[PATCH] score: Clarify code block
Joel Sherrill
joel at rtems.org
Mon Jan 23 19:43:32 UTC 2023
On Mon, Jan 23, 2023, 9:18 AM Gedare Bloom <gedare at rtems.org> wrote:
> ok. also ok would have been merging the lines.
I like not chaining the assignments. I think simple lines are easier for
review. I suspect some coding style wouldn't like it anyway.
> On Mon, Jan 23, 2023 at 6:18 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> > Do not use a chained assignment for code clarity.
> > Update #4818.
> > cpukit/score/src/threadcreateidle.c | 2 +-
> > 1 file changed, 1 insertion(+), 1 deletion(-)
> > diff --git a/cpukit/score/src/threadcreateidle.c
> b/cpukit/score/src/threadcreateidle.c
> > index cb15d5cc3c..4f16a57099 100644
> > --- a/cpukit/score/src/threadcreateidle.c
> > +++ b/cpukit/score/src/threadcreateidle.c
> > @@ -105,7 +105,7 @@ static void _Thread_Create_idle_for_CPU(
> > * WARNING!!! This is necessary to "kick" start the system and
> > * MUST be done before _Thread_Start is invoked.
> > - cpu->heir =
> > + cpu->heir = idle;
> > cpu->executing = idle;
> > #if defined(RTEMS_SMP)
> > cpu->ancestor = idle;
> > 2.35.3
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230123/a404d700/attachment.htm>
