[PATCH] score: Clarify code block
Gedare Bloom
gedare at rtems.org
Mon Jan 23 15:18:04 UTC 2023
ok. also ok would have been merging the lines.
On Mon, Jan 23, 2023 at 6:18 AM Sebastian Huber
> Do not use a chained assignment for code clarity.
> Update #4818.
> cpukit/score/src/threadcreateidle.c | 2 +-
> 1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/cpukit/score/src/threadcreateidle.c b/cpukit/score/src/threadcreateidle.c
> index cb15d5cc3c..4f16a57099 100644
> --- a/cpukit/score/src/threadcreateidle.c
> +++ b/cpukit/score/src/threadcreateidle.c
> @@ -105,7 +105,7 @@ static void _Thread_Create_idle_for_CPU(
> * WARNING!!! This is necessary to "kick" start the system and
> * MUST be done before _Thread_Start is invoked.
> - cpu->heir =
> + cpu->heir = idle;
> cpu->executing = idle;
> #if defined(RTEMS_SMP)
> cpu->ancestor = idle;
> 2.35.3
> devel mailing list
> devel at rtems.org
