[PATCH v1 4/4] testsuites/libtest/dl11: Add DL test for TLS
Kinsey Moore wkm042 at oarcorp.com
Fri Jan 20 00:24:09 UTC 2023
On 1/19/2023 6:16 PM, Chris Johns wrote:
> On 20/1/2023 8:40 am, Kinsey Moore wrote:
>> On 1/15/2023 6:07 PM, Chris Johns wrote:
>>> On 13/1/2023 12:51 pm, Kinsey Moore wrote:
>>>> On Thu, Jan 12, 2023 at 5:11 PM Joel Sherrill <joel at rtems.org
>>>> <mailto:joel at rtems.org>> wrote:
>>>>       Will this need to be added as an expected fail on other architectures?
>>>>       Just wondering how many bsp test configuration files need touching
>>>> I suppose I could set it to enabled for only AArch64 for now. It would
>>>> definitely fail on other architectures.
>>> Should we enable it for archs we would like supported for 6 and then make sure
>>> we have support for the release?
>>> The support is a side effect of the switch to TLS in newlib and not related to
>>> libdl.
>> That sounds reasonable. I'll leave it as-is.
>> Assuming that's commit approval, I'll open a ticket for the missing support.
> Yes and sorry for not making this clear.
Thanks! The ticket has been created: https://devel.rtems.org/ticket/4802
Kinsey
