Typo in rtems-libbsd/rtems_waf/rtems.py?
Tue Jan 17 20:08:16 UTC 2023
On 18/1/2023 6:16 am, Frank Kühndel wrote:
> have you installed RTEMS (not only the tools) in `${RTEMS_ROOT}` before
> configuring libbsd? If I am not mistaken, installing RTEMS creates the
> `share/rtems6` directory.
This is correct and it is a simple and fast key to see if a kernel of a specific
version has been installed.
> On 1/17/23 18:11, Heinz Junkes wrote:
>> Hi,
>> It looks like there is a typo in rtems-libbsd/rtems_waf/rtems.py.
>> rtems_share_rtems_version = os.path.join(rtems_path, 'share', 'rtems' +
>> rtems_version)
>> if not os.path.exists(os.path.join(rtems_share_rtems_version)):
>>      ctx.fatal('RTEMS path is not valid, "%s" not found.' %
>> I think that "+ rtems_version" does not belong there?
>> git clonehttps://github.com/RTEMS/rtems-libbsd.git
>> cd rtems-libbsd/
>> git checkout 6-freebsd-12
>> git submodule init
>> git submodule update rtems_waf
>> ./waf configure --prefix=${RTEMS_ROOT} --rtems-bsps=powerpc/beatnik
>> --buildset=buildset/default.ini
As Frank points put the kernel needs to be installed before this command is run.
>> leads to :
>> # project  configured on Tue Jan 17 17:46:09 2023 by
>> # waf 2.0.19 (abi 20, python 20710f0 on linux2)
>> # using ./waf configure --prefix=/home/rtems/MVME6100_6_RUN/rtems/6
>> --rtems-bsps=powerpc/beatnik --buildset=buildset/default.ini
>> Setting top to
>> /home/rtems/MVME6100_6_INST/rtems-libbsd
>> Setting out to
>> /home/rtems/MVME6100_6_INST/rtems-libbsd/build
>> from /home/rtems/MVME6100_6_INST/rtems-libbsd: RTEMS path is not valid,
>> "/home/rtems/MVME6100_6_RUN/rtems/6/share/rtems6" not found.
>> Heinz
