[PATCH 2/3] build: Replace variant patterns with a list
Sebastian Huber
Thu Jan 19 07:06:18 UTC 2023
On 19.01.23 01:17, Chris Johns wrote:
>>> Why has this been done?
>> The enabled-by expressions used in patch 3 do not support regular expressions.
> I did not pick that up. Why was that regx functionality removed? Is it related
> to scripting and rtems-central?
The enabled-by expressions supported by the wscript don't support
regular expressions:
https://github.com/RTEMS/rtems/blob/master/wscript#L144
The interesting part of the patch set is patch 3:
Merge the "default" and "default-by-variant" attributes. Use an
"enabled-by" expression to select the default value based on the enabled
set. This makes it possible to select default values depending on other
options. For example you could choose memory settings based on whether
RTEMS_SMP is enabled or disabled.
>>> Why the noise in the patch of only lines being moved? Where has this come from?
>>> Is there a new requirement spec fields be in some osrt of order?
>> I did the change with a script which sorted the lists. In general, the lists
>> should be sorted.
> This is a good example of problems a lack of scripting support along side the
> build spec files creates. It makes manual changes difficult when rules get
> layered like this plus it means you are the only one who can make generated
> changes without there being a clash of scripting specifics, ie my script vs your
> script or something like that.
I don't understand what is the problem with the sorted lists. If you
have a list of unordered phrases, it is not unusual to still sort them
in lexicographic order.
> And I have no intention in cloning rtems-central and learning how to use it.
> There was a primary agreement for the separation of all qual work and the
> ability for it to be removed from the project without any side effects.
You don't have to use the stuff in rtems-central, it could be just more
convenient and efficient. It would be possible to write a Github action
which checks that the build items match the expected format for pull
requests.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
