[PATCH] cpuuse: Use standard wording and group name
Sebastian Huber
Mon Jan 23 14:35:11 UTC 2023
Use standard wording in CPU usage reporting files.
cpukit/include/rtems/cpuuse.h | 16 ++++++++--------
cpukit/libmisc/cpuuse/cpuusagedata.c | 7 +++----
cpukit/libmisc/cpuuse/cpuusagereport.c | 5 +++--
cpukit/libmisc/cpuuse/cpuusagereset.c | 5 +++--
cpukit/libmisc/cpuuse/cpuusagetop.c | 5 +++--
5 files changed, 20 insertions(+), 18 deletions(-)
diff --git a/cpukit/include/rtems/cpuuse.h b/cpukit/include/rtems/cpuuse.h
index 86338a7332..45672d93de 100644
--- a/cpukit/include/rtems/cpuuse.h
+++ b/cpukit/include/rtems/cpuuse.h
@@ -3,7 +3,7 @@
* @file
- * @ingroup libmisc_cpuuse
+ * @ingroup RTEMSAPICPUUsageReporting
* @brief This header file provides the CPU usage reporting API.
@@ -62,7 +62,7 @@ extern "C" {
/* Generated from spec:/rtems/cpuuse/if/group */
- * @defgroup libmisc_cpuuse CPU Usage Reporting
+ * @defgroup RTEMSAPICPUUsageReporting CPU Usage Reporting
* @ingroup RTEMSAPI
@@ -78,7 +78,7 @@ struct rtems_printer;
/* Generated from spec:/rtems/cpuuse/if/cpu-info-report */
* @brief Reports the CPU information using the printer plugin.
@@ -100,7 +100,7 @@ int rtems_cpu_info_report( const struct rtems_printer *printer );
/* Generated from spec:/rtems/cpuuse/if/report */
* @brief Reports the CPU usage of each thread using the printk() printer.
@@ -125,7 +125,7 @@ void rtems_cpu_usage_report( void );
/* Generated from spec:/rtems/cpuuse/if/report-with-plugin */
* @brief Reports the CPU usage of each thread using the printer plugin.
@@ -149,7 +149,7 @@ void rtems_cpu_usage_report_with_plugin( const struct rtems_printer *printer );
/* Generated from spec:/rtems/cpuuse/if/reset */
* @brief Resets the CPU usage of each thread.
@@ -171,7 +171,7 @@ void rtems_cpu_usage_reset( void );
/* Generated from spec:/rtems/cpuuse/if/top */
* @brief Starts an interactive CPU usage reporting using the printk() printer.
@@ -196,7 +196,7 @@ void rtems_cpu_usage_top( void );
/* Generated from spec:/rtems/cpuuse/if/top-with-plugin */
* @brief Starts an interactive CPU usage reporting using the printer plugin.
diff --git a/cpukit/libmisc/cpuuse/cpuusagedata.c b/cpukit/libmisc/cpuuse/cpuusagedata.c
index 350ade309b..b28ba5c3ad 100644
--- a/cpukit/libmisc/cpuuse/cpuusagedata.c
+++ b/cpukit/libmisc/cpuuse/cpuusagedata.c
@@ -3,11 +3,10 @@
* @file
- * @ingroup libmisc_cpuuse CPU Usage
- * @brief CPU Usage Data
- * CPU Usage Reporter - Shared Data
+ * @brief This source file contains the definition of
+ * ::CPU_usage_Uptime_at_last_reset.
diff --git a/cpukit/libmisc/cpuuse/cpuusagereport.c b/cpukit/libmisc/cpuuse/cpuusagereport.c
index bc7c897db5..69e9c78518 100644
--- a/cpukit/libmisc/cpuuse/cpuusagereport.c
+++ b/cpukit/libmisc/cpuuse/cpuusagereport.c
@@ -3,9 +3,10 @@
* @file
- * @brief CPU Usage Report
+ * rtems_cpu_usage_report() and rtems_cpu_usage_report_with_plugin().
diff --git a/cpukit/libmisc/cpuuse/cpuusagereset.c b/cpukit/libmisc/cpuuse/cpuusagereset.c
index bdfba7c944..e8b76cd189 100644
--- a/cpukit/libmisc/cpuuse/cpuusagereset.c
+++ b/cpukit/libmisc/cpuuse/cpuusagereset.c
@@ -3,9 +3,10 @@
* @file
- * @brief CPU Usage Reset
+ * rtems_cpu_usage_reset().
diff --git a/cpukit/libmisc/cpuuse/cpuusagetop.c b/cpukit/libmisc/cpuuse/cpuusagetop.c
index 045a38ae55..1ee3a5571c 100644
--- a/cpukit/libmisc/cpuuse/cpuusagetop.c
+++ b/cpukit/libmisc/cpuuse/cpuusagetop.c
@@ -3,9 +3,10 @@
* @file
- * @brief CPU Usage Top
+ * rtems_cpu_usage_top() and rtems_cpu_usage_top_with_plugin().
2.35.3
