[PATCH 2/3] build: Replace variant patterns with a list
Chris Johns
chrisj at rtems.org
Wed Jan 18 03:59:19 UTC 2023
Hi Sebastian,
I had not got to this part of the patch set because the other was being
discussed. I thought a patch set was considerd as a whole rather than having to
deal with the extra complexity of possible splits and if they exist? If this was
pull request or merge request in a tool none of this patch set would have been
applied unless split into separate merge reguests. :)
Why has this been done?
Why the noise in the patch of only lines being moved? Where has this come from?
Is there a new requirement spec fields be in some osrt of order?
Thanks
On 12/1/2023 11:03 pm, Sebastian Huber wrote:
> Replace the variant patterns in the default-by-variant list with an
> explicit list of matching BSPs.
> The change was tested by comparing the output of
> ./waf bspdefaults
> before and after the change.
The change message does not explain the line movements.
> .../bsps/aarch64/xilinx-zynqmp/optclki2c0.yml | 8 +++----
> .../bsps/aarch64/xilinx-zynqmp/optclki2c1.yml | 8 +++----
> .../bsps/aarch64/xilinx-zynqmp/optclkuart.yml | 7 +++++--
> .../bsps/aarch64/xilinx-zynqmp/optloadoff.yml | 2 +-
> .../bsps/aarch64/xilinx-zynqmp/optramori.yml | 2 +-
> .../arm/altera-cyclone-v/optclkfastidle.yml | 4 +++-
> spec/build/bsps/arm/beagle/optam335x.yml | 3 ++-
> spec/build/bsps/arm/beagle/optdebug.yml | 3 ++-
> spec/build/bsps/arm/beagle/optdm3730.yml | 3 ++-
> spec/build/bsps/arm/imx/optcachedata.yml | 4 +++-
> spec/build/bsps/arm/imx/optcacheinst.yml | 4 +++-
> spec/build/bsps/arm/lm3s69xx/optgpioahb.yml | 4 ++--
> spec/build/bsps/arm/lm3s69xx/optgpionum.yml | 7 ++++---
> spec/build/bsps/arm/lm3s69xx/optlm3s3749.yml | 2 +-
> spec/build/bsps/arm/lm3s69xx/optlm3s6965.yml | 3 ++-
> spec/build/bsps/arm/lm3s69xx/optlm4f120.yml | 2 +-
> spec/build/bsps/arm/lm3s69xx/optssiblks.yml | 7 ++++---
> spec/build/bsps/arm/lm3s69xx/optsysclk.yml | 6 ++++--
> spec/build/bsps/arm/lm3s69xx/optudma.yml | 4 ++--
> spec/build/bsps/arm/lm3s69xx/optxtalcfg.yml | 7 ++++---
> spec/build/bsps/arm/lpc24xx/optcclk.yml | 12 +++++++----
> spec/build/bsps/arm/lpc24xx/optdmachn.yml | 11 ++++++++--
> spec/build/bsps/arm/lpc24xx/optemcclkdiv.yml | 6 ++++--
> .../bsps/arm/lpc24xx/optemcis42s32800b.yml | 4 ++--
> .../bsps/arm/lpc24xx/optemcis42s32800d7.yml | 3 ++-
> .../build/bsps/arm/lpc24xx/optemcm29w160e.yml | 3 ++-
> .../bsps/arm/lpc24xx/optemcm29w320e70.yml | 3 ++-
> .../bsps/arm/lpc24xx/optemcmt48lc4m16a2.yml | 3 ++-
> spec/build/bsps/arm/lpc24xx/optethrmii.yml | 5 ++++-
> spec/build/bsps/arm/lpc24xx/optheapext.yml | 3 ++-
> spec/build/bsps/arm/lpc24xx/optoscmain.yml | 3 ++-
> spec/build/bsps/arm/lpc24xx/optotgi2c.yml | 6 ++++--
> spec/build/bsps/arm/lpc24xx/optpclkdiv.yml | 6 ++++--
> spec/build/bsps/arm/lpc24xx/optstopeth.yml | 3 ++-
> spec/build/bsps/arm/lpc24xx/optstopusb.yml | 3 ++-
> spec/build/bsps/arm/lpc24xx/optuart1cfg.yml | 5 ++++-
> spec/build/bsps/arm/lpc24xx/optuart2cfg.yml | 12 ++++++++---
> spec/build/bsps/arm/lpc24xx/optuart3cfg.yml | 7 +++++--
> spec/build/bsps/arm/lpc32xx/optotgi2c.yml | 4 +++-
> spec/build/bsps/arm/lpc32xx/optotgvbus.yml | 4 +++-
> spec/build/bsps/arm/lpc32xx/optscratchsz.yml | 4 +++-
> .../bsps/arm/realview-pbx-a9/optcachedata.yml | 4 +++-
> .../bsps/arm/realview-pbx-a9/optcacheinst.yml | 4 +++-
> .../arm/realview-pbx-a9/optclkbootcpu.yml | 4 +++-
> .../arm/realview-pbx-a9/optclkfastidle.yml | 4 +++-
> spec/build/bsps/arm/stm32f4/opteni2c1.yml | 2 +-
> spec/build/bsps/arm/stm32f4/optf10xxx.yml | 2 +-
> spec/build/bsps/arm/stm32f4/optf4xxxx.yml | 2 +-
> spec/build/bsps/arm/stm32f4/opthclk.yml | 2 +-
> spec/build/bsps/arm/stm32f4/optpclk1.yml | 2 +-
> spec/build/bsps/arm/stm32f4/optpclk2.yml | 2 +-
> spec/build/bsps/arm/stm32f4/optsysclk.yml | 2 +-
> spec/build/bsps/arm/stm32h7/abi.yml | 2 +-
> spec/build/bsps/arm/stm32h7/optbootcore.yml | 4 ++--
> spec/build/bsps/arm/stm32h7/optenuart4.yml | 4 ++--
> spec/build/bsps/arm/stm32h7/optenuart5.yml | 6 +++---
> spec/build/bsps/arm/stm32h7/optenuart7.yml | 6 +++---
> spec/build/bsps/arm/stm32h7/optenuart8.yml | 2 +-
> spec/build/bsps/arm/stm32h7/optenuart9.yml | 6 +++---
> spec/build/bsps/arm/stm32h7/optenusart10.yml | 6 +++---
> spec/build/bsps/arm/stm32h7/optenusart3.yml | 6 +++---
> spec/build/bsps/arm/stm32h7/optenusart6.yml | 6 +++---
> spec/build/bsps/arm/stm32h7/optlinkcmds.yml | 8 +++----
> .../bsps/arm/stm32h7/optmemflashorigin.yml | 2 +-
> spec/build/bsps/arm/stm32h7/optmemflashsz.yml | 2 +-
> .../build/bsps/arm/stm32h7/optmemsdram1sz.yml | 8 +++----
> .../build/bsps/arm/stm32h7/optmemsdram2sz.yml | 4 ++--
> spec/build/bsps/arm/stm32h7/optpwrsupply.yml | 6 +++---
> .../arm/stm32h7/optusart1alternatefunc.yml | 2 +-
> .../bsps/arm/stm32h7/optusart1gpiopins.yml | 2 +-
> .../bsps/arm/stm32h7/optusart1gpioregs.yml | 2 +-
> .../bsps/arm/xilinx-zynq/opta9periphclk.yml | 4 ++--
> .../bsps/arm/xilinx-zynq/optcachedata.yml | 4 +++-
> .../bsps/arm/xilinx-zynq/optcacheinst.yml | 4 +++-
> .../bsps/arm/xilinx-zynq/optclkcpu1x.yml | 4 ++--
> .../bsps/arm/xilinx-zynq/optclkfastidle.yml | 4 +++-
> .../build/bsps/arm/xilinx-zynq/optclkuart.yml | 4 ++--
> .../bsps/arm/xilinx-zynqmp/optcachedata.yml | 4 +++-
> .../bsps/arm/xilinx-zynqmp/optcacheinst.yml | 4 +++-
> .../bsps/arm/xilinx-zynqmp/optclkfastidle.yml | 4 +++-
> .../bsps/arm/xilinx-zynqmp/optclkuart.yml | 2 +-
> .../build/bsps/dev/irq/optarmgic-icc-bpr0.yml | 14 ++++++++++++-
> .../bsps/dev/irq/optarmgic-icc-igrpen0.yml | 14 ++++++++++++-
> .../microblaze/microblaze_fpga/optramlen.yml | 3 ++-
> spec/build/bsps/optcachedata.yml | 15 ++++++++++++-
> spec/build/bsps/optcacheinst.yml | 15 ++++++++++++-
> spec/build/bsps/optclkbootcpu.yml | 15 ++++++++++++-
> spec/build/bsps/optclkfastidle.yml | 15 ++++++++++++-
> spec/build/bsps/optconsolebaud.yml | 2 +-
> spec/build/bsps/optdtb.yml | 2 +-
> spec/build/bsps/optdtbheaderpath.yml | 2 +-
> spec/build/bsps/optxilsupportpath.yml | 2 +-
> spec/build/bsps/powerpc/gen5200/optuboot.yml | 3 ++-
> .../bsps/powerpc/motorola_powerpc/optqemu.yml | 3 ++-
> .../bsps/powerpc/mpc55xxevb/ofmpllptmfd.yml | 4 ++--
> .../bsps/powerpc/mpc55xxevb/optchiptype.yml | 8 +++----
> .../bsps/powerpc/mpc55xxevb/optclkemios.yml | 6 +++---
> .../bsps/powerpc/mpc55xxevb/optclkpit.yml | 4 ++--
> .../powerpc/mpc55xxevb/optemiosprescal.yml | 2 +-
> .../powerpc/mpc55xxevb/optfmpllprediv.yml | 4 ++--
> .../bsps/powerpc/mpc55xxevb/optirqtblsz.yml | 6 +++---
> .../bsps/powerpc/mpc55xxevb/optlowinit.yml | 3 +--
> .../bsps/powerpc/mpc55xxevb/optmpc5566evb.yml | 2 +-
> .../powerpc/mpc55xxevb/optmpc5674fevb.yml | 2 +-
> .../bsps/powerpc/mpc55xxevb/optnullprot.yml | 4 ++--
> .../bsps/powerpc/mpc55xxevb/optrefclk.yml | 6 +++---
> .../powerpc/mpc55xxevb/optsmc9218ipinirq.yml | 2 +-
> .../powerpc/mpc55xxevb/optsmc9218ipinrst.yml | 2 +-
> .../bsps/powerpc/mpc55xxevb/optsysclk.yml | 4 ++--
> .../bsps/powerpc/mpc55xxevb/optsysclkdiv.yml | 2 +-
> spec/build/bsps/powerpc/qoriq/optbucsr.yml | 3 ++-
> .../build/bsps/powerpc/qoriq/optbusclkdiv.yml | 3 ++-
> .../bsps/powerpc/qoriq/optcachealign.yml | 3 ++-
> .../bsps/powerpc/qoriq/optcachedatal2sz.yml | 3 ++-
> .../bsps/powerpc/qoriq/optcacheinstl2sz.yml | 3 ++-
> spec/build/bsps/powerpc/qoriq/optchipnum.yml | 3 ++-
> spec/build/bsps/powerpc/qoriq/optchipser.yml | 3 ++-
> spec/build/bsps/powerpc/qoriq/optcpucnt.yml | 3 ++-
> spec/build/bsps/powerpc/qoriq/opthid0.yml | 3 ++-
> spec/build/bsps/powerpc/qoriq/opthyp.yml | 3 ++-
> spec/build/bsps/powerpc/qoriq/optmas7.yml | 3 ++-
> spec/build/bsps/powerpc/qoriq/optmsr.yml | 4 ++--
> spec/build/bsps/powerpc/qoriq/optspefscr.yml | 3 ++-
> spec/build/bsps/powerpc/qoriq/optthrdcnt.yml | 3 ++-
> spec/build/bsps/powerpc/qoriq/opttlb1cnt.yml | 3 ++-
> spec/build/bsps/riscv/noel/abi.yml | 3 +--
> spec/build/bsps/riscv/optextirqmax.yml | 2 +-
> spec/build/bsps/riscv/optrambegin.yml | 8 +++++--
> spec/build/bsps/riscv/optramsize.yml | 2 +-
> .../bsps/riscv/riscv/optfrdme310arty.yml | 2 +-
> spec/build/bsps/riscv/riscv/optmpfs.yml | 2 +-
> spec/build/bsps/riscv/riscv/optns16550max.yml | 4 ++--
> spec/build/cpukit/optarchbits.yml | 21 ++++++++++++++-----
> spec/build/cpukit/optboothartid.yml | 2 +-
> 134 files changed, 400 insertions(+), 210 deletions(-)
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c0.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c0.yml
> index 98a2222353..1005594abe 100644
> --- a/spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c0.yml
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c0.yml
> @@ -10,16 +10,16 @@ default: 111111111
> default-by-variant:
> - value: 111111111
> variants:
> - - aarch64/xilinx_zynqmp_ilp32_qemu.*
> + - aarch64/xilinx_zynqmp_ilp32_qemu
> - value: 111111111
> variants:
> - - aarch64/xilinx_zynqmp_ilp32_zu3eg.*
> + - aarch64/xilinx_zynqmp_ilp32_zu3eg
> - value: 111111111
> variants:
> - - aarch64/xilinx_zynqmp_lp64_qemu.*
> + - aarch64/xilinx_zynqmp_lp64_qemu
> - value: 111111111
> variants:
> - - aarch64/xilinx_zynqmp_lp64_zu3eg.*
> + - aarch64/xilinx_zynqmp_lp64_zu3eg
> description: |
> ZynqMP i2c0 clock frequency in Hz. This is the frequency after the signal
> has been processed using the values passed to the I2C0_REF_CTRL register.
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c1.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c1.yml
> index 6fe6c18dfa..f1b26578e0 100644
> --- a/spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c1.yml
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c1.yml
> default-by-variant:
> - value: 111111111
> variants:
> - value: 111111111
> variants:
> - value: 111111111
> variants:
> - value: 111111111
> variants:
> description: |
> ZynqMP i2c1 clock frequency in Hz. This is the frequency after the signal
> has been processed using the values passed to the I2C1_REF_CTRL register.
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optclkuart.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optclkuart.yml
> index d663d6f640..24f232e711 100644
> --- a/spec/build/bsps/aarch64/xilinx-zynqmp/optclkuart.yml
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optclkuart.yml
> @@ -9,8 +9,11 @@ default: 100000000
> default-by-variant:
> - value: 100000000
> variants:
> - - aarch64/xilinx_zynqmp_ilp32.*
> - - aarch64/xilinx_zynqmp_lp64.*
> + - aarch64/xilinx_zynqmp_lp64_cfc400x
> description: |
> Zynq UART clock frequency in Hz
> enabled-by: true
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
> index 6a7c0f2acf..2f9d8b1ffc 100644
> --- a/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
> @@ -11,9 +11,9 @@ default: 32768
> default-by-variant:
> - value: 0
> variants:
> description: |
> offset of RAM region from memory area base
> enabled-by: true
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
> index e3a171ab65..449303fcdf 100644
> --- a/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
> @@ -11,9 +11,9 @@ default: 1073840128
> default-by-variant:
> - value: 268435456
> variants:
> description: |
> base address of memory area available to the BSP
> enabled-by: true
> diff --git a/spec/build/bsps/arm/altera-cyclone-v/optclkfastidle.yml b/spec/build/bsps/arm/altera-cyclone-v/optclkfastidle.yml
> index b800b20428..61333a11f1 100644
> --- a/spec/build/bsps/arm/altera-cyclone-v/optclkfastidle.yml
> +++ b/spec/build/bsps/arm/altera-cyclone-v/optclkfastidle.yml
> @@ -9,7 +9,9 @@ default: false
> default-by-variant:
> - value: true
> variants:
> - - arm/.*qemu
> + - arm/lm3s6965_qemu
> + - arm/realview_pbx_a9_qemu
> + - arm/xilinx_zynq_a9_qemu
> description: |
> This sets a mode where the time runs as fast as possible when a clock ISR occurs while the IDLE thread is executing. This can significantly reduce simulation times.
> enabled-by: true
> diff --git a/spec/build/bsps/arm/beagle/optam335x.yml b/spec/build/bsps/arm/beagle/optam335x.yml
> index 2453aae088..6641cef403 100644
> --- a/spec/build/bsps/arm/beagle/optam335x.yml
> +++ b/spec/build/bsps/arm/beagle/optam335x.yml
> @@ -9,7 +9,8 @@ default: false
> default-by-variant:
> - value: true
> variants:
> - - arm/beaglebone.*
> + - arm/beagleboneblack
> + - arm/beaglebonewhite
> description: |
> true if SOC is AM335X
> enabled-by: true
> diff --git a/spec/build/bsps/arm/beagle/optdebug.yml b/spec/build/bsps/arm/beagle/optdebug.yml
> index 54f6c55f9a..8a5dc7ee96 100644
> --- a/spec/build/bsps/arm/beagle/optdebug.yml
> +++ b/spec/build/bsps/arm/beagle/optdebug.yml
> default-by-variant:
> - value: false
> variants:
> description: |
> Enable BBB debug
> enabled-by: true
> diff --git a/spec/build/bsps/arm/beagle/optdm3730.yml b/spec/build/bsps/arm/beagle/optdm3730.yml
> index 3dd60260f3..4161ee29f1 100644
> --- a/spec/build/bsps/arm/beagle/optdm3730.yml
> +++ b/spec/build/bsps/arm/beagle/optdm3730.yml
> default-by-variant:
> - value: true
> variants:
> - - arm/beagleboard.*
> + - arm/beagleboardorig
> + - arm/beagleboardxm
> description: |
> true if SOC is DM3730
> enabled-by: true
> diff --git a/spec/build/bsps/arm/imx/optcachedata.yml b/spec/build/bsps/arm/imx/optcachedata.yml
> index 1664b0fc31..23b1410385 100644
> --- a/spec/build/bsps/arm/imx/optcachedata.yml
> +++ b/spec/build/bsps/arm/imx/optcachedata.yml
> @@ -9,7 +9,9 @@ default: true
> default-by-variant:
> - value: false
> variants:
> - - arm/.*qemu
> description: |
> enable data cache
> enabled-by: true
> diff --git a/spec/build/bsps/arm/imx/optcacheinst.yml b/spec/build/bsps/arm/imx/optcacheinst.yml
> index b191133af9..f172cc4b58 100644
> --- a/spec/build/bsps/arm/imx/optcacheinst.yml
> +++ b/spec/build/bsps/arm/imx/optcacheinst.yml
> default-by-variant:
> - value: false
> variants:
> - - arm/.*qemu
> description: |
> enable instruction cache
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lm3s69xx/optgpioahb.yml b/spec/build/bsps/arm/lm3s69xx/optgpioahb.yml
> index 5266ec8549..77e1c9219e 100644
> --- a/spec/build/bsps/arm/lm3s69xx/optgpioahb.yml
> +++ b/spec/build/bsps/arm/lm3s69xx/optgpioahb.yml
> @@ -9,10 +9,10 @@ default: false
> default-by-variant:
> - value: true
> variants:
> - - arm/lm3s3749.*
> + - arm/lm3s3749
> - value: true
> variants:
> - - arm/lm4f.*
> + - arm/lm4f120
> description: |
> use AHB apperture to access GPIO registers
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lm3s69xx/optgpionum.yml b/spec/build/bsps/arm/lm3s69xx/optgpionum.yml
> index 05911d140c..bbccdd5a58 100644
> --- a/spec/build/bsps/arm/lm3s69xx/optgpionum.yml
> +++ b/spec/build/bsps/arm/lm3s69xx/optgpionum.yml
> @@ -9,13 +9,14 @@ default: 0
> default-by-variant:
> - value: 8
> variants:
> - - arm/lm3s3749.*
> + - arm/lm3s3749
> - value: 7
> variants:
> - - arm/lm3s6965.*
> + - arm/lm3s6965
> - value: 6
> variants:
> - - arm/lm4f120.*
> + - arm/lm4f120
> description: |
> number of GPIO blocks supported by MCU
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lm3s69xx/optlm3s3749.yml b/spec/build/bsps/arm/lm3s69xx/optlm3s3749.yml
> index 22199d8d59..9ca33cbe94 100644
> --- a/spec/build/bsps/arm/lm3s69xx/optlm3s3749.yml
> +++ b/spec/build/bsps/arm/lm3s69xx/optlm3s3749.yml
> @@ -9,7 +9,7 @@ default: false
> default-by-variant:
> - value: true
> variants:
> - - arm/lm3s3749.*
> + - arm/lm3s3749
> description: |
> board has LM3S3749 MCU
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lm3s69xx/optlm3s6965.yml b/spec/build/bsps/arm/lm3s69xx/optlm3s6965.yml
> index be01195f1d..6c11733729 100644
> --- a/spec/build/bsps/arm/lm3s69xx/optlm3s6965.yml
> +++ b/spec/build/bsps/arm/lm3s69xx/optlm3s6965.yml
> default-by-variant:
> - value: true
> variants:
> - - arm/lm3s6965.*
> + - arm/lm3s6965
> description: |
> board has LM3S6965 MCU
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lm3s69xx/optlm4f120.yml b/spec/build/bsps/arm/lm3s69xx/optlm4f120.yml
> index b3c59921b6..af60aee4d6 100644
> --- a/spec/build/bsps/arm/lm3s69xx/optlm4f120.yml
> +++ b/spec/build/bsps/arm/lm3s69xx/optlm4f120.yml
> default-by-variant:
> - value: true
> variants:
> - - arm/lm4f120.*
> + - arm/lm4f120
> description: |
> board has LM4F120xxx MCU
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lm3s69xx/optssiblks.yml b/spec/build/bsps/arm/lm3s69xx/optssiblks.yml
> index 551a27cbf2..3234606781 100644
> --- a/spec/build/bsps/arm/lm3s69xx/optssiblks.yml
> +++ b/spec/build/bsps/arm/lm3s69xx/optssiblks.yml
> default-by-variant:
> - value: 2
> variants:
> - - arm/lm3s3749.*
> + - arm/lm3s3749
> - value: 1
> variants:
> - - arm/lm3s6965.*
> + - arm/lm3s6965
> - value: 4
> variants:
> - - arm/lm4f120.*
> + - arm/lm4f120
> description: |
> number of SSI blocks supported by MCU
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lm3s69xx/optsysclk.yml b/spec/build/bsps/arm/lm3s69xx/optsysclk.yml
> index ffdd8d78c3..14fcbcd84d 100644
> --- a/spec/build/bsps/arm/lm3s69xx/optsysclk.yml
> +++ b/spec/build/bsps/arm/lm3s69xx/optsysclk.yml
> @@ -9,10 +9,12 @@ default: 0
> default-by-variant:
> - value: 50000000
> variants:
> - - arm/lm3s.*
> + - arm/lm3s3749
> + - arm/lm3s6965
> - value: 80000000
> variants:
> - - arm/lm4f.*
> + - arm/lm4f120
> description: |
> system clock in Hz
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lm3s69xx/optudma.yml b/spec/build/bsps/arm/lm3s69xx/optudma.yml
> index 88aae5094c..9445b273ec 100644
> --- a/spec/build/bsps/arm/lm3s69xx/optudma.yml
> +++ b/spec/build/bsps/arm/lm3s69xx/optudma.yml
> default-by-variant:
> - value: true
> variants:
> - - arm/lm3s3749.*
> + - arm/lm3s3749
> - value: true
> variants:
> - - arm/lm4f.*
> + - arm/lm4f120
> description: |
> defined if MCU supports UDMA
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lm3s69xx/optxtalcfg.yml b/spec/build/bsps/arm/lm3s69xx/optxtalcfg.yml
> index d034385cd3..8eebf87000 100644
> --- a/spec/build/bsps/arm/lm3s69xx/optxtalcfg.yml
> +++ b/spec/build/bsps/arm/lm3s69xx/optxtalcfg.yml
> default-by-variant:
> - value: 14
> variants:
> - - arm/lm3s6965.*
> + - arm/lm3s6965
> - value: 16
> variants:
> - - arm/lm3s3749.*
> + - arm/lm3s3749
> - value: 21
> variants:
> - - arm/lm4f120.*
> + - arm/lm4f120
> description: |
> crystal configuration for RCC register
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lpc24xx/optcclk.yml b/spec/build/bsps/arm/lpc24xx/optcclk.yml
> index aacf2192c2..e9700ce101 100644
> --- a/spec/build/bsps/arm/lpc24xx/optcclk.yml
> +++ b/spec/build/bsps/arm/lpc24xx/optcclk.yml
> @@ -9,16 +9,20 @@ default: 72000000
> default-by-variant:
> - value: 96000000
> variants:
> - - arm/lpc17xx_ea.*
> + - arm/lpc17xx_ea_ram
> + - arm/lpc17xx_ea_rom_int
> - value: 96000000
> variants:
> - - arm/lpc40xx_ea.*
> + - arm/lpc40xx_ea_ram
> + - arm/lpc40xx_ea_rom_int
> - value: 58982400
> variants:
> - - arm/lpc23.*
> + - arm/lpc2362
> + - arm/lpc23xx_tli800
> - value: 51612800
> variants:
> - - arm/lpc24xx_plx800_.*
> + - arm/lpc24xx_plx800_ram
> + - arm/lpc24xx_plx800_rom_int
> description: |
> CPU clock in Hz
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lpc24xx/optdmachn.yml b/spec/build/bsps/arm/lpc24xx/optdmachn.yml
> index 1a67589bfc..f1f57dca60 100644
> --- a/spec/build/bsps/arm/lpc24xx/optdmachn.yml
> +++ b/spec/build/bsps/arm/lpc24xx/optdmachn.yml
> @@ -9,10 +9,17 @@ default: 2
> default-by-variant:
> - value: 8
> variants:
> - - arm/lpc17.*
> + - arm/lpc1768_mbed
> + - arm/lpc1768_mbed_ahb_ram
> + - arm/lpc1768_mbed_ahb_ram_eth
> + - arm/lpc17xx_plx800_ram
> + - arm/lpc17xx_plx800_rom_int
> - value: 8
> variants:
> - - arm/lpc40.*
> description: |
> DMA channel count
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lpc24xx/optemcclkdiv.yml b/spec/build/bsps/arm/lpc24xx/optemcclkdiv.yml
> index 8851dadfa7..36ff19f07b 100644
> --- a/spec/build/bsps/arm/lpc24xx/optemcclkdiv.yml
> +++ b/spec/build/bsps/arm/lpc24xx/optemcclkdiv.yml
> @@ -9,10 +9,12 @@ default: 1
> default-by-variant:
> - value: 2
> variants:
> - value: 2
> variants:
> description: |
> clock divider for EMCCLK (EMCCLK = CCLK / EMCCLKDIV)
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lpc24xx/optemcis42s32800b.yml b/spec/build/bsps/arm/lpc24xx/optemcis42s32800b.yml
> index de40eca73a..c6162af143 100644
> --- a/spec/build/bsps/arm/lpc24xx/optemcis42s32800b.yml
> +++ b/spec/build/bsps/arm/lpc24xx/optemcis42s32800b.yml
> default-by-variant:
> - value: true
> variants:
> - - arm/lpc17xx_ea_rom_.*
> - value: true
> variants:
> - - arm/lpc40xx_ea_rom_.*
> description: |
> enable ISSI IS42S32800B configuration for EMC
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lpc24xx/optemcis42s32800d7.yml b/spec/build/bsps/arm/lpc24xx/optemcis42s32800d7.yml
> index e7ad228709..71d2b38f27 100644
> --- a/spec/build/bsps/arm/lpc24xx/optemcis42s32800d7.yml
> +++ b/spec/build/bsps/arm/lpc24xx/optemcis42s32800d7.yml
> default-by-variant:
> - value: true
> variants:
> - - arm/.*_plx800_rom_.*
> description: |
> enable ISSI IS42S32800D7 configuration for EMC
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lpc24xx/optemcm29w160e.yml b/spec/build/bsps/arm/lpc24xx/optemcm29w160e.yml
> index 40a4bfbf71..02f233165c 100644
> --- a/spec/build/bsps/arm/lpc24xx/optemcm29w160e.yml
> +++ b/spec/build/bsps/arm/lpc24xx/optemcm29w160e.yml
> default-by-variant:
> - value: true
> variants:
> - - arm/lpc24xx_ncs_rom_.*
> + - arm/lpc24xx_ncs_rom_ext
> + - arm/lpc24xx_ncs_rom_int
> description: |
> enable M29W160E configuration for EMC
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lpc24xx/optemcm29w320e70.yml b/spec/build/bsps/arm/lpc24xx/optemcm29w320e70.yml
> index a32c1a3eb6..66aa8c5cad 100644
> --- a/spec/build/bsps/arm/lpc24xx/optemcm29w320e70.yml
> +++ b/spec/build/bsps/arm/lpc24xx/optemcm29w320e70.yml
> default-by-variant:
> - value: true
> variants:
> description: |
> enable M29W320E70 configuration for EMC
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lpc24xx/optemcmt48lc4m16a2.yml b/spec/build/bsps/arm/lpc24xx/optemcmt48lc4m16a2.yml
> index ab6f25fef8..02b92e0710 100644
> --- a/spec/build/bsps/arm/lpc24xx/optemcmt48lc4m16a2.yml
> +++ b/spec/build/bsps/arm/lpc24xx/optemcmt48lc4m16a2.yml
> default-by-variant:
> - value: true
> variants:
> description: |
> enable Micron MT48LC4M16A2 configuration for EMC
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lpc24xx/optethrmii.yml b/spec/build/bsps/arm/lpc24xx/optethrmii.yml
> index c7c3627c82..6dc25d0d86 100644
> --- a/spec/build/bsps/arm/lpc24xx/optethrmii.yml
> +++ b/spec/build/bsps/arm/lpc24xx/optethrmii.yml
> @@ -9,7 +9,10 @@ default: false
> default-by-variant:
> - value: true
> variants:
> - - arm/.*_ea_.*
> description: |
> enable RMII for Ethernet
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lpc24xx/optheapext.yml b/spec/build/bsps/arm/lpc24xx/optheapext.yml
> index b485eb6cc3..90acde9447 100644
> --- a/spec/build/bsps/arm/lpc24xx/optheapext.yml
> +++ b/spec/build/bsps/arm/lpc24xx/optheapext.yml
> default-by-variant:
> - value: true
> variants:
> - - arm/lpc23.*
> + - arm/lpc2362
> description: |
> enable heap extend by Ethernet and USB regions
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lpc24xx/optoscmain.yml b/spec/build/bsps/arm/lpc24xx/optoscmain.yml
> index ec529345a1..2a483213de 100644
> --- a/spec/build/bsps/arm/lpc24xx/optoscmain.yml
> +++ b/spec/build/bsps/arm/lpc24xx/optoscmain.yml
> @@ -9,7 +9,8 @@ default: 12000000
> default-by-variant:
> - value: 3686400
> variants:
> - - arm/lpc23.*
> + - arm/lpc2362
> description: |
> main oscillator frequency in Hz
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lpc24xx/optotgi2c.yml b/spec/build/bsps/arm/lpc24xx/optotgi2c.yml
> index 4e205cb0af..e92754d99f 100644
> --- a/spec/build/bsps/arm/lpc24xx/optotgi2c.yml
> +++ b/spec/build/bsps/arm/lpc24xx/optotgi2c.yml
> default-by-variant:
> - value: 94
> variants:
> - value: 94
> variants:
> description: |
> USB OTG transceiver I2C address used by USB stack
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lpc24xx/optpclkdiv.yml b/spec/build/bsps/arm/lpc24xx/optpclkdiv.yml
> index 296486c78f..bc4984bc3d 100644
> --- a/spec/build/bsps/arm/lpc24xx/optpclkdiv.yml
> +++ b/spec/build/bsps/arm/lpc24xx/optpclkdiv.yml
> default-by-variant:
> - value: 2
> variants:
> - value: 2
> variants:
> description: |
> clock divider for default PCLK (PCLK = CCLK / PCLKDIV)
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lpc24xx/optstopeth.yml b/spec/build/bsps/arm/lpc24xx/optstopeth.yml
> index 60f07f9a06..2baf76da8c 100644
> --- a/spec/build/bsps/arm/lpc24xx/optstopeth.yml
> +++ b/spec/build/bsps/arm/lpc24xx/optstopeth.yml
> @@ -9,7 +9,8 @@ default: true
> default-by-variant:
> - value: false
> variants:
> - - arm/lpc23.*
> + - arm/lpc2362
> description: |
> stop Ethernet controller at start-up to avoid DMA interference
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lpc24xx/optstopusb.yml b/spec/build/bsps/arm/lpc24xx/optstopusb.yml
> index 2f2bfc5c93..b895ff7df3 100644
> --- a/spec/build/bsps/arm/lpc24xx/optstopusb.yml
> +++ b/spec/build/bsps/arm/lpc24xx/optstopusb.yml
> default-by-variant:
> - value: false
> variants:
> - - arm/lpc23.*
> + - arm/lpc2362
> description: |
> stop USB controller at start-up to avoid DMA interference
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lpc24xx/optuart1cfg.yml b/spec/build/bsps/arm/lpc24xx/optuart1cfg.yml
> index c1f133f08f..055f8bbbee 100644
> --- a/spec/build/bsps/arm/lpc24xx/optuart1cfg.yml
> +++ b/spec/build/bsps/arm/lpc24xx/optuart1cfg.yml
> default-by-variant:
> - value: false
> variants:
> - - arm/.*_plx800_.*
> description: |
> configuration for UART 1
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lpc24xx/optuart2cfg.yml b/spec/build/bsps/arm/lpc24xx/optuart2cfg.yml
> index 3e523147ca..0f9bbad26b 100644
> --- a/spec/build/bsps/arm/lpc24xx/optuart2cfg.yml
> +++ b/spec/build/bsps/arm/lpc24xx/optuart2cfg.yml
> @@ -9,13 +9,19 @@ default: false
> default-by-variant:
> - value: false
> variants:
> - - arm/lpc23.*
> + - arm/lpc2362
> - value: false
> variants:
> - - arm/lpc24xx_ncs_.*
> + - arm/lpc24xx_ncs_ram
> - value: false
> variants:
> description: |
> configuration for UART 2
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lpc24xx/optuart3cfg.yml b/spec/build/bsps/arm/lpc24xx/optuart3cfg.yml
> index 2af84c927d..991be593f3 100644
> --- a/spec/build/bsps/arm/lpc24xx/optuart3cfg.yml
> +++ b/spec/build/bsps/arm/lpc24xx/optuart3cfg.yml
> @@ -9,10 +9,13 @@ default: false
> default-by-variant:
> - value: false
> variants:
> - - arm/lpc23.*
> + - arm/lpc2362
> - value: false
> variants:
> description: |
> configuration for UART 3
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lpc32xx/optotgi2c.yml b/spec/build/bsps/arm/lpc32xx/optotgi2c.yml
> index 72137d9c27..55119b35cf 100644
> --- a/spec/build/bsps/arm/lpc32xx/optotgi2c.yml
> +++ b/spec/build/bsps/arm/lpc32xx/optotgi2c.yml
> @@ -9,7 +9,9 @@ default: 0
> default-by-variant:
> - value: 88
> variants:
> - - arm/lpc32xx_mzx.*
> + - arm/lpc32xx_mzx
> + - arm/lpc32xx_mzx_stage_1
> + - arm/lpc32xx_mzx_stage_2
> description: |
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lpc32xx/optotgvbus.yml b/spec/build/bsps/arm/lpc32xx/optotgvbus.yml
> index 0d9d6b65f5..e5d2563a7b 100644
> --- a/spec/build/bsps/arm/lpc32xx/optotgvbus.yml
> +++ b/spec/build/bsps/arm/lpc32xx/optotgvbus.yml
> default-by-variant:
> - value: USB_OTG_VBUS_POWER_WITH_CHARGE_PUMP
> variants:
> + - arm/lpc32xx_mzx
> description: |
> USB OTG transceiver VBUS policy
> enabled-by: true
> diff --git a/spec/build/bsps/arm/lpc32xx/optscratchsz.yml b/spec/build/bsps/arm/lpc32xx/optscratchsz.yml
> index c54f1ae7b3..ad8473d57d 100644
> --- a/spec/build/bsps/arm/lpc32xx/optscratchsz.yml
> +++ b/spec/build/bsps/arm/lpc32xx/optscratchsz.yml
> default-by-variant:
> - value: 4096
> variants:
> + - arm/lpc32xx_mzx
> description: |
> size of scratch area
> enabled-by: true
> diff --git a/spec/build/bsps/arm/realview-pbx-a9/optcachedata.yml b/spec/build/bsps/arm/realview-pbx-a9/optcachedata.yml
> --- a/spec/build/bsps/arm/realview-pbx-a9/optcachedata.yml
> +++ b/spec/build/bsps/arm/realview-pbx-a9/optcachedata.yml
> default-by-variant:
> - value: false
> variants:
> - - arm/.*qemu
> description: |
> enable data cache
> enabled-by: true
> diff --git a/spec/build/bsps/arm/realview-pbx-a9/optcacheinst.yml b/spec/build/bsps/arm/realview-pbx-a9/optcacheinst.yml
> --- a/spec/build/bsps/arm/realview-pbx-a9/optcacheinst.yml
> +++ b/spec/build/bsps/arm/realview-pbx-a9/optcacheinst.yml
> default-by-variant:
> - value: false
> variants:
> - - arm/.*qemu
> description: |
> enabled-by: true
> diff --git a/spec/build/bsps/arm/realview-pbx-a9/optclkbootcpu.yml b/spec/build/bsps/arm/realview-pbx-a9/optclkbootcpu.yml
> index 8d78c9ce6a..8cca180892 100644
> --- a/spec/build/bsps/arm/realview-pbx-a9/optclkbootcpu.yml
> +++ b/spec/build/bsps/arm/realview-pbx-a9/optclkbootcpu.yml
> default-by-variant:
> - value: true
> variants:
> - - arm/.*qemu.*
> description: |
> If defined, then do the clock tick processing on the boot processor on behalf of all other processors.
> enabled-by: true
> diff --git a/spec/build/bsps/arm/realview-pbx-a9/optclkfastidle.yml b/spec/build/bsps/arm/realview-pbx-a9/optclkfastidle.yml
> index e4624223eb..61333a11f1 100644
> --- a/spec/build/bsps/arm/realview-pbx-a9/optclkfastidle.yml
> +++ b/spec/build/bsps/arm/realview-pbx-a9/optclkfastidle.yml
> default-by-variant:
> - value: true
> variants:
> - - arm/.*qemu.*
> description: |
> enabled-by: true
> diff --git a/spec/build/bsps/arm/stm32f4/opteni2c1.yml b/spec/build/bsps/arm/stm32f4/opteni2c1.yml
> index e200c81623..ab8dd78926 100644
> --- a/spec/build/bsps/arm/stm32f4/opteni2c1.yml
> +++ b/spec/build/bsps/arm/stm32f4/opteni2c1.yml
> default-by-variant:
> - value: true
> variants:
> - - arm/stm32f1.*
> + - arm/stm32f105rc
> description: |
> enable I2C 1
> enabled-by: true
> diff --git a/spec/build/bsps/arm/stm32f4/optf10xxx.yml b/spec/build/bsps/arm/stm32f4/optf10xxx.yml
> index 54f1418cf9..a1cc76ff37 100644
> --- a/spec/build/bsps/arm/stm32f4/optf10xxx.yml
> +++ b/spec/build/bsps/arm/stm32f4/optf10xxx.yml
> default-by-variant:
> - value: true
> variants:
> - - arm/stm32f1.*
> + - arm/stm32f105rc
> description: |
> Chip belongs to the STM32F10XXX family.
> enabled-by: true
> diff --git a/spec/build/bsps/arm/stm32f4/optf4xxxx.yml b/spec/build/bsps/arm/stm32f4/optf4xxxx.yml
> index 66604f249a..891aacc3c3 100644
> --- a/spec/build/bsps/arm/stm32f4/optf4xxxx.yml
> +++ b/spec/build/bsps/arm/stm32f4/optf4xxxx.yml
> default-by-variant:
> - value: true
> variants:
> - - arm/stm32f4.*
> + - arm/stm32f4
> description: |
> Chip belongs to the STM32F4XXXX family.
> enabled-by: true
> diff --git a/spec/build/bsps/arm/stm32f4/opthclk.yml b/spec/build/bsps/arm/stm32f4/opthclk.yml
> index 7f315f12b2..b827fffe33 100644
> --- a/spec/build/bsps/arm/stm32f4/opthclk.yml
> +++ b/spec/build/bsps/arm/stm32f4/opthclk.yml
> @@ -9,7 +9,7 @@ default: 16000000
> default-by-variant:
> - value: 8000000
> variants:
> - - arm/stm32f1.*
> + - arm/stm32f105rc
> description: |
> HCLK frequency in Hz
> enabled-by: true
> diff --git a/spec/build/bsps/arm/stm32f4/optpclk1.yml b/spec/build/bsps/arm/stm32f4/optpclk1.yml
> index 9ac285b0bc..79aafa89a9 100644
> --- a/spec/build/bsps/arm/stm32f4/optpclk1.yml
> +++ b/spec/build/bsps/arm/stm32f4/optpclk1.yml
> default-by-variant:
> - value: 8000000
> variants:
> - - arm/stm32f1.*
> + - arm/stm32f105rc
> description: |
> PCLK1 frequency in Hz
> enabled-by: true
> diff --git a/spec/build/bsps/arm/stm32f4/optpclk2.yml b/spec/build/bsps/arm/stm32f4/optpclk2.yml
> index e51eeaf36f..43ce9f9c04 100644
> --- a/spec/build/bsps/arm/stm32f4/optpclk2.yml
> +++ b/spec/build/bsps/arm/stm32f4/optpclk2.yml
> default-by-variant:
> - value: 8000000
> variants:
> - - arm/stm32f1.*
> + - arm/stm32f105rc
> description: |
> PCLK2 frequency in Hz
> enabled-by: true
> diff --git a/spec/build/bsps/arm/stm32f4/optsysclk.yml b/spec/build/bsps/arm/stm32f4/optsysclk.yml
> index 5f08d4ecde..9dd081d475 100644
> --- a/spec/build/bsps/arm/stm32f4/optsysclk.yml
> +++ b/spec/build/bsps/arm/stm32f4/optsysclk.yml
> default-by-variant:
> - value: 8000000
> variants:
> - - arm/stm32f1.*
> + - arm/stm32f105rc
> description: |
> SYSCLK frequency in Hz
> enabled-by: true
> diff --git a/spec/build/bsps/arm/stm32h7/abi.yml b/spec/build/bsps/arm/stm32h7/abi.yml
> index 1f48596190..27da264d03 100644
> --- a/spec/build/bsps/arm/stm32h7/abi.yml
> +++ b/spec/build/bsps/arm/stm32h7/abi.yml
> @@ -18,8 +18,8 @@ default-by-variant:
> - -mfpu=fpv4-sp-d16
> - -mfloat-abi=hard
> variants:
> - - arm/stm32h757i-eval-m4
> - arm/stm32h747i-disco-m4
> + - arm/stm32h757i-eval-m4
> description: |
> ABI flags
> enabled-by: true
> diff --git a/spec/build/bsps/arm/stm32h7/optbootcore.yml b/spec/build/bsps/arm/stm32h7/optbootcore.yml
> index ad50f8ef77..c248939bbe 100644
> --- a/spec/build/bsps/arm/stm32h7/optbootcore.yml
> +++ b/spec/build/bsps/arm/stm32h7/optbootcore.yml
> @@ -13,12 +13,12 @@ default: BOOT_CORE_DEFINE_NOT_NEEDED
> default-by-variant:
> - value: CORE_CM7
> variants:
> - value: CORE_CM4
> variants:
> description: |
> Select the boot core. Possible values are CORE_CM7 and CORE_CM4
> enabled-by: true
> diff --git a/spec/build/bsps/arm/stm32h7/optenuart4.yml b/spec/build/bsps/arm/stm32h7/optenuart4.yml
> index ab49af31f9..b95b2372f7 100644
> --- a/spec/build/bsps/arm/stm32h7/optenuart4.yml
> +++ b/spec/build/bsps/arm/stm32h7/optenuart4.yml
> @@ -9,10 +9,10 @@ default: true
> default-by-variant:
> - value: false
> variants:
> description: |
> Enable UART4 device in console driver.
> enabled-by: true
> diff --git a/spec/build/bsps/arm/stm32h7/optenuart5.yml b/spec/build/bsps/arm/stm32h7/optenuart5.yml
> index 502e02c61d..db70f25470 100644
> --- a/spec/build/bsps/arm/stm32h7/optenuart5.yml
> +++ b/spec/build/bsps/arm/stm32h7/optenuart5.yml
> @@ -9,11 +9,11 @@ default: true
> default-by-variant:
> - value: false
> variants:
> - - arm/stm32h7b3i-dk
> + - arm/stm32h7b3i-dk
> description: |
> Enable UART5 device in console driver.
> enabled-by: true
> diff --git a/spec/build/bsps/arm/stm32h7/optenuart7.yml b/spec/build/bsps/arm/stm32h7/optenuart7.yml
> index fb061158cd..6fdc57cec8 100644
> --- a/spec/build/bsps/arm/stm32h7/optenuart7.yml
> +++ b/spec/build/bsps/arm/stm32h7/optenuart7.yml
> default-by-variant:
> - value: false
> variants:
> description: |
> Enable UART7 device in console driver.
> enabled-by: true
> diff --git a/spec/build/bsps/arm/stm32h7/optenuart8.yml b/spec/build/bsps/arm/stm32h7/optenuart8.yml
> index 74de622e09..0dc550d701 100644
> --- a/spec/build/bsps/arm/stm32h7/optenuart8.yml
> +++ b/spec/build/bsps/arm/stm32h7/optenuart8.yml
> @@ -9,9 +9,9 @@ default: true
> default-by-variant:
> - value: false
> variants:
> description: |
> Enable UART8 device in console driver.
> enabled-by: true
> diff --git a/spec/build/bsps/arm/stm32h7/optenuart9.yml b/spec/build/bsps/arm/stm32h7/optenuart9.yml
> index af0d2e037b..9c364b7fec 100644
> --- a/spec/build/bsps/arm/stm32h7/optenuart9.yml
> +++ b/spec/build/bsps/arm/stm32h7/optenuart9.yml
> default-by-variant:
> - value: false
> variants:
> description: |
> Enable UART9 device in console driver.
> enabled-by: true
> diff --git a/spec/build/bsps/arm/stm32h7/optenusart10.yml b/spec/build/bsps/arm/stm32h7/optenusart10.yml
> index c44bffad73..a23ce86e7e 100644
> --- a/spec/build/bsps/arm/stm32h7/optenusart10.yml
> +++ b/spec/build/bsps/arm/stm32h7/optenusart10.yml
> default-by-variant:
> - value: false
> variants:
> description: |
> Enable USART10 device in console driver.
> enabled-by: true
> diff --git a/spec/build/bsps/arm/stm32h7/optenusart3.yml b/spec/build/bsps/arm/stm32h7/optenusart3.yml
> index a0027c8266..48f5ce7e9f 100644
> --- a/spec/build/bsps/arm/stm32h7/optenusart3.yml
> +++ b/spec/build/bsps/arm/stm32h7/optenusart3.yml
> default-by-variant:
> - value: false
> variants:
> description: |
> Enable USART3 device in console driver.
> enabled-by: true
> diff --git a/spec/build/bsps/arm/stm32h7/optenusart6.yml b/spec/build/bsps/arm/stm32h7/optenusart6.yml
> index 7c4e9aee5b..1090bbce39 100644
> --- a/spec/build/bsps/arm/stm32h7/optenusart6.yml
> +++ b/spec/build/bsps/arm/stm32h7/optenusart6.yml
> default-by-variant:
> - value: false
> variants:
> description: |
> Enable USART6 device in console driver.
> enabled-by: true
> diff --git a/spec/build/bsps/arm/stm32h7/optlinkcmds.yml b/spec/build/bsps/arm/stm32h7/optlinkcmds.yml
> index 59d4354ae2..ed10fe94d1 100644
> --- a/spec/build/bsps/arm/stm32h7/optlinkcmds.yml
> +++ b/spec/build/bsps/arm/stm32h7/optlinkcmds.yml
> @@ -9,12 +9,12 @@ default: linkcmds.sdram
> default-by-variant:
> - value: linkcmds.flash
> variants:
> + - arm/nucleo-h743zi
> - - arm/nucleo-h743zi
> description: |
> The default linker command file. Must be either linkcmds.flash,
> linkcmds.sdram, linkcmds.sram, linkcmds.sram_sdram
> diff --git a/spec/build/bsps/arm/stm32h7/optmemflashorigin.yml b/spec/build/bsps/arm/stm32h7/optmemflashorigin.yml
> index 4e155fa14a..f3e1cfcf0e 100644
> --- a/spec/build/bsps/arm/stm32h7/optmemflashorigin.yml
> +++ b/spec/build/bsps/arm/stm32h7/optmemflashorigin.yml
> @@ -9,8 +9,8 @@ default: 134217728
> default-by-variant:
> - value: 135266304
> variants:
> description: |
> Origin address of the internal flash.
> enabled-by: true
> diff --git a/spec/build/bsps/arm/stm32h7/optmemflashsz.yml b/spec/build/bsps/arm/stm32h7/optmemflashsz.yml
> index 945bc16c4d..ca845b968e 100644
> --- a/spec/build/bsps/arm/stm32h7/optmemflashsz.yml
> +++ b/spec/build/bsps/arm/stm32h7/optmemflashsz.yml
> @@ -9,8 +9,8 @@ default: 2097152
> default-by-variant:
> - value: 1048576
> variants:
> description: |
> Size of the internal flash in bytes.
> enabled-by: true
> diff --git a/spec/build/bsps/arm/stm32h7/optmemsdram1sz.yml b/spec/build/bsps/arm/stm32h7/optmemsdram1sz.yml
> index 9f36a510f2..c9ec44ec3f 100644
> --- a/spec/build/bsps/arm/stm32h7/optmemsdram1sz.yml
> +++ b/spec/build/bsps/arm/stm32h7/optmemsdram1sz.yml
> @@ -9,12 +9,12 @@ default: 33554432
> default-by-variant:
> - value: 0
> variants:
> description: |
> Size of the SDRAM 1 in bytes.
> enabled-by: true
> diff --git a/spec/build/bsps/arm/stm32h7/optmemsdram2sz.yml b/spec/build/bsps/arm/stm32h7/optmemsdram2sz.yml
> index b042fa796b..1b8d4a2b4c 100644
> --- a/spec/build/bsps/arm/stm32h7/optmemsdram2sz.yml
> +++ b/spec/build/bsps/arm/stm32h7/optmemsdram2sz.yml
> @@ -9,10 +9,10 @@ default: 0
> default-by-variant:
> - value: 33554432
> variants:
> description: |
> Size of the SDRAM 2 in bytes.
> enabled-by: true
> diff --git a/spec/build/bsps/arm/stm32h7/optpwrsupply.yml b/spec/build/bsps/arm/stm32h7/optpwrsupply.yml
> index 9270eedbd4..6534cf6143 100644
> --- a/spec/build/bsps/arm/stm32h7/optpwrsupply.yml
> +++ b/spec/build/bsps/arm/stm32h7/optpwrsupply.yml
> @@ -9,11 +9,11 @@ default: PWR_LDO_SUPPLY
> default-by-variant:
> - value: PWR_DIRECT_SMPS_SUPPLY
> variants:
> description: |
> Board power supply mechanism configuration. WARNING: wrong configuration here
> may result in your board being unaccessible using ST-Link interface! Please
> diff --git a/spec/build/bsps/arm/stm32h7/optusart1alternatefunc.yml b/spec/build/bsps/arm/stm32h7/optusart1alternatefunc.yml
> index b0d3d86a6c..e0f39814e8 100644
> --- a/spec/build/bsps/arm/stm32h7/optusart1alternatefunc.yml
> +++ b/spec/build/bsps/arm/stm32h7/optusart1alternatefunc.yml
> @@ -9,9 +9,9 @@ default: GPIO_AF4_USART1
> default-by-variant:
> - value: GPIO_AF7_USART1
> variants:
> description: |
> Alternate function mapping for the USART1 pin configuration.
> enabled-by: true
> diff --git a/spec/build/bsps/arm/stm32h7/optusart1gpiopins.yml b/spec/build/bsps/arm/stm32h7/optusart1gpiopins.yml
> index b8920d9276..cc81ce408b 100644
> --- a/spec/build/bsps/arm/stm32h7/optusart1gpiopins.yml
> +++ b/spec/build/bsps/arm/stm32h7/optusart1gpiopins.yml
> @@ -9,9 +9,9 @@ default: ( GPIO_PIN_14 | GPIO_PIN_15 )
> default-by-variant:
> - value: ( GPIO_PIN_9 | GPIO_PIN_10 )
> variants:
> description: |
> GPIO pins used for the USART1 pin configuration.
> enabled-by: true
> diff --git a/spec/build/bsps/arm/stm32h7/optusart1gpioregs.yml b/spec/build/bsps/arm/stm32h7/optusart1gpioregs.yml
> index 79e8ab02f2..890579b9f8 100644
> --- a/spec/build/bsps/arm/stm32h7/optusart1gpioregs.yml
> +++ b/spec/build/bsps/arm/stm32h7/optusart1gpioregs.yml
> @@ -9,9 +9,9 @@ default: GPIOD
> default-by-variant:
> - value: GPIOA
> variants:
> - value: GPIOB
> variants:
> diff --git a/spec/build/bsps/arm/xilinx-zynq/opta9periphclk.yml b/spec/build/bsps/arm/xilinx-zynq/opta9periphclk.yml
> index 0b10b47bc2..39cb972a74 100644
> --- a/spec/build/bsps/arm/xilinx-zynq/opta9periphclk.yml
> +++ b/spec/build/bsps/arm/xilinx-zynq/opta9periphclk.yml
> @@ -9,10 +9,10 @@ default: 100000000
> default-by-variant:
> - value: 333333333
> variants:
> - - arm/xilinx_zynq_zc702.*
> + - arm/xilinx_zynq_zc702
> - value: 666666667
> variants:
> - - arm/xilinx_zynq_zedboard.*
> + - arm/xilinx_zynq_zedboard
> description: |
> ARM Cortex-A9 MPCore PERIPHCLK clock frequency in Hz
> enabled-by: true
> diff --git a/spec/build/bsps/arm/xilinx-zynq/optcachedata.yml b/spec/build/bsps/arm/xilinx-zynq/optcachedata.yml
> --- a/spec/build/bsps/arm/xilinx-zynq/optcachedata.yml
> +++ b/spec/build/bsps/arm/xilinx-zynq/optcachedata.yml
> default-by-variant:
> - value: false
> variants:
> - - arm/.*qemu
> description: |
> enable data cache
> enabled-by: true
> diff --git a/spec/build/bsps/arm/xilinx-zynq/optcacheinst.yml b/spec/build/bsps/arm/xilinx-zynq/optcacheinst.yml
> --- a/spec/build/bsps/arm/xilinx-zynq/optcacheinst.yml
> +++ b/spec/build/bsps/arm/xilinx-zynq/optcacheinst.yml
> default-by-variant:
> - value: false
> variants:
> - - arm/.*qemu
> description: |
> enabled-by: true
> diff --git a/spec/build/bsps/arm/xilinx-zynq/optclkcpu1x.yml b/spec/build/bsps/arm/xilinx-zynq/optclkcpu1x.yml
> index 1f93f52a8a..57b7187cdf 100644
> --- a/spec/build/bsps/arm/xilinx-zynq/optclkcpu1x.yml
> +++ b/spec/build/bsps/arm/xilinx-zynq/optclkcpu1x.yml
> @@ -9,10 +9,10 @@ default: 111111111
> default-by-variant:
> - value: 111111111
> variants:
> - value: 111111111
> variants:
> description: |
> Zynq cpu_1x clock frequency in Hz
> enabled-by: true
> diff --git a/spec/build/bsps/arm/xilinx-zynq/optclkfastidle.yml b/spec/build/bsps/arm/xilinx-zynq/optclkfastidle.yml
> --- a/spec/build/bsps/arm/xilinx-zynq/optclkfastidle.yml
> +++ b/spec/build/bsps/arm/xilinx-zynq/optclkfastidle.yml
> default-by-variant:
> - value: true
> variants:
> - - arm/.*qemu
> description: |
> enabled-by: true
> diff --git a/spec/build/bsps/arm/xilinx-zynq/optclkuart.yml b/spec/build/bsps/arm/xilinx-zynq/optclkuart.yml
> index 7d69273eb2..56a6056687 100644
> --- a/spec/build/bsps/arm/xilinx-zynq/optclkuart.yml
> +++ b/spec/build/bsps/arm/xilinx-zynq/optclkuart.yml
> @@ -9,10 +9,10 @@ default: 50000000
> default-by-variant:
> - value: 50000000
> variants:
> - value: 50000000
> variants:
> description: |
> enabled-by: true
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp/optcachedata.yml b/spec/build/bsps/arm/xilinx-zynqmp/optcachedata.yml
> --- a/spec/build/bsps/arm/xilinx-zynqmp/optcachedata.yml
> +++ b/spec/build/bsps/arm/xilinx-zynqmp/optcachedata.yml
> default-by-variant:
> - value: false
> variants:
> - - arm/.*qemu
> description: |
> enable data cache
> enabled-by: true
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp/optcacheinst.yml b/spec/build/bsps/arm/xilinx-zynqmp/optcacheinst.yml
> --- a/spec/build/bsps/arm/xilinx-zynqmp/optcacheinst.yml
> +++ b/spec/build/bsps/arm/xilinx-zynqmp/optcacheinst.yml
> default-by-variant:
> - value: false
> variants:
> - - arm/.*qemu
> description: |
> enabled-by: true
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp/optclkfastidle.yml b/spec/build/bsps/arm/xilinx-zynqmp/optclkfastidle.yml
> --- a/spec/build/bsps/arm/xilinx-zynqmp/optclkfastidle.yml
> +++ b/spec/build/bsps/arm/xilinx-zynqmp/optclkfastidle.yml
> default-by-variant:
> - value: true
> variants:
> - - arm/.*qemu
> description: |
> enabled-by: true
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp/optclkuart.yml b/spec/build/bsps/arm/xilinx-zynqmp/optclkuart.yml
> index a2def36606..df6cd08847 100644
> --- a/spec/build/bsps/arm/xilinx-zynqmp/optclkuart.yml
> +++ b/spec/build/bsps/arm/xilinx-zynqmp/optclkuart.yml
> @@ -9,7 +9,7 @@ default: 100000000
> default-by-variant:
> - value: 100000000
> variants:
> - - arm/xilinx_zynqmp_ultra96.*
> + - arm/xilinx_zynqmp_ultra96
> description: |
> enabled-by: true
> diff --git a/spec/build/bsps/dev/irq/optarmgic-icc-bpr0.yml b/spec/build/bsps/dev/irq/optarmgic-icc-bpr0.yml
> index 01933d00ca..758b4d7d10 100644
> --- a/spec/build/bsps/dev/irq/optarmgic-icc-bpr0.yml
> +++ b/spec/build/bsps/dev/irq/optarmgic-icc-bpr0.yml
> @@ -9,7 +9,19 @@ default: 2
> default-by-variant:
> - value: null
> variants:
> - - aarch64/.*
> + - aarch64/a53_ilp32_qemu
> + - aarch64/a53_lp64_qemu
> + - aarch64/a72_ilp32_qemu
> + - aarch64/a72_lp64_qemu
> + - aarch64/raspberrypi4b
> + - aarch64/xilinx_versal_aiedge
> + - aarch64/xilinx_versal_qemu
> + - aarch64/xilinx_versal_vck190
> description: |
> Defines the initial value of the ICC_BPR0 register of the ARM GIC CPU
> Interface. The value is optional. If it is not defined, then the register
> diff --git a/spec/build/bsps/dev/irq/optarmgic-icc-igrpen0.yml b/spec/build/bsps/dev/irq/optarmgic-icc-igrpen0.yml
> index aea536d7d1..143468f834 100644
> --- a/spec/build/bsps/dev/irq/optarmgic-icc-igrpen0.yml
> +++ b/spec/build/bsps/dev/irq/optarmgic-icc-igrpen0.yml
> @@ -9,7 +9,19 @@ default: 1
> default-by-variant:
> - value: null
> variants:
> - - aarch64/.*
> description: |
> Defines the initial value of the ICC_IGRPEN0 register of the ARM GIC CPU
> diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optramlen.yml b/spec/build/bsps/microblaze/microblaze_fpga/optramlen.yml
> index e1bcfbaf88..bb12934884 100644
> --- a/spec/build/bsps/microblaze/microblaze_fpga/optramlen.yml
> +++ b/spec/build/bsps/microblaze/microblaze_fpga/optramlen.yml
> @@ -11,7 +11,8 @@ default: 268435456
> default-by-variant:
> - value: 2147483648
> variants:
> - - microblaze/kcu105.*
> + - microblaze/kcu105
> + - microblaze/kcu105_qemu
> description: |
> length of memory area available to the BSP
> enabled-by: true
> diff --git a/spec/build/bsps/optcachedata.yml b/spec/build/bsps/optcachedata.yml
> index 6e48d171ff..87ab0385a6 100644
> --- a/spec/build/bsps/optcachedata.yml
> +++ b/spec/build/bsps/optcachedata.yml
> @@ -10,7 +10,20 @@ default: true
> default-by-variant:
> - value: false
> variants:
> - - .*qemu.*
> + - powerpc/qemuppc
> + - powerpc/qemuprep
> + - powerpc/qemuprep-altivec
> description: |
> Enable data cache
> enabled-by: true
> diff --git a/spec/build/bsps/optcacheinst.yml b/spec/build/bsps/optcacheinst.yml
> index 035414bf0c..ac0afc964a 100644
> --- a/spec/build/bsps/optcacheinst.yml
> +++ b/spec/build/bsps/optcacheinst.yml
> default-by-variant:
> - value: false
> variants:
> - - .*qemu.*
> + - powerpc/qemuppc
> description: |
> Enable instruction cache
> enabled-by: true
> diff --git a/spec/build/bsps/optclkbootcpu.yml b/spec/build/bsps/optclkbootcpu.yml
> index d65cc2b67f..4044926fb8 100644
> --- a/spec/build/bsps/optclkbootcpu.yml
> +++ b/spec/build/bsps/optclkbootcpu.yml
> @@ -10,7 +10,20 @@ default: false
> default-by-variant:
> - value: true
> variants:
> - - .*qemu.*
> + - powerpc/qemuppc
> description: |
> Do the clock tick processing on the boot processor on behalf of all other
> processors.
> diff --git a/spec/build/bsps/optclkfastidle.yml b/spec/build/bsps/optclkfastidle.yml
> index 31fb840a9c..e0b3698992 100644
> --- a/spec/build/bsps/optclkfastidle.yml
> +++ b/spec/build/bsps/optclkfastidle.yml
> @@ -9,7 +9,20 @@ default: false
> default-by-variant:
> - value: true
> variants:
> - - .*qemu.*
> + - powerpc/qemuppc
> description: |
> Set a mode where the time runs as fast as possible when a clock ISR occurs
> while the IDLE thread is executing; this can significantly reduce simulation
> diff --git a/spec/build/bsps/optconsolebaud.yml b/spec/build/bsps/optconsolebaud.yml
> index b32dfb8888..8e754579cd 100644
> --- a/spec/build/bsps/optconsolebaud.yml
> +++ b/spec/build/bsps/optconsolebaud.yml
> @@ -11,8 +11,8 @@ default-by-variant:
> variants:
> - bsps/powerpc/motorola_powerpc
> - m68k/m5484FireEngine
> - - powerpc/hsc_cm01
> - powerpc/beatnik
> + - powerpc/hsc_cm01
> - powerpc/mvme3100
> - powerpc/mvme5500
> - value: 19200
> diff --git a/spec/build/bsps/optdtb.yml b/spec/build/bsps/optdtb.yml
> index 54ae7aa770..e38cc5a071 100644
> --- a/spec/build/bsps/optdtb.yml
> +++ b/spec/build/bsps/optdtb.yml
> default-by-variant:
> - value: true
> variants:
> - - riscv/mpfs64.*
> + - riscv/mpfs64imafdc
> description: |
> the path to the header file containing the device tree binary. See the BSP
> documentation for more information.
> diff --git a/spec/build/bsps/optdtbheaderpath.yml b/spec/build/bsps/optdtbheaderpath.yml
> index 7e294ce058..a069d084b2 100644
> --- a/spec/build/bsps/optdtbheaderpath.yml
> +++ b/spec/build/bsps/optdtbheaderpath.yml
> default-by-variant:
> - value: bsp/mpfs-dtb.h
> variants:
> - - riscv/mpfs64.*
> description: |
> diff --git a/spec/build/bsps/optxilsupportpath.yml b/spec/build/bsps/optxilsupportpath.yml
> index d70d4d0b69..25ddaf062c 100644
> --- a/spec/build/bsps/optxilsupportpath.yml
> +++ b/spec/build/bsps/optxilsupportpath.yml
> @@ -22,10 +22,10 @@ default-by-variant:
> - value: arm/ARMv8/64bit
> variants:
> - - bsps/aarch64/xilinx_versal
> + - bsps/aarch64/xilinx_versal
> description: Set the Xilinx support path
> enabled-by: true
> format: '{}'
> diff --git a/spec/build/bsps/powerpc/gen5200/optuboot.yml b/spec/build/bsps/powerpc/gen5200/optuboot.yml
> index 19ed770a9f..4d44060774 100644
> --- a/spec/build/bsps/powerpc/gen5200/optuboot.yml
> +++ b/spec/build/bsps/powerpc/gen5200/optuboot.yml
> default-by-variant:
> - value: true
> variants:
> - - powerpc/pm520.*
> + - powerpc/pm520_cr825
> + - powerpc/pm520_ze30
> - value: true
> variants:
> - powerpc/icecube
> diff --git a/spec/build/bsps/powerpc/motorola_powerpc/optqemu.yml b/spec/build/bsps/powerpc/motorola_powerpc/optqemu.yml
> index 962584da83..0e861eed0c 100644
> --- a/spec/build/bsps/powerpc/motorola_powerpc/optqemu.yml
> +++ b/spec/build/bsps/powerpc/motorola_powerpc/optqemu.yml
> default-by-variant:
> - value: true
> variants:
> - - powerpc/qemuprep.*
> description: |
> Defined for QEMU BSP -- undefined for others
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/ofmpllptmfd.yml b/spec/build/bsps/powerpc/mpc55xxevb/ofmpllptmfd.yml
> index 8918318f51..7c1a1fa869 100644
> --- a/spec/build/bsps/powerpc/mpc55xxevb/ofmpllptmfd.yml
> +++ b/spec/build/bsps/powerpc/mpc55xxevb/ofmpllptmfd.yml
> @@ -12,10 +12,10 @@ default-by-variant:
> - powerpc/gwlcfm
> - value: 111
> variants:
> - - powerpc/mpc5668g.*
> + - powerpc/mpc5668g
> - value: 66
> variants:
> - - powerpc/mpc5674f.*
> + - powerpc/mpc5674fevb
> description: |
> Must be defined to be the PLL multiplication factor for clock generation
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optchiptype.yml b/spec/build/bsps/powerpc/mpc55xxevb/optchiptype.yml
> index ae9ed015e7..d1d037d34c 100644
> --- a/spec/build/bsps/powerpc/mpc55xxevb/optchiptype.yml
> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optchiptype.yml
> @@ -12,16 +12,16 @@ default-by-variant:
> - powerpc/gwlcfm
> - value: 5566
> variants:
> - - powerpc/mpc5566.*
> + - powerpc/mpc5566evb
> - value: 5643
> variants:
> - - powerpc/mpc5643l.*
> + - powerpc/mpc5643l_evb
> - value: 5668
> variants:
> - value: 5674
> variants:
> description: |
> specifies the chip type in use (e.g. 5554 for MPC5554)
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optclkemios.yml b/spec/build/bsps/powerpc/mpc55xxevb/optclkemios.yml
> index e60b33217e..d7cf9b927d 100644
> --- a/spec/build/bsps/powerpc/mpc55xxevb/optclkemios.yml
> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optclkemios.yml
> @@ -9,13 +9,13 @@ default: 23
> default-by-variant:
> - value: null
> variants:
> - value: null
> variants:
> - value: 31
> variants:
> description: |
> selects the eMIOS channel for the RTEMS system tick (the default is the last channel)
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optclkpit.yml b/spec/build/bsps/powerpc/mpc55xxevb/optclkpit.yml
> index 3edac8e3f0..9ae42801cb 100644
> --- a/spec/build/bsps/powerpc/mpc55xxevb/optclkpit.yml
> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optclkpit.yml
> @@ -9,10 +9,10 @@ default: null
> default-by-variant:
> - value: 3
> variants:
> - value: 8
> variants:
> description: |
> selects the PIT channel for the RTEMS system tick (the default is the last channel)
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optemiosprescal.yml b/spec/build/bsps/powerpc/mpc55xxevb/optemiosprescal.yml
> index 78bc00dff8..931b97e56d 100644
> --- a/spec/build/bsps/powerpc/mpc55xxevb/optemiosprescal.yml
> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optemiosprescal.yml
> @@ -12,7 +12,7 @@ default-by-variant:
> - powerpc/gwlcfm
> - value: null
> variants:
> description: |
> Must be defined to set the EMIOS prescaler
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optfmpllprediv.yml b/spec/build/bsps/powerpc/mpc55xxevb/optfmpllprediv.yml
> index fe81e18515..84df5a1dad 100644
> --- a/spec/build/bsps/powerpc/mpc55xxevb/optfmpllprediv.yml
> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optfmpllprediv.yml
> - powerpc/gwlcfm
> - value: 6
> variants:
> - value: 5
> variants:
> description: |
> Must be defined to be the PLL predivider factor for clock generation
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optirqtblsz.yml b/spec/build/bsps/powerpc/mpc55xxevb/optirqtblsz.yml
> index 70b5fd0f25..a5f7417674 100644
> --- a/spec/build/bsps/powerpc/mpc55xxevb/optirqtblsz.yml
> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optirqtblsz.yml
> @@ -9,13 +9,13 @@ default: 63
> default-by-variant:
> - value: 127
> variants:
> - value: 127
> variants:
> - value: 255
> variants:
> description: |
> defines the maximum number of interrupt handlers
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optlowinit.yml b/spec/build/bsps/powerpc/mpc55xxevb/optlowinit.yml
> index 615b68cdf9..232b759bf8 100644
> --- a/spec/build/bsps/powerpc/mpc55xxevb/optlowinit.yml
> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optlowinit.yml
> @@ -8,8 +8,7 @@ copyrights:
> default: true
> default-by-variant:
> - value: false
> - variants:
> - - powerpc/mpc5674f_.*app
> + variants: []
> description: |
> if defined, do low level initialization
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optmpc5566evb.yml b/spec/build/bsps/powerpc/mpc55xxevb/optmpc5566evb.yml
> index 46d39d959d..cc549ede34 100644
> --- a/spec/build/bsps/powerpc/mpc55xxevb/optmpc5566evb.yml
> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optmpc5566evb.yml
> default-by-variant:
> - value: true
> variants:
> - - powerpc/mpc5566evb.*
> description: |
> if defined, use custom settings for MPC5566EVB board
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optmpc5674fevb.yml b/spec/build/bsps/powerpc/mpc55xxevb/optmpc5674fevb.yml
> index 05679fadb3..83a694c193 100644
> --- a/spec/build/bsps/powerpc/mpc55xxevb/optmpc5674fevb.yml
> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optmpc5674fevb.yml
> default-by-variant:
> - value: true
> variants:
> - - powerpc/mpc5674fevb.*
> description: |
> if defined, use custom settings for MPC5674FEVB board
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optnullprot.yml b/spec/build/bsps/powerpc/mpc55xxevb/optnullprot.yml
> index 27747835fc..0c081ab189 100644
> --- a/spec/build/bsps/powerpc/mpc55xxevb/optnullprot.yml
> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optnullprot.yml
> default-by-variant:
> - value: true
> variants:
> - value: true
> variants:
> description: |
> enable NULL pointer protection
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optrefclk.yml b/spec/build/bsps/powerpc/mpc55xxevb/optrefclk.yml
> index 6748954449..8b4fd9a0f0 100644
> --- a/spec/build/bsps/powerpc/mpc55xxevb/optrefclk.yml
> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optrefclk.yml
> @@ -12,13 +12,13 @@ default-by-variant:
> - powerpc/gwlcfm
> - value: 40000000
> variants:
> - - powerpc/mpc5643l_evb.*
> - value: 25000000
> variants:
> - value: 40000000
> variants:
> description: |
> None
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optsmc9218ipinirq.yml b/spec/build/bsps/powerpc/mpc55xxevb/optsmc9218ipinirq.yml
> index 1a339c7e72..cfba195031 100644
> --- a/spec/build/bsps/powerpc/mpc55xxevb/optsmc9218ipinirq.yml
> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optsmc9218ipinirq.yml
> @@ -9,7 +9,7 @@ default: null
> default-by-variant:
> - value: 193
> variants:
> description: |
> IRQ pin for SMSC9218I network interface
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optsmc9218ipinrst.yml b/spec/build/bsps/powerpc/mpc55xxevb/optsmc9218ipinrst.yml
> index 6f8585b6e2..d770ce02ed 100644
> --- a/spec/build/bsps/powerpc/mpc55xxevb/optsmc9218ipinrst.yml
> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optsmc9218ipinrst.yml
> default-by-variant:
> - value: 186
> variants:
> description: |
> reset pin for SMSC9218I network interface
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optsysclk.yml b/spec/build/bsps/powerpc/mpc55xxevb/optsysclk.yml
> index 8edffed6e9..6d4e1554f1 100644
> --- a/spec/build/bsps/powerpc/mpc55xxevb/optsysclk.yml
> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optsysclk.yml
> - powerpc/gwlcfm
> - value: 116000000
> variants:
> - value: 264000000
> variants:
> description: |
> The system clock frequency in Hz.
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optsysclkdiv.yml b/spec/build/bsps/powerpc/mpc55xxevb/optsysclkdiv.yml
> index 739f139e49..293e2ed9a6 100644
> --- a/spec/build/bsps/powerpc/mpc55xxevb/optsysclkdiv.yml
> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optsysclkdiv.yml
> default-by-variant:
> - value: 2
> variants:
> description: |
> system clock divider
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/qoriq/optbucsr.yml b/spec/build/bsps/powerpc/qoriq/optbucsr.yml
> index fe64767307..5b7af9ce5d 100644
> --- a/spec/build/bsps/powerpc/qoriq/optbucsr.yml
> +++ b/spec/build/bsps/powerpc/qoriq/optbucsr.yml
> @@ -9,7 +9,8 @@ default: null
> default-by-variant:
> - value: 20972033
> variants:
> - - powerpc/qoriq_e6500.*
> + - powerpc/qoriq_e6500_32
> + - powerpc/qoriq_e6500_64
> description: |
> initial BUCSR value
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/qoriq/optbusclkdiv.yml b/spec/build/bsps/powerpc/qoriq/optbusclkdiv.yml
> index 217718a1dc..74adc5ae9d 100644
> --- a/spec/build/bsps/powerpc/qoriq/optbusclkdiv.yml
> +++ b/spec/build/bsps/powerpc/qoriq/optbusclkdiv.yml
> default-by-variant:
> - value: 2
> variants:
> description: |
> divider of the platform clock to get the clock most on-chip peripherals
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/qoriq/optcachealign.yml b/spec/build/bsps/powerpc/qoriq/optcachealign.yml
> index 77e30c86c7..80423556e9 100644
> --- a/spec/build/bsps/powerpc/qoriq/optcachealign.yml
> +++ b/spec/build/bsps/powerpc/qoriq/optcachealign.yml
> default-by-variant:
> - value: 64
> variants:
> description: |
> the cache alignment
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/qoriq/optcachedatal2sz.yml b/spec/build/bsps/powerpc/qoriq/optcachedatal2sz.yml
> index ef4ee635ef..28566edad9 100644
> --- a/spec/build/bsps/powerpc/qoriq/optcachedatal2sz.yml
> +++ b/spec/build/bsps/powerpc/qoriq/optcachedatal2sz.yml
> @@ -9,7 +9,8 @@ default: 262144
> default-by-variant:
> - value: 2097152
> variants:
> description: |
> the L2 data cache size
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/qoriq/optcacheinstl2sz.yml b/spec/build/bsps/powerpc/qoriq/optcacheinstl2sz.yml
> index 133941ff7b..ea16d60a8b 100644
> --- a/spec/build/bsps/powerpc/qoriq/optcacheinstl2sz.yml
> +++ b/spec/build/bsps/powerpc/qoriq/optcacheinstl2sz.yml
> default-by-variant:
> - value: 2097152
> variants:
> description: |
> the L2 instruction cache size
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/qoriq/optchipnum.yml b/spec/build/bsps/powerpc/qoriq/optchipnum.yml
> index f8bb14166f..6e465ac41b 100644
> --- a/spec/build/bsps/powerpc/qoriq/optchipnum.yml
> +++ b/spec/build/bsps/powerpc/qoriq/optchipnum.yml
> @@ -9,7 +9,8 @@ default: 1020
> default-by-variant:
> - value: 0
> variants:
> description: |
> chip number, e.g. 1020, 2040, 2080, 4240
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/qoriq/optchipser.yml b/spec/build/bsps/powerpc/qoriq/optchipser.yml
> index c566b49761..29c0c01d6f 100644
> --- a/spec/build/bsps/powerpc/qoriq/optchipser.yml
> +++ b/spec/build/bsps/powerpc/qoriq/optchipser.yml
> @@ -9,7 +9,8 @@ default: P
> default-by-variant:
> - value: T
> variants:
> description: |
> chip series, e.g. 'P' or 'T'
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/qoriq/optcpucnt.yml b/spec/build/bsps/powerpc/qoriq/optcpucnt.yml
> index db805547e2..61b2048edc 100644
> --- a/spec/build/bsps/powerpc/qoriq/optcpucnt.yml
> +++ b/spec/build/bsps/powerpc/qoriq/optcpucnt.yml
> default-by-variant:
> - value: 24
> variants:
> description: |
> maximum virtual processor count
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/qoriq/opthid0.yml b/spec/build/bsps/powerpc/qoriq/opthid0.yml
> index c0b1a56346..cdc6b51e95 100644
> --- a/spec/build/bsps/powerpc/qoriq/opthid0.yml
> +++ b/spec/build/bsps/powerpc/qoriq/opthid0.yml
> default-by-variant:
> - value: 1073741824
> variants:
> description: |
> initial HID0 value (EN_L2MMU_MHD is set by default on the T-series)
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/qoriq/opthyp.yml b/spec/build/bsps/powerpc/qoriq/opthyp.yml
> index ccb383c8b5..39901fed5d 100644
> --- a/spec/build/bsps/powerpc/qoriq/opthyp.yml
> +++ b/spec/build/bsps/powerpc/qoriq/opthyp.yml
> default-by-variant:
> - value: true
> variants:
> description: |
> defined if the processor core has a hypervisor mode
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/qoriq/optmas7.yml b/spec/build/bsps/powerpc/qoriq/optmas7.yml
> index 77ed473263..debecaad28 100644
> --- a/spec/build/bsps/powerpc/qoriq/optmas7.yml
> +++ b/spec/build/bsps/powerpc/qoriq/optmas7.yml
> @@ -9,7 +9,8 @@ default: 0
> default-by-variant:
> - value: 15
> variants:
> description: |
> MAS7 value for device TLB1 entries
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/qoriq/optmsr.yml b/spec/build/bsps/powerpc/qoriq/optmsr.yml
> index 5327f63c6f..8bf6f8c75f 100644
> --- a/spec/build/bsps/powerpc/qoriq/optmsr.yml
> +++ b/spec/build/bsps/powerpc/qoriq/optmsr.yml
> @@ -9,10 +9,10 @@ default: 33554944
> default-by-variant:
> - value: 2181046784
> variants:
> - - powerpc/qoriq_e6500_64.*
> - value: 33563136
> variants:
> - - powerpc/qoriq_e6500_32.*
> description: |
> initial MSR value
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/qoriq/optspefscr.yml b/spec/build/bsps/powerpc/qoriq/optspefscr.yml
> index 820eef00ec..497f91eae3 100644
> --- a/spec/build/bsps/powerpc/qoriq/optspefscr.yml
> +++ b/spec/build/bsps/powerpc/qoriq/optspefscr.yml
> default-by-variant:
> - value: null
> variants:
> description: |
> initial SPEFSCR value
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/qoriq/optthrdcnt.yml b/spec/build/bsps/powerpc/qoriq/optthrdcnt.yml
> index 5a2b67bf5c..9fca5dc401 100644
> --- a/spec/build/bsps/powerpc/qoriq/optthrdcnt.yml
> +++ b/spec/build/bsps/powerpc/qoriq/optthrdcnt.yml
> default-by-variant:
> - value: 2
> variants:
> description: |
> the number of threads per core
> enabled-by: true
> diff --git a/spec/build/bsps/powerpc/qoriq/opttlb1cnt.yml b/spec/build/bsps/powerpc/qoriq/opttlb1cnt.yml
> index 4b9ed660b7..ac123ecb0c 100644
> --- a/spec/build/bsps/powerpc/qoriq/opttlb1cnt.yml
> +++ b/spec/build/bsps/powerpc/qoriq/opttlb1cnt.yml
> @@ -9,7 +9,8 @@ default: 16
> default-by-variant:
> - value: 64
> variants:
> description: |
> TLB1 entry count
> enabled-by: true
> diff --git a/spec/build/bsps/riscv/noel/abi.yml b/spec/build/bsps/riscv/noel/abi.yml
> index f81e0c1a60..558ba70c95 100644
> --- a/spec/build/bsps/riscv/noel/abi.yml
> +++ b/spec/build/bsps/riscv/noel/abi.yml
> @@ -28,8 +28,7 @@ default-by-variant:
> - value:
> - -march=rv64im
> - -mabi=lp64
> - variants:
> - - riscv/noel64im
> + variants: []
> - value:
> - -march=rv32imafd
> - -mabi=ilp32d
> diff --git a/spec/build/bsps/riscv/optextirqmax.yml b/spec/build/bsps/riscv/optextirqmax.yml
> index 20b05b4aaf..eddb0a78d5 100644
> --- a/spec/build/bsps/riscv/optextirqmax.yml
> +++ b/spec/build/bsps/riscv/optextirqmax.yml
> @@ -9,7 +9,7 @@ default: 128
> default-by-variant:
> - value: 187
> variants:
> - - riscv/mpfs64.*
> description: |
> maximum number of external interrupts supported by the BSP (default 128)
> enabled-by: true
> diff --git a/spec/build/bsps/riscv/optrambegin.yml b/spec/build/bsps/riscv/optrambegin.yml
> index 8890334915..047c25d66d 100644
> --- a/spec/build/bsps/riscv/optrambegin.yml
> +++ b/spec/build/bsps/riscv/optrambegin.yml
> @@ -12,13 +12,17 @@ default: 2147483648
> default-by-variant:
> - value: 0
> variants:
> - - riscv/noel.*
> + - riscv/noel32im
> + - riscv/noel32imafd
> + - riscv/noel64imac
> + - riscv/noel64imafd
> + - riscv/noel64imafdc
> - value: 1073741824
> variants:
> - riscv/griscv
> - value: 68719476736
> variants:
> - - riscv/mpfs64.*
> description: ''
> enabled-by: true
> format: '{:#010x}'
> diff --git a/spec/build/bsps/riscv/optramsize.yml b/spec/build/bsps/riscv/optramsize.yml
> index 316cc906de..3e123fc650 100644
> --- a/spec/build/bsps/riscv/optramsize.yml
> +++ b/spec/build/bsps/riscv/optramsize.yml
> @@ -18,7 +18,7 @@ default-by-variant:
> - riscv/griscv
> - value: 268435456
> variants:
> - - riscv/mpfs64.*
> description: ''
> enabled-by: true
> format: '{:#010x}'
> diff --git a/spec/build/bsps/riscv/riscv/optfrdme310arty.yml b/spec/build/bsps/riscv/riscv/optfrdme310arty.yml
> index 0623694cca..4bb43a9a18 100644
> --- a/spec/build/bsps/riscv/riscv/optfrdme310arty.yml
> +++ b/spec/build/bsps/riscv/riscv/optfrdme310arty.yml
> default-by-variant:
> - value: true
> variants:
> - - riscv/frdme310arty.*
> + - riscv/frdme310arty
> description: |
> enables support sifive Freedom E310 Arty board if defined to a non-zero value,otherwise it is disabled (disabled by default)
> enabled-by: true
> diff --git a/spec/build/bsps/riscv/riscv/optmpfs.yml b/spec/build/bsps/riscv/riscv/optmpfs.yml
> index 17614567e3..2b734c203b 100644
> --- a/spec/build/bsps/riscv/riscv/optmpfs.yml
> +++ b/spec/build/bsps/riscv/riscv/optmpfs.yml
> default-by-variant:
> - value: true
> variants:
> - - riscv/mpfs64.*
> description: |
> enables support Microchip PolarFire SoC if defined to a non-zero value,otherwise it is disabled (disabled by default)
> enabled-by: true
> diff --git a/spec/build/bsps/riscv/riscv/optns16550max.yml b/spec/build/bsps/riscv/riscv/optns16550max.yml
> index 66189cfdfd..41a23ee10d 100644
> --- a/spec/build/bsps/riscv/riscv/optns16550max.yml
> +++ b/spec/build/bsps/riscv/riscv/optns16550max.yml
> @@ -9,10 +9,10 @@ default: 2
> default-by-variant:
> - value: null
> variants:
> - value: 1
> variants:
> - - riscv/mpfs64.*
> description: |
> maximum number of NS16550 devices supported by the console driver (2 by default)
> enabled-by: true
> diff --git a/spec/build/cpukit/optarchbits.yml b/spec/build/cpukit/optarchbits.yml
> index 0ec4a9fe7e..ba8d52aa61 100644
> --- a/spec/build/cpukit/optarchbits.yml
> +++ b/spec/build/cpukit/optarchbits.yml
> @@ -11,15 +11,26 @@ default-by-variant:
> - value:
> - '64'
> variants:
> - - riscv/mpfs64.*
> - - riscv/noel64.*
> - - riscv/rv64.*
> + - riscv/rv64imac
> + - riscv/rv64imafd
> + - riscv/rv64imafdc
> - value:
> - '32'
> variants:
> - riscv/griscv
> - - riscv/noel32.*
> - - riscv/rv32.*
> + - riscv/noel32im
> + - riscv/rv32i
> + - riscv/rv32iac
> + - riscv/rv32im
> + - riscv/rv32imac
> + - riscv/rv32imafc
> + - riscv/rv32imafd
> + - riscv/rv32imafdc
> description: The architecture word bits for the clang target triple.
> enabled-by:
> - and:
> diff --git a/spec/build/cpukit/optboothartid.yml b/spec/build/cpukit/optboothartid.yml
> index f6cf6da6d4..e23154d4b4 100644
> --- a/spec/build/cpukit/optboothartid.yml
> +++ b/spec/build/cpukit/optboothartid.yml
> @@ -9,7 +9,7 @@ default: 0
> default-by-variant:
> - value: 1
> variants:
> - - riscv/mpfs64.*
> description: |
> boot hartid (processor number) of risc-v cpu (default 0)
> enabled-by: riscv
