Prioritizing and documenting libbsd development goals (was: libbsd updates)
Thomas DOERFLER Thomas.Doerfler at embedded-brains.de
Mon Jan 23 15:39:11 UTC 2023
Hello,
since we are maintaining an RTOS: IMHO Real time capabilities would need
a higher level, even above code/RAM sizes.
Meaining that the libbsd functionality should not have a (significant)
negative impact on RTEMS tasks NOT using libbsd.
wkr,
Thomas.
Am 23.01.23 um 14:33 schrieb Christian MAUDERER:
> Hello,
> like suggested earlier in the original discussion I would suggest to
> prioritize our development goals for libbsd and later evaluate the two
> problems discussed in the thread based on this. Let's first agree on
> development goals (that also can be added to the libbsd documentation).
>  From the thread and responses, I currently have collected the following
> goals / priorities. I replaced my original extensibility and
> debuggability with Joels transparency because it's a good summary term
> for these two points.
>  From highest to lowest priority:
> - Maintainability: How easy is it for the people doing the main
> maintenance tasks to do that work.
> - Transparency: How easy it is to understand the code? Relevant for
> extending and debugging.
> - Code and RAM sizes (or other hardware requirements): Whether we meet
> the minimum hardware requirements.
> - Modularity: How well and easy the system can be adapted to target
> applications. Have only few official ways to enable / disable modules in
> the subsystem.
> - Real time capabilities: No hard real time requirements for libbsd core
> but we have to make sure that it doesn't have a negative impact on other
> subsystems.
> - Performance: Whether libbsd performes well enough in the typical use
> cases.
> That means (for example): If it makes the system more maintainable, the
> performance isn't that important. If it reduces the size, we can trade
> off some performance or real time capabilities.
> Would you prioritize different? Did I miss some additional points from
> the discussion?
> Best regards
> Christian
> On 2023-01-20 08:32, Christian MAUDERER wrote:
>> Hello,
>> recently an internal discussion about updates in the libbsd started.
>> All who participated in the discussion agreed that we should move the
>> discussion to a public one. Below you can find the mail thread. It's
>> oldest mail first. Mails are split with lines of = signs. I removed
>> some duplicated mail text in case there were no inline comments. The
>> date/time of the mails are in my current locale which is UTC+1.
>> Best regards
>> Christian
>> On 2023-01-03 16:52, Thomas DOERFLER wrote:
>>> Hello,
>>> first of all I wish you all a healthy, happy and successful new year.
>>> Unfortunately I already have to re-raise an issue: One of our customers
>>> has asked us about the RTEMS libbsd update policy. Since we still use a
>>> rather old libbsd version, it contains "OpenSSL 1.1.1d-freebsd  10 Sep
>>> 2019", there are many openSSL fixes missing when using RTEMS, and this
>>> most likely is true for other parts of libbsd.
>>> IMHO we should find a way to overcome the current libbsd update blocking
>>> points and try to stay close to the FreeBSD code (maybe in a 1-3 month
>>> interval).
>>> AFAIK the big blocking point are the different views around changes of
>>> the file descriptor handling between RTEMS and BSD (this may be a bit
>>> off the real topic, I am not yet into the details). In the next week I
>>> would like to get things rolling to see the pros and cons of both
>>> possible implementations and I would be happy if those closely involved
>>> would support this.
>>> Apart from the current blocking point, can we agree that staying close
>>> the the FreeBSD code (with a 1-3 month update/sync interval) would be
>>> desirable?
>>> Kind regards to you all,
>>> Thomas.
>> On 2023-01-12 01:24, Gedare Bloom wrote:
>>> Hi Thomas,
>>> I think the goal you have stated is laudable and fits with the initial
>>> design goals of libbsd. I will take a closer look at this topic and
>>> report back soon, I hope. I have remained (purposefully) ignorant
>>> about libbsd evolution over time, but I guess it is time for me to
>>> learn a bit more and catch up.
>>>  From what I have understood about the current blocking issue, it has
>>> to do with the changes that were made to use FreeBSD File Descriptors
>>> and the VFS. However, one of the main problems that was noted actually
>>> appears to be just related to the size increase caused by the syscall
>>> glue implemented in a single .c file. So, I will plan to start my
>>> libbsd learning adventure by trying to split that .c file apart into
>>> separate build components to see how/if that alleviates the linked
>>> image size. If successful, that should get us closer.
>>> I think we can then revisit whether or not the FreeBSD File
>>> Descriptors themselves are in fact problematic.
>>> It would also be helpful to decide if we want to clarify any
>>> requirements for libbsd maintenance. So, for example, the ability to
>>> keep it updated on a rolling basis would require good automation and
>>> validation that changes/updates remain usable. It would appear that
>>> there are some minimum resource requirements that some users of libbsd
>>> would like to remain under if possible. To ensure that would require
>>> establishing what platform(s) have resource requirements for using
>>> libbsd, and adding configurations/testing to check for when those
>>> resources are exceeded by an update. Because it is entirely plausible
>>> that an update pulls in changes from upstream that causes the
>>> resources to grow.
>>> Gedare
>> On 2023-01-12 08:46, Sebastian Huber wrote:
>>> Hello Gedare,
>>> On 12.01.23 01:24, Gedare Bloom wrote:
>>>> Hi Thomas,
>>> yes, one of the goals of libbsd was to follow the FreeBSD upstream,
>>> however, I was the only one doing this work in the past and I was busy
>>> with other things in the last three years (mainly the RTEMS
>>> pre-qualification). We need a more automated way to keep libbsd up to
>>> date. My proposal is to focus on the master branch since the FreeBSD EOL
>>> is 31. December 2023. We could use FreeBSD 14 for the next production
>>> branch. The current libbsd synchronization support was designed to do
>>> updates from Subversion. With Git we can do things more efficiently. I
>>> would replace the libbsd build system with the one from RTEMS (waf +
>>> spec items). With the spec items we can more easily read the data in
>>> other scripts. For continuous and automatic updates I would do the
>>> following:
>>> 1. Check out the FreeBSD X branch.
>>> 2. Move all FreeBSD top-level directories under the new "freebsd"
>>> directory and merge in all updates from FreeBSD.
>>> 3. Gather the set of files imported from FreeBSD. Name the set F.
>>> 4. Pick a start FreeBSD commit C.
>>> 5. Make a patch from C to C + 1 for the file set F.
>>> 6. Cherry pick the patch to the associated libbsd branch, if this fails,
>>> send a message and stop.
>>> 7. Build libbsd for the reference BSP, if this fails, send a message and
>>> stop.
>>> 8. Run the tests for the reference BSP, if this fails, send a message
>>> and stop.
>>> 9. Set C to C + 1, go to 5.
>>> Update problems can be more easily fixed if you just have a single
>>> commit. This approach makes it easier to fix things directly in FreeBSD
>>> and then get the fixes automatically into libbsd. Individual commits
>>> make it possible to use git bisect.
>>> I already started to work on this.
>>> https://github.com/sebhub/rtems-libbsd/tree/master-update
>>> I updated the FreeBSD baseline from 2019-09-24 to 2020-02-09 (again no
>>> issues with the system calls). The problem areas during updates are UMA,
>>> sleep queues, callouts, and the introduction of SMP optimizations
>>> through per-processor data structures. I added the ntpd support and
>>> started with the integration of the VFS/NFS support. This was not easy
>>> since FreeBSD was quite active in these five months and touch a lot of
>>> code in the VFS/NFS area.
>>> All the embedded brains contributions are in the 6-freebsd-12 and the
>>> master branch. This is not the case for other contributions. If I
>>> proceed with the update of the master branch moving this stuff from the
>>> 6-freebsd-12 branch to master will get more difficult.
>>> I have two issues:
>>> 1. The system calls in a single RTEMS-specific file.
>>> 2. The use of FreeBSD file descriptors.
>>> Both issues are fixed by the patch set. I don't see a benefit in
>>> splitting the RTEMS-specific file into one file per system call. The
>>> original approach is still the best approach. I don't know why it was
>>> changed without a discussion on the RTEMS mailing list. It worked for
>>> years, it allows compiler optimizations, it is easy to review, and there
>>> are no issues during updates.
>>> I updated the patch set so that it doesn't require changes in RTEMS:
>>> https://github.com/sebhub/rtems-libbsd/tree/filedesc
>>> File descriptors on top of file descriptors make little sense. Also
>>> FreeBSD has some implementation overheads which are unnecessary in the
>>> RTEMS context in which the maximum file descriptor count is fixed at
>>> link time.
>>>> resources to grow.
>>> Yes, it is possible that changes in FreeBSD lead to a higher resource
>>> usage and it would be good to have tests which catch this. However, the
>>> current problems were not caused by FreeBSD changes. The really big
>>> issue is that we didn't manage to integrate FreeBSD changes in the last
>>> three years.
>> On 2023-01-12 19:12, Gedare Bloom wrote:
>>> On Thu, Jan 12, 2023 at 12:46 AM Sebastian Huber
>>> <sebastian.huber at embedded-brains.de> wrote:
>>>> Hello Gedare,
>>>>> Hi Thomas,
>>>> EOL
>>>> following:
>>>> fails,
>>>> and
>>>> stop.
>>>> and stop.
>>> Thanks for that description. It makes sense, and I think this is a
>>> good direction for us to be heading. However, we do have to resolve
>>> the "fork" that currently exists between master and 6-freebsd-12.
>>>> UMA,
>>> Yes, we need to resolve this issue. Thank you for having patience so
>>> far with it. I have not been able to put much thought or energy to it
>>> before now.
>>>> I have two issues:
>>> It looks to me like it is reverted rather than fixed. Since Chris
>>> apparently found it necessary to change, it is best if we can resolve
>>> the difference between what he needed and what you need. Simply
>>> returning back to the prior state is not respectful to him. Similarly,
>>> to be respectful to you, we should understand the pros/cons of each
>>> approach and try to resolve them. I am willing to do some of this work
>>> on a voluntary (unpaid) basis to help the community move forward, but
>>> I suspect it will eventually require compromise (and code) from both
>>> of you.
>>>  From what I have seen, the reason that the syscalls were consolidated
>>> was to make it easier to work across related syscalls. Maintainability
>>> is decided by the *next* person to work on the code. It looks to me
>>> like it is considerably easier to find the RTEMS syscall layer in the
>>> consolidated approach, and to work across layers.
>>> There is also a performance benefit to allow the compiler to optimize
>>> the syscall away, but that also impacts debuggability if our syscall
>>> layer disappears. The tradeoffs between maintainability and
>>> debuggability vs performance appear to be fairly complicated in this
>>> space. There's not a great description to me yet of what is required
>>> for performance, while the documentation of libbsd has mostly favored
>>> maintainability as a primary objective. So I think that any argument
>>> to do something for performance reasons has to be accompanied by clear
>>> evidence that the performance improvement matters.
>>>> there
>>> I think the change was announced:
>>> https://lists.rtems.org/pipermail/devel/2021-July/068573.html
>>> This is just another outcome of our current way of handling change
>>> management. Changes can easily be lost in the email exchange.
>>>> link time.
>>> Are there any performance analyses that quantify the impact of the
>>> implementation overhead of FreeBSD File Descriptors? Again, this is
>>> about the tradeoff between maintainability and performance. i can't
>>> make value judgments about performance without understanding the
>>> resource constraints of the target platforms, and the performance
>>> metrics (code size, heap size, throughput?) that are used to decide if
>>> an optimization is worth sacrificing maintainability. It has always
>>> been my understanding that the libbsd strives for maintainability
>>> first and foremost. So to unilaterally reject code changes that reduce
>>> the maintenance burden (by keeping us closer to the vanilla FreeBSD
>>> code base) in the name of performance requires two things:
>>> 1. Evidence that the performance improvement is substantial.
>>> 2. Argument that the implementation of the performance improvement is
>>> the most maintainable way to achieve it.
>>> So far, I haven't seen either of these with respect to the runtime
>>> overheads. And I haven't seen a good argument that injecting the
>>> syscall implementations into FreeBSD is better than having them live
>>> separately in the rtemsbsd layer.
>> On 2023-01-13 08:26, Sebastian Huber wrote:
>>> On 12.01.23 19:12, Gedare Bloom wrote:
>>>>> I have two issues:
>>>> of you.
>>> I would not have looked into that if I had not experienced two problems:
>>> 1. The ntpd crashed somewhere in the area of file descriptors. I tried
>>> to debug this, but the code is too complex compared to just using the
>>> RTEMS file descriptors. This is why I removed the FreeBSD file
>> descriptors.
>>> 2. I updated a project using the old network stack and libusb to just
>>> use libbsd. Here I have a RAM limitation of 16MiB. Wasting at least 4MiB
>>> for unused stuff is not that great. This lead to the system call
>>> aggregation issue.
>>> What do you mean with "work across related syscalls"? For example, the
>>> socket related system call implementations are in uipc_syscalls.c. Here
>>> we had:
>>> #ifdef __rtems__
>>> static
>>> #endif /* __rtems__ */
>>> int
>>> sys_sendto(struct thread *td, struct sendto_args *uap)
>>>      struct msghdr msg;
>>>      struct iovec aiov;
>>>      msg.msg_name = __DECONST(void *, uap->to);
>>>      msg.msg_namelen = uap->tolen;
>>>      msg.msg_iov = &aiov;
>>>      msg.msg_iovlen = 1;
>>>      msg.msg_control = 0;
>>> #ifdef COMPAT_OLDSOCK
>>>      if (SV_PROC_FLAG(td->td_proc, SV_AOUT))
>>>          msg.msg_flags = 0;
>>> #endif
>>>      aiov.iov_base = __DECONST(void *, uap->buf);
>>>      aiov.iov_len = uap->len;
>>>      return (sendit(td, uap->s, &msg, uap->flags));
>>> #ifdef __rtems__
>>> ssize_t
>>> sendto(int socket, const void *message, size_t length, int flags,
>>>      const struct sockaddr *dest_addr, socklen_t dest_len)
>>>      struct thread *td = rtems_bsd_get_curthread_or_null();
>>>      struct sendto_args ua = {
>>>          .s = socket,
>>>          .buf = (caddr_t) message,
>>>          .len = length,
>>>          .flags = flags,
>>>          .to = dest_addr,
>>>          .tolen = dest_len
>>>      int error;
>>>      if (td != NULL) {
>>>          error = sys_sendto(td, &ua);
>>>      } else {
>>>          error = ENOMEM;
>>>      if (error == 0) {
>>>          return td->td_retval[0];
>>>      } else {
>>>          rtems_set_errno_and_return_minus_one(error);
>>> The sys_sendto() is unmodified and the RTEMS adoption is below the
>>> implementation. This is easy to review and understand. Everything is in
>>> one place. There are no issues during updates and I know what I am
>>> talking about:
>>> git log ./freebsd/sys/kern/uipc_syscalls.c | grep 'Update to F'
>>>      Update to FreeBSD stable/12 2019-09-23
>>>      Update to FreeBSD stable/12 2019-02-11
>>>      Update to FreeBSD stable/12 2019-01-16
>>>      Update to FreeBSD head 2018-11-15
>>>      Update to FreeBSD head 2018-09-17
>>>      Update to FreeBSD head 2018-06-01
>>>      Update to FreeBSD head 2018-04-01
>>>      Update to FreeBSD head 2017-12-01
>>>      Update to FreeBSD head 2017-08-01
>>>      Update to FreeBSD head 2017-04-04
>>>      Update to FreeBSD head 2016-12-10
>>>      Update to FreeBSD head 2016-08-23
>>>      Update to FreeBSD 9.3
>>>      Update to FreeBSD 9.2
>>>      Update to FreeBSD 8.4
>>> In general, the system call related area is not an issue during updates
>>> since the system call interface is pretty stable. System call stability
>>> is a very important thing for FreeBSD/Linux/etc.
>>>> Maintainability
>>>> is decided by the*next*  person to work on the code.
>>> So far I am the only one who expressed plans to synchronize libbsd with
>>> the upstream FreeBSD development.
>>>> It looks to me
>>> Moving things to a separate file instead of having it directly under the
>>> implementation function is considerably easier to find?
>>>> layer disappears.
>>> If you want to debug you have to reduce the optimization level anyway.
>>> You can use for example -fno-inline.
>>> Talking about maintainability here sounds fairly abstract to me. This
>>> should be underlined with concrete examples. In the master branch there
>>> is no kern_descrip.c which is a 4k LOC source file. I don't know how
>>> adding this file improves maintainability. The VFS/NFS support works
>>> without the FreeBSD file descriptors.
>> there
>>> Sorry, I didn't notice this e-mail before. In this time frame I was
>>> quite busy with the RTEMS pre-qualification activity and holidays.
>>>>> link time.
>>> If you are interested I suggest to build libbsd for the
>>> arm/xilinx_zynq_a9_qemu BSP with optimization disabled. Then step
>>> through a socket send/receive system call on the master and 6-freebsd-12
>>> branch and in particular getsock_cap().
>> On 2023-01-16 14:30, Christian MAUDERER wrote:
>>> Hello,
>>> I think we have a bit of a new situation here: There are two approaches
>>> to a problem, and it seems that no consent can be found with the usual
>>> discussions. May I suggest that we try a more top-down approach: Let's
>>> agree what are the important points that we want to reach and then try
>>> to evaluate the problem based on these?
>>> What I have seen in the discussions, the following points should be
>>> evaluated:
>>> - Maintainability: Who does the main maintenance work and how easy is it
>>> for them to do that work?
>>> - Extensibility: Who works with the code and how easy is it for them to
>>> contribute?
>>> - Debuggability: How easy is it to debug / understand a problem and the
>>> related code?
>>> - Code and RAM sizes (or other hardware requirements): What are the
>>> minimum requirements and do we meet them?
>>> - Performance: Which are our use cases and does it perform well enough
>>> in these?
>>> - Real time capabilities: Does the subsystem have any real time
>>> requirements?
>>> These could be valid for basically any part of RTEMS (so that list could
>>> be useful for further similar problems). We should try to find out where
>>> our focus for libbsd is. For example, I think that real time capability
>>> was never important for libbsd.
>>> Where do you see the focus for libbsd? Please feel free to add further
>>> points and rate the ones above.
>>> Based on what we agree as most important points, we then should analyze
>>> the suggested solutions. From my point of view, we have at least three
>>> mostly independent parts in this discussion:
>>> - Updated NFS support. I think it's clear that the target for all of us
>>> is that it works.
>>> - Libbsd file descriptors: Chris imported them to the 6-freebsd-12
>>> branch when adding the NFS support. Sebastian wants to get rid of them
>>> again.
>>> - Collected system calls: Different opinions where the system calls
>>> should be located.
>>> Did I miss a fourth part of the problem?
>>> Please note: Of course I'm biased because I talk a lot more with
>>> Sebastian than with Chris. Despite that I'll try to be as objective as
>>> possible in this discussion.
>>> Best regards
>>> Christian
>> On 2023-01-16 17:33, Thomas DOERFLER wrote:
>>> Hello,
>>> just my two cents regarding real time capability:
>>> The point should not only consider, whether a certain subsystem has real
>>> time requirements, but also whether a certain patch/solution influences
>>> the real time capabilities of RTEMS as a whole.
>>> wkr,
>>> Thomas.
>> On 2023-01-16 17:55, Joel Sherrill wrote:
>>> On Mon, Jan 16, 2023 at 10:33 AM Thomas DOERFLER
>>> <Thomas.Doerfler at embedded-brains.de
>>> <mailto:Thomas.Doerfler at embedded-brains.de>> wrote:
>>>     Hello,
>>>     real
>> influences
>>> libbsd made us realize that source transparency and compatibility is
>> a big
>>> factor and must be considered any time we import/reuse third party code.
>>> libbsd is a huge amount of code and it is of paramount importance to
>>> minimize changes and RTEMS special code. Doing so increases the
>>> maintenance burden and adds risk of introducing incompatibility with
>>> FreeBSD.
>>> If something from FreeBSD cannot be supported on RTEMS or (in this
>>> case) is too large for some desired targets, then a way must be found to
>>> make the FreeBSD import leaner. Perhaps a configuration option to avoid
>>> some memory allocations. Or a configuration option to disable the
>>> part of
>>> the code in question that pulls in what is not needed for the specific
>>> application and target in question.
>>> The RTEMS way is to make features optional and drop out cleanly.
>>> We do not have a history of hacking up ported package.
>>> libbsd's first order goal is source transparency to ease updates,
>>> maintenance, and avoid introducing bugs/incompatibilities.
>>> I have trouble believing that this is about performance and we don't
>>> make real-time claims about libbsd because that would mean FreeBSD
>>> made those claims and they don't. It is about functionality and
>>> compatibility. I'm sure FreeBSD has made their implementation as
>>> performant as possible but without a worry about memory consumption.
>>> The unnecessary code for this specific application/target needs to be
>>> identified and simply configured out.
>>> Transparency and compatibility override any other considerations or
>>> options.
>>> --joel
>> On 2023-01-17 11:38, Christian MAUDERER wrote:
>>> Hello Joel,
>>> Am 16.01.23 um 17:55 schrieb Joel Sherrill:
>>>>     Hello,
>>>>     real
>>>> influences
>>>> libbsd made us realize that source transparency and compatibility is a
>>>> big
>>>> code.
>>>> FreeBSD.
>>>> found to
>> part of
>>>> options.
>>> Is the transparency and compatibility a new point? From how I read your
>>> text it is mostly part of maintainability and debugability as well as a
>>> bit extensibility that I mentioned in my list earlier.
>>> Beneath that you added a point to the list that is related but not the
>>> same as code and RAM size:
>>> applications. Additionally: What is the official way to enable / disable
>>> modules in the subsystem.
>>> Best regards
>>> Christian
>> After this mail it has been suggested to continue the discussion on
>> devel and all agreed that the mails can be re-posted.
>> devel mailing list
>> devel at rtems.org
embedded brains GmbH
Herr Thomas DOERFLER
Dornierstr. 4
82178 Puchheim
Germany
email: Thomas.DOERFLER at embedded-brains.de
phone: +49- 89-18 94 741 - 12
mobil: +49-176-15 22 06-02
fax:   +49- 89-18 94 741 - 09
Registernummer: HRB 157899
