[PATCH v1 4/4] testsuites/libtest/dl11: Add DL test for TLS
Fri Jan 20 00:16:16 UTC 2023
On 20/1/2023 8:40 am, Kinsey Moore wrote:
> On 1/15/2023 6:07 PM, Chris Johns wrote:
>> On 13/1/2023 12:51 pm, Kinsey Moore wrote:
>>> On Thu, Jan 12, 2023 at 5:11 PM Joel Sherrill <joel at rtems.org
>>> <mailto:joel at rtems.org>> wrote:
>>>      Will this need to be added as an expected fail on other architectures?
>>>      Just wondering how many bsp test configuration files need touching
>>> I suppose I could set it to enabled for only AArch64 for now. It would
>>> definitely fail on other architectures.
>> Should we enable it for archs we would like supported for 6 and then make sure
>> we have support for the release?
>> The support is a side effect of the switch to TLS in newlib and not related to
>> libdl.
> That sounds reasonable. I'll leave it as-is.
> Assuming that's commit approval, I'll open a ticket for the missing support.
Yes and sorry for not making this clear.
