* rapid
-* "``reasonably``",
+* reasonably
-* "``relevant``",
+* relevant
-* "``robust``",
+* robust
-* "``satisfactory``",
+* satisfactory
-* "``several``",
+* several
-* "``shall be included but not limited to``",
+* shall be included but not limited to
-* "``simple``",
+* simple
-* "``small``",
+* small
-* "``some``",
+* some
-* "``state of the art``",
+* state of the art
-* "``sufficient``",
+* sufficient
-* "``suitable``",
+* suitable
-* "``support``",
+* support
-* "``systematically``",
+* systematically
-* "``transparent``",
+* transparent
-* "``typical``",
+* typical
-* "``user friendly``",
+* user friendly
-* "``usually``",
+* usually
-* "``versatile``", and
+* versatile
-* "``when necessary``".
+* when necessary
This type is used by the following types:
2.35.3
