leon3 validation test failures
    Joel Sherrill
    joel at rtems.org
    Wed Jan 25 15:40:27 UTC 2023
Hi
Looking at the build results for leon3, there are only a couple of failures
but they are odd and I hoped someone could look into them.
I think this one looks OK.
https://lists.rtems.org/pipermail/build/2023-January/039497.html
[rtems-test] sparc/leon3: RTEMS_DEBUG, RTEMS_POSIX_API: Passed:615 Failed:0
Timeout:0 Test-Too-long:0 Invalid:0 Wrong:0
This has a few other
https://lists.rtems.org/pipermail/build/2023-January/039496.html
[rtems-test] sparc/leon3: RTEMS_POSIX_API: Passed:614 Failed:1 Timeout:0
The failure is psxkey07
=>  test start: PSXKEY 7
] *** BEGIN OF TEST PSXKEY 7 ***
] *** TEST VERSION: 6.0.0.c8c713c6bdd73aa1d491f0f42bb5236e927e5f03
] *** TEST STATE: EXPECTED_PASS
] *** TEST BUILD: RTEMS_POSIX_API
] *** TEST TOOLS: 12.2.1 20221121 (RTEMS 6, RSB
65f83cf973d6f1f8974ea1818e653753b83eaea8, Newlib b9898fc)
] Init - Mutex 1 create - OK
] Init - Mutex 2 create - OK
] Init - Condition variable 1 create - OK
] Init - Condition variable 2 create - OK
] Init - pthread Key create - OK
] ../../../testsuites/psxtests/psxkey07/init.c: 67 !sc
] cpu 0 in error mode (tt = 0x80)
]    187100  4000a240:  91d02000   ta  0x0
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230125/07ebd891/attachment.htm>
