[PATCH 3/3] bsps/xilinx-zynqmp: Add JFFS2 GQSPI NOR driver
Alex White alex.white at oarcorp.com
Mon Jan 23 19:52:07 UTC 2023
 bsps/aarch64/xilinx-zynqmp/include/bsp/irq.h  |   1 +
 .../include/bsp/jffs2_xqspipsu.h              |  62 ++++++
 bsps/aarch64/xilinx-zynqmp/jffs2_xqspipsu.c   | 186 ++++++++++++++++++
 spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml |   2 +
 .../aarch64/xilinx-zynqmp/objjffs2qspinor.yml |  22 +++
 5 files changed, 273 insertions(+)
 create mode 100644 bsps/aarch64/xilinx-zynqmp/include/bsp/jffs2_xqspipsu.h
 create mode 100644 bsps/aarch64/xilinx-zynqmp/jffs2_xqspipsu.c
 create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/objjffs2qspinor.yml
diff --git a/bsps/aarch64/xilinx-zynqmp/include/bsp/irq.h b/bsps/aarch64/xilinx-zynqmp/include/bsp/irq.h
index 3ffb01d1df..2cbe99f863 100644
--- a/bsps/aarch64/xilinx-zynqmp/include/bsp/irq.h
+++ b/bsps/aarch64/xilinx-zynqmp/include/bsp/irq.h
@@ -53,6 +53,7 @@ extern "C" {
 /* Interrupts vectors */
 #define BSP_TIMER_VIRT_PPI 27
 #define BSP_TIMER_PHYS_NS_PPI 30
+#define ZYNQMP_IRQ_QSPI 47
 #define ZYNQMP_IRQ_I2C_0 49
 #define ZYNQMP_IRQ_I2C_1 50
 #define ZYNQMP_IRQ_UART_0 54
diff --git a/bsps/aarch64/xilinx-zynqmp/include/bsp/jffs2_xqspipsu.h b/bsps/aarch64/xilinx-zynqmp/include/bsp/jffs2_xqspipsu.h
new file mode 100644
index 0000000000..ac957bb686
--- /dev/null
+++ b/bsps/aarch64/xilinx-zynqmp/include/bsp/jffs2_xqspipsu.h
@@ -0,0 +1,62 @@
+ * @file
+ * @ingroup RTEMSBSPsAArch64XilinxZynqMP
+ * @brief XilinxZynqMP QSPI JFFS2 flash driver definitions
+ * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
+ * are met:
+#ifndef LIBBSP_XILINX_ZYNQMP_JFFS2_XQSPIPSU_H
+#define LIBBSP_XILINX_ZYNQMP_JFFS2_XQSPIPSU_H
+#include "xqspipsu.h"
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @brief Mount jffs2 filesystem.
+ * @param[in] mount_dir The directory to mount the filesystem at.
+ * @param[in] qspipsu_ptr A pointer to an initialized QSPI instance.
+ * @retval 0 Successful operation. Negative number otherwise.
+int xilinx_zynqmp_nor_jffs2_initialize(
+  const char *mount_dir,
+  XQspiPsu *qspipsu_ptr
+#ifdef __cplusplus
+#endif /* LIBBSP_XILINX_ZYNQMP_JFFS2_XQSPIPSU_H */
diff --git a/bsps/aarch64/xilinx-zynqmp/jffs2_xqspipsu.c b/bsps/aarch64/xilinx-zynqmp/jffs2_xqspipsu.c
index 0000000000..f647c19ec1
--- /dev/null
+++ b/bsps/aarch64/xilinx-zynqmp/jffs2_xqspipsu.c
@@ -0,0 +1,186 @@
+ * are met:
+#include <string.h>
+#include <bsp/irq.h>
+#include <bsp/jffs2_xqspipsu.h>
+#include <rtems/jffs2.h>
+#include <rtems/libio.h>
+#include <xqspipsu-flash-helper.h>
+typedef struct {
+  rtems_jffs2_flash_control super;
+  XQspiPsu *qspipsu;
+} flash_control;
+/* From the N25Q512A datasheet */
+#define BLOCK_SIZE (64UL * 1024UL)
+#define FLASH_SIZE (1024UL * BLOCK_SIZE)
+#define FLASH_DEVICE_ID 0xbb20 /* Type: 0xbb, Capacity: 0x20 */
+static flash_control *get_flash_control( rtems_jffs2_flash_control *super )
+  return (flash_control *) super;
+static int do_read(
+  rtems_jffs2_flash_control *super,
+  uint32_t offset,
+  unsigned char *buffer,
+  size_t size_of_buffer
+  int Status;
+  flash_control *self = get_flash_control( super );
+  XQspiPsu *QspiPsuPtr = self->qspipsu;
+  u8* ReadBuffer = NULL;
+  Status = QspiPsu_NOR_Read(
+    QspiPsuPtr,
+    offset,
+    size_of_buffer,
+    &ReadBuffer
+  if ( Status != XST_SUCCESS ) {
+    return Status;
+   * We have to copy since we can't be sure that buffer is properly aligned.
+  memcpy( buffer, ReadBuffer, size_of_buffer );
+  return 0;
+static int do_write(
+  uint32_t offset,
+  const unsigned char *buffer,
+  int Status;
+  Status = QspiPsu_NOR_Write(
+    QspiPsuPtr,
+    offset,
+    size_of_buffer,
+    (unsigned char *) buffer
+    return Status;
+  return 0;
+static int do_erase(
+  uint32_t offset
+  int Status;
+  Status = QspiPsu_NOR_Erase(
+    QspiPsuPtr,
+    offset,
+    BLOCK_SIZE
+    return Status;
+  return 0;
+static void do_destroy( rtems_jffs2_flash_control *super )
+  rtems_interrupt_handler_remove(
+    ZYNQMP_IRQ_QSPI,
+    (rtems_interrupt_handler) XQspiPsu_InterruptHandler,
+    self->qspipsu
+static flash_control flash_instance = {
+  .super = {
+    .block_size        = BLOCK_SIZE,
+    .flash_size        = FLASH_SIZE,
+    .read              = do_read,
+    .write             = do_write,
+    .erase             = do_erase,
+    .destroy           = do_destroy,
+    .device_identifier = FLASH_DEVICE_ID
+static rtems_jffs2_mount_data mount_data = {
+  .flash_control      = &flash_instance.super,
+  .compressor_control = NULL
+  int rv = 0;
+  flash_instance.qspipsu = qspipsu_ptr;
+  rv = QspiPsu_NOR_Initialize(
+    flash_instance.qspipsu,
+    ZYNQMP_IRQ_QSPI
+  if ( rv != 0 ) {
+    return rv;
+  rv = mount(
+    NULL,
+    mount_dir,
+    RTEMS_FILESYSTEM_TYPE_JFFS2,
+    RTEMS_FILESYSTEM_READ_WRITE,
+    &mount_data
+  if ( rv != 0 ) {
+    return rv;
+  return 0;
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
index 4274d1222f..f0c3a13ffd 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
@@ -20,6 +20,8 @@ links:
   uid: abi
 - role: build-dependency
   uid: obj
+- role: build-dependency
+  uid: objjffs2qspinor
   uid: objsmp
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/objjffs2qspinor.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/objjffs2qspinor.yml
index 0000000000..818e32d985
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/objjffs2qspinor.yml
@@ -0,0 +1,22 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: objects
+cflags: []
+copyrights:
+- Copyright (C) 2022 On-Line Applications Research (OAR)
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+- bsps/include/dev/spi/
+- bsps/include/xil/
+- bsps/include/xil/${XIL_SUPPORT_PATH}/
+install:
+- destination: ${BSP_INCLUDEDIR}/bsp
+  source:
+  - bsps/aarch64/xilinx-zynqmp/include/bsp/jffs2_xqspipsu.h
+links:
+  uid: ../../objqspipsu
+source:
+- bsps/aarch64/xilinx-zynqmp/jffs2_xqspipsu.c
+type: build
2.34.1
