[PATCH 2/3] bsps: Add Xilinx GQSPI flash helper
Alex White
alex.white at oarcorp.com
Mon Jan 23 19:52:06 UTC 2023
This adds helper functions for working with NOR flash connected to the
Xilinx GQSPI controller. The helper functions are based on Xilinx's
QSPIPSU flash interrupt example.
bsps/include/dev/spi/xqspipsu-flash-helper.h | 81 +
bsps/shared/dev/spi/xqspipsu-flash-helper.c | 2005 ++++++++++++++++++
spec/build/bsps/objqspipsu.yml | 32 +
spec/build/bsps/optxpssysctrlbaseaddress.yml | 18 +
4 files changed, 2136 insertions(+)
create mode 100644 bsps/include/dev/spi/xqspipsu-flash-helper.h
create mode 100644 bsps/shared/dev/spi/xqspipsu-flash-helper.c
create mode 100644 spec/build/bsps/objqspipsu.yml
create mode 100644 spec/build/bsps/optxpssysctrlbaseaddress.yml
diff --git a/bsps/include/dev/spi/xqspipsu-flash-helper.h b/bsps/include/dev/spi/xqspipsu-flash-helper.h
new file mode 100644
index 0000000000..075f7f826d
--- /dev/null
+++ b/bsps/include/dev/spi/xqspipsu-flash-helper.h
@@ -0,0 +1,81 @@
+* Copyright (C) 2018 - 2022 Xilinx, Inc. All rights reserved.
+* SPDX-License-Identifier: MIT
+#include "xqspipsu.h"
+int QspiPsu_NOR_Initialize(
+ XQspiPsu *QspiPsuInstancePtr,
+ u16 QspiPsuIntrId
+ * This function erases the sectors in the serial Flash connected to the
+ * QSPIPSU interface.
+ * @param QspiPsuPtr is a pointer to the QSPIPSU driver component to use.
+ * @param Address contains the address of the first sector which needs to
+ * be erased.
+ * @param ByteCount contains the total size to be erased.
+ * @return XST_SUCCESS if successful, else XST_FAILURE.
+ * @note None.
+int QspiPsu_NOR_Erase(
+ XQspiPsu *QspiPsuPtr,
+ u32 Address,
+ u32 ByteCount
+ * This function writes to the serial Flash connected to the QSPIPSU interface.
+ * All the data put into the buffer must be in the same page of the device with
+ * page boundaries being on 256 byte boundaries.
+ * @param Address contains the address to write data to in the Flash.
+ * @param ByteCount contains the number of bytes to write.
+ * @param WriteBfrPtr is pointer to the write buffer (which is to be transmitted)
+ * @note None.
+int QspiPsu_NOR_Write(
+ u32 Address,
+ u32 ByteCount,
+ u8 *WriteBfrPtr
+ * This function performs a read. Default setting is in DMA mode.
+ * be erased.
+ * @param ReadBfrPtr is pointer to the read buffer to which valid received data
+ * should be written
+ * @note None.
+int QspiPsu_NOR_Read(
+ u32 Address,
+ u32 ByteCount,
+ u8 **ReadBfrPtr
diff --git a/bsps/shared/dev/spi/xqspipsu-flash-helper.c b/bsps/shared/dev/spi/xqspipsu-flash-helper.c
index 0000000000..ae9223bef6
--- /dev/null
+++ b/bsps/shared/dev/spi/xqspipsu-flash-helper.c
@@ -0,0 +1,2005 @@
+ * @file xqspipsu_flash_helper.c
+ * This file contains flash helper functions for the QSPIPSU driver. It
+ * consists of modified functions from Xilinx's flash example in
+ * examples/xqspipsu_generic_flash_interrupt_example.c of the qspipsu driver.
+#include "xqspipsu_flash_config.h"
+#include "xqspipsu-flash-helper.h"
+#include <rtems.h>
+ * Number of flash pages to be written.
+#define PAGE_COUNT 32
+ * Max page size to initialize write and read buffer
+#define MAX_PAGE_SIZE 1024
+#define TEST_ADDRESS 0x000000
+#define ENTER_4B 1
+#define EXIT_4B 0
+u8 ReadCmd;
+u8 WriteCmd;
+u8 StatusCmd;
+u8 SectorEraseCmd;
+u8 FSRFlag;
+static int FlashReadID(XQspiPsu *QspiPsuPtr);
+static int MultiDieRead(
+ u32 Address,
+ u32 ByteCount,
+ u8 Command,
+ u8 *WriteBfrPtr,
+ u8 *ReadBfrPtr
+static u32 GetRealAddr(
+ u32 Address
+static int BulkErase(
+ u8 *WriteBfrPtr
+static int DieErase(
+ u8 *WriteBfrPtr
+static int QspiPsuSetupIntrSystem(
+ u16 QspiPsuIntrId
+static void QspiPsuHandler(
+ void *CallBackRef,
+ u32 StatusEvent,
+ unsigned int ByteCount
+static int FlashEnterExit4BAddMode(
+ unsigned int Enable
+static int FlashEnableQuadMode(XQspiPsu *QspiPsuPtr);
+u8 TxBfrPtr;
+u8 ReadBfrPtr[3];
+u32 FlashMake;
+u32 FCTIndex; /* Flash configuration table index */
+static XQspiPsu_Msg FlashMsg[5];
+ * The following variables are shared between non-interrupt processing and
+ * interrupt processing such that they must be global.
+volatile int TransferInProgress;
+ * The following variable tracks any errors that occur during interrupt
+ * processing
+int Error;
+ * The following variable allows a test value to be added to the values that
+ * are written to the Flash such that unique values can be generated to
+ * guarantee the writes to the Flash were successful
+int Test = 1;
+ * The following variables are used to read and write to the flash and they
+ * are global to avoid having large buffers on the stack
+ * The buffer size accounts for maximum page size and maximum banks -
+ * for each bank separate read will be performed leading to that many
+ * (overhead+dummy) bytes
+#ifdef __ICCARM__
+#pragma data_alignment = 32
+u8 ReadBuffer[(PAGE_COUNT * MAX_PAGE_SIZE) + (DATA_OFFSET + DUMMY_SIZE)*8];
+#else
+u8 ReadBuffer[(PAGE_COUNT * MAX_PAGE_SIZE) + (DATA_OFFSET + DUMMY_SIZE)*8] __attribute__ ((aligned(64)));
+#endif
+u8 WriteBuffer[(PAGE_COUNT * MAX_PAGE_SIZE) + DATA_OFFSET];
+u8 CmdBfr[8];
+ * The following constants specify the max amount of data and the size of the
+ * the buffer required to hold the data and overhead to transfer the data to
+ * and from the Flash. Initialized to single flash page size.
+u32 MaxData = PAGE_COUNT*256;
+ u16 QspiPsuIntrId
+ int Status;
+ if (QspiPsuInstancePtr == NULL) {
+ return XST_FAILURE;
+ * Connect the QspiPsu device to the interrupt subsystem such that
+ * interrupts can occur. This function is application specific
+ Status = QspiPsuSetupIntrSystem(QspiPsuInstancePtr, QspiPsuIntrId);
+ if (Status != XST_SUCCESS) {
+ * Setup the handler for the QSPIPSU that will be called from the
+ * interrupt context when an QSPIPSU status occurs, specify a pointer to
+ * the QSPIPSU driver instance as the callback reference
+ * so the handler is able to access the instance data
+ XQspiPsu_SetStatusHandler(QspiPsuInstancePtr, QspiPsuInstancePtr,
+ (XQspiPsu_StatusHandler) QspiPsuHandler);
+ * Set Manual Start
+ XQspiPsu_SetOptions(QspiPsuInstancePtr, XQSPIPSU_MANUAL_START_OPTION);
+ * Set the prescaler for QSPIPSU clock
+ XQspiPsu_SetClkPrescaler(QspiPsuInstancePtr, XQSPIPSU_CLK_PRESCALE_8);
+ XQspiPsu_SelectFlash(QspiPsuInstancePtr,
+ XQSPIPSU_SELECT_FLASH_CS_LOWER,
+ XQSPIPSU_SELECT_FLASH_BUS_LOWER);
+ * Read flash ID and obtain all flash related information
+ * It is important to call the read id function before
+ * performing proceeding to any operation, including
+ * preparing the WriteBuffer
+ Status = FlashReadID(QspiPsuInstancePtr);
+ * Some flash needs to enable Quad mode before using
+ * quad commands.
+ Status = FlashEnableQuadMode(QspiPsuInstancePtr);
+ * Address size and read command selection
+ * Micron flash on REMUS doesn't support these 4B write/erase commands
+ if(QspiPsuInstancePtr->Config.BusWidth == BUSWIDTH_SINGLE)
+ ReadCmd = FAST_READ_CMD;
+ else if(QspiPsuInstancePtr->Config.BusWidth == BUSWIDTH_DOUBLE)
+ ReadCmd = DUAL_READ_CMD;
+ else
+ ReadCmd = QUAD_READ_CMD;
+ WriteCmd = WRITE_CMD;
+ SectorEraseCmd = SEC_ERASE_CMD;
+ if ((Flash_Config_Table[FCTIndex].NumDie > 1) &&
+ (FlashMake == MICRON_ID_BYTE0)) {
+ StatusCmd = READ_FLAG_STATUS_CMD;
+ FSRFlag = 1;
+ } else {
+ StatusCmd = READ_STATUS_CMD;
+ FSRFlag = 0;
+ if (Flash_Config_Table[FCTIndex].FlashDeviceSize > SIXTEENMB) {
+ Status = FlashEnterExit4BAddMode(QspiPsuInstancePtr, ENTER_4B);
+ if (FlashMake == SPANSION_ID_BYTE0) {
+ ReadCmd = FAST_READ_CMD_4B;
+ ReadCmd = DUAL_READ_CMD_4B;
+ else
+ ReadCmd = QUAD_READ_CMD_4B;
+ WriteCmd = WRITE_CMD_4B;
+ SectorEraseCmd = SEC_ERASE_CMD_4B;
+ return XST_SUCCESS;
+ * Callback handler.
+ * @param CallBackRef is the upper layer callback reference passed back
+ * when the callback function is invoked.
+ * @param StatusEvent is the event that just occurred.
+ * @param ByteCount is the number of bytes transferred up until the event
+ * occurred.
+ * @return None
+ * @note None.
+ u32 StatusEvent,
+ * Indicate the transfer on the QSPIPSU bus is no longer in progress
+ * regardless of the status event
+ TransferInProgress = FALSE;
+ * If the event was not transfer done, then track it as an error
+ if (StatusEvent != XST_SPI_TRANSFER_DONE) {
+ Error++;
+ * Reads the flash ID and identifies the flash in FCT table.
+ * @note None.
+ int Status;
+ u32 ReadId = 0;
+ * Read ID
+ TxBfrPtr = READ_ID;
+ FlashMsg[0].TxBfrPtr = &TxBfrPtr;
+ FlashMsg[0].RxBfrPtr = NULL;
+ FlashMsg[0].ByteCount = 1;
+ FlashMsg[0].BusWidth = XQSPIPSU_SELECT_MODE_SPI;
+ FlashMsg[0].Flags = XQSPIPSU_MSG_FLAG_TX;
+ FlashMsg[1].TxBfrPtr = NULL;
+ FlashMsg[1].RxBfrPtr = ReadBfrPtr;
+ FlashMsg[1].ByteCount = 3;
+ FlashMsg[1].BusWidth = XQSPIPSU_SELECT_MODE_SPI;
+ FlashMsg[1].Flags = XQSPIPSU_MSG_FLAG_RX;
+ TransferInProgress = TRUE;
+ Status = XQspiPsu_InterruptTransfer(QspiPsuPtr, FlashMsg, 2);
+ while (TransferInProgress);
+ /* In case of dual, read both and ensure they are same make/size */
+ * Deduce flash make
+ FlashMake = ReadBfrPtr[0];
+ ReadId = ((ReadBfrPtr[0] << 16) | (ReadBfrPtr[1] << 8) | ReadBfrPtr[2]);
+ * Assign corresponding index in the Flash configuration table
+ Status = CalculateFCTIndex(ReadId, &FCTIndex);
+ u32 Address,
+ u32 ByteCount,
+ u8 *WriteBfrPtr
+ u8 WriteEnableCmd;
+ u8 ReadStatusCmd;
+ u8 FlashStatus[2];
+ u8 WriteCmdBfr[5];
+ u32 RealAddr;
+ u32 CmdByteCount;
+ int Status;
+ WriteEnableCmd = WRITE_ENABLE_CMD;
+ * Translate address based on type of connection
+ * If stacked assert the slave select based on address
+ RealAddr = GetRealAddr(QspiPsuPtr, Address);
+ * Send the write enable command to the Flash so that it can be
+ * written to, this needs to be sent as a separate transfer before
+ * the write
+ FlashMsg[0].TxBfrPtr = &WriteEnableCmd;
+ Status = XQspiPsu_InterruptTransfer(QspiPsuPtr, FlashMsg, 1);
+ WriteCmdBfr[COMMAND_OFFSET] = WriteCmd;
+ /* To be used only if 4B address program cmd is supported by flash */
+ WriteCmdBfr[ADDRESS_1_OFFSET] =
+ (u8)((RealAddr & 0xFF000000) >> 24);
+ WriteCmdBfr[ADDRESS_2_OFFSET] =
+ (u8)((RealAddr & 0xFF0000) >> 16);
+ WriteCmdBfr[ADDRESS_3_OFFSET] =
+ (u8)((RealAddr & 0xFF00) >> 8);
+ WriteCmdBfr[ADDRESS_4_OFFSET] =
+ (u8)(RealAddr & 0xFF);
+ CmdByteCount = 5;
+ } else {
+ CmdByteCount = 4;
+ FlashMsg[0].TxBfrPtr = WriteCmdBfr;
+ FlashMsg[0].ByteCount = CmdByteCount;
+ FlashMsg[1].TxBfrPtr = WriteBfrPtr;
+ FlashMsg[1].RxBfrPtr = NULL;
+ FlashMsg[1].ByteCount = ByteCount;
+ FlashMsg[1].Flags = XQSPIPSU_MSG_FLAG_TX;
+ if (QspiPsuPtr->Config.ConnectionMode ==
+ XQSPIPSU_CONNECTION_MODE_PARALLEL) {
+ FlashMsg[1].Flags |= XQSPIPSU_MSG_FLAG_STRIPE;
+ * Wait for the write command to the Flash to be completed, it takes
+ * some time for the data to be written
+ while (1) {
+ ReadStatusCmd = StatusCmd;
+ FlashMsg[0].TxBfrPtr = &ReadStatusCmd;
+ FlashMsg[1].RxBfrPtr = FlashStatus;
+ FlashMsg[1].ByteCount = 2;
+ if (FSRFlag) {
+ FlashStatus[1] &= FlashStatus[0];
+ } else {
+ FlashStatus[1] |= FlashStatus[0];
+ if (FSRFlag) {
+ if ((FlashStatus[1] & 0x80) != 0) {
+ break;
+ } else {
+ if ((FlashStatus[1] & 0x01) == 0) {
+ break;
+ return 0;
+ u32 Address,
+ u32 ByteCount
+ u8 ReadStatusCmd;
+ int Sector;
+ u32 RealAddr;
+ u32 NumSect;
+ int Status;
+ u32 SectSize;
+ u32 SectMask;
+ if(QspiPsuPtr->Config.ConnectionMode == XQSPIPSU_CONNECTION_MODE_PARALLEL) {
+ SectMask = (Flash_Config_Table[FCTIndex]).SectMask - (Flash_Config_Table[FCTIndex]).SectSize;
+ SectSize = (Flash_Config_Table[FCTIndex]).SectSize * 2;
+ NumSect = (Flash_Config_Table[FCTIndex]).NumSect;
+ } else if (QspiPsuPtr->Config.ConnectionMode == XQSPIPSU_CONNECTION_MODE_STACKED) {
+ NumSect = (Flash_Config_Table[FCTIndex]).NumSect * 2;
+ SectMask = (Flash_Config_Table[FCTIndex]).SectMask;
+ SectSize = (Flash_Config_Table[FCTIndex]).SectSize;
+ } else {
+ * If erase size is same as the total size of the flash, use bulk erase
+ * command or die erase command multiple times as required
+ if (ByteCount == NumSect * SectSize) {
+ XQSPIPSU_CONNECTION_MODE_STACKED) {
+ XQspiPsu_SelectFlash(QspiPsuPtr,
+ if (Flash_Config_Table[FCTIndex].NumDie == 1) {
+ * Call Bulk erase
+ BulkErase(QspiPsuPtr, CmdBfr);
+ if (Flash_Config_Table[FCTIndex].NumDie > 1) {
+ * Call Die erase
+ DieErase(QspiPsuPtr, CmdBfr);
+ * If stacked mode, bulk erase second flash
+ XQSPIPSU_SELECT_FLASH_CS_UPPER,
+ * Call Bulk erase
+ * Call Die erase
+ return 0;
+ * If the erase size is less than the total size of the flash, use
+ * sector erase command
+ * Calculate no. of sectors to erase based on byte count
+ NumSect = (ByteCount / SectSize) + 1;
+ * If ByteCount to k sectors,
+ * but the address range spans from N to N+k+1 sectors, then
+ * increment no. of sectors to be erased
+ if (((Address + ByteCount) & SectMask) ==
+ ((Address + (NumSect * SectSize)) & SectMask)) {
+ NumSect++;
+ for (Sector = 0; Sector < NumSect; Sector++) {
+ * transfer before the write
+ CmdBfr[COMMAND_OFFSET] = SectorEraseCmd;
+ * To be used only if 4B address sector erase cmd is
+ * supported by flash
+ CmdBfr[ADDRESS_1_OFFSET] =
+ CmdBfr[ADDRESS_2_OFFSET] =
+ CmdBfr[ADDRESS_3_OFFSET] =
+ CmdBfr[ADDRESS_4_OFFSET] =
+ FlashMsg[0].ByteCount = 5;
+ } else {
+ FlashMsg[0].ByteCount = 4;
+ FlashMsg[0].TxBfrPtr = CmdBfr;
+ * Wait for the erase command to be completed
+ while (1) {
+ FlashMsg, 2);
+ if (FSRFlag) {
+ } else {
+ if (FSRFlag) {
+ break;
+ } else {
+ break;
+ Address += SectSize;
+ return 0;
+ u32 Address,
+ u32 ByteCount,
+ u8 **ReadBfrPtr
+ u32 RealAddr;
+ u32 DiscardByteCnt;
+ u32 FlashMsgCnt;
+ int Status;
+ *ReadBfrPtr = ReadBuffer;
+ /* Check die boundary conditions if required for any flash */
+ Status = MultiDieRead(QspiPsuPtr, Address, ByteCount, ReadCmd,
+ CmdBfr, *ReadBfrPtr);
+ } else {
+ /* For Dual Stacked, split and read for boundary crossing */
+ CmdBfr[COMMAND_OFFSET] = ReadCmd;
+ DiscardByteCnt = 5;
+ } else {
+ DiscardByteCnt = 4;
+ FlashMsg[0].ByteCount = DiscardByteCnt;
+ FlashMsgCnt = 1;
+ /* It is recommended to have a separate entry for dummy */
+ if (ReadCmd == FAST_READ_CMD || ReadCmd == DUAL_READ_CMD ||
+ ReadCmd == QUAD_READ_CMD || ReadCmd == FAST_READ_CMD_4B ||
+ ReadCmd == DUAL_READ_CMD_4B ||
+ ReadCmd == QUAD_READ_CMD_4B) {
+ /* Update Dummy cycles as per flash specs for QUAD IO */
+ * It is recommended that Bus width value during dummy
+ * phase should be same as data phase
+ ReadCmd == FAST_READ_CMD_4B) {
+ if (ReadCmd == DUAL_READ_CMD ||
+ ReadCmd == DUAL_READ_CMD_4B) {
+ XQSPIPSU_SELECT_MODE_DUALSPI;
+ if (ReadCmd == QUAD_READ_CMD ||
+ XQSPIPSU_SELECT_MODE_QUADSPI;
+ FlashMsg[1].ByteCount = DUMMY_CLOCKS;
+ FlashMsg[1].Flags = 0;
+ FlashMsgCnt++;
+ /* Dummy cycles need to be changed as per flash specs
+ * for QUAD IO
+ if (ReadCmd == FAST_READ_CMD || ReadCmd == FAST_READ_CMD_4B)
+ FlashMsg[FlashMsgCnt].BusWidth =
+ XQSPIPSU_SELECT_MODE_SPI;
+ if (ReadCmd == DUAL_READ_CMD || ReadCmd == DUAL_READ_CMD_4B)
+ if (ReadCmd == QUAD_READ_CMD || ReadCmd == QUAD_READ_CMD_4B)
+ FlashMsg[FlashMsgCnt].TxBfrPtr = NULL;
+ FlashMsg[FlashMsgCnt].RxBfrPtr = *ReadBfrPtr;
+ FlashMsg[FlashMsgCnt].ByteCount = ByteCount;
+ FlashMsg[FlashMsgCnt].Flags = XQSPIPSU_MSG_FLAG_RX;
+ FlashMsg[FlashMsgCnt].Flags |= XQSPIPSU_MSG_FLAG_STRIPE;
+ FlashMsgCnt + 1);
+ return 0;
+ * This function performs a read operation for multi die flash devices.
+ * Default setting is in DMA mode.
+ * be erased.
+ * @param Command is the command used to read data from the flash.
+ * Supports normal, fast, dual and quad read commands.
+ * @param WriteBfrPtr is pointer to the write buffer which contains data to be
+ * transmitted
+ * @note None.
+ u32 Address,
+ u32 ByteCount,
+ u8 Command,
+ u8 *WriteBfrPtr,
+ u8 *ReadBfrPtr
+ u32 RealAddr;
+ u32 FlashMsgCnt;
+ int Status;
+ u32 cur_bank = 0;
+ u32 nxt_bank = 0;
+ u32 bank_size;
+ u32 remain_len = ByteCount;
+ u32 data_len;
+ u32 transfer_len;
+ u8 *ReadBuffer = ReadBfrPtr;
+ * Some flash devices like N25Q512 have multiple dies
+ * in it. Read operation in these devices is bounded
+ * by its die segment. In a continuous read, across
+ * multiple dies, when the last byte of the selected
+ * die segment is read, the next byte read is the
+ * first byte of the same die segment. This is Die
+ * cross over issue. So to handle this issue, split
+ * a read transaction, that spans across multiple
+ * banks, into one read per bank. Bank size is 16MB
+ * for single and dual stacked mode and 32MB for dual
+ * parallel mode.
+ bank_size = SIXTEENMB << 1;
+ else
+ bank_size = SIXTEENMB;
+ while (remain_len) {
+ cur_bank = Address / bank_size;
+ nxt_bank = (Address + remain_len) / bank_size;
+ if (cur_bank != nxt_bank) {
+ transfer_len = (bank_size * (cur_bank + 1)) - Address;
+ if (remain_len < transfer_len)
+ data_len = remain_len;
+ else
+ data_len = transfer_len;
+ } else {
+ WriteBfrPtr[COMMAND_OFFSET] = Command;
+ WriteBfrPtr[ADDRESS_1_OFFSET] =
+ WriteBfrPtr[ADDRESS_2_OFFSET] =
+ WriteBfrPtr[ADDRESS_3_OFFSET] =
+ WriteBfrPtr[ADDRESS_4_OFFSET] =
+ } else {
+ FlashMsg[0].TxBfrPtr = WriteBfrPtr;
+ FlashMsgCnt = 1;
+ if (Command == FAST_READ_CMD || Command == DUAL_READ_CMD ||
+ Command == QUAD_READ_CMD || Command == FAST_READ_CMD_4B ||
+ Command == DUAL_READ_CMD_4B ||
+ Command == QUAD_READ_CMD_4B) {
+ Command == FAST_READ_CMD_4B) {
+ if (Command == DUAL_READ_CMD ||
+ Command == DUAL_READ_CMD_4B) {
+ if (Command == QUAD_READ_CMD ||
+ FlashMsgCnt++;
+ * specs for QUAD IO
+ if (Command == FAST_READ_CMD || Command == FAST_READ_CMD_4B)
+ if (Command == DUAL_READ_CMD || Command == DUAL_READ_CMD_4B)
+ if (Command == QUAD_READ_CMD || Command == QUAD_READ_CMD_4B)
+ FlashMsg[FlashMsgCnt].RxBfrPtr = ReadBuffer;
+ FlashMsg[FlashMsgCnt].ByteCount = data_len;
+ XQSPIPSU_MSG_FLAG_STRIPE;
+ FlashMsgCnt + 1);
+ ReadBuffer += data_len;
+ Address += data_len;
+ remain_len -= data_len;
+ return 0;
+ * This functions performs a bulk erase operation when the
+ * flash device has a single die. Works for both Spansion and Micron
+ * @param WriteBfrPtr is the pointer to command+address to be sent
+ * @note None.
+ u8 *WriteBfrPtr
+ u8 ReadStatusCmd;
+ int Status;
+ * the write
+ WriteBfrPtr[COMMAND_OFFSET] = BULK_ERASE_CMD;
+ while (1) {
+ if (FSRFlag) {
+ } else {
+ if (FSRFlag) {
+ break;
+ } else {
+ break;
+ return 0;
+ * This functions performs a die erase operation on all the die in
+ * the flash device. This function uses the die erase command for
+ * Micron 512Mbit and 1Gbit
+ * @note None.
+ u8 *WriteBfrPtr
+ u8 DieCnt;
+ u8 ReadStatusCmd;
+ int Status;
+ u32 DieSize = 0;
+ u32 Address;
+ u32 RealAddr;
+ u32 SectSize = 0;
+ u32 NumSect = 0;
+ if (QspiPsuPtr->Config.ConnectionMode == XQSPIPSU_CONNECTION_MODE_PARALLEL) {
+ } else {
+ DieSize = (NumSect * SectSize) / Flash_Config_Table[FCTIndex].NumDie;
+ for (DieCnt = 0;
+ DieCnt < Flash_Config_Table[FCTIndex].NumDie;
+ DieCnt++) {
+ * before the write
+ WriteBfrPtr[COMMAND_OFFSET] = DIE_ERASE_CMD;
+ Address = DieSize * DieCnt;
+ } else {
+ * it takes some time for the data to be written
+ while (1) {
+ FlashMsg, 2);
+ if (FSRFlag) {
+ } else {
+ if (FSRFlag) {
+ break;
+ } else {
+ break;
+ return 0;
+ * This functions translates the address based on the type of interconnection.
+ * In case of stacked, this function asserts the corresponding slave select.
+ * @param Address which is to be accessed (for erase, write or read)
+ * @return RealAddr is the translated address - for single it is unchanged;
+ * for stacked, the lower flash size is subtracted;
+ * for parallel the address is divided by 2.
+ * @note In addition to get the actual address to work on flash this
+ * function also selects the CS and BUS based on the configuration
+ * detected.
+ u32 Address
+ u32 RealAddr = 0;
+ switch (QspiPsuPtr->Config.ConnectionMode) {
+ case XQSPIPSU_CONNECTION_MODE_SINGLE:
+ RealAddr = Address;
+ break;
+ case XQSPIPSU_CONNECTION_MODE_STACKED:
+ /* Select lower or upper Flash based on sector address */
+ if (Address & Flash_Config_Table[FCTIndex].FlashDeviceSize) {
+ * Subtract first flash size when accessing second flash
+ RealAddr = Address &
+ (~Flash_Config_Table[FCTIndex].FlashDeviceSize);
+ }else{
+ * Set selection to L_PAGE
+ break;
+ case XQSPIPSU_CONNECTION_MODE_PARALLEL:
+ * The effective address in each flash is the actual
+ * address / 2
+ XQSPIPSU_SELECT_FLASH_CS_BOTH,
+ XQSPIPSU_SELECT_FLASH_BUS_BOTH);
+ RealAddr = Address / 2;
+ break;
+ default:
+ /* RealAddr wont be assigned in this case; */
+ break;
+ return(RealAddr);
+ * This function setups the interrupt system for a QspiPsu device.
+ * @param QspiPsuInstancePtr is a pointer to the instance of the
+ * QspiPsu device.
+ * @param QspiPsuIntrId is the interrupt Id for an QSPIPSU device.
+ * @return XST_SUCCESS if successful, otherwise XST_FAILURE.
+ * @note None.
+ u16 QspiPsuIntrId
+ return rtems_interrupt_handler_install(
+ QspiPsuIntrId,
+ NULL,
+ RTEMS_INTERRUPT_UNIQUE,
+ (rtems_interrupt_handler) XQspiPsu_InterruptHandler,
+ QspiPsuInstancePtr
+ * @brief
+ * This API enters the flash device into 4 bytes addressing mode.
+ * As per the Micron and ISSI spec, before issuing the command
+ * to enter into 4 byte addr mode, a write enable command is issued.
+ * For Macronix and Winbond flash parts write
+ * enable is not required.
+ * @param Enable is a either 1 or 0 if 1 then enters 4 byte if 0 exits.
+ * @return
+ * - XST_SUCCESS if successful.
+ * - XST_FAILURE if it fails.
+ int Status;
+ u8 Cmd;
+ u8 WriteDisableCmd;
+ u8 ReadStatusCmd;
+ u8 WriteBuffer[2] = {0};
+ u8 FlashStatus[2] = {0};
+ if (Enable) {
+ Cmd = ENTER_4B_ADDR_MODE;
+ } else {
+ if (FlashMake == ISSI_ID_BYTE0)
+ Cmd = EXIT_4B_ADDR_MODE_ISSI;
+ else
+ Cmd = EXIT_4B_ADDR_MODE;
+ switch (FlashMake) {
+ case ISSI_ID_BYTE0:
+ case MICRON_ID_BYTE0:
+ GetRealAddr(QspiPsuPtr, TEST_ADDRESS);
+ break;
+ case SPANSION_ID_BYTE0:
+ /* Read Extended Addres Register */
+ WriteBuffer[0] = BANK_REG_RD;
+ FlashMsg[0].TxBfrPtr = &WriteBuffer[0];
+ FlashMsg[1].RxBfrPtr = &WriteBuffer[1];
+ FlashMsg[1].ByteCount = 1;
+ if (Enable) {
+ WriteBuffer[0] = BANK_REG_WR;
+ WriteBuffer[1] |= 1 << 7;
+ } else {
+ WriteBuffer[1] &= ~(0x01 << 7);
+ FlashMsg[1].TxBfrPtr = &WriteBuffer[1];
+ FlashMsg[2].RxBfrPtr = NULL;
+ FlashMsg[2].BusWidth = XQSPIPSU_SELECT_MODE_SPI;
+ FlashMsg[2].Flags = XQSPIPSU_MSG_FLAG_TX;
+ FlashMsg[2].ByteCount = 1;
+ FlashMsg[1].RxBfrPtr = &FlashStatus[0];
+ return Status;
+ default:
+ * Write enable command is not required.
+ break;
+ FlashMsg[0].TxBfrPtr = &Cmd;
+ while (1) {
+ if (FSRFlag) {
+ } else {
+ if (FSRFlag) {
+ break;
+ } else {
+ break;
+ WriteDisableCmd = WRITE_DISABLE_CMD;
+ FlashMsg[0].TxBfrPtr = &WriteDisableCmd;
+ break;
+ default:
+ * Write disable command is not required.
+ break;
+ return Status;
+ * @brief
+ * This API enables Quad mode for the flash parts which require to enable quad
+ * mode before using Quad commands.
+ * For S25FL-L series flash parts this is required as the default configuration
+ * is x1/x2 mode.
+ * @return
+ int Status;
+ u8 ReadStatusCmd;
+ u8 StatusRegVal;
+ u8 WriteBuffer[3] = {0};
+ TxBfrPtr = READ_CONFIG_CMD;
+ FlashMsg[1].RxBfrPtr = &WriteBuffer[2];
+ FlashMsg, 2);
+ * so that it can be written to, this needs
+ * to be sent as a separate transfer before
+ * the write
+ FlashMsg, 1);
+ WriteBuffer[0] = WRITE_CONFIG_CMD;
+ WriteBuffer[1] |= 0x02;
+ WriteBuffer[2] |= 0x01 << 1;
+ FlashMsg, 2);
+ while (1) {
+ TxBfrPtr = READ_STATUS_CMD;
+ FlashMsg, 2);
+ if (FSRFlag) {
+ }else {
+ if ((FlashStatus[1] & 0x01) == 0x00)
+ break;
+ break;
+ * Read Status Register to a buffer
+ ReadStatusCmd = READ_STATUS_CMD;
+ if (FSRFlag) {
+ } else {
+ * Set Quad Enable Bit in the buffer
+ StatusRegVal = FlashStatus[1];
+ StatusRegVal |= 0x1 << QUAD_MODE_ENABLE_BIT;
+ * Write enable
+ * Write Status register
+ WriteBuffer[COMMAND_OFFSET] = WRITE_STATUS_CMD;
+ FlashMsg[0].TxBfrPtr = WriteBuffer;
+ FlashMsg[1].TxBfrPtr = &StatusRegVal;
+ * Write Disable
+ WriteEnableCmd = WRITE_DISABLE_CMD;
+ break;
+ case WINBOND_ID_BYTE0:
+ ReadStatusCmd = READ_STATUS_REG_2_CMD;
+ if (FSRFlag) {
+ } else {
+ StatusRegVal |= 0x1 << WB_QUAD_MODE_ENABLE_BIT;
+ * Write Enable
+ WriteBuffer[COMMAND_OFFSET] = WRITE_STATUS_REG_2_CMD;
+ while (1) {
+ if (FSRFlag) {
+ } else {
+ if ((FlashStatus[1] & 0x01) == 0x00) {
+ break;
+ * Write Disable
+ break;
+ default:
+ * Currently only S25FL-L series requires the
+ * Quad enable bit to be set to 1.
+ Status = XST_SUCCESS;
+ break;
+ return Status;
diff --git a/spec/build/bsps/objqspipsu.yml b/spec/build/bsps/objqspipsu.yml
index 0000000000..5f8679c83c
--- /dev/null
+++ b/spec/build/bsps/objqspipsu.yml
@@ -0,0 +1,32 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: objects
+cflags: []
+copyrights:
+- Copyright (C) 2022 On-Line Applications Research (OAR)
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+- bsps/include/dev/spi/
+- bsps/include/xil/
+- bsps/include/xil/${XIL_SUPPORT_PATH}/
+install:
+- destination: ${BSP_INCLUDEDIR}/dev/spi
+ source:
+ - bsps/include/dev/spi/xqspipsu_control.h
+ - bsps/include/dev/spi/xqspipsu_flash_config.h
+ - bsps/include/dev/spi/xqspipsu_hw.h
+ - bsps/include/dev/spi/xqspipsu-flash-helper.h
+ - bsps/include/dev/spi/xqspipsu.h
+links:
+- role: build-dependency
+ uid: objxilinxsupport
+ uid: optxpssysctrlbaseaddress
+source:
+- bsps/shared/dev/spi/xqspipsu_control.c
+- bsps/shared/dev/spi/xqspipsu_hw.c
+- bsps/shared/dev/spi/xqspipsu_options.c
+- bsps/shared/dev/spi/xqspipsu-flash-helper.c
+- bsps/shared/dev/spi/xqspipsu.c
+type: build
diff --git a/spec/build/bsps/optxpssysctrlbaseaddress.yml b/spec/build/bsps/optxpssysctrlbaseaddress.yml
index 0000000000..644cbccc58
--- /dev/null
+++ b/spec/build/bsps/optxpssysctrlbaseaddress.yml
@@ -0,0 +1,18 @@
+actions:
+- get-integer: null
+- assert-uint32: null
+- env-assign: null
+- format-and-define: null
+build-type: option
+copyrights:
+- Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
+default: 0xFF180000
+default-by-variant: []
+description: |
+ base address of XPS
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: XPS_SYS_CTRL_BASEADDR
+type: build
2.34.1
