[PATCH] cpuuse: Use standard wording and group name
Mon Jan 23 15:18:57 UTC 2023
These doxygen patches look fine.
On Mon, Jan 23, 2023 at 7:35 AM Sebastian Huber
> Use standard wording in CPU usage reporting files.
>  cpukit/include/rtems/cpuuse.h          | 16 ++++++++--------
>  cpukit/libmisc/cpuuse/cpuusagedata.c   |  7 +++----
>  cpukit/libmisc/cpuuse/cpuusagereport.c |  5 +++--
>  cpukit/libmisc/cpuuse/cpuusagereset.c  |  5 +++--
>  cpukit/libmisc/cpuuse/cpuusagetop.c    |  5 +++--
>  5 files changed, 20 insertions(+), 18 deletions(-)
> diff --git a/cpukit/include/rtems/cpuuse.h b/cpukit/include/rtems/cpuuse.h
> index 86338a7332..45672d93de 100644
> --- a/cpukit/include/rtems/cpuuse.h
> +++ b/cpukit/include/rtems/cpuuse.h
> @@ -3,7 +3,7 @@
>   * @file
> - * @ingroup libmisc_cpuuse
> + * @ingroup RTEMSAPICPUUsageReporting
>   * @brief This header file provides the CPU usage reporting API.
> @@ -62,7 +62,7 @@ extern "C" {
>  /* Generated from spec:/rtems/cpuuse/if/group */
> - * @defgroup libmisc_cpuuse CPU Usage Reporting
> + * @defgroup RTEMSAPICPUUsageReporting CPU Usage Reporting
>   * @ingroup RTEMSAPI
> @@ -78,7 +78,7 @@ struct rtems_printer;
>  /* Generated from spec:/rtems/cpuuse/if/cpu-info-report */
>   * @brief Reports the CPU information using the printer plugin.
> @@ -100,7 +100,7 @@ int rtems_cpu_info_report( const struct rtems_printer *printer );
>  /* Generated from spec:/rtems/cpuuse/if/report */
>   * @brief Reports the CPU usage of each thread using the printk() printer.
> @@ -125,7 +125,7 @@ void rtems_cpu_usage_report( void );
>  /* Generated from spec:/rtems/cpuuse/if/report-with-plugin */
>   * @brief Reports the CPU usage of each thread using the printer plugin.
> @@ -149,7 +149,7 @@ void rtems_cpu_usage_report_with_plugin( const struct rtems_printer *printer );
>  /* Generated from spec:/rtems/cpuuse/if/reset */
>   * @brief Resets the CPU usage of each thread.
> @@ -171,7 +171,7 @@ void rtems_cpu_usage_reset( void );
>  /* Generated from spec:/rtems/cpuuse/if/top */
>   * @brief Starts an interactive CPU usage reporting using the printk() printer.
> @@ -196,7 +196,7 @@ void rtems_cpu_usage_top( void );
>  /* Generated from spec:/rtems/cpuuse/if/top-with-plugin */
>   * @brief Starts an interactive CPU usage reporting using the printer plugin.
> diff --git a/cpukit/libmisc/cpuuse/cpuusagedata.c b/cpukit/libmisc/cpuuse/cpuusagedata.c
> index 350ade309b..b28ba5c3ad 100644
> --- a/cpukit/libmisc/cpuuse/cpuusagedata.c
> +++ b/cpukit/libmisc/cpuuse/cpuusagedata.c
> @@ -3,11 +3,10 @@
>   * @file
> - * @ingroup libmisc_cpuuse CPU Usage
> - * @brief CPU Usage Data
> - * CPU Usage Reporter - Shared Data
> + * @brief This source file contains the definition of
> + *   ::CPU_usage_Uptime_at_last_reset.
> diff --git a/cpukit/libmisc/cpuuse/cpuusagereport.c b/cpukit/libmisc/cpuuse/cpuusagereport.c
> index bc7c897db5..69e9c78518 100644
> --- a/cpukit/libmisc/cpuuse/cpuusagereport.c
> +++ b/cpukit/libmisc/cpuuse/cpuusagereport.c
> @@ -3,9 +3,10 @@
>   * @file
> - * @brief CPU Usage Report
> + *   rtems_cpu_usage_report() and rtems_cpu_usage_report_with_plugin().
> diff --git a/cpukit/libmisc/cpuuse/cpuusagereset.c b/cpukit/libmisc/cpuuse/cpuusagereset.c
> index bdfba7c944..e8b76cd189 100644
> --- a/cpukit/libmisc/cpuuse/cpuusagereset.c
> +++ b/cpukit/libmisc/cpuuse/cpuusagereset.c
> @@ -3,9 +3,10 @@
>   * @file
> - * @brief CPU Usage Reset
> + *   rtems_cpu_usage_reset().
> diff --git a/cpukit/libmisc/cpuuse/cpuusagetop.c b/cpukit/libmisc/cpuuse/cpuusagetop.c
> index 045a38ae55..1ee3a5571c 100644
> --- a/cpukit/libmisc/cpuuse/cpuusagetop.c
> +++ b/cpukit/libmisc/cpuuse/cpuusagetop.c
> @@ -3,9 +3,10 @@
>   * @file
> - * @brief CPU Usage Top
> + *   rtems_cpu_usage_top() and rtems_cpu_usage_top_with_plugin().
> 2.35.3
> devel mailing list
> devel at rtems.org
