[PATCH 2/3] build: Replace variant patterns with a list
Wed Jan 18 07:00:31 UTC 2023
On 18.01.23 04:59, Chris Johns wrote:
> Hi Sebastian,
> I had not got to this part of the patch set because the other was being
> discussed. I thought a patch set was considerd as a whole rather than having to
> deal with the extra complexity of possible splits and if they exist? If this was
> pull request or merge request in a tool none of this patch set would have been
> applied unless split into separate merge reguests. :)
Sorry, I thought you were already finished with the patch set. Maybe we
should move the patch review to pull requests.
> Why has this been done?
The enabled-by expressions used in patch 3 do not support regular
expressions.
> Why the noise in the patch of only lines being moved? Where has this come from?
> Is there a new requirement spec fields be in some osrt of order?
I did the change with a script which sorted the lists. In general, the
lists should be sorted.
> Thanks
> Chris
> On 12/1/2023 11:03 pm, Sebastian Huber wrote:
>> Replace the variant patterns in the default-by-variant list with an
>> explicit list of matching BSPs.
>> The change was tested by comparing the output of
>>    ./waf bspdefaults
>> before and after the change.
> The change message does not explain the line movements.
> Chris
>>   .../bsps/aarch64/xilinx-zynqmp/optclki2c0.yml |  8 +++----
>>   .../bsps/aarch64/xilinx-zynqmp/optclki2c1.yml |  8 +++----
>>   .../bsps/aarch64/xilinx-zynqmp/optclkuart.yml |  7 +++++--
>>   .../bsps/aarch64/xilinx-zynqmp/optloadoff.yml |  2 +-
>>   .../bsps/aarch64/xilinx-zynqmp/optramori.yml  |  2 +-
>>   .../arm/altera-cyclone-v/optclkfastidle.yml   |  4 +++-
>>   spec/build/bsps/arm/beagle/optam335x.yml      |  3 ++-
>>   spec/build/bsps/arm/beagle/optdebug.yml       |  3 ++-
>>   spec/build/bsps/arm/beagle/optdm3730.yml      |  3 ++-
>>   spec/build/bsps/arm/imx/optcachedata.yml      |  4 +++-
>>   spec/build/bsps/arm/imx/optcacheinst.yml      |  4 +++-
>>   spec/build/bsps/arm/lm3s69xx/optgpioahb.yml   |  4 ++--
>>   spec/build/bsps/arm/lm3s69xx/optgpionum.yml   |  7 ++++---
>>   spec/build/bsps/arm/lm3s69xx/optlm3s3749.yml  |  2 +-
>>   spec/build/bsps/arm/lm3s69xx/optlm3s6965.yml  |  3 ++-
>>   spec/build/bsps/arm/lm3s69xx/optlm4f120.yml   |  2 +-
>>   spec/build/bsps/arm/lm3s69xx/optssiblks.yml   |  7 ++++---
>>   spec/build/bsps/arm/lm3s69xx/optsysclk.yml    |  6 ++++--
>>   spec/build/bsps/arm/lm3s69xx/optudma.yml      |  4 ++--
>>   spec/build/bsps/arm/lm3s69xx/optxtalcfg.yml   |  7 ++++---
>>   spec/build/bsps/arm/lpc24xx/optcclk.yml       | 12 +++++++----
>>   spec/build/bsps/arm/lpc24xx/optdmachn.yml     | 11 ++++++++--
>>   spec/build/bsps/arm/lpc24xx/optemcclkdiv.yml  |  6 ++++--
>>   .../bsps/arm/lpc24xx/optemcis42s32800b.yml    |  4 ++--
>>   .../bsps/arm/lpc24xx/optemcis42s32800d7.yml   |  3 ++-
>>   .../build/bsps/arm/lpc24xx/optemcm29w160e.yml |  3 ++-
>>   .../bsps/arm/lpc24xx/optemcm29w320e70.yml     |  3 ++-
>>   .../bsps/arm/lpc24xx/optemcmt48lc4m16a2.yml   |  3 ++-
>>   spec/build/bsps/arm/lpc24xx/optethrmii.yml    |  5 ++++-
>>   spec/build/bsps/arm/lpc24xx/optheapext.yml    |  3 ++-
>>   spec/build/bsps/arm/lpc24xx/optoscmain.yml    |  3 ++-
>>   spec/build/bsps/arm/lpc24xx/optotgi2c.yml     |  6 ++++--
>>   spec/build/bsps/arm/lpc24xx/optpclkdiv.yml    |  6 ++++--
>>   spec/build/bsps/arm/lpc24xx/optstopeth.yml    |  3 ++-
>>   spec/build/bsps/arm/lpc24xx/optstopusb.yml    |  3 ++-
>>   spec/build/bsps/arm/lpc24xx/optuart1cfg.yml   |  5 ++++-
>>   spec/build/bsps/arm/lpc24xx/optuart2cfg.yml   | 12 ++++++++---
>>   spec/build/bsps/arm/lpc24xx/optuart3cfg.yml   |  7 +++++--
>>   spec/build/bsps/arm/lpc32xx/optotgi2c.yml     |  4 +++-
>>   spec/build/bsps/arm/lpc32xx/optotgvbus.yml    |  4 +++-
>>   spec/build/bsps/arm/lpc32xx/optscratchsz.yml  |  4 +++-
>>   .../bsps/arm/realview-pbx-a9/optcachedata.yml |  4 +++-
>>   .../bsps/arm/realview-pbx-a9/optcacheinst.yml |  4 +++-
>>   .../arm/realview-pbx-a9/optclkbootcpu.yml     |  4 +++-
>>   .../arm/realview-pbx-a9/optclkfastidle.yml    |  4 +++-
>>   spec/build/bsps/arm/stm32f4/opteni2c1.yml     |  2 +-
>>   spec/build/bsps/arm/stm32f4/optf10xxx.yml     |  2 +-
>>   spec/build/bsps/arm/stm32f4/optf4xxxx.yml     |  2 +-
>>   spec/build/bsps/arm/stm32f4/opthclk.yml       |  2 +-
>>   spec/build/bsps/arm/stm32f4/optpclk1.yml      |  2 +-
>>   spec/build/bsps/arm/stm32f4/optpclk2.yml      |  2 +-
>>   spec/build/bsps/arm/stm32f4/optsysclk.yml     |  2 +-
>>   spec/build/bsps/arm/stm32h7/abi.yml           |  2 +-
>>   spec/build/bsps/arm/stm32h7/optbootcore.yml   |  4 ++--
>>   spec/build/bsps/arm/stm32h7/optenuart4.yml    |  4 ++--
>>   spec/build/bsps/arm/stm32h7/optenuart5.yml    |  6 +++---
>>   spec/build/bsps/arm/stm32h7/optenuart7.yml    |  6 +++---
>>   spec/build/bsps/arm/stm32h7/optenuart8.yml    |  2 +-
>>   spec/build/bsps/arm/stm32h7/optenuart9.yml    |  6 +++---
>>   spec/build/bsps/arm/stm32h7/optenusart10.yml  |  6 +++---
>>   spec/build/bsps/arm/stm32h7/optenusart3.yml   |  6 +++---
>>   spec/build/bsps/arm/stm32h7/optenusart6.yml   |  6 +++---
>>   spec/build/bsps/arm/stm32h7/optlinkcmds.yml   |  8 +++----
>>   .../bsps/arm/stm32h7/optmemflashorigin.yml    |  2 +-
>>   spec/build/bsps/arm/stm32h7/optmemflashsz.yml |  2 +-
>>   .../build/bsps/arm/stm32h7/optmemsdram1sz.yml |  8 +++----
>>   .../build/bsps/arm/stm32h7/optmemsdram2sz.yml |  4 ++--
>>   spec/build/bsps/arm/stm32h7/optpwrsupply.yml  |  6 +++---
>>   .../arm/stm32h7/optusart1alternatefunc.yml    |  2 +-
>>   .../bsps/arm/stm32h7/optusart1gpiopins.yml    |  2 +-
>>   .../bsps/arm/stm32h7/optusart1gpioregs.yml    |  2 +-
>>   .../bsps/arm/xilinx-zynq/opta9periphclk.yml   |  4 ++--
>>   .../bsps/arm/xilinx-zynq/optcachedata.yml     |  4 +++-
>>   .../bsps/arm/xilinx-zynq/optcacheinst.yml     |  4 +++-
>>   .../bsps/arm/xilinx-zynq/optclkcpu1x.yml      |  4 ++--
>>   .../bsps/arm/xilinx-zynq/optclkfastidle.yml   |  4 +++-
>>   .../build/bsps/arm/xilinx-zynq/optclkuart.yml |  4 ++--
>>   .../bsps/arm/xilinx-zynqmp/optcachedata.yml   |  4 +++-
>>   .../bsps/arm/xilinx-zynqmp/optcacheinst.yml   |  4 +++-
>>   .../bsps/arm/xilinx-zynqmp/optclkfastidle.yml |  4 +++-
>>   .../bsps/arm/xilinx-zynqmp/optclkuart.yml     |  2 +-
>>   .../build/bsps/dev/irq/optarmgic-icc-bpr0.yml | 14 ++++++++++++-
>>   .../bsps/dev/irq/optarmgic-icc-igrpen0.yml    | 14 ++++++++++++-
>>   .../microblaze/microblaze_fpga/optramlen.yml  |  3 ++-
>>   spec/build/bsps/optcachedata.yml              | 15 ++++++++++++-
>>   spec/build/bsps/optcacheinst.yml              | 15 ++++++++++++-
>>   spec/build/bsps/optclkbootcpu.yml             | 15 ++++++++++++-
>>   spec/build/bsps/optclkfastidle.yml            | 15 ++++++++++++-
>>   spec/build/bsps/optconsolebaud.yml            |  2 +-
>>   spec/build/bsps/optdtb.yml                    |  2 +-
>>   spec/build/bsps/optdtbheaderpath.yml          |  2 +-
>>   spec/build/bsps/optxilsupportpath.yml         |  2 +-
>>   spec/build/bsps/powerpc/gen5200/optuboot.yml  |  3 ++-
>>   .../bsps/powerpc/motorola_powerpc/optqemu.yml |  3 ++-
>>   .../bsps/powerpc/mpc55xxevb/ofmpllptmfd.yml   |  4 ++--
>>   .../bsps/powerpc/mpc55xxevb/optchiptype.yml   |  8 +++----
>>   .../bsps/powerpc/mpc55xxevb/optclkemios.yml   |  6 +++---
>>   .../bsps/powerpc/mpc55xxevb/optclkpit.yml     |  4 ++--
>>   .../powerpc/mpc55xxevb/optemiosprescal.yml    |  2 +-
>>   .../powerpc/mpc55xxevb/optfmpllprediv.yml     |  4 ++--
>>   .../bsps/powerpc/mpc55xxevb/optirqtblsz.yml   |  6 +++---
>>   .../bsps/powerpc/mpc55xxevb/optlowinit.yml    |  3 +--
>>   .../bsps/powerpc/mpc55xxevb/optmpc5566evb.yml |  2 +-
>>   .../powerpc/mpc55xxevb/optmpc5674fevb.yml     |  2 +-
>>   .../bsps/powerpc/mpc55xxevb/optnullprot.yml   |  4 ++--
>>   .../bsps/powerpc/mpc55xxevb/optrefclk.yml     |  6 +++---
>>   .../powerpc/mpc55xxevb/optsmc9218ipinirq.yml  |  2 +-
>>   .../powerpc/mpc55xxevb/optsmc9218ipinrst.yml  |  2 +-
>>   .../bsps/powerpc/mpc55xxevb/optsysclk.yml     |  4 ++--
>>   .../bsps/powerpc/mpc55xxevb/optsysclkdiv.yml  |  2 +-
>>   spec/build/bsps/powerpc/qoriq/optbucsr.yml    |  3 ++-
>>   .../build/bsps/powerpc/qoriq/optbusclkdiv.yml |  3 ++-
>>   .../bsps/powerpc/qoriq/optcachealign.yml      |  3 ++-
>>   .../bsps/powerpc/qoriq/optcachedatal2sz.yml   |  3 ++-
>>   .../bsps/powerpc/qoriq/optcacheinstl2sz.yml   |  3 ++-
>>   spec/build/bsps/powerpc/qoriq/optchipnum.yml  |  3 ++-
>>   spec/build/bsps/powerpc/qoriq/optchipser.yml  |  3 ++-
>>   spec/build/bsps/powerpc/qoriq/optcpucnt.yml   |  3 ++-
>>   spec/build/bsps/powerpc/qoriq/opthid0.yml     |  3 ++-
>>   spec/build/bsps/powerpc/qoriq/opthyp.yml      |  3 ++-
>>   spec/build/bsps/powerpc/qoriq/optmas7.yml     |  3 ++-
>>   spec/build/bsps/powerpc/qoriq/optmsr.yml      |  4 ++--
>>   spec/build/bsps/powerpc/qoriq/optspefscr.yml  |  3 ++-
>>   spec/build/bsps/powerpc/qoriq/optthrdcnt.yml  |  3 ++-
>>   spec/build/bsps/powerpc/qoriq/opttlb1cnt.yml  |  3 ++-
>>   spec/build/bsps/riscv/noel/abi.yml            |  3 +--
>>   spec/build/bsps/riscv/optextirqmax.yml        |  2 +-
>>   spec/build/bsps/riscv/optrambegin.yml         |  8 +++++--
>>   spec/build/bsps/riscv/optramsize.yml          |  2 +-
>>   .../bsps/riscv/riscv/optfrdme310arty.yml      |  2 +-
>>   spec/build/bsps/riscv/riscv/optmpfs.yml       |  2 +-
>>   spec/build/bsps/riscv/riscv/optns16550max.yml |  4 ++--
>>   spec/build/cpukit/optarchbits.yml             | 21 ++++++++++++++-----
>>   spec/build/cpukit/optboothartid.yml           |  2 +-
>>   134 files changed, 400 insertions(+), 210 deletions(-)
>> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c0.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c0.yml
>> index 98a2222353..1005594abe 100644
>> --- a/spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c0.yml
>> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c0.yml
>> @@ -10,16 +10,16 @@ default: 111111111
>>   default-by-variant:
>>   - value: 111111111
>>     variants:
>> -  - aarch64/xilinx_zynqmp_ilp32_qemu.*
>> +  - aarch64/xilinx_zynqmp_ilp32_qemu
>>   - value: 111111111
>>     variants:
>> -  - aarch64/xilinx_zynqmp_ilp32_zu3eg.*
>> +  - aarch64/xilinx_zynqmp_ilp32_zu3eg
>>   - value: 111111111
>>     variants:
>> -  - aarch64/xilinx_zynqmp_lp64_qemu.*
>> +  - aarch64/xilinx_zynqmp_lp64_qemu
>>   - value: 111111111
>>     variants:
>> -  - aarch64/xilinx_zynqmp_lp64_zu3eg.*
>> +  - aarch64/xilinx_zynqmp_lp64_zu3eg
>>   description: |
>>     ZynqMP i2c0 clock frequency in Hz. This is the frequency after the signal
>>     has been processed using the values passed to the I2C0_REF_CTRL register.
>> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c1.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c1.yml
>> index 6fe6c18dfa..f1b26578e0 100644
>> --- a/spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c1.yml
>> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c1.yml
>>   default-by-variant:
>>   - value: 111111111
>>     variants:
>>   - value: 111111111
>>     variants:
>>   - value: 111111111
>>     variants:
>>   - value: 111111111
>>     variants:
>>   description: |
>>     ZynqMP i2c1 clock frequency in Hz. This is the frequency after the signal
>>     has been processed using the values passed to the I2C1_REF_CTRL register.
>> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optclkuart.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optclkuart.yml
>> index d663d6f640..24f232e711 100644
>> --- a/spec/build/bsps/aarch64/xilinx-zynqmp/optclkuart.yml
>> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optclkuart.yml
>> @@ -9,8 +9,11 @@ default: 100000000
>>   default-by-variant:
>>   - value: 100000000
>>     variants:
>> -  - aarch64/xilinx_zynqmp_ilp32.*
>> -  - aarch64/xilinx_zynqmp_lp64.*
>> +  - aarch64/xilinx_zynqmp_lp64_cfc400x
>>   description: |
>>     Zynq UART clock frequency in Hz
>>   enabled-by: true
>> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
>> index 6a7c0f2acf..2f9d8b1ffc 100644
>> --- a/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
>> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
>> @@ -11,9 +11,9 @@ default: 32768
>>   default-by-variant:
>>   - value: 0
>>     variants:
>>   description: |
>>     offset of RAM region from memory area base
>>   enabled-by: true
>> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
>> index e3a171ab65..449303fcdf 100644
>> --- a/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
>> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
>> @@ -11,9 +11,9 @@ default: 1073840128
>>   default-by-variant:
>>   - value: 268435456
>>     variants:
>>   description: |
>>     base address of memory area available to the BSP
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/altera-cyclone-v/optclkfastidle.yml b/spec/build/bsps/arm/altera-cyclone-v/optclkfastidle.yml
>> index b800b20428..61333a11f1 100644
>> --- a/spec/build/bsps/arm/altera-cyclone-v/optclkfastidle.yml
>> +++ b/spec/build/bsps/arm/altera-cyclone-v/optclkfastidle.yml
>> @@ -9,7 +9,9 @@ default: false
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - arm/.*qemu
>> +  - arm/lm3s6965_qemu
>> +  - arm/realview_pbx_a9_qemu
>> +  - arm/xilinx_zynq_a9_qemu
>>   description: |
>>     This sets a mode where the time runs as fast as possible when a clock ISR occurs while the IDLE thread is executing.  This can significantly reduce simulation times.
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/beagle/optam335x.yml b/spec/build/bsps/arm/beagle/optam335x.yml
>> index 2453aae088..6641cef403 100644
>> --- a/spec/build/bsps/arm/beagle/optam335x.yml
>> +++ b/spec/build/bsps/arm/beagle/optam335x.yml
>> @@ -9,7 +9,8 @@ default: false
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - arm/beaglebone.*
>> +  - arm/beagleboneblack
>> +  - arm/beaglebonewhite
>>   description: |
>>     true if SOC is AM335X
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/beagle/optdebug.yml b/spec/build/bsps/arm/beagle/optdebug.yml
>> index 54f6c55f9a..8a5dc7ee96 100644
>> --- a/spec/build/bsps/arm/beagle/optdebug.yml
>> +++ b/spec/build/bsps/arm/beagle/optdebug.yml
>>   default-by-variant:
>>   - value: false
>>     variants:
>>   description: |
>>     Enable BBB debug
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/beagle/optdm3730.yml b/spec/build/bsps/arm/beagle/optdm3730.yml
>> index 3dd60260f3..4161ee29f1 100644
>> --- a/spec/build/bsps/arm/beagle/optdm3730.yml
>> +++ b/spec/build/bsps/arm/beagle/optdm3730.yml
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - arm/beagleboard.*
>> +  - arm/beagleboardorig
>> +  - arm/beagleboardxm
>>   description: |
>>     true if SOC is DM3730
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/imx/optcachedata.yml b/spec/build/bsps/arm/imx/optcachedata.yml
>> index 1664b0fc31..23b1410385 100644
>> --- a/spec/build/bsps/arm/imx/optcachedata.yml
>> +++ b/spec/build/bsps/arm/imx/optcachedata.yml
>> @@ -9,7 +9,9 @@ default: true
>>   default-by-variant:
>>   - value: false
>>     variants:
>> -  - arm/.*qemu
>>   description: |
>>     enable data cache
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/imx/optcacheinst.yml b/spec/build/bsps/arm/imx/optcacheinst.yml
>> index b191133af9..f172cc4b58 100644
>> --- a/spec/build/bsps/arm/imx/optcacheinst.yml
>> +++ b/spec/build/bsps/arm/imx/optcacheinst.yml
>>   default-by-variant:
>>   - value: false
>>     variants:
>> -  - arm/.*qemu
>>   description: |
>>     enable instruction cache
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lm3s69xx/optgpioahb.yml b/spec/build/bsps/arm/lm3s69xx/optgpioahb.yml
>> index 5266ec8549..77e1c9219e 100644
>> --- a/spec/build/bsps/arm/lm3s69xx/optgpioahb.yml
>> +++ b/spec/build/bsps/arm/lm3s69xx/optgpioahb.yml
>> @@ -9,10 +9,10 @@ default: false
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - arm/lm3s3749.*
>> +  - arm/lm3s3749
>>   - value: true
>>     variants:
>> -  - arm/lm4f.*
>> +  - arm/lm4f120
>>   description: |
>>     use AHB apperture to access GPIO registers
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lm3s69xx/optgpionum.yml b/spec/build/bsps/arm/lm3s69xx/optgpionum.yml
>> index 05911d140c..bbccdd5a58 100644
>> --- a/spec/build/bsps/arm/lm3s69xx/optgpionum.yml
>> +++ b/spec/build/bsps/arm/lm3s69xx/optgpionum.yml
>> @@ -9,13 +9,14 @@ default: 0
>>   default-by-variant:
>>   - value: 8
>>     variants:
>> -  - arm/lm3s3749.*
>> +  - arm/lm3s3749
>>   - value: 7
>>     variants:
>> -  - arm/lm3s6965.*
>> +  - arm/lm3s6965
>>   - value: 6
>>     variants:
>> -  - arm/lm4f120.*
>> +  - arm/lm4f120
>>   description: |
>>     number of GPIO blocks supported by MCU
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lm3s69xx/optlm3s3749.yml b/spec/build/bsps/arm/lm3s69xx/optlm3s3749.yml
>> index 22199d8d59..9ca33cbe94 100644
>> --- a/spec/build/bsps/arm/lm3s69xx/optlm3s3749.yml
>> +++ b/spec/build/bsps/arm/lm3s69xx/optlm3s3749.yml
>> @@ -9,7 +9,7 @@ default: false
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - arm/lm3s3749.*
>> +  - arm/lm3s3749
>>   description: |
>>     board has LM3S3749 MCU
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lm3s69xx/optlm3s6965.yml b/spec/build/bsps/arm/lm3s69xx/optlm3s6965.yml
>> index be01195f1d..6c11733729 100644
>> --- a/spec/build/bsps/arm/lm3s69xx/optlm3s6965.yml
>> +++ b/spec/build/bsps/arm/lm3s69xx/optlm3s6965.yml
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - arm/lm3s6965.*
>> +  - arm/lm3s6965
>>   description: |
>>     board has LM3S6965 MCU
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lm3s69xx/optlm4f120.yml b/spec/build/bsps/arm/lm3s69xx/optlm4f120.yml
>> index b3c59921b6..af60aee4d6 100644
>> --- a/spec/build/bsps/arm/lm3s69xx/optlm4f120.yml
>> +++ b/spec/build/bsps/arm/lm3s69xx/optlm4f120.yml
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - arm/lm4f120.*
>> +  - arm/lm4f120
>>   description: |
>>     board has LM4F120xxx MCU
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lm3s69xx/optssiblks.yml b/spec/build/bsps/arm/lm3s69xx/optssiblks.yml
>> index 551a27cbf2..3234606781 100644
>> --- a/spec/build/bsps/arm/lm3s69xx/optssiblks.yml
>> +++ b/spec/build/bsps/arm/lm3s69xx/optssiblks.yml
>>   default-by-variant:
>>   - value: 2
>>     variants:
>> -  - arm/lm3s3749.*
>> +  - arm/lm3s3749
>>   - value: 1
>>     variants:
>> -  - arm/lm3s6965.*
>> +  - arm/lm3s6965
>>   - value: 4
>>     variants:
>> -  - arm/lm4f120.*
>> +  - arm/lm4f120
>>   description: |
>>     number of SSI blocks supported by MCU
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lm3s69xx/optsysclk.yml b/spec/build/bsps/arm/lm3s69xx/optsysclk.yml
>> index ffdd8d78c3..14fcbcd84d 100644
>> --- a/spec/build/bsps/arm/lm3s69xx/optsysclk.yml
>> +++ b/spec/build/bsps/arm/lm3s69xx/optsysclk.yml
>> @@ -9,10 +9,12 @@ default: 0
>>   default-by-variant:
>>   - value: 50000000
>>     variants:
>> -  - arm/lm3s.*
>> +  - arm/lm3s3749
>> +  - arm/lm3s6965
>>   - value: 80000000
>>     variants:
>> -  - arm/lm4f.*
>> +  - arm/lm4f120
>>   description: |
>>     system clock in Hz
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lm3s69xx/optudma.yml b/spec/build/bsps/arm/lm3s69xx/optudma.yml
>> index 88aae5094c..9445b273ec 100644
>> --- a/spec/build/bsps/arm/lm3s69xx/optudma.yml
>> +++ b/spec/build/bsps/arm/lm3s69xx/optudma.yml
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - arm/lm3s3749.*
>> +  - arm/lm3s3749
>>   - value: true
>>     variants:
>> -  - arm/lm4f.*
>> +  - arm/lm4f120
>>   description: |
>>     defined if MCU supports UDMA
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lm3s69xx/optxtalcfg.yml b/spec/build/bsps/arm/lm3s69xx/optxtalcfg.yml
>> index d034385cd3..8eebf87000 100644
>> --- a/spec/build/bsps/arm/lm3s69xx/optxtalcfg.yml
>> +++ b/spec/build/bsps/arm/lm3s69xx/optxtalcfg.yml
>>   default-by-variant:
>>   - value: 14
>>     variants:
>> -  - arm/lm3s6965.*
>> +  - arm/lm3s6965
>>   - value: 16
>>     variants:
>> -  - arm/lm3s3749.*
>> +  - arm/lm3s3749
>>   - value: 21
>>     variants:
>> -  - arm/lm4f120.*
>> +  - arm/lm4f120
>>   description: |
>>     crystal configuration for RCC register
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lpc24xx/optcclk.yml b/spec/build/bsps/arm/lpc24xx/optcclk.yml
>> index aacf2192c2..e9700ce101 100644
>> --- a/spec/build/bsps/arm/lpc24xx/optcclk.yml
>> +++ b/spec/build/bsps/arm/lpc24xx/optcclk.yml
>> @@ -9,16 +9,20 @@ default: 72000000
>>   default-by-variant:
>>   - value: 96000000
>>     variants:
>> -  - arm/lpc17xx_ea.*
>> +  - arm/lpc17xx_ea_ram
>> +  - arm/lpc17xx_ea_rom_int
>>   - value: 96000000
>>     variants:
>> -  - arm/lpc40xx_ea.*
>> +  - arm/lpc40xx_ea_ram
>> +  - arm/lpc40xx_ea_rom_int
>>   - value: 58982400
>>     variants:
>> -  - arm/lpc23.*
>> +  - arm/lpc2362
>> +  - arm/lpc23xx_tli800
>>   - value: 51612800
>>     variants:
>> -  - arm/lpc24xx_plx800_.*
>> +  - arm/lpc24xx_plx800_ram
>> +  - arm/lpc24xx_plx800_rom_int
>>   description: |
>>     CPU clock in Hz
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lpc24xx/optdmachn.yml b/spec/build/bsps/arm/lpc24xx/optdmachn.yml
>> index 1a67589bfc..f1f57dca60 100644
>> --- a/spec/build/bsps/arm/lpc24xx/optdmachn.yml
>> +++ b/spec/build/bsps/arm/lpc24xx/optdmachn.yml
>> @@ -9,10 +9,17 @@ default: 2
>>   default-by-variant:
>>   - value: 8
>>     variants:
>> -  - arm/lpc17.*
>> +  - arm/lpc1768_mbed
>> +  - arm/lpc1768_mbed_ahb_ram
>> +  - arm/lpc1768_mbed_ahb_ram_eth
>> +  - arm/lpc17xx_plx800_ram
>> +  - arm/lpc17xx_plx800_rom_int
>>   - value: 8
>>     variants:
>> -  - arm/lpc40.*
>>   description: |
>>     DMA channel count
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lpc24xx/optemcclkdiv.yml b/spec/build/bsps/arm/lpc24xx/optemcclkdiv.yml
>> index 8851dadfa7..36ff19f07b 100644
>> --- a/spec/build/bsps/arm/lpc24xx/optemcclkdiv.yml
>> +++ b/spec/build/bsps/arm/lpc24xx/optemcclkdiv.yml
>> @@ -9,10 +9,12 @@ default: 1
>>   default-by-variant:
>>   - value: 2
>>     variants:
>>   - value: 2
>>     variants:
>>   description: |
>>     clock divider for EMCCLK (EMCCLK = CCLK / EMCCLKDIV)
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lpc24xx/optemcis42s32800b.yml b/spec/build/bsps/arm/lpc24xx/optemcis42s32800b.yml
>> index de40eca73a..c6162af143 100644
>> --- a/spec/build/bsps/arm/lpc24xx/optemcis42s32800b.yml
>> +++ b/spec/build/bsps/arm/lpc24xx/optemcis42s32800b.yml
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - arm/lpc17xx_ea_rom_.*
>>   - value: true
>>     variants:
>> -  - arm/lpc40xx_ea_rom_.*
>>   description: |
>>     enable ISSI IS42S32800B configuration for EMC
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lpc24xx/optemcis42s32800d7.yml b/spec/build/bsps/arm/lpc24xx/optemcis42s32800d7.yml
>> index e7ad228709..71d2b38f27 100644
>> --- a/spec/build/bsps/arm/lpc24xx/optemcis42s32800d7.yml
>> +++ b/spec/build/bsps/arm/lpc24xx/optemcis42s32800d7.yml
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - arm/.*_plx800_rom_.*
>>   description: |
>>     enable ISSI IS42S32800D7 configuration for EMC
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lpc24xx/optemcm29w160e.yml b/spec/build/bsps/arm/lpc24xx/optemcm29w160e.yml
>> index 40a4bfbf71..02f233165c 100644
>> --- a/spec/build/bsps/arm/lpc24xx/optemcm29w160e.yml
>> +++ b/spec/build/bsps/arm/lpc24xx/optemcm29w160e.yml
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - arm/lpc24xx_ncs_rom_.*
>> +  - arm/lpc24xx_ncs_rom_ext
>> +  - arm/lpc24xx_ncs_rom_int
>>   description: |
>>     enable M29W160E configuration for EMC
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lpc24xx/optemcm29w320e70.yml b/spec/build/bsps/arm/lpc24xx/optemcm29w320e70.yml
>> index a32c1a3eb6..66aa8c5cad 100644
>> --- a/spec/build/bsps/arm/lpc24xx/optemcm29w320e70.yml
>> +++ b/spec/build/bsps/arm/lpc24xx/optemcm29w320e70.yml
>>   default-by-variant:
>>   - value: true
>>     variants:
>>   description: |
>>     enable M29W320E70 configuration for EMC
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lpc24xx/optemcmt48lc4m16a2.yml b/spec/build/bsps/arm/lpc24xx/optemcmt48lc4m16a2.yml
>> index ab6f25fef8..02b92e0710 100644
>> --- a/spec/build/bsps/arm/lpc24xx/optemcmt48lc4m16a2.yml
>> +++ b/spec/build/bsps/arm/lpc24xx/optemcmt48lc4m16a2.yml
>>   default-by-variant:
>>   - value: true
>>     variants:
>>   description: |
>>     enable Micron MT48LC4M16A2 configuration for EMC
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lpc24xx/optethrmii.yml b/spec/build/bsps/arm/lpc24xx/optethrmii.yml
>> index c7c3627c82..6dc25d0d86 100644
>> --- a/spec/build/bsps/arm/lpc24xx/optethrmii.yml
>> +++ b/spec/build/bsps/arm/lpc24xx/optethrmii.yml
>> @@ -9,7 +9,10 @@ default: false
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - arm/.*_ea_.*
>>   description: |
>>     enable RMII for Ethernet
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lpc24xx/optheapext.yml b/spec/build/bsps/arm/lpc24xx/optheapext.yml
>> index b485eb6cc3..90acde9447 100644
>> --- a/spec/build/bsps/arm/lpc24xx/optheapext.yml
>> +++ b/spec/build/bsps/arm/lpc24xx/optheapext.yml
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - arm/lpc23.*
>> +  - arm/lpc2362
>>   description: |
>>     enable heap extend by Ethernet and USB regions
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lpc24xx/optoscmain.yml b/spec/build/bsps/arm/lpc24xx/optoscmain.yml
>> index ec529345a1..2a483213de 100644
>> --- a/spec/build/bsps/arm/lpc24xx/optoscmain.yml
>> +++ b/spec/build/bsps/arm/lpc24xx/optoscmain.yml
>> @@ -9,7 +9,8 @@ default: 12000000
>>   default-by-variant:
>>   - value: 3686400
>>     variants:
>> -  - arm/lpc23.*
>> +  - arm/lpc2362
>>   description: |
>>     main oscillator frequency in Hz
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lpc24xx/optotgi2c.yml b/spec/build/bsps/arm/lpc24xx/optotgi2c.yml
>> index 4e205cb0af..e92754d99f 100644
>> --- a/spec/build/bsps/arm/lpc24xx/optotgi2c.yml
>> +++ b/spec/build/bsps/arm/lpc24xx/optotgi2c.yml
>>   default-by-variant:
>>   - value: 94
>>     variants:
>>   - value: 94
>>     variants:
>>   description: |
>>     USB OTG transceiver I2C address used by USB stack
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lpc24xx/optpclkdiv.yml b/spec/build/bsps/arm/lpc24xx/optpclkdiv.yml
>> index 296486c78f..bc4984bc3d 100644
>> --- a/spec/build/bsps/arm/lpc24xx/optpclkdiv.yml
>> +++ b/spec/build/bsps/arm/lpc24xx/optpclkdiv.yml
>>   default-by-variant:
>>   - value: 2
>>     variants:
>>   - value: 2
>>     variants:
>>   description: |
>>     clock divider for default PCLK (PCLK = CCLK / PCLKDIV)
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lpc24xx/optstopeth.yml b/spec/build/bsps/arm/lpc24xx/optstopeth.yml
>> index 60f07f9a06..2baf76da8c 100644
>> --- a/spec/build/bsps/arm/lpc24xx/optstopeth.yml
>> +++ b/spec/build/bsps/arm/lpc24xx/optstopeth.yml
>> @@ -9,7 +9,8 @@ default: true
>>   default-by-variant:
>>   - value: false
>>     variants:
>> -  - arm/lpc23.*
>> +  - arm/lpc2362
>>   description: |
>>     stop Ethernet controller at start-up to avoid DMA interference
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lpc24xx/optstopusb.yml b/spec/build/bsps/arm/lpc24xx/optstopusb.yml
>> index 2f2bfc5c93..b895ff7df3 100644
>> --- a/spec/build/bsps/arm/lpc24xx/optstopusb.yml
>> +++ b/spec/build/bsps/arm/lpc24xx/optstopusb.yml
>>   default-by-variant:
>>   - value: false
>>     variants:
>> -  - arm/lpc23.*
>> +  - arm/lpc2362
>>   description: |
>>     stop USB controller at start-up to avoid DMA interference
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lpc24xx/optuart1cfg.yml b/spec/build/bsps/arm/lpc24xx/optuart1cfg.yml
>> index c1f133f08f..055f8bbbee 100644
>> --- a/spec/build/bsps/arm/lpc24xx/optuart1cfg.yml
>> +++ b/spec/build/bsps/arm/lpc24xx/optuart1cfg.yml
>>   default-by-variant:
>>   - value: false
>>     variants:
>> -  - arm/.*_plx800_.*
>>   description: |
>>     configuration for UART 1
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lpc24xx/optuart2cfg.yml b/spec/build/bsps/arm/lpc24xx/optuart2cfg.yml
>> index 3e523147ca..0f9bbad26b 100644
>> --- a/spec/build/bsps/arm/lpc24xx/optuart2cfg.yml
>> +++ b/spec/build/bsps/arm/lpc24xx/optuart2cfg.yml
>> @@ -9,13 +9,19 @@ default: false
>>   default-by-variant:
>>   - value: false
>>     variants:
>> -  - arm/lpc23.*
>> +  - arm/lpc2362
>>   - value: false
>>     variants:
>> -  - arm/lpc24xx_ncs_.*
>> +  - arm/lpc24xx_ncs_ram
>>   - value: false
>>     variants:
>>   description: |
>>     configuration for UART 2
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lpc24xx/optuart3cfg.yml b/spec/build/bsps/arm/lpc24xx/optuart3cfg.yml
>> index 2af84c927d..991be593f3 100644
>> --- a/spec/build/bsps/arm/lpc24xx/optuart3cfg.yml
>> +++ b/spec/build/bsps/arm/lpc24xx/optuart3cfg.yml
>> @@ -9,10 +9,13 @@ default: false
>>   default-by-variant:
>>   - value: false
>>     variants:
>> -  - arm/lpc23.*
>> +  - arm/lpc2362
>>   - value: false
>>     variants:
>>   description: |
>>     configuration for UART 3
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lpc32xx/optotgi2c.yml b/spec/build/bsps/arm/lpc32xx/optotgi2c.yml
>> index 72137d9c27..55119b35cf 100644
>> --- a/spec/build/bsps/arm/lpc32xx/optotgi2c.yml
>> +++ b/spec/build/bsps/arm/lpc32xx/optotgi2c.yml
>> @@ -9,7 +9,9 @@ default: 0
>>   default-by-variant:
>>   - value: 88
>>     variants:
>> -  - arm/lpc32xx_mzx.*
>> +  - arm/lpc32xx_mzx
>> +  - arm/lpc32xx_mzx_stage_1
>> +  - arm/lpc32xx_mzx_stage_2
>>   description: |
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lpc32xx/optotgvbus.yml b/spec/build/bsps/arm/lpc32xx/optotgvbus.yml
>> index 0d9d6b65f5..e5d2563a7b 100644
>> --- a/spec/build/bsps/arm/lpc32xx/optotgvbus.yml
>> +++ b/spec/build/bsps/arm/lpc32xx/optotgvbus.yml
>>   default-by-variant:
>>   - value: USB_OTG_VBUS_POWER_WITH_CHARGE_PUMP
>>     variants:
>> +  - arm/lpc32xx_mzx
>>   description: |
>>     USB OTG transceiver VBUS policy
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/lpc32xx/optscratchsz.yml b/spec/build/bsps/arm/lpc32xx/optscratchsz.yml
>> index c54f1ae7b3..ad8473d57d 100644
>> --- a/spec/build/bsps/arm/lpc32xx/optscratchsz.yml
>> +++ b/spec/build/bsps/arm/lpc32xx/optscratchsz.yml
>>   default-by-variant:
>>   - value: 4096
>>     variants:
>> +  - arm/lpc32xx_mzx
>>   description: |
>>     size of scratch area
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/realview-pbx-a9/optcachedata.yml b/spec/build/bsps/arm/realview-pbx-a9/optcachedata.yml
>> --- a/spec/build/bsps/arm/realview-pbx-a9/optcachedata.yml
>> +++ b/spec/build/bsps/arm/realview-pbx-a9/optcachedata.yml
>>   default-by-variant:
>>   - value: false
>>     variants:
>> -  - arm/.*qemu
>>   description: |
>>     enable data cache
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/realview-pbx-a9/optcacheinst.yml b/spec/build/bsps/arm/realview-pbx-a9/optcacheinst.yml
>> --- a/spec/build/bsps/arm/realview-pbx-a9/optcacheinst.yml
>> +++ b/spec/build/bsps/arm/realview-pbx-a9/optcacheinst.yml
>>   default-by-variant:
>>   - value: false
>>     variants:
>> -  - arm/.*qemu
>>   description: |
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/realview-pbx-a9/optclkbootcpu.yml b/spec/build/bsps/arm/realview-pbx-a9/optclkbootcpu.yml
>> index 8d78c9ce6a..8cca180892 100644
>> --- a/spec/build/bsps/arm/realview-pbx-a9/optclkbootcpu.yml
>> +++ b/spec/build/bsps/arm/realview-pbx-a9/optclkbootcpu.yml
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - arm/.*qemu.*
>>   description: |
>>     If defined, then do the clock tick processing on the boot processor on behalf of all other processors.
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/realview-pbx-a9/optclkfastidle.yml b/spec/build/bsps/arm/realview-pbx-a9/optclkfastidle.yml
>> index e4624223eb..61333a11f1 100644
>> --- a/spec/build/bsps/arm/realview-pbx-a9/optclkfastidle.yml
>> +++ b/spec/build/bsps/arm/realview-pbx-a9/optclkfastidle.yml
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - arm/.*qemu.*
>>   description: |
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/stm32f4/opteni2c1.yml b/spec/build/bsps/arm/stm32f4/opteni2c1.yml
>> index e200c81623..ab8dd78926 100644
>> --- a/spec/build/bsps/arm/stm32f4/opteni2c1.yml
>> +++ b/spec/build/bsps/arm/stm32f4/opteni2c1.yml
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - arm/stm32f1.*
>> +  - arm/stm32f105rc
>>   description: |
>>     enable I2C 1
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/stm32f4/optf10xxx.yml b/spec/build/bsps/arm/stm32f4/optf10xxx.yml
>> index 54f1418cf9..a1cc76ff37 100644
>> --- a/spec/build/bsps/arm/stm32f4/optf10xxx.yml
>> +++ b/spec/build/bsps/arm/stm32f4/optf10xxx.yml
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - arm/stm32f1.*
>> +  - arm/stm32f105rc
>>   description: |
>>     Chip belongs to the STM32F10XXX family.
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/stm32f4/optf4xxxx.yml b/spec/build/bsps/arm/stm32f4/optf4xxxx.yml
>> index 66604f249a..891aacc3c3 100644
>> --- a/spec/build/bsps/arm/stm32f4/optf4xxxx.yml
>> +++ b/spec/build/bsps/arm/stm32f4/optf4xxxx.yml
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - arm/stm32f4.*
>> +  - arm/stm32f4
>>   description: |
>>     Chip belongs to the STM32F4XXXX family.
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/stm32f4/opthclk.yml b/spec/build/bsps/arm/stm32f4/opthclk.yml
>> index 7f315f12b2..b827fffe33 100644
>> --- a/spec/build/bsps/arm/stm32f4/opthclk.yml
>> +++ b/spec/build/bsps/arm/stm32f4/opthclk.yml
>> @@ -9,7 +9,7 @@ default: 16000000
>>   default-by-variant:
>>   - value: 8000000
>>     variants:
>> -  - arm/stm32f1.*
>> +  - arm/stm32f105rc
>>   description: |
>>     HCLK frequency in Hz
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/stm32f4/optpclk1.yml b/spec/build/bsps/arm/stm32f4/optpclk1.yml
>> index 9ac285b0bc..79aafa89a9 100644
>> --- a/spec/build/bsps/arm/stm32f4/optpclk1.yml
>> +++ b/spec/build/bsps/arm/stm32f4/optpclk1.yml
>>   default-by-variant:
>>   - value: 8000000
>>     variants:
>> -  - arm/stm32f1.*
>> +  - arm/stm32f105rc
>>   description: |
>>     PCLK1 frequency in Hz
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/stm32f4/optpclk2.yml b/spec/build/bsps/arm/stm32f4/optpclk2.yml
>> index e51eeaf36f..43ce9f9c04 100644
>> --- a/spec/build/bsps/arm/stm32f4/optpclk2.yml
>> +++ b/spec/build/bsps/arm/stm32f4/optpclk2.yml
>>   default-by-variant:
>>   - value: 8000000
>>     variants:
>> -  - arm/stm32f1.*
>> +  - arm/stm32f105rc
>>   description: |
>>     PCLK2 frequency in Hz
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/stm32f4/optsysclk.yml b/spec/build/bsps/arm/stm32f4/optsysclk.yml
>> index 5f08d4ecde..9dd081d475 100644
>> --- a/spec/build/bsps/arm/stm32f4/optsysclk.yml
>> +++ b/spec/build/bsps/arm/stm32f4/optsysclk.yml
>>   default-by-variant:
>>   - value: 8000000
>>     variants:
>> -  - arm/stm32f1.*
>> +  - arm/stm32f105rc
>>   description: |
>>     SYSCLK frequency in Hz
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/stm32h7/abi.yml b/spec/build/bsps/arm/stm32h7/abi.yml
>> index 1f48596190..27da264d03 100644
>> --- a/spec/build/bsps/arm/stm32h7/abi.yml
>> +++ b/spec/build/bsps/arm/stm32h7/abi.yml
>> @@ -18,8 +18,8 @@ default-by-variant:
>>     - -mfpu=fpv4-sp-d16
>>     - -mfloat-abi=hard
>>     variants:
>> -  - arm/stm32h757i-eval-m4
>>     - arm/stm32h747i-disco-m4
>> +  - arm/stm32h757i-eval-m4
>>   description: |
>>     ABI flags
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/stm32h7/optbootcore.yml b/spec/build/bsps/arm/stm32h7/optbootcore.yml
>> index ad50f8ef77..c248939bbe 100644
>> --- a/spec/build/bsps/arm/stm32h7/optbootcore.yml
>> +++ b/spec/build/bsps/arm/stm32h7/optbootcore.yml
>> @@ -13,12 +13,12 @@ default: BOOT_CORE_DEFINE_NOT_NEEDED
>>   default-by-variant:
>>   - value: CORE_CM7
>>     variants:
>>   - value: CORE_CM4
>>     variants:
>>   description: |
>>     Select the boot core. Possible values are CORE_CM7 and CORE_CM4
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/stm32h7/optenuart4.yml b/spec/build/bsps/arm/stm32h7/optenuart4.yml
>> index ab49af31f9..b95b2372f7 100644
>> --- a/spec/build/bsps/arm/stm32h7/optenuart4.yml
>> +++ b/spec/build/bsps/arm/stm32h7/optenuart4.yml
>> @@ -9,10 +9,10 @@ default: true
>>   default-by-variant:
>>   - value: false
>>     variants:
>>   description: |
>>     Enable UART4 device in console driver.
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/stm32h7/optenuart5.yml b/spec/build/bsps/arm/stm32h7/optenuart5.yml
>> index 502e02c61d..db70f25470 100644
>> --- a/spec/build/bsps/arm/stm32h7/optenuart5.yml
>> +++ b/spec/build/bsps/arm/stm32h7/optenuart5.yml
>> @@ -9,11 +9,11 @@ default: true
>>   default-by-variant:
>>   - value: false
>>     variants:
>> -  - arm/stm32h7b3i-dk
>> +  - arm/stm32h7b3i-dk
>>   description: |
>>     Enable UART5 device in console driver.
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/stm32h7/optenuart7.yml b/spec/build/bsps/arm/stm32h7/optenuart7.yml
>> index fb061158cd..6fdc57cec8 100644
>> --- a/spec/build/bsps/arm/stm32h7/optenuart7.yml
>> +++ b/spec/build/bsps/arm/stm32h7/optenuart7.yml
>>   default-by-variant:
>>   - value: false
>>     variants:
>>   description: |
>>     Enable UART7 device in console driver.
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/stm32h7/optenuart8.yml b/spec/build/bsps/arm/stm32h7/optenuart8.yml
>> index 74de622e09..0dc550d701 100644
>> --- a/spec/build/bsps/arm/stm32h7/optenuart8.yml
>> +++ b/spec/build/bsps/arm/stm32h7/optenuart8.yml
>> @@ -9,9 +9,9 @@ default: true
>>   default-by-variant:
>>   - value: false
>>     variants:
>>   description: |
>>     Enable UART8 device in console driver.
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/stm32h7/optenuart9.yml b/spec/build/bsps/arm/stm32h7/optenuart9.yml
>> index af0d2e037b..9c364b7fec 100644
>> --- a/spec/build/bsps/arm/stm32h7/optenuart9.yml
>> +++ b/spec/build/bsps/arm/stm32h7/optenuart9.yml
>>   default-by-variant:
>>   - value: false
>>     variants:
>>   description: |
>>     Enable UART9 device in console driver.
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/stm32h7/optenusart10.yml b/spec/build/bsps/arm/stm32h7/optenusart10.yml
>> index c44bffad73..a23ce86e7e 100644
>> --- a/spec/build/bsps/arm/stm32h7/optenusart10.yml
>> +++ b/spec/build/bsps/arm/stm32h7/optenusart10.yml
>>   default-by-variant:
>>   - value: false
>>     variants:
>>   description: |
>>     Enable USART10 device in console driver.
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/stm32h7/optenusart3.yml b/spec/build/bsps/arm/stm32h7/optenusart3.yml
>> index a0027c8266..48f5ce7e9f 100644
>> --- a/spec/build/bsps/arm/stm32h7/optenusart3.yml
>> +++ b/spec/build/bsps/arm/stm32h7/optenusart3.yml
>>   default-by-variant:
>>   - value: false
>>     variants:
>>   description: |
>>     Enable USART3 device in console driver.
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/stm32h7/optenusart6.yml b/spec/build/bsps/arm/stm32h7/optenusart6.yml
>> index 7c4e9aee5b..1090bbce39 100644
>> --- a/spec/build/bsps/arm/stm32h7/optenusart6.yml
>> +++ b/spec/build/bsps/arm/stm32h7/optenusart6.yml
>>   default-by-variant:
>>   - value: false
>>     variants:
>>   description: |
>>     Enable USART6 device in console driver.
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/stm32h7/optlinkcmds.yml b/spec/build/bsps/arm/stm32h7/optlinkcmds.yml
>> index 59d4354ae2..ed10fe94d1 100644
>> --- a/spec/build/bsps/arm/stm32h7/optlinkcmds.yml
>> +++ b/spec/build/bsps/arm/stm32h7/optlinkcmds.yml
>> @@ -9,12 +9,12 @@ default: linkcmds.sdram
>>   default-by-variant:
>>   - value: linkcmds.flash
>>     variants:
>> +  - arm/nucleo-h743zi
>> -  - arm/nucleo-h743zi
>>   description: |
>>     The default linker command file.  Must be either linkcmds.flash,
>>     linkcmds.sdram, linkcmds.sram, linkcmds.sram_sdram
>> diff --git a/spec/build/bsps/arm/stm32h7/optmemflashorigin.yml b/spec/build/bsps/arm/stm32h7/optmemflashorigin.yml
>> index 4e155fa14a..f3e1cfcf0e 100644
>> --- a/spec/build/bsps/arm/stm32h7/optmemflashorigin.yml
>> +++ b/spec/build/bsps/arm/stm32h7/optmemflashorigin.yml
>> @@ -9,8 +9,8 @@ default: 134217728
>>   default-by-variant:
>>   - value: 135266304
>>     variants:
>>   description: |
>>     Origin address of the internal flash.
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/stm32h7/optmemflashsz.yml b/spec/build/bsps/arm/stm32h7/optmemflashsz.yml
>> index 945bc16c4d..ca845b968e 100644
>> --- a/spec/build/bsps/arm/stm32h7/optmemflashsz.yml
>> +++ b/spec/build/bsps/arm/stm32h7/optmemflashsz.yml
>> @@ -9,8 +9,8 @@ default: 2097152
>>   default-by-variant:
>>   - value: 1048576
>>     variants:
>>   description: |
>>     Size of the internal flash in bytes.
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/stm32h7/optmemsdram1sz.yml b/spec/build/bsps/arm/stm32h7/optmemsdram1sz.yml
>> index 9f36a510f2..c9ec44ec3f 100644
>> --- a/spec/build/bsps/arm/stm32h7/optmemsdram1sz.yml
>> +++ b/spec/build/bsps/arm/stm32h7/optmemsdram1sz.yml
>> @@ -9,12 +9,12 @@ default: 33554432
>>   default-by-variant:
>>   - value: 0
>>     variants:
>>   description: |
>>     Size of the SDRAM 1 in bytes.
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/stm32h7/optmemsdram2sz.yml b/spec/build/bsps/arm/stm32h7/optmemsdram2sz.yml
>> index b042fa796b..1b8d4a2b4c 100644
>> --- a/spec/build/bsps/arm/stm32h7/optmemsdram2sz.yml
>> +++ b/spec/build/bsps/arm/stm32h7/optmemsdram2sz.yml
>> @@ -9,10 +9,10 @@ default: 0
>>   default-by-variant:
>>   - value: 33554432
>>     variants:
>>   description: |
>>     Size of the SDRAM 2 in bytes.
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/stm32h7/optpwrsupply.yml b/spec/build/bsps/arm/stm32h7/optpwrsupply.yml
>> index 9270eedbd4..6534cf6143 100644
>> --- a/spec/build/bsps/arm/stm32h7/optpwrsupply.yml
>> +++ b/spec/build/bsps/arm/stm32h7/optpwrsupply.yml
>> @@ -9,11 +9,11 @@ default: PWR_LDO_SUPPLY
>>   default-by-variant:
>>   - value: PWR_DIRECT_SMPS_SUPPLY
>>     variants:
>>   description: |
>>     Board power supply mechanism configuration. WARNING: wrong configuration here
>>     may result in your board being unaccessible using ST-Link interface! Please
>> diff --git a/spec/build/bsps/arm/stm32h7/optusart1alternatefunc.yml b/spec/build/bsps/arm/stm32h7/optusart1alternatefunc.yml
>> index b0d3d86a6c..e0f39814e8 100644
>> --- a/spec/build/bsps/arm/stm32h7/optusart1alternatefunc.yml
>> +++ b/spec/build/bsps/arm/stm32h7/optusart1alternatefunc.yml
>> @@ -9,9 +9,9 @@ default: GPIO_AF4_USART1
>>   default-by-variant:
>>   - value: GPIO_AF7_USART1
>>     variants:
>>   description: |
>>     Alternate function mapping for the USART1 pin configuration.
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/stm32h7/optusart1gpiopins.yml b/spec/build/bsps/arm/stm32h7/optusart1gpiopins.yml
>> index b8920d9276..cc81ce408b 100644
>> --- a/spec/build/bsps/arm/stm32h7/optusart1gpiopins.yml
>> +++ b/spec/build/bsps/arm/stm32h7/optusart1gpiopins.yml
>> @@ -9,9 +9,9 @@ default: ( GPIO_PIN_14 | GPIO_PIN_15 )
>>   default-by-variant:
>>   - value: ( GPIO_PIN_9 | GPIO_PIN_10 )
>>     variants:
>>   description: |
>>     GPIO pins used for the USART1 pin configuration.
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/stm32h7/optusart1gpioregs.yml b/spec/build/bsps/arm/stm32h7/optusart1gpioregs.yml
>> index 79e8ab02f2..890579b9f8 100644
>> --- a/spec/build/bsps/arm/stm32h7/optusart1gpioregs.yml
>> +++ b/spec/build/bsps/arm/stm32h7/optusart1gpioregs.yml
>> @@ -9,9 +9,9 @@ default: GPIOD
>>   default-by-variant:
>>   - value: GPIOA
>>     variants:
>>   - value: GPIOB
>>     variants:
>> diff --git a/spec/build/bsps/arm/xilinx-zynq/opta9periphclk.yml b/spec/build/bsps/arm/xilinx-zynq/opta9periphclk.yml
>> index 0b10b47bc2..39cb972a74 100644
>> --- a/spec/build/bsps/arm/xilinx-zynq/opta9periphclk.yml
>> +++ b/spec/build/bsps/arm/xilinx-zynq/opta9periphclk.yml
>> @@ -9,10 +9,10 @@ default: 100000000
>>   default-by-variant:
>>   - value: 333333333
>>     variants:
>> -  - arm/xilinx_zynq_zc702.*
>> +  - arm/xilinx_zynq_zc702
>>   - value: 666666667
>>     variants:
>> -  - arm/xilinx_zynq_zedboard.*
>> +  - arm/xilinx_zynq_zedboard
>>   description: |
>>     ARM Cortex-A9 MPCore PERIPHCLK clock frequency in Hz
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/xilinx-zynq/optcachedata.yml b/spec/build/bsps/arm/xilinx-zynq/optcachedata.yml
>> --- a/spec/build/bsps/arm/xilinx-zynq/optcachedata.yml
>> +++ b/spec/build/bsps/arm/xilinx-zynq/optcachedata.yml
>>   default-by-variant:
>>   - value: false
>>     variants:
>> -  - arm/.*qemu
>>   description: |
>>     enable data cache
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/xilinx-zynq/optcacheinst.yml b/spec/build/bsps/arm/xilinx-zynq/optcacheinst.yml
>> --- a/spec/build/bsps/arm/xilinx-zynq/optcacheinst.yml
>> +++ b/spec/build/bsps/arm/xilinx-zynq/optcacheinst.yml
>>   default-by-variant:
>>   - value: false
>>     variants:
>> -  - arm/.*qemu
>>   description: |
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/xilinx-zynq/optclkcpu1x.yml b/spec/build/bsps/arm/xilinx-zynq/optclkcpu1x.yml
>> index 1f93f52a8a..57b7187cdf 100644
>> --- a/spec/build/bsps/arm/xilinx-zynq/optclkcpu1x.yml
>> +++ b/spec/build/bsps/arm/xilinx-zynq/optclkcpu1x.yml
>> @@ -9,10 +9,10 @@ default: 111111111
>>   default-by-variant:
>>   - value: 111111111
>>     variants:
>>   - value: 111111111
>>     variants:
>>   description: |
>>     Zynq cpu_1x clock frequency in Hz
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/xilinx-zynq/optclkfastidle.yml b/spec/build/bsps/arm/xilinx-zynq/optclkfastidle.yml
>> --- a/spec/build/bsps/arm/xilinx-zynq/optclkfastidle.yml
>> +++ b/spec/build/bsps/arm/xilinx-zynq/optclkfastidle.yml
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - arm/.*qemu
>>   description: |
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/xilinx-zynq/optclkuart.yml b/spec/build/bsps/arm/xilinx-zynq/optclkuart.yml
>> index 7d69273eb2..56a6056687 100644
>> --- a/spec/build/bsps/arm/xilinx-zynq/optclkuart.yml
>> +++ b/spec/build/bsps/arm/xilinx-zynq/optclkuart.yml
>> @@ -9,10 +9,10 @@ default: 50000000
>>   default-by-variant:
>>   - value: 50000000
>>     variants:
>>   - value: 50000000
>>     variants:
>>   description: |
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/xilinx-zynqmp/optcachedata.yml b/spec/build/bsps/arm/xilinx-zynqmp/optcachedata.yml
>> --- a/spec/build/bsps/arm/xilinx-zynqmp/optcachedata.yml
>> +++ b/spec/build/bsps/arm/xilinx-zynqmp/optcachedata.yml
>>   default-by-variant:
>>   - value: false
>>     variants:
>> -  - arm/.*qemu
>>   description: |
>>     enable data cache
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/xilinx-zynqmp/optcacheinst.yml b/spec/build/bsps/arm/xilinx-zynqmp/optcacheinst.yml
>> --- a/spec/build/bsps/arm/xilinx-zynqmp/optcacheinst.yml
>> +++ b/spec/build/bsps/arm/xilinx-zynqmp/optcacheinst.yml
>>   default-by-variant:
>>   - value: false
>>     variants:
>> -  - arm/.*qemu
>>   description: |
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/xilinx-zynqmp/optclkfastidle.yml b/spec/build/bsps/arm/xilinx-zynqmp/optclkfastidle.yml
>> --- a/spec/build/bsps/arm/xilinx-zynqmp/optclkfastidle.yml
>> +++ b/spec/build/bsps/arm/xilinx-zynqmp/optclkfastidle.yml
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - arm/.*qemu
>>   description: |
>>   enabled-by: true
>> diff --git a/spec/build/bsps/arm/xilinx-zynqmp/optclkuart.yml b/spec/build/bsps/arm/xilinx-zynqmp/optclkuart.yml
>> index a2def36606..df6cd08847 100644
>> --- a/spec/build/bsps/arm/xilinx-zynqmp/optclkuart.yml
>> +++ b/spec/build/bsps/arm/xilinx-zynqmp/optclkuart.yml
>> @@ -9,7 +9,7 @@ default: 100000000
>>   default-by-variant:
>>   - value: 100000000
>>     variants:
>> -  - arm/xilinx_zynqmp_ultra96.*
>> +  - arm/xilinx_zynqmp_ultra96
>>   description: |
>>   enabled-by: true
>> diff --git a/spec/build/bsps/dev/irq/optarmgic-icc-bpr0.yml b/spec/build/bsps/dev/irq/optarmgic-icc-bpr0.yml
>> index 01933d00ca..758b4d7d10 100644
>> --- a/spec/build/bsps/dev/irq/optarmgic-icc-bpr0.yml
>> +++ b/spec/build/bsps/dev/irq/optarmgic-icc-bpr0.yml
>> @@ -9,7 +9,19 @@ default: 2
>>   default-by-variant:
>>   - value: null
>>     variants:
>> -  - aarch64/.*
>> +  - aarch64/a53_ilp32_qemu
>> +  - aarch64/a53_lp64_qemu
>> +  - aarch64/a72_ilp32_qemu
>> +  - aarch64/a72_lp64_qemu
>> +  - aarch64/raspberrypi4b
>> +  - aarch64/xilinx_versal_aiedge
>> +  - aarch64/xilinx_versal_qemu
>> +  - aarch64/xilinx_versal_vck190
>>   description: |
>>     Defines the initial value of the ICC_BPR0 register of the ARM GIC CPU
>>     Interface.  The value is optional.  If it is not defined, then the register
>> diff --git a/spec/build/bsps/dev/irq/optarmgic-icc-igrpen0.yml b/spec/build/bsps/dev/irq/optarmgic-icc-igrpen0.yml
>> index aea536d7d1..143468f834 100644
>> --- a/spec/build/bsps/dev/irq/optarmgic-icc-igrpen0.yml
>> +++ b/spec/build/bsps/dev/irq/optarmgic-icc-igrpen0.yml
>> @@ -9,7 +9,19 @@ default: 1
>>   default-by-variant:
>>   - value: null
>>     variants:
>> -  - aarch64/.*
>>   description: |
>>     Defines the initial value of the ICC_IGRPEN0 register of the ARM GIC CPU
>> diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optramlen.yml b/spec/build/bsps/microblaze/microblaze_fpga/optramlen.yml
>> index e1bcfbaf88..bb12934884 100644
>> --- a/spec/build/bsps/microblaze/microblaze_fpga/optramlen.yml
>> +++ b/spec/build/bsps/microblaze/microblaze_fpga/optramlen.yml
>> @@ -11,7 +11,8 @@ default: 268435456
>>   default-by-variant:
>>   - value: 2147483648
>>     variants:
>> -  - microblaze/kcu105.*
>> +  - microblaze/kcu105
>> +  - microblaze/kcu105_qemu
>>   description: |
>>     length of memory area available to the BSP
>>   enabled-by: true
>> diff --git a/spec/build/bsps/optcachedata.yml b/spec/build/bsps/optcachedata.yml
>> index 6e48d171ff..87ab0385a6 100644
>> --- a/spec/build/bsps/optcachedata.yml
>> +++ b/spec/build/bsps/optcachedata.yml
>> @@ -10,7 +10,20 @@ default: true
>>   default-by-variant:
>>   - value: false
>>     variants:
>> -  - .*qemu.*
>> +  - powerpc/qemuppc
>> +  - powerpc/qemuprep
>> +  - powerpc/qemuprep-altivec
>>   description: |
>>     Enable data cache
>>   enabled-by: true
>> diff --git a/spec/build/bsps/optcacheinst.yml b/spec/build/bsps/optcacheinst.yml
>> index 035414bf0c..ac0afc964a 100644
>> --- a/spec/build/bsps/optcacheinst.yml
>> +++ b/spec/build/bsps/optcacheinst.yml
>>   default-by-variant:
>>   - value: false
>>     variants:
>> -  - .*qemu.*
>> +  - powerpc/qemuppc
>>   description: |
>>     Enable instruction cache
>>   enabled-by: true
>> diff --git a/spec/build/bsps/optclkbootcpu.yml b/spec/build/bsps/optclkbootcpu.yml
>> index d65cc2b67f..4044926fb8 100644
>> --- a/spec/build/bsps/optclkbootcpu.yml
>> +++ b/spec/build/bsps/optclkbootcpu.yml
>> @@ -10,7 +10,20 @@ default: false
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - .*qemu.*
>> +  - powerpc/qemuppc
>>   description: |
>>     Do the clock tick processing on the boot processor on behalf of all other
>>     processors.
>> diff --git a/spec/build/bsps/optclkfastidle.yml b/spec/build/bsps/optclkfastidle.yml
>> index 31fb840a9c..e0b3698992 100644
>> --- a/spec/build/bsps/optclkfastidle.yml
>> +++ b/spec/build/bsps/optclkfastidle.yml
>> @@ -9,7 +9,20 @@ default: false
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - .*qemu.*
>> +  - powerpc/qemuppc
>>   description: |
>>     Set a mode where the time runs as fast as possible when a clock ISR occurs
>>     while the IDLE thread is executing; this can significantly reduce simulation
>> diff --git a/spec/build/bsps/optconsolebaud.yml b/spec/build/bsps/optconsolebaud.yml
>> index b32dfb8888..8e754579cd 100644
>> --- a/spec/build/bsps/optconsolebaud.yml
>> +++ b/spec/build/bsps/optconsolebaud.yml
>> @@ -11,8 +11,8 @@ default-by-variant:
>>     variants:
>>     - bsps/powerpc/motorola_powerpc
>>     - m68k/m5484FireEngine
>> -  - powerpc/hsc_cm01
>>     - powerpc/beatnik
>> +  - powerpc/hsc_cm01
>>     - powerpc/mvme3100
>>     - powerpc/mvme5500
>>   - value: 19200
>> diff --git a/spec/build/bsps/optdtb.yml b/spec/build/bsps/optdtb.yml
>> index 54ae7aa770..e38cc5a071 100644
>> --- a/spec/build/bsps/optdtb.yml
>> +++ b/spec/build/bsps/optdtb.yml
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - riscv/mpfs64.*
>> +  - riscv/mpfs64imafdc
>>   description: |
>>     the path to the header file containing the device tree binary. See the BSP
>>     documentation for more information.
>> diff --git a/spec/build/bsps/optdtbheaderpath.yml b/spec/build/bsps/optdtbheaderpath.yml
>> index 7e294ce058..a069d084b2 100644
>> --- a/spec/build/bsps/optdtbheaderpath.yml
>> +++ b/spec/build/bsps/optdtbheaderpath.yml
>>   default-by-variant:
>>   - value: bsp/mpfs-dtb.h
>>     variants:
>> -  - riscv/mpfs64.*
>>   description: |
>> diff --git a/spec/build/bsps/optxilsupportpath.yml b/spec/build/bsps/optxilsupportpath.yml
>> index d70d4d0b69..25ddaf062c 100644
>> --- a/spec/build/bsps/optxilsupportpath.yml
>> +++ b/spec/build/bsps/optxilsupportpath.yml
>> @@ -22,10 +22,10 @@ default-by-variant:
>>   - value: arm/ARMv8/64bit
>>     variants:
>> -  - bsps/aarch64/xilinx_versal
>> +  - bsps/aarch64/xilinx_versal
>>   description: Set the Xilinx support path
>>   enabled-by: true
>>   format: '{}'
>> diff --git a/spec/build/bsps/powerpc/gen5200/optuboot.yml b/spec/build/bsps/powerpc/gen5200/optuboot.yml
>> index 19ed770a9f..4d44060774 100644
>> --- a/spec/build/bsps/powerpc/gen5200/optuboot.yml
>> +++ b/spec/build/bsps/powerpc/gen5200/optuboot.yml
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - powerpc/pm520.*
>> +  - powerpc/pm520_cr825
>> +  - powerpc/pm520_ze30
>>   - value: true
>>     variants:
>>     - powerpc/icecube
>> diff --git a/spec/build/bsps/powerpc/motorola_powerpc/optqemu.yml b/spec/build/bsps/powerpc/motorola_powerpc/optqemu.yml
>> index 962584da83..0e861eed0c 100644
>> --- a/spec/build/bsps/powerpc/motorola_powerpc/optqemu.yml
>> +++ b/spec/build/bsps/powerpc/motorola_powerpc/optqemu.yml
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - powerpc/qemuprep.*
>>   description: |
>>     Defined for QEMU BSP -- undefined for others
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/ofmpllptmfd.yml b/spec/build/bsps/powerpc/mpc55xxevb/ofmpllptmfd.yml
>> index 8918318f51..7c1a1fa869 100644
>> --- a/spec/build/bsps/powerpc/mpc55xxevb/ofmpllptmfd.yml
>> +++ b/spec/build/bsps/powerpc/mpc55xxevb/ofmpllptmfd.yml
>> @@ -12,10 +12,10 @@ default-by-variant:
>>     - powerpc/gwlcfm
>>   - value: 111
>>     variants:
>> -  - powerpc/mpc5668g.*
>> +  - powerpc/mpc5668g
>>   - value: 66
>>     variants:
>> -  - powerpc/mpc5674f.*
>> +  - powerpc/mpc5674fevb
>>   description: |
>>     Must be defined to be the PLL multiplication factor for clock generation
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optchiptype.yml b/spec/build/bsps/powerpc/mpc55xxevb/optchiptype.yml
>> index ae9ed015e7..d1d037d34c 100644
>> --- a/spec/build/bsps/powerpc/mpc55xxevb/optchiptype.yml
>> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optchiptype.yml
>> @@ -12,16 +12,16 @@ default-by-variant:
>>     - powerpc/gwlcfm
>>   - value: 5566
>>     variants:
>> -  - powerpc/mpc5566.*
>> +  - powerpc/mpc5566evb
>>   - value: 5643
>>     variants:
>> -  - powerpc/mpc5643l.*
>> +  - powerpc/mpc5643l_evb
>>   - value: 5668
>>     variants:
>>   - value: 5674
>>     variants:
>>   description: |
>>     specifies the chip type in use (e.g. 5554 for MPC5554)
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optclkemios.yml b/spec/build/bsps/powerpc/mpc55xxevb/optclkemios.yml
>> index e60b33217e..d7cf9b927d 100644
>> --- a/spec/build/bsps/powerpc/mpc55xxevb/optclkemios.yml
>> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optclkemios.yml
>> @@ -9,13 +9,13 @@ default: 23
>>   default-by-variant:
>>   - value: null
>>     variants:
>>   - value: null
>>     variants:
>>   - value: 31
>>     variants:
>>   description: |
>>     selects the eMIOS channel for the RTEMS system tick (the default is the last channel)
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optclkpit.yml b/spec/build/bsps/powerpc/mpc55xxevb/optclkpit.yml
>> index 3edac8e3f0..9ae42801cb 100644
>> --- a/spec/build/bsps/powerpc/mpc55xxevb/optclkpit.yml
>> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optclkpit.yml
>> @@ -9,10 +9,10 @@ default: null
>>   default-by-variant:
>>   - value: 3
>>     variants:
>>   - value: 8
>>     variants:
>>   description: |
>>     selects the PIT channel for the RTEMS system tick (the default is the last channel)
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optemiosprescal.yml b/spec/build/bsps/powerpc/mpc55xxevb/optemiosprescal.yml
>> index 78bc00dff8..931b97e56d 100644
>> --- a/spec/build/bsps/powerpc/mpc55xxevb/optemiosprescal.yml
>> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optemiosprescal.yml
>> @@ -12,7 +12,7 @@ default-by-variant:
>>     - powerpc/gwlcfm
>>   - value: null
>>     variants:
>>   description: |
>>     Must be defined to set the EMIOS prescaler
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optfmpllprediv.yml b/spec/build/bsps/powerpc/mpc55xxevb/optfmpllprediv.yml
>> index fe81e18515..84df5a1dad 100644
>> --- a/spec/build/bsps/powerpc/mpc55xxevb/optfmpllprediv.yml
>> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optfmpllprediv.yml
>>     - powerpc/gwlcfm
>>   - value: 6
>>     variants:
>>   - value: 5
>>     variants:
>>   description: |
>>     Must be defined to be the PLL predivider factor for clock generation
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optirqtblsz.yml b/spec/build/bsps/powerpc/mpc55xxevb/optirqtblsz.yml
>> index 70b5fd0f25..a5f7417674 100644
>> --- a/spec/build/bsps/powerpc/mpc55xxevb/optirqtblsz.yml
>> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optirqtblsz.yml
>> @@ -9,13 +9,13 @@ default: 63
>>   default-by-variant:
>>   - value: 127
>>     variants:
>>   - value: 127
>>     variants:
>>   - value: 255
>>     variants:
>>   description: |
>>     defines the maximum number of interrupt handlers
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optlowinit.yml b/spec/build/bsps/powerpc/mpc55xxevb/optlowinit.yml
>> index 615b68cdf9..232b759bf8 100644
>> --- a/spec/build/bsps/powerpc/mpc55xxevb/optlowinit.yml
>> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optlowinit.yml
>> @@ -8,8 +8,7 @@ copyrights:
>>   default: true
>>   default-by-variant:
>>   - value: false
>> -  variants:
>> -  - powerpc/mpc5674f_.*app
>> +  variants: []
>>   description: |
>>     if defined, do low level initialization
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optmpc5566evb.yml b/spec/build/bsps/powerpc/mpc55xxevb/optmpc5566evb.yml
>> index 46d39d959d..cc549ede34 100644
>> --- a/spec/build/bsps/powerpc/mpc55xxevb/optmpc5566evb.yml
>> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optmpc5566evb.yml
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - powerpc/mpc5566evb.*
>>   description: |
>>     if defined, use custom settings for MPC5566EVB board
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optmpc5674fevb.yml b/spec/build/bsps/powerpc/mpc55xxevb/optmpc5674fevb.yml
>> index 05679fadb3..83a694c193 100644
>> --- a/spec/build/bsps/powerpc/mpc55xxevb/optmpc5674fevb.yml
>> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optmpc5674fevb.yml
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - powerpc/mpc5674fevb.*
>>   description: |
>>     if defined, use custom settings for MPC5674FEVB board
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optnullprot.yml b/spec/build/bsps/powerpc/mpc55xxevb/optnullprot.yml
>> index 27747835fc..0c081ab189 100644
>> --- a/spec/build/bsps/powerpc/mpc55xxevb/optnullprot.yml
>> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optnullprot.yml
>>   default-by-variant:
>>   - value: true
>>     variants:
>>   - value: true
>>     variants:
>>   description: |
>>     enable NULL pointer protection
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optrefclk.yml b/spec/build/bsps/powerpc/mpc55xxevb/optrefclk.yml
>> index 6748954449..8b4fd9a0f0 100644
>> --- a/spec/build/bsps/powerpc/mpc55xxevb/optrefclk.yml
>> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optrefclk.yml
>> @@ -12,13 +12,13 @@ default-by-variant:
>>     - powerpc/gwlcfm
>>   - value: 40000000
>>     variants:
>> -  - powerpc/mpc5643l_evb.*
>>   - value: 25000000
>>     variants:
>>   - value: 40000000
>>     variants:
>>   description: |
>>     None
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optsmc9218ipinirq.yml b/spec/build/bsps/powerpc/mpc55xxevb/optsmc9218ipinirq.yml
>> index 1a339c7e72..cfba195031 100644
>> --- a/spec/build/bsps/powerpc/mpc55xxevb/optsmc9218ipinirq.yml
>> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optsmc9218ipinirq.yml
>> @@ -9,7 +9,7 @@ default: null
>>   default-by-variant:
>>   - value: 193
>>     variants:
>>   description: |
>>     IRQ pin for SMSC9218I network interface
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optsmc9218ipinrst.yml b/spec/build/bsps/powerpc/mpc55xxevb/optsmc9218ipinrst.yml
>> index 6f8585b6e2..d770ce02ed 100644
>> --- a/spec/build/bsps/powerpc/mpc55xxevb/optsmc9218ipinrst.yml
>> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optsmc9218ipinrst.yml
>>   default-by-variant:
>>   - value: 186
>>     variants:
>>   description: |
>>     reset pin for SMSC9218I network interface
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optsysclk.yml b/spec/build/bsps/powerpc/mpc55xxevb/optsysclk.yml
>> index 8edffed6e9..6d4e1554f1 100644
>> --- a/spec/build/bsps/powerpc/mpc55xxevb/optsysclk.yml
>> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optsysclk.yml
>>     - powerpc/gwlcfm
>>   - value: 116000000
>>     variants:
>>   - value: 264000000
>>     variants:
>>   description: |
>>     The system clock frequency in Hz.
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/mpc55xxevb/optsysclkdiv.yml b/spec/build/bsps/powerpc/mpc55xxevb/optsysclkdiv.yml
>> index 739f139e49..293e2ed9a6 100644
>> --- a/spec/build/bsps/powerpc/mpc55xxevb/optsysclkdiv.yml
>> +++ b/spec/build/bsps/powerpc/mpc55xxevb/optsysclkdiv.yml
>>   default-by-variant:
>>   - value: 2
>>     variants:
>>   description: |
>>     system clock divider
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/qoriq/optbucsr.yml b/spec/build/bsps/powerpc/qoriq/optbucsr.yml
>> index fe64767307..5b7af9ce5d 100644
>> --- a/spec/build/bsps/powerpc/qoriq/optbucsr.yml
>> +++ b/spec/build/bsps/powerpc/qoriq/optbucsr.yml
>> @@ -9,7 +9,8 @@ default: null
>>   default-by-variant:
>>   - value: 20972033
>>     variants:
>> -  - powerpc/qoriq_e6500.*
>> +  - powerpc/qoriq_e6500_32
>> +  - powerpc/qoriq_e6500_64
>>   description: |
>>     initial BUCSR value
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/qoriq/optbusclkdiv.yml b/spec/build/bsps/powerpc/qoriq/optbusclkdiv.yml
>> index 217718a1dc..74adc5ae9d 100644
>> --- a/spec/build/bsps/powerpc/qoriq/optbusclkdiv.yml
>> +++ b/spec/build/bsps/powerpc/qoriq/optbusclkdiv.yml
>>   default-by-variant:
>>   - value: 2
>>     variants:
>>   description: |
>>     divider of the platform clock to get the clock most on-chip peripherals
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/qoriq/optcachealign.yml b/spec/build/bsps/powerpc/qoriq/optcachealign.yml
>> index 77e30c86c7..80423556e9 100644
>> --- a/spec/build/bsps/powerpc/qoriq/optcachealign.yml
>> +++ b/spec/build/bsps/powerpc/qoriq/optcachealign.yml
>>   default-by-variant:
>>   - value: 64
>>     variants:
>>   description: |
>>     the cache alignment
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/qoriq/optcachedatal2sz.yml b/spec/build/bsps/powerpc/qoriq/optcachedatal2sz.yml
>> index ef4ee635ef..28566edad9 100644
>> --- a/spec/build/bsps/powerpc/qoriq/optcachedatal2sz.yml
>> +++ b/spec/build/bsps/powerpc/qoriq/optcachedatal2sz.yml
>> @@ -9,7 +9,8 @@ default: 262144
>>   default-by-variant:
>>   - value: 2097152
>>     variants:
>>   description: |
>>     the L2 data cache size
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/qoriq/optcacheinstl2sz.yml b/spec/build/bsps/powerpc/qoriq/optcacheinstl2sz.yml
>> index 133941ff7b..ea16d60a8b 100644
>> --- a/spec/build/bsps/powerpc/qoriq/optcacheinstl2sz.yml
>> +++ b/spec/build/bsps/powerpc/qoriq/optcacheinstl2sz.yml
>>   default-by-variant:
>>   - value: 2097152
>>     variants:
>>   description: |
>>     the L2 instruction cache size
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/qoriq/optchipnum.yml b/spec/build/bsps/powerpc/qoriq/optchipnum.yml
>> index f8bb14166f..6e465ac41b 100644
>> --- a/spec/build/bsps/powerpc/qoriq/optchipnum.yml
>> +++ b/spec/build/bsps/powerpc/qoriq/optchipnum.yml
>> @@ -9,7 +9,8 @@ default: 1020
>>   default-by-variant:
>>   - value: 0
>>     variants:
>>   description: |
>>     chip number, e.g. 1020, 2040, 2080, 4240
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/qoriq/optchipser.yml b/spec/build/bsps/powerpc/qoriq/optchipser.yml
>> index c566b49761..29c0c01d6f 100644
>> --- a/spec/build/bsps/powerpc/qoriq/optchipser.yml
>> +++ b/spec/build/bsps/powerpc/qoriq/optchipser.yml
>> @@ -9,7 +9,8 @@ default: P
>>   default-by-variant:
>>   - value: T
>>     variants:
>>   description: |
>>     chip series, e.g. 'P' or 'T'
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/qoriq/optcpucnt.yml b/spec/build/bsps/powerpc/qoriq/optcpucnt.yml
>> index db805547e2..61b2048edc 100644
>> --- a/spec/build/bsps/powerpc/qoriq/optcpucnt.yml
>> +++ b/spec/build/bsps/powerpc/qoriq/optcpucnt.yml
>>   default-by-variant:
>>   - value: 24
>>     variants:
>>   description: |
>>     maximum virtual processor count
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/qoriq/opthid0.yml b/spec/build/bsps/powerpc/qoriq/opthid0.yml
>> index c0b1a56346..cdc6b51e95 100644
>> --- a/spec/build/bsps/powerpc/qoriq/opthid0.yml
>> +++ b/spec/build/bsps/powerpc/qoriq/opthid0.yml
>>   default-by-variant:
>>   - value: 1073741824
>>     variants:
>>   description: |
>>     initial HID0 value (EN_L2MMU_MHD is set by default on the T-series)
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/qoriq/opthyp.yml b/spec/build/bsps/powerpc/qoriq/opthyp.yml
>> index ccb383c8b5..39901fed5d 100644
>> --- a/spec/build/bsps/powerpc/qoriq/opthyp.yml
>> +++ b/spec/build/bsps/powerpc/qoriq/opthyp.yml
>>   default-by-variant:
>>   - value: true
>>     variants:
>>   description: |
>>     defined if the processor core has a hypervisor mode
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/qoriq/optmas7.yml b/spec/build/bsps/powerpc/qoriq/optmas7.yml
>> index 77ed473263..debecaad28 100644
>> --- a/spec/build/bsps/powerpc/qoriq/optmas7.yml
>> +++ b/spec/build/bsps/powerpc/qoriq/optmas7.yml
>> @@ -9,7 +9,8 @@ default: 0
>>   default-by-variant:
>>   - value: 15
>>     variants:
>>   description: |
>>     MAS7 value for device TLB1 entries
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/qoriq/optmsr.yml b/spec/build/bsps/powerpc/qoriq/optmsr.yml
>> index 5327f63c6f..8bf6f8c75f 100644
>> --- a/spec/build/bsps/powerpc/qoriq/optmsr.yml
>> +++ b/spec/build/bsps/powerpc/qoriq/optmsr.yml
>> @@ -9,10 +9,10 @@ default: 33554944
>>   default-by-variant:
>>   - value: 2181046784
>>     variants:
>> -  - powerpc/qoriq_e6500_64.*
>>   - value: 33563136
>>     variants:
>> -  - powerpc/qoriq_e6500_32.*
>>   description: |
>>     initial MSR value
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/qoriq/optspefscr.yml b/spec/build/bsps/powerpc/qoriq/optspefscr.yml
>> index 820eef00ec..497f91eae3 100644
>> --- a/spec/build/bsps/powerpc/qoriq/optspefscr.yml
>> +++ b/spec/build/bsps/powerpc/qoriq/optspefscr.yml
>>   default-by-variant:
>>   - value: null
>>     variants:
>>   description: |
>>     initial SPEFSCR value
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/qoriq/optthrdcnt.yml b/spec/build/bsps/powerpc/qoriq/optthrdcnt.yml
>> index 5a2b67bf5c..9fca5dc401 100644
>> --- a/spec/build/bsps/powerpc/qoriq/optthrdcnt.yml
>> +++ b/spec/build/bsps/powerpc/qoriq/optthrdcnt.yml
>>   default-by-variant:
>>   - value: 2
>>     variants:
>>   description: |
>>     the number of threads per core
>>   enabled-by: true
>> diff --git a/spec/build/bsps/powerpc/qoriq/opttlb1cnt.yml b/spec/build/bsps/powerpc/qoriq/opttlb1cnt.yml
>> index 4b9ed660b7..ac123ecb0c 100644
>> --- a/spec/build/bsps/powerpc/qoriq/opttlb1cnt.yml
>> +++ b/spec/build/bsps/powerpc/qoriq/opttlb1cnt.yml
>> @@ -9,7 +9,8 @@ default: 16
>>   default-by-variant:
>>   - value: 64
>>     variants:
>>   description: |
>>     TLB1 entry count
>>   enabled-by: true
>> diff --git a/spec/build/bsps/riscv/noel/abi.yml b/spec/build/bsps/riscv/noel/abi.yml
>> index f81e0c1a60..558ba70c95 100644
>> --- a/spec/build/bsps/riscv/noel/abi.yml
>> +++ b/spec/build/bsps/riscv/noel/abi.yml
>> @@ -28,8 +28,7 @@ default-by-variant:
>>   - value:
>>     - -march=rv64im
>>     - -mabi=lp64
>> -  variants:
>> -  - riscv/noel64im
>> +  variants: []
>>   - value:
>>     - -march=rv32imafd
>>     - -mabi=ilp32d
>> diff --git a/spec/build/bsps/riscv/optextirqmax.yml b/spec/build/bsps/riscv/optextirqmax.yml
>> index 20b05b4aaf..eddb0a78d5 100644
>> --- a/spec/build/bsps/riscv/optextirqmax.yml
>> +++ b/spec/build/bsps/riscv/optextirqmax.yml
>> @@ -9,7 +9,7 @@ default: 128
>>   default-by-variant:
>>   - value: 187
>>     variants:
>> -  - riscv/mpfs64.*
>>   description: |
>>     maximum number of external interrupts supported by the BSP (default 128)
>>   enabled-by: true
>> diff --git a/spec/build/bsps/riscv/optrambegin.yml b/spec/build/bsps/riscv/optrambegin.yml
>> index 8890334915..047c25d66d 100644
>> --- a/spec/build/bsps/riscv/optrambegin.yml
>> +++ b/spec/build/bsps/riscv/optrambegin.yml
>> @@ -12,13 +12,17 @@ default: 2147483648
>>   default-by-variant:
>>   - value: 0
>>     variants:
>> -  - riscv/noel.*
>> +  - riscv/noel32im
>> +  - riscv/noel32imafd
>> +  - riscv/noel64imac
>> +  - riscv/noel64imafd
>> +  - riscv/noel64imafdc
>>   - value: 1073741824
>>     variants:
>>     - riscv/griscv
>>   - value: 68719476736
>>     variants:
>> -  - riscv/mpfs64.*
>>   description: ''
>>   enabled-by: true
>>   format: '{:#010x}'
>> diff --git a/spec/build/bsps/riscv/optramsize.yml b/spec/build/bsps/riscv/optramsize.yml
>> index 316cc906de..3e123fc650 100644
>> --- a/spec/build/bsps/riscv/optramsize.yml
>> +++ b/spec/build/bsps/riscv/optramsize.yml
>> @@ -18,7 +18,7 @@ default-by-variant:
>>     - riscv/griscv
>>   - value: 268435456
>>     variants:
>> -  - riscv/mpfs64.*
>>   description: ''
>>   enabled-by: true
>>   format: '{:#010x}'
>> diff --git a/spec/build/bsps/riscv/riscv/optfrdme310arty.yml b/spec/build/bsps/riscv/riscv/optfrdme310arty.yml
>> index 0623694cca..4bb43a9a18 100644
>> --- a/spec/build/bsps/riscv/riscv/optfrdme310arty.yml
>> +++ b/spec/build/bsps/riscv/riscv/optfrdme310arty.yml
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - riscv/frdme310arty.*
>> +  - riscv/frdme310arty
>>   description: |
>>     enables support sifive Freedom E310 Arty board if defined to a non-zero value,otherwise it is disabled (disabled by default)
>>   enabled-by: true
>> diff --git a/spec/build/bsps/riscv/riscv/optmpfs.yml b/spec/build/bsps/riscv/riscv/optmpfs.yml
>> index 17614567e3..2b734c203b 100644
>> --- a/spec/build/bsps/riscv/riscv/optmpfs.yml
>> +++ b/spec/build/bsps/riscv/riscv/optmpfs.yml
>>   default-by-variant:
>>   - value: true
>>     variants:
>> -  - riscv/mpfs64.*
>>   description: |
>>     enables support Microchip PolarFire SoC if defined to a non-zero value,otherwise it is disabled (disabled by default)
>>   enabled-by: true
>> diff --git a/spec/build/bsps/riscv/riscv/optns16550max.yml b/spec/build/bsps/riscv/riscv/optns16550max.yml
>> index 66189cfdfd..41a23ee10d 100644
>> --- a/spec/build/bsps/riscv/riscv/optns16550max.yml
>> +++ b/spec/build/bsps/riscv/riscv/optns16550max.yml
>> @@ -9,10 +9,10 @@ default: 2
>>   default-by-variant:
>>   - value: null
>>     variants:
>>   - value: 1
>>     variants:
>> -  - riscv/mpfs64.*
>>   description: |
>>     maximum number of NS16550 devices supported by the console driver (2 by default)
>>   enabled-by: true
>> diff --git a/spec/build/cpukit/optarchbits.yml b/spec/build/cpukit/optarchbits.yml
>> index 0ec4a9fe7e..ba8d52aa61 100644
>> --- a/spec/build/cpukit/optarchbits.yml
>> +++ b/spec/build/cpukit/optarchbits.yml
>> @@ -11,15 +11,26 @@ default-by-variant:
>>   - value:
>>     - '64'
>>     variants:
>> -  - riscv/mpfs64.*
>> -  - riscv/noel64.*
>> -  - riscv/rv64.*
>> +  - riscv/rv64imac
>> +  - riscv/rv64imafd
>> +  - riscv/rv64imafdc
>>   - value:
>>     - '32'
>>     variants:
>>     - riscv/griscv
>> -  - riscv/noel32.*
>> -  - riscv/rv32.*
>> +  - riscv/noel32im
>> +  - riscv/rv32i
>> +  - riscv/rv32iac
>> +  - riscv/rv32im
>> +  - riscv/rv32imac
>> +  - riscv/rv32imafc
>> +  - riscv/rv32imafd
>> +  - riscv/rv32imafdc
>>   description: The architecture word bits for the clang target triple.
>>   enabled-by:
>>   - and:
>> diff --git a/spec/build/cpukit/optboothartid.yml b/spec/build/cpukit/optboothartid.yml
>> index f6cf6da6d4..e23154d4b4 100644
>> --- a/spec/build/cpukit/optboothartid.yml
>> +++ b/spec/build/cpukit/optboothartid.yml
>> @@ -9,7 +9,7 @@ default: 0
>>   default-by-variant:
>>   - value: 1
>>     variants:
>> -  - riscv/mpfs64.*
>>   description: |
>>     boot hartid (processor number) of risc-v cpu (default 0)
>>   enabled-by: riscv
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
